View Full Version : Swap Shop
- 1984 Excalibur Catamaran 30 Surface Drives
- Set 500 HP for sale
- 22 pitch Bravo 1 4 blade
- Land and Sea Sternjack - Bravo
- -2 Sportmaster Lower
- 3 Mercruiser 8.1 `s 496 MAg./ 3 Bravo 1
- Set of Twin Engine Throttles/Shifters
- Gaffrig Speedo / Merc Air Filters
- Lh/rh 30p Bravo 1 Props
- NEW Mercruiser Exhaust
- New BBC Intakes
- trade Props?
- Misc Stereo Equipment - wheels - clean out shop sale
- 575 SCI long block
- Brand New Comp Cams Spring Mic 1.800" -2- 2.200"
- KE Ignition Mounting Bracket Complete for Bravo
- 2ea Callies Magnum bbc 4.625 cranks
- TRADE or SELL: Bronson lab 26p bravo for 28p bravo / hydromotive / etc....
- 16x25 Cleaver Props 1" shaft Kiekefer set
- Mercury High Five 25p Prop - 5 blade outboard prop
- Mercruiser Shift Assist Parts
- Procharger M4 Parts
- Pair Of Imco Sc Drives
- (2) merc 500HP carb CAMS
- Dart Single Plane
- 830 Holley
- Dominator Carb, Intake, Spacer, Flame Arrest
- 500 EFI Pistons $125.00
- (2) 18"x3" Revolution Marine Oil Coolers - NEW!!
- Mini Hawk
- Mercruiser props 30p
- antique car auction plus harleys and colllectables
- Bravo Gimbals Inner Plates and Rams TRS Rams & Drives Merc Trans
- Water pick ups Throttles Shifters Grab Handles
- 540 Crower rods and pistons Tall Deck Block cranck
- Ps Pumps Trim Pumps Remote oil filter
- Mufflers and Perko batt switch
- K Planes 450's Dual Ram Sell or Trade
- Fuel Filter Heads Fuel Pumps Y Blocks Bleed back Valves
- Fender holders 3 8" diameter
- 454 engines 1 complete 1 short 3 bare Imco Manifolds
- Mallory Fuel regs
- Batt Box Race and gil marine
- Siingle wire alt
- New V Belt Merc Replacement Alt MERC # 805884P -135.00 SHIPPED LWR 48 1 YR WARRANTY
- Blower Shop Billet 14-71 blower
- 1991 43 Scarab Thunder
- Merc #3 for sale
- Borg Warner 71c Trannies
- Huber 1050 Trannies
- Fiberglass Hatch Inserts for blowers
- Hydromotive props
- 85 Chris Cat (NO POWER)
- aluminum welder
- Super chargers
- Hyd Steering Control/actuator Valve
- big block parts, 525sc, bravo 1 many blue mercrusier parts gil exhaust, blocks
- Mercury Racing 16 3/4 x 33... 5 blade props off #6 drives
- lathma hynautic heim joints reservoir krc pump hydraulic steering
- 17x32 four blade props labed
- 38 cigarette boat hull and trailer
- #3 drives and gimbles on ex boxes
- cobra motors 900hp
- 2007 4x4 gm 2500HD parts
- K-Planes - $275
- 2ea. 850cfm Holley marine carbs
- Steering and tabs
- 1989 Formula 272 SR1 NEED TO SELL!!!!!!
- 27 Hydromotives LH RH
- 1990/2010 Formula 272 Sr1 Hull Complete
- thundervolt ignition
- trailers
- 2 Sets Cmi Big Tubes, Strait Backs
- parting out a 38 cigarette race boat
- WTB bbc exhuast manifolds
- 4 imco stainless risers
- Gen VI Marine Kinetics Roller Cam
- 500 HP Rotating Assembly
- 2 Pair CMI big tubes with 5" tails
- 26 spline speedmaster props for sale
- 439 short block
- 99 28 warlock sxt 21k or part out
- Swim platform
- Hoss racing props for speedmaster
- bbc scat crank pistons and rods
- Gil Dry Exhaust for BBC
- 468 Complete carb to pan with exhaust
- gil/merc.headers
- Intercooler
- Imco Sc Drives With -3in Sc Lowers
- aftermarket closed cooling overflow bottle 30bucks
- 502 block and other misc parts
- 5.7 Mercruiser complete package $ 3,500.
- 2-pair, GILL Offshore exhaust system...
- XR Bravo outdrives for sale...
- Dewald Racing Props for Outboard Cat
- 28 hydromotive labbed props
- 30 Pitch Bravo I Props
- Bravo I SS Prop 22p - $175 obo
- Captains call system 496 Merc (NEW)
- 1991 Baja 240 es low hours- with 525 blue engine or without engine
- Props MUST GO 4 Blade Speedmaster!!!
- OMC 14 1/2 x 20 Raker
- 454 Partial Engine Gen IV $300
- 6.0l motor and trany
- myco trailer
- 32p bravo 1 4 blade $450 for the set
- Pair 06 525/w125hrs...submerged, flushed, run, pickled
- 2" HVH CNC 4150 Spacers
- Gil Trs Tail Pipes (new)
- Imco Sc Drives With -3in. Sc Lowers
- msd dist.
