View Full Version : Swap Shop
- LSx engine parts
- BBC Parts, 68’ 396
- BBC Edelbrock Performer RPM Aluminum Heads
- Imco Clutch Shaft and -2 Lower Vertical Shaft
- Latham water pick ups
- 525 EFI Fuel Cooler
- McGard Propeller Lock - 74040
- Diverters - 2 sets
- 502 Connecting Rods
- Harden marine silver faced gauges twins
- Latham full steering trs
- Mirage 25/24 set
- Stainless marine dry exhsust ssm/trs
- 8 plate bellhousing oil coolers
- 09 6.5l GM Marine Turbo Diesel
- Mercury Thunderbolt IV w/cannon plug
- Mark IV 454 30 over
- Mark IV Oil Pan
- 3 Msd boxes and two coils.
- White faced Gaffrig Gauges for 98 Formula 353
- Bravo 1 and Maximus prop sets
- New Hardin sand strainers
- Cool fuel MPI set up complete
- Pair of XR uppers
- 900sc mooneyham intakes and lee cupronickelchillers
- transom mount stainless mufflers
- 2 raw water pumps with fuel pump provisons 2 available
- Sport master -2 lower
- Pair xr drives with sport master -2 lowers
- Bravo 1 26p
- Bravo 1 swept back
- CMI etop try Tails
- Tie Bar for Bravo 1
- bravo 1 dwp lower case
- ssm#4 lower case
- bravo bearing tool 91-864220
- 2 sets of #6 props
- 5.7 ignition modules
- 500 ignition module
- alpha one gen 2 rebuilt upper with1.32 -1 gears
- DWP Bravo I lower case
- Need hp 500s complete
- Pair of 500efi complete with exhaust need full rebuild
- 1471 Blowers, Intercoolers and Intakes
- TRS complete. L&R
- Super Shorty Drive, Bolts to TRS Gimbel
- HD transmission drive plates & steel flywheels
- CMI sound choice and compressor exhaust
- Trs drive hyd cylinders.
- For Sale: RHS Aluminum Cylinder Heads
- Stellings green headers
- 25' Eliminator Daytona ICC Engine Hatch (NEW)
- Perko flush valve $20 Livorsi w.p. Gauge $20
- Thunderbolt ignition modules
- Parts for sale.
- 1995 Navy Seal HSB
- Brand new labbed 32 for sale
- 24ft JAWS Offshore Powerboat/ NO ENGINE, DRIVE or TRANSMISSION
- IMCO -2 Lower 1.36 gears 1.25 prop shaft
- Pair of 3.0 liter whipplechargers for 525
- 2 Sets - 4 Props for #6 Drives Excellent Condition
- (2) Anodized Aluminum Brackets
- (2) Billet Aluminum Light Weight Flywheels
- (2) Sets 1.70 ROLLER ROCKERS W/ COMP CAMS GUIDE PLATES
- (2) super cyborg hi perf. Transmissions
- 34P LH Bravo 1 BBlades Labbed - $350 shipped
- Murcury Marine Motorola 600sci computer's PCM ECU x2
- Gen VI 502 block, heads, crank, rods...
- J E Blower Pistons New
- Oil coolers
- Pair / Bravo 1/2” Spacers
- Garmin GPS 546s $275
- Mooneyham 10-71 blower and snout
- 4 Carburetors 850-950 cm and Air Filters
- 2 871 Blowers with intakes
- 2 Keith Eckert 3 stage Water pumps
- (2) 850 CFM Holley Carburetors
- (2) Dominator Flame Arrestors
- Holley 1050 CFM Marine Carburetors
- 496 custom cowling
- Daytona sensors cd1 marine.
- Konrad 520 sterndrive
- Velvet Drive 72l h transmission
- (4) Anodized Aluminum Brackets
- Billet flame arrestor
- ZF 85 IV transmission
- 07 6.6l Duramax Turbo Diesel Complete Setup
- (2) Anodized Aluminum Alternator Brackets
- (2) Billet Aluminum Remote Filter Heads with Brackets
- Brand new Ilmor 625 Motor in crate
- MBQuart 6.5 GRILLS ONLY (yesteryear)
- MSD rev limiters
- Intakes,Carbs,Cams and Oil Coolers
- Latham Marine X/XR wing plate
- Mirage Props
- SS 6AN hose and AN Fittings
- BBC Flame Thrower ll Distributors
- 8.3 Whipple Blower with or without Carburetors
- Iso imco sc upper or xr upper
- 502 crank, rods, pistons, timing covers. GARAGE SALE BBC PARTS
- BBC heads 088 fresh/ new merlin 345cc heads
- Oil pans gen 4 and gen5/6 offshore
- latham steering bracket for xr
- Weldon fuel pumps
- Xr lower lwp $2200
- T&D Machine Shaft Rockers for: 2 Engines, Came off Big Chief Heads
- Dry Sump Oil System Deal!
- CMI Headers
- Drive Guardian
- Lightning Headers BBC
- Stainless Marine exhaust
- Drew marine boat steering stabilizers
- Mechanical Steering parts, Steering actuator and Livorsi steering wheel
- (2) MSD PRO MAG 12 w/ Control Boxes
- (2) 206 B PSI Marine Screw Type Blower Set ups Complete
- Volvo Penta Big Block EFI Intake Assembly
- 598 cu in 1200 HP
- Mercury Racing & Mercruiser 502 MAG Throttle Bodies
- Imco sct lower
- Crash Boxes - (2) For Sale
- Drive on Floating "JET DOCK" for Pontoon Boat
- Edelbrock Ovalport RPM Air Gap Intake Manifolds - 2
- Cometic Head Gaskets - NEW!
