View Full Version : Swap Shop
- Bravo And Alfa Parts !!
- Garage sale
- manifolds
- wanted electric bolsters
- 1 standard trs, 2 gimbals with trim rams
- Turndowns -All sizes for sale
- Pair of Hydromotive Quad IVs 26pitch (will separate)
- CMI switchable tails
- parts for sale-flywheel, oil filter bracket.... 454/bbc parts
- WANTED: 2" Shorty Lower Drive
- wtb 088 502 heads or hp500 heads
- WTB - HP 500 Dart intakes
- 454 BBC accessories starter, alternator brackets etc.
- need drives?
- Hydromotive 24,26,28 props
- WTB! shifter and oil filter brackets for Gil exhaust
- GEN4 parts
- Alpha Drive for 454
- Weiand Team G Intake
- KIEKHAEFER Throttle w/trim switch
- wanted: bbc stock thermostat housing
- Leaning Posts and Misc. Parts for Sale
- looking for dual engine and shift controls
- 454 Shortblock Needed
- Gauges,trim tabs needed
- Bravo One RH/LH 26
- hatch scoop
- Shop cleaning
- WTB dual engine shift and throttle controls
- Stock BBC Exhaust
- exhaust
- more parts huber trans stellings headers
- Bravo 1 Drive $800
- sbc water pump crossover
- Bravo Drives
- trs bell housing top mount starter
- Oil - Power Steering cooler
- complete 177 weiand blowers and intercoolers
- NEEDED!! 24p bravo 1 prop
- 2 Bravo 1 drives imco shafts showers nose cones
- wtb - 2 pair angle cut tall BBC valve covers
- need 3" tall stainless perf. risers
- Looking for bravo 1 outdrive
- 27P Mirage plus set
- f350 drw short bed 4x4
- Need 2.5 Powerhead
- WANTED: Complete 496HO whipple or pro charger
- Need a 1.5 XR upper new or rebuilt
- Wanted Bolsters
- Parts I need
- WTB Pro Systems 950
- Alpha Gen One $650
- 502 efi intake
- M3SC procharger
- charlynn helm
- In need of a drop in 454
- 4" Exhaust Hose
- GM LS marine conversion Parts
- Bravo Stellings headers W Dry tails nice!
- Polished Exhaust Turndowns- cmi mufflers
- Bad azz almost completely restored Magnum
- Never titled 18K LB tri axle - 11K
- wanted:k plane pins with tab fir indicators
- gil aluminum bell housing
- Merc 454 carb- less than 4 hours run time
- WTB Sea Pump Bracket
- 28 cig lifting hook
- old stuff from magnum cheap
- 496 Throttlebody $50
- Two Re programed Merc 500 EFI ECM'S for sale
- Fountain Dash Panel & Morse Twin controls
- WTB BBC cheap
- WTB a Thunderbolt 4 V6 module....
- 2 - 502 magnum fuel injection setups complete
- Full Cover 35' Fountain Lightning
- Two Brand New Maximus Props
- WANTED: circulation pump pulley
- New Livorsi Billet single controls
- Tons of Parts for Sale!
- bravo lower
- HP Gimbal & Transom Plate
- WTB single engine controls
- XR Sportmaster 1.36 Standard length
- more parts relief vaves + switch panel
- 23 Hydromotive Quad IVs for sale
- Harding Marine 2-piece Valve Covers (2 sets)
- Bolster seats
- exhaust manifolds and dry pipes
- 350 chevy
- WANTED: B&M 250 Supercharger Belt Tensioners
- 671 blower
- Livorsi Monster Trim Guage - New, Black carbon
- 2 Merucry Racing Remote Thermostatic Oil Filter Head Mount
- IMCO -2inch SC pair with stelling boxes
- 23 Mirage pair
- RC Boat Miss Vegas Aquacraft 45 MPH
- WTB: Tall deck BBC
- new holley 750 carb
- Bbc Pumps ,motor Misc Bbc !!! LOTS
- Exhaust for sale
- WTB 3-5 switch AC panel
- 2006 13' Hotdog boat and trailer
- Alternators
- MSD-For Sale
- Flame Arresters
- Cross Overs/T-Stat Housings
- Remote Oil Housings
- Kieth Eickert Sea Pumps
- Flywheel/Dampner for sale
- Baja Force 235 Hull For Sale
- For Sale Fresh 454 motor 500hp good price
- WTB 23 Mirage Plus RH prop
- Boat Yard Fork Lift Negative Drop
- Complete Black Hawk package
- 500 efi inake mainfold
- New Xr Lower Driveshaft Assembley
- Rolex two-tone Daytona & 18k Presidential....
- #5 spacers
- 38 cigarette race boat hull only
- 502 & 454 f/s in NJ
- cleaning garage misc parts
- wtb water pressure relief valve
- WTB 27 Mirage plus
- WTB - EFI HP 500/621 cam.
- Merlin Intake Manifold - $285 O.B.O.
