View Full Version : Swap Shop
- 27' Kryptonite sale or trade
- Need Merc Accessories
- Remote Oil Filter mounts
- HP500 Water Pump assembly
- two 1271 blowers
- two new 1071 blowers
- HP500 Stock Oil Pans
- Dart Iron Eagle Heads
- Crane Cams 168731 (8620 copper hardened)
- P5X's - 26" - pair, barely used!!!
- 2 pair bravo 3 xr props
- mini halk
- 18' Hydrostream Valero
- Garage Sale...Lots of GOOD Stuff!
- Mercury 525 SS headers
- Parts for trade
- Rebuilt Bravo one lower unit
- 27 magnum cockpit cover
- Trailer wanted
- Merc 420 parts
- bravo xr drives
- 1"1/4 premium marine water hose
- FS: Complete Mercruiser 5.7L 325 horse small block in NY
- Need a set of 420hp heads
- Flex plate for Borg Warner 72C trans
- bravo and mirage prop hardware
- merc university training discs
- SCS crash box
- 20P Enertia Prop 3 blade RH
- 496 Mag 375HP For Sale
- Oil Cooler 2" x 15"
- Used Imco Breather/Puke Tank
- KE Dual Cooler Bell Housing
- Props
- 30P bravos for 28P bravos?
- Mercury Labbed 28" Bravo 1's
- 2 600 Holley carbs.
- Mercruiser/Gil HP500 manifolds & risers
- stainless marine jack plate
- 24 P bravo 4 blades and 500 efi parts
- 27P Mirage Plus RH
- Misc 454 MAG MPI Parts
- mayfair rams
- Fiberglass Scoop, New In Box , Bolt On
- rex marine dual pickup drive shower like new
- Miscellaneous Valve Train Parts, cams and pistons….
- gibson turndown's
- 4 1050 blower carbs
- Intake and carb
- Steph's Pan
- -----Merc trans-----
- Used parts list
- Bravo 1 4 blade prop
- 625 Ilmor
- New 540 blower motors
- two 622ci blower motors 900hp
- HVH Super Sucker carb. spacer for 4150
- Wanted (2) 2X16 oil coolers and (2) holley 850's
- 2 Sets of Slip in Mufflers 4"
- Merc Cool Fuel
- mercury 19p LH cleaver
- Bravo XR Lower Gear Sets
- Bravo XR Upper Gear Set
- 280 K-planes
- Livorsi Tachs w hour meters
- Number Six Transom Assemblies
- BAM Transmissions
- HVH Super Sucker for Dominator
- airboat
- 10" hydraulic jack plate
- 502 Block Wanted
- Dart single plane intake , Merc AFB/Weber carb for 502 , K&N , GLM manifolds ,
- 454 mag fuel injection mefi3
- Aluminum swim platform 24 boat
- Lifeline Jackets anyone?
- Hydraulic helm,props
- looking for bravo 1 24P
- Speedmaster Cleaver Props 15x22 RH/LH
- Carling Switches from McLeod Seats
- F 15 canopy
- 1/2" bravo spacer
- New Bravo's
- BRAND NEW TRS's 1 SET still in box
- 2 pair of Merc. Racing 4" exhaust tips
- Whipple Charger off 2000 502 MPI
- 4" slip in silencers/mufflers
- 1" Drive Spacers
- Bravo Drives Forsale $$$
- 502 rods+pistons , inconel valves , more stuff
- Exhaust manifolds BBC
- 17.5 x 34R Four blade for ssm6
- Have a set of 26" Bravo 1 and 27" Mirage...
- Merc 454 needs rebuild , RPM intake , large oval ports
- 2002 bravo 1 lower
- L&R QS21 Props for Thunderbolt V8 22 Mod.
- 468CI blower engine- fresh
- Msd Plug Wires
- Throttle Cables
- 454-gen5 Or 6 Not Sure
- Looking for an eggbeater
- Myco Spare Tire Rim
- Whipple 500efi parts
- Bravo One drive anode plates(new)
- Humminbird hand held VHF
- Cmi Sport Tubes
- FS Greddy Warning EGT Gauge
- Labbed 30 Bravo 1's BBlades
- Misc Parts
- Merc 525 Sc Efi Diagnostic Manual
- Bravo CV joint assmbly
- Cmi Exhaust Stubs For Dyno
- Have a nice set of CMI-E Top Stainless Headers
- Heads
- Cmi E-tops
- Speedmaster Stuff
- 24P bravo 1's w/ hubs
- Halo drive showers
- (2) KPM billet water pumps
- Dual cooler bell housing, race engine mounts, flywheel/flex-plate, starters
- Pair of Dominators and Gafffrig Flame Arrestors
- Speedmaster #3 transom assemblys
- #3, 4, 5 gimbals with trim rams (2 / twins)
- Lots of parts for sale - please have a look
- Volvo Gauges - EVC system
- 4 Merc Kiekhaefer trim pumps
- 2 inner plate transom assemblies for #3, 4, or 5SSMs
- Gaffrig switchable mufflers
- 5 Holley Marine 750cfm carbs
- Stelling tailstocks for boxes
- Bravo I Gimbal Assemblies (2)
- HP 500 Carb Intake
- Assorted 500 efi parts
- Switchable exhaust diverters
- 357 windsheild
- Four Stainless Marine Risers $500
- Two B & M powercharger 250s for $2K
- Wanted Gear Set
- 32p hydromotives Q4 Plus Props
- Gen V 502 complete
- Lifeline Jacket trade
- Bravo Couplers
- Ssm 3-5 Gimabals
- Swap Pair Rev-4 19" for Pair Bravo-1 22"
- Hatch Accuators
- Trim pump part needed
- NEW: (2) Merc 525 race oil filters $20. includes ship.