- Pair of IMCO SCX’s with 1400 lowers with #6
- Pair of Borg warner 72C transmissions 1018
- TRS trim cylinders
- 4-4" exhaust tips
- BBC aluminum flywheels
- Full Hynautic steering system helm to stern
- 25 Mirage plus RH/LH
- Merc Valve Cover name plates
- Blower Shop 5.9” Snout
- Remote Anodized Aluminum Oil Filter Head and Bracket
- 5" Exhaust Diverters - 2 Engines
- Edelbrock RPM Air Gap BBC Intake Manifold
- 4 Stage Dry Sump Oil Pump
- Stainless Marine Risors - 2 Engines
- Dry Sump Oil Pans
- 2 sets of Cast Aluminum Valve Covers
- Blower intake & 4" high cupronickel inner cooler
- 8.3 Whipple for sale
- Purple Steering Wheel and Hub
- Maretron J2K100 Gateway
- 1.24 gears
- HP-500 Oil Coolers
- Scarab windscreen for sale
- NOS GM Perf Siamese bow tie Blocks...1106, ....1107
- Gaffrig Superflo 5” muffers with air pump
- Rev 4 Props
- 540ci/ 625HP Carb Motor/ Fresh Rebuild
- Bravo 1:50 Lower Gear Set
- Cam, Lifters, Intake, etc...
- Fresh Professionally Built Blower Motor
- Velvet Drives 73c pair 1:1 ratio
- Bravo Drive Coolers ( New )
- Oil Pan, Pump, and Windage Tray
- 4 external exhaust tips
- Cleaning out the shop PART 1..getting ready to move
- 2017 Arneson ASD-8 Drive Parts Standard 10" and Custom 16" Cat Tie Bar Towers ETC....
- Rolla propellers
- 31" tie bar with clevis joints
- SSM VI Props, 17.5X30X16 degree. 5-blades
- SSM VI Gear set 43-848787A1 (19/27) 1.49 ratio
- Bravo drives (3)
- Compete Big Block Bravo swap
- Tons of Parts, located in Europe, ship WW
- B&M pulleys
- 28 nordic heat trailer
- Broken whipple
- Props
- Bravo 1 DWP lower
- Mercury CLE and Bobs Nose cone Low water Pickup Flusher
- 25p three blade bravo 1 mirage props
- CMI 525 Headers
- Thermostat housings
- Large list of parts for sale
- Edlebrock performer oval port intakes
- Merlin Intakes 800 Holley carbs
- Arnesson Asd- 8 drives.. Complete with rams and vent tubes
- Total Seal Rings
- Parts
- Parting out Trs Cigarette
- 5 blade Mercury #6 cnc 5 blade props
- Dominator flame arresters
- 502 short block gen 6 brand new
- Gil risers and other parts
- Need help identifying trophy for sale
- 1974 mercruiser mark 2 complete with everything power steering gimbal housing trans/o
- bravo I OC set.14-30-4RH LAB FINISHED
- 454 = 330 HP Parts
- Cockpit carpet
- Mercruiser 454/502 MPI 500 EFI Delco Distributors W/Module
- Garage sale
- 454 / 330 parts or repair
- TRS driveline complete. L&R
- BBC Iron Log manifolds Make offer
- Parts for sale + shipping cost on all parts
- 2016 Indmar 400 Raptor 6.2l Inboard Like New
- 4" Clamp on mufflers set of 4 nice shape
- Wet Sounds SW-808-W 8" Coxial Speakers
- IMCO SC Lower
- Imco rear caps
- BBC aluminum exhaust manifolds
- 1988 Formula 272 SR1 hull
- 1985 Wellcraft Nova 2 (needs resto)
- 1/2/3 engine kiekhafer zero effort controls
- Hydraulic steering
- 1 Pair Gibson Clamp-on Mufflers
- hydraulic steering
- 468 Bravo full swap 5500 shipped includeds Ex
- Imco power flow plus bravo
- (2) Pair of Mercury Racing 5 Blade Offshore Props Nice Propellers $4900
- bravo 1 1.50 upper
- Bravo XR 1inch drive spacer
- New solid aluminum swim platform cnc engraved with Pantera name and logo
- Dana marine hatch lifts
- Misc. parts
- Gil Offshore BBC Exhaust Manifolds
- Bblades 4-speed props 32 pitch
- 496 engine cover
- Raymarine P79 In-Hull Transducer - NIB $100 Shipped
- Transom Mount Trim Kit
- Garmin accessories
- Pair Dart 540's Falme arrestor to oil pans
- bell housing style oil coolers
- BBC Elgin 1.72 roller rockers (2 sets)
- Parts
- hp500 carb
- Baja 302 windshield
- Wet sump #6 drives
- Imco Power Flow bbc polished exhaust
- 2 pairs of stainless marine dry-to-the-tip through hull risers for bravos
- Brodex BBC tall deck dominator intakes
- 72c with speedmaster tails
- 496ho heads
- Bravo 1 uppers
- Sport masters
- 91 27 fountain part out 502 bravo
- Mirage Props - 27 Pitch
- Crower Roller lifters
- Imco steering caps
- B&M 250 bbc blower kit
- Free 4" Bilge Blower
- Techmate
- Corsa captain call diverters
- Free Zinc Anode B1 Prop Shaft
- 6-blade bravo style props