- Baja lay in carpets
- B-Max HT Drives less than 10 hours a piece
- anyone need stock 454mag mpi Exhaust man.&risers
- WTB Throttles/shifters for twin engine
- Holley/B&M 250 blower complete $3,000
- ASD-8 trim and sterring cylinders
- LH 4 blade clever
- Gen 4 454 used parts
- Want to buy: Rex Marine Dual pickup "it's cool" bravo 1 shower
- New Attwood Avenir seats Garelick mounts
- Drive Spacer 1"for XR Drive
- Drew Marine Shotgun Silencers
- 24' Fastload trailer
- motor mounts
- WTB Dart or Merlin X tall deck 4500 intakes
- Mercury Maximus Prop Rh 26 5 Blade Stock Used
- Things i'm selling
- 23 Hydromotive Quad IV props truly excellent cond.
- Hydromotive 23 pitch quad IVs
- 5" cmi switchable mufflers
- NEW Rollmaster Gen.6 roller timing chain set.
- Arneson ASD-6
- Mercury propellers 4 blades 16.5 X 27
- Arneson ASD-8-10
- Garage sale of sorts...
- Oil Pans Bravo Shower Grab Handle more...
- TRS parts
- FS/WTT Kodiak Marine Exhaust Manifolds/Imco Risers
- 5 BBL #6 17.5x27 props
- New or very nice baot trailer for 28 Cigarette
- Used Gaffrig Gps Speedo Head
- New Eddie Marine Drive Actuator Kit
- 30 p bravo 1s labbed by b blades
- Mercury 350 Decal Set
- Hydromotive Quad 4 Blade Pair 24p
- mufflers
- looking for 4" rubber exhaust hose
- Pair 32P Bravo 1 Props
- 32P Bravo 1 RH Prop
- 34P Bravo 1 LH Prop
- Hardin Marine Cyclone Silencers
- WTB: 454 Mag EFI Supercharger Kit
- Have 5 blade maximus for sale
- WTB 4" Clamp on Mufflers
- Pertronix electronic ignition (Ford)
- looking for hp 500
- Mercury DDT for sale
- looking for 280 or 380 k plane mounting plates
- Pro Charger
- Eddie Marine Battery Boxes
- Two Weiand 177's with intakes $1400 obo each
- Zero effort controls(triple)
- lots of parts
- Trs Gimble Housings Cheap!!!!
- wanted: k plane pumps, lines, indicators
- 575 Sci Cast Iron Heads F/s
- two 3a drives
- 10.200 tall deck block
- bbc valve covers
- Looking for 2 sets of Valve covers
- Upgrade your single engine boat cheap
- Throttle Up Prop Boxes for #6 or Bravo props
- Mirage Plus SS 23P & Flo-Torque Hub
- Latham Triple sticks
- Apache / Comanche bolsters
- B Brackets and other stuff for sale
- Mercury 420 or Hawk 525
- 24 Vector Project boat
- FORMULA -1 Race tunnel boat Carbon fiber
- CMI Headers and Tail Pipes, and race mount
- Mefi 4
- Need a pair of XR uppers
- Trade - Hydromotive P5-29's for P5-27's
- #6 lower housings wet sump pefect shape. Also have daytona crash boxes
- bell housing coolers nice shape.
- #6 Propellers 4 blade 17-1/8x31 17-1/4x30
- WANTED: 2" IMCO or Sportmaster shorty. 1.5 ratio 1" shaft.
- wanted: lounge seats to fit a 25' baja or other
- Drag Boat Misc Stuff !!
- 14.5x28 4 Blade Lab Merc Cleavers
- Arneson ASD-8 hub needed
- WTB Deck Hatch
- Mercruiser thunderbolt IV 502 Distributor No module used like new
- Stock Bravo 1 22's
- TRADE 3A drives for XR
- merc #6 props
- 23 Hydro Quad IV Props -L & R flawless -swap for 25s?
- Speedmaster props
- Wtb - 496 Ho
- Indicator and Bezels
- 454/365 Magnum package $1900
- Bravo Gimbal
- Stainless Marine Risers
- Marine swap meet
- Brand New sealed copy of "Searace" by John Crouse
- GLM 7.4 manifolds and riser stock replacement 2 sets
- more pic
- more pictures
- Bravo Drive for sale
- miscellaneous parts
- Cleaning the Garage
- Latham Trim Tabs 18"
- Fresh World 509 - $4,500
- 2" sportmaster lower
- TRS Trim piston
- Misc Bbc, Controls, Props And More !!!
- Bravo one 30 Labbed Bblades
- 27 Eliminator Daytona Hull and trailer project
- 2" sportmaster
- For Sale: 13" Inflatable Race Tunnel, Turn Key Package.
- Drew Marine Shotgun Exhaust Single Application
- Exhaust Parts For Triple
- 3 Blade Stainless Prop by Hill Propellers
- Gaffrig W/100mph speedo NEW
- Plugs,filters Oils.
- HD Transom Assemblies
- Merc Bravo 1 Quicksilver Mirage Prop Set 25P LH & RH
- needed xr or imco upper
- 850 K-B Carburetor w/J tubes & 350 SBC
- Bravo 22s left and right
- SCS Zero drag Crashboxes
- 525 Merc Intakes
- 825HP Blower engine