- Merc 3 drive parts and gimbles
- Maximus 26P props
- 2 5'' cmi mufflers
- 17x32 #6 props
- Remote oil cooler sandwich adapter BBC
- Best Retailer For Imco Steering System Components
- WANTED: Stainless Marine tails for #3Speedmaster set-up w/transmissions
- trade for a center console
- Two Complete Trs Drives Mint
- dominator carb 525 sc fuel lines
- quick jet change bowls (dominator carb)
- Dana Manifolds
- NEW Bravo XR in box
- (2) Eliminator cooler cushions
- Merc Operations/maintainence Info Guides
- B&M 250 everything you need
- SSM 17" X 30p 19 spline 3 Blades
- Aqua Step
- (2) Bravo lower vertical shafts
- (2) Bravo LWP lower drive cases
- 2001 Mercury Racing 540 Bulldog
- two supercharger linkages
- Swap 1" shorty IMCO for 2" Shorty
- Need an XR LWP
- 598ci Tall Deck 801HP @ 6000rpm, Turn Key. Make Offer
- 382 swap for a 312 anybody????
- 5" Switchable Mufflers & Donkey D!cks Free if you pay shipping.
- Fountain bimini top
- Blue 7" steering hub
- two bbc tall deck blower manfolds
- JL Audio M770-CCS-CG-WH 7.5" components
- Teague sea strainers
- LED pop up bow light
- Simrek Halo Bravo 1 drive showers
- CMI dry pipes
- P5X's - 26" - I got em, you need em!
- 582" Short Block
- Lots of Carbs
- Stelling Tail Stock Bearing
- Cover for 42 ft $300.00
- Mufflers
- Dino Steering Wheel
- Silent Choice + Y pipes 2 sets
- Merc Intakes
- Bravo 1
- Mach 26
- Mirage 23
- TRS Drives
- Misc. Merc. Parts.
- Mirage 25p - Pair
- Ford 302 motor w/crank,rods, pistons, bearing caps, make offer
- 8.2L 502 standard bore, make offer
- 2 Bed / 2 Bath Condo at LOTO 16mm w/40' SLIP
- alpha gen 2 II drive
- 1993 26' CORSA for sale
- 1997 Road King HD \ Ski boat
- OK 27 Formula 1986 running
- 24 Carrera ,also project
- Pair of Cometic Head Gaskets 502
- 97 Bravo 1
- 27 PHYTON ( project )
- carb spacers
- Trs Parts, Drives,trannies, Gimbles, Tie Bar
- Hardin Marine Shiftersw/trim
- Stainless Marine exhaust risers
- Merc Hp Series 454\502\572 Manual
- 1999 Mercury 2.5. Low Freash Water Hrs
- Merc Ignition Module-6D12A-V8-HP
- Gil Aluminum Risers
- Silent Choice
- Crane BBC HR 139681 camshaft
- Sportmaster lowers
- Mirage Plus 21p Rh & Lh
- Ace 1000lb PWC Davit
- Mirage 23P props
- Gen 5\6 454
- 500 EFI ECM's
- OPA GPS system
- Intercom and helmits
- 502/415 HP MPI For Sale
- Mecr 3's
- Fel-Prp Marine #17046 Head Gaskets
- Mercruiser Pre-Alpha Drives (2)
- pair of 26P Bravos
- B&M Blower Kit - Polished and Intercooled
- relays for hatch actuators
- 27 mag single 540 #3 speedmaster
- Trading Tranny
- 2008/1979 35' cig mistress and trailer
- hydromotive props QIV 25 & 27
- #2 Tailstocks
- White MOMO Steering wheel
- 14 1/2 X32p Mercury Labbed 4 Blade Cleavers/ Mint!
- Pair of #6 Spacers
- 99 Hd
- B&M 250 pulley needed
- -2 IMCO Shaft...NEW! and some other Plates
- Transom Plate Assembly
- stellings
- 454 Mark IV forged cranks.. 2 availible
- 280S K-plane Plates
- 26 Bravo 1's
- Need To Go
