View Full Version : Swap Shop
- Gen IV Tall deck GM blocks
- EMI Risers BRAND NEW
- 188 Heads 26 Hours since rebuild
- 1000 cfm pro systems 4150 carbs
- STAINLESS mARINE 2 SETS BIG BLOCK
- Cmi sport tube straight back headers with tails
- Bravo Latham Steering Wing Plate
- bravo gimbla rings and bells imco sc cavitation plates
- Pair of 72C 10-18-014 transmissions
- Baja Decals.....
- BBC 990 heads 7/16 Rods/Pistons
- parts cleaning shop
- Candy Blue - Fender Holders 8.5" x 20"
- FS: Cams, Jesel Rocker Arms, Lifters, and Pushrods
- 2 x Two Stage Billet Seawater Pumps
- Blowers,Chillers, and Drive forsale or trade
- Two complete EFI and Ignition
- EMI Stainless Risers (No manifolds)
- Garmin 2010C GPS Map, (Color)
- KE Billet 2 stage Water Pump (NEW)
- Tall Deck Littlefield 8:71 with Superchiller and 1150 Marine Holley Dominators.
- BAM Super Cyborg Trans. Zero Hours
- B Max gears
- Holley 850
- Gentry twin turbo setups for big block chevy two avail
- 96 TOP GUN on Ebay
- Mallory merc Dist have 2
- alpha one gen 2 upper for 454 with 1.32-1 gear set
- MerCruiser Bravo 454 502 Water Pump Assembly 46-807151A8
- (2) XR/SCX Drive Lines (Yokes) for IMCO extension boxes
- gps speedometers
- 454 Intake Manifold Gaskets and Riser Gaskets
- A few things for sale or trade possibly
- 8.1 with whipple
- Crower severe duty BBC solid roller lifters
- PPI highback bucket seats
- 25' IMP Haul For Free
- Mercruiser 496 / 8.1 new service repair manual
- Indicators and Drive/Trim/ Tab switches.
- Pair of Latham Marine Bravo Cast Rear Caps With Steering Mounts
- Brass sea water pumps merc
- Headers
- gen 5 and 6 bbc raw water pump
- bravo xr parts
- HP transmission flex plate
- Water outlet divider thermostat 454 bbc
- Mercury Racing Smartcraft Display
- Stainless Marine Twin Engine Outboard Bracket
- 2.5 Sport Master Cases
- 502 MPI Mefi 2 System
- BBC Parts List two
- BBC parts Exhaust, cam rockers etc. First list
- Mercury Seawater Pump for 850SCI thru 1200SCI Engines
- Complete twin TRS + twin 72c green tag BW +trim+housing+gimbal+hoses+everything!
- Gen 6 509 short block
- Afr 305 heads cnc chamber
- Gen 5/6 raw water/fuel pump
- Bolt on mods for 7.4l 330hp
- CUT Rev4 Props for sale
- 2 High Back Racing Seats
- K Plane Tab Position Actuators- NEW
- P-Ayer SBC Mock Up Engine For Sale
- Alpha One Drive
- 2 complete msd ignitions with merc harness
- (2) 3"x24" [pwer steering/oil coolers
- (2) HP500 Thermostatic oil filter heads
- (2) Thunderbolt Ignitions complete
- (2)Dual Plane GM Aluminum Inakes with Carbs and flame Arrestors
- Bravo 22p props
- JE 700 Pistons and rods
- Ssm 3's and gimbals
- (2) IMCO PN: 01-3549 Extended Drive shafts.
- 454 mpi
- Imco wing plates
- Morel hydraulic lifters 4603
- 1987 33 cougar part out no power no drive lines
- "Imco'' Merc Replacement Riser 3" Taller ss
- Imco Powerflo "SA" Risers
- Hydromotive P-5 26 pitch
- TRS Transom assembly
- TRS 1.50 drive
- alpha one gen 2 with 1.32-1 gears for bbc or built small block
- westerbeke genset
- Ford F-650 14' Bed Cummins Allison Automatic Low 23,200miles $24,999
- Blower Hatch 38 Cigarette Flat Deck
- pair of 502s early hp 500s
- 1080p Epson Home Cinema 8350 HD Projector
- dual stage sea pump
- Propeller - Quicksilver 14.5 x 23P
- Number 6 Gears
- Propeller - Mirage Plus 14.5 x 25 Labbed by BBlades
- Propeller - Mirage 14.5 X 25P labbed & rehubbed by BBlades
- cmi headers with tails
- 2 Pairs of 500 HP EFI Heads
- Rocker Arms & Stud Girdles for Sale
- Pair of Bravo I 1 One Drives
- Cigarette Swim Platform
- Valve train for bbc
- 2 1071 Blowers complete
- LIVORSI LED NAVIGATION LIGHTS - new
- GM Rectangle Port Heads, 26 Hours.
- 60 hr. Square top xr with -2 imco
- Edelbrock Performer Intakes
- Microfiche reader
- split 2x4 blower intake 4150 bases
- volvo props
- L+R Hydromotive Q4 27 props
- 2 sets of MIRAGE 23 P PROPS
- Pair of MIRAGE 25P props
- 2 sets Pro Comp heads BBC 320cc
- Gen 5/6 Hardin 10qt pans
- Oil Cooler
- Mercury Marine Engine Harness (NEW)
- merc bravo block off exhaust plate
- TEAGUE PLATINUM XR OUTDRIVE - $6900 (Lake Havasu City) ON C/L
- Lifeline jacket.