- transom thu hull water pickups
- Wtb b&m 250 rotors
- Zero effort control quadrant Mercury Racing New
- Revolution 4 prop 19P standard rotation
- Exhaust 4" Muffler Tips
- teague 900 efi imco gimble
- Perko LED Side Lights
- 850 barry grant carb
- 71 series Superchiller
- Holley 850 Marine
- Power LED 48" Anchor Light For Sale
- Fortress FX 23 Anchor for Sale
- exhaust, tabs, trannys
- 1979 SEACRAFT 23 project $ 500.
- blocks and crank
- 1999 Sr24 Htm
- BBC Edelbrock Cast Aluminum Valve Covers and Cast Aluminum Oil Pan - Custom made???
- Morse "MY" Throttle/Shifter Controls- Single Engine - New
- Livorsi Moster Gauge Set, Monster Rings, Rocker Panel,
- Cam lifters springs BBC
- Sbc
- Merc BBC 496 Exhaust manifolds & risers
- prop hubs
- 14qt gil oil pan and pick up
- HP500 Motor & misc parts
- 32 Skater Hatch , 499.00
- props 28 pitch labed pair
- J.E. blower pistons
- big shaft 4's, boxes, imco steering, and trannys $20k
- Pair Of 5-Blade 16.5 X 31.5 Props For #6 Drives
- Imco Scx Complete With 1.24 Sc Lowers Smoking Deal
- Pair Of Imco Sc Drives W/ 3in. Shorties
- BB chev sea pump bracket+pump
- Cigarette Bolsters
- Trim cylinders
- 380 K plane tabs $600
- #3 drives gimbles and ex boxes
- top mount starters
- two 850 cobra power blowers motors
- #6 gimbles used
- two new 535ci 650hp motors
- two new 540 tunnelram motors 725 hp
- Cmi Sport Tubes & Tails
- brand new bbc dart blocks 10.200 steel caps
- bbc crank 4.500
- 1071 blowers
- EMI Thunder exhaust with SS risers
- Need good set of lower 1.35 XR gears
- 99 31ft Kachina Vindicator minis motor and drive
- 420 Mega Blower Parts - NEW!!
- 26' Trailer and Eddie Marine Tabs for sale
- misc parts for sale
- 2 pair big tube headers
- Merc SSM 3/4/5 Extension boxes with carriers....
- #3 Speed Master Drive
- Nose cones
- FS 1991 32 fountain fever
- Wanted two sets of big block chevy exhuast
- 750HP 509ci Blower Motor fresh! 10k
- 500 EFI Mercury Racing Air Filters
- ome 454 mag carb 40 bucks
- Any interest un powered?
- 2 good condition offshore motor mounts
- Will Trade Two 26" Bravo One's for a Pair of 24"s....
- TRS package.
- 4 Blade 32p Bravo 1 set
- Pair of Merc XR 2in shorties swept back 20hrs
- 2 Complete XR drives
- Ceasar Inflatable Catamaran Dingy 10.5ft/30hp
- WTB: 2 sea strainers
- 1271 blowers
- Low water flush
- 35 cigarette mistress
- Big Block Chevy Parts
- Post Swap Meet Blow Out!
- 1989 Formula 272 Sr1
- 468 BBC Gen V - Zero hours
- Wanted:2pair Gil dry exhaust TRS
- auto meter
- gaffrig white swich panel
- bravo y pipes and muffers
- two #3 drives and gimbles
- two new 900hp blower motors
- 28p Hydro Q-IV Props
- 33 Powerplay
- looking for procharger
- More parts - Steering, prop, coolers, etc
- WTS Mercruiser 496 HO
- Whipple 3.3L stage 3 with demon carb, 2 complete kits
- 2000 formula 353 hull for sale
- Choppa pipes
- TRS 2 Trannys Upgraded 10 Disc Fresh.
- Bravo,alpha trim pump
- 24P Bravo One 4 Blade
- Cmi E-top Tail Pipes
- Bravo One 32 Pitch Labbed
- Speedmaster props #6 lower cases crash boxes trs trans drive
- 1996 Carrera 257 hull with free motor
- 540 motors
- Teague Polished Fuel Filter Head
- Bravo XR Sweptback Complete Drives (2) - $9,000/pair
- TRS Drive and Trans
- thounder 4 bolt boxes
- Fiberglass swim platform
- 16.5x29 3blades
- Lab 29 Bravo $450
- Gibson 4.5" clamp on mufflers $425
- strainers
- Superchip Flashpaq 5.7 hemi
- silent choice captins call setup 4
- Mercury Racing Props Sets Outboard Cat
- 28' Scarab fully rigged hull $6500
- Hardin sand strainers
- -2 IMCO lowers and XR upper
- mirage 25 pitch props
- mustang drag car very nice
- 24 Pitch Bravo 1 Right For Sale
- Refrig. out of 94 Fountain
- #6 drive and trim tab pumps
- Hydromotive prop, bbc intake
- alpha one upper 1.63 ratio
- crane ignition works great
- silver monster gauge livorsi 100 gps speedo
- 31 5 blade herrings $1100
- labbed 34 bravo 1 lh and rh $1000 obo
- 32 labbed bravos less than 30 minutes run time
- 24' Twister Hull
- Chris Craft XK 21 -speed/ski ..$ 3k
- wtb imco gimbal ring or imco transom ass.
- WTB: Marine 650/750
- stock 454 mag mpi exhaust
- 1985 Scarab II Panther? Part Out
- Wanted: BBC aluminum flywheel
- 30 Scarab Panther -Cheap