- More parts
- 2 custom lunati cams
- CMI headers bravo app
- Scorpion 1.8 rockers
- Worldnav 740060
- Bravo swept back XR 30 hours
- Xr sweptback -2 sportmaster
- imco extension box driveshaft
- 1982 excalibur hawk
- K Plane Actuators- NEW
- Speedmaster SSM 3 drives, pair w/ everything. $ 8500
- MARINE MACHINE External HYD Steering - Twins
- BBC short blocks, long blocks parts 454, 509, afrs
- Custom grind roller cams from 540's
- Scat 6.385 H Beam rods and SRP piston 4.530
- RPM 4.375" stroke FORGED crank BBC
- Marine machine steering 280 k planes bravo XR and more
- Hering 5 blade
- TRS Transom covers
- Hydromotive 25P
- Hydromotive 23 pich 4 blade
- 1985 avanti 22 ft , complete clean super solid hull on trailer with trs 3900.00
- Roller lifter sets gen5-6
- Latham Marine TRS Steering Mount
- Props/mufflers
- Parts for sale
- 502 engine........
- 35 - 38' Aluminum S. Fla Trailer in NC. 12k cap. $ 3900
- 2001 roadmaster tri axle trailer
- set of trim indiators for triples
- throttles and shifters for twins tripples
- 2 1071 blower kits complete
- bbc bare block casting 3855962
- Silent Choice
- 2009 Ace Trailer For Sale
- Latham Throttles. $ 300. FREE shipping.
- Sterndriver 25 pitch props
- Twin 383 Small block chevy
- Gaffrig Throttle and Shifter for Twins
- Pr 170025 Barry Grant fuel pressure reg.
- complete drivline set up for bravo
- Teague Tall breathers
- Engine parts and Formula 357 and 302 SR-1 KAAMA Parts Round 4
- pair of bravo 4 blades 22 pitch
- Pair of 5 blade 17.25 X 33P
- 420 style finned valve covers
- Cams For Sale Two new 741's and Two Custom Grinds.....
- Gen 5 454 .030 short block
- 250 blower in box from blower shop with BRAND NEW intake and lots of accesories
- Brand new procharger m1sc kit for carb bbc
- Formula 271 Fastech v-berth mirror $100 shipped
- Imco 2' shortie w/ bravo xr shaft
- pair Lantham steering cylinders
- Cast allumium Bomar hatches
- Aluminum tandem axle trailer 2 years old!
- Transmissions velevt drive bell houisings
- pedestal seats
- 34' Sutphen Project
- Aluminum tri axle trailer 38-42'
- BBC parts and boat parts
- Gen 5 502 rotating assy $400
- McLoed Bolsters!!!
- Heads complete, valve covers with breathers, crane gold rockers, pushrods and lifters
- 2000 Apache Warrior T/S
- Pair of trs drives, gimbals, transmissions
- TRS inner transom plates
- Trade 3+ up imco boxes for imco neutral boxes
- Pair of hydromotive Q4 26 props for TRS
- Complete drop in "MRD 600"
- Stainless Marine Manifolds an long risers
- Complete 454 mpi setup
- hp 500 engine complete drop in
- 12 meter bolsters
- Mercruiser Scan Tool Brand New
- 4.5 gaffrig switchable mufflers
- Gil manifolds
- Black k throttle/shifter for twins
- 2 stage water pumps
- Mercruiser Alpha One Upper
- Rex Marine Battery Box
- Mercruiser #12632A6 Engine Coupler
- Side by side drop down bolsters
- Pair mirage 25p props
- Marine machine hydraulic steering
- Trs drives, trans, gimbals
- parting formula 419 complete part out
- 30' Velocity Global Warming
- 12 meter fountain rigged hull
- (2) Bravo Ones w/ IMCO Showers
- Push rods
- 32 - 34' Aluminum Trailer. Towmaster. Triple Axle $ 3500
- PROCHARGER M1SC FOR SALE 454/502mpi
- Paying members
- Pair of gil manifolds
- CMI 525 Diverters
- CMI 525 headers
- Motor Oil Drain hose kits
- New volvo penta impeller kits
- Free
- Hydraulic Steering Lines
- Crane Hydraulic Roller Lifters
- Srp pistons
- Mercury 700 sc pistons
- 2003 volvo penta 350 gxi 320 hp long block
- Mercury H-Beam Rods
- IMCO Marine 2 Inch Short Lower Unit
- White mercury mercruiser zero effort control two lever for single motor
- M8 Drives For Sale
- Bravo XR helmets for sale
- staggerd engine motor mounts
- misc parts
- misc parts
- misc parts
- mercruiser bellhousing
- Trade: stock 26P Bravo 1 prop for a 24P Bravo 1
- K-trol Triple engine controls. $ 500 Free Shipping
- Pistons/Rods 502/540
- 3 Huber/Bam Trannies For sale
- 4" bolt on mufflers
- Bravo Stagger Engine Kit
- More engine plates driveshafts ect
- Mark 4 heads
- Set motor plates
- Mercruiser Alpha One Assembly Tools
- 34p L&R Bravo 4 blades - 5hrs use
- Mercruiser Alpha NIB Gear Kit
- Smith Brothers 5/16 SBC Pushrods
- Comp Magnum SBC Pushrods
- SBC OEM Hyd Roller Conversion Kit
- Melling Performance 10555 Oil Pump
- Quicksilver Coil 392-7803 A4
- Merc Alpha Shift Interrupter Switch Old Style NLA
- Merc Distributor Ignition Sensor
