View Full Version : Swap Shop
- 850 Demon Carbs
- Bravo 1 28P RH
- CMI Aft Fire Switchable Mufflers
- Powder-coated Grey Dead Pedals
- Hynautic H-42 Helm Kit
- Bravo-1 vertical shaft
- BMAX B-Max Outdrive Part Out, -2 Lower Complete for Bolt on (30hr)
- Is there any dealers that take motorcycles in on trade?
- Steering helm to make dual steering
- Mercury XR w/ Imco SC lower
- 14,000# boat lift at LOTO Millstone marina
- Cleaver Props LH 23 and 21
- 19 spline props
- 280 Tabs System Complete
- stainless props
- water pump kits
- 36" Tie Bar
- Baja .38 Special
- 28 Maximus RH
- 15.5 x 31 20 degree herring
- 31 hydromotive 4 blade 1.25
- Hydromotive 30 P5 set 1.25 solid
- 17.5 x 32 26 spline RH
- 34 bravo RH labbed
- 18x29 26 spline props
- Crane Cam and lifters
- Keith Eickert Oil Pan
- Hering 5 Blade 17-33-16 props
- 280 k plane plates
- Thru hull tips
- 30p bravo one - left
- 2 Dominators
- NEW 1350 Mercs with M8 Drives and Gimbles 1.30 Ratio $275000
- Dart/Mercury 525 Heads
- 280 K Planes
- Optima battery boxes
- #6 drive nose cone
- #6 drive spacers
- Merc Racing RH #6 32 x 16.5 , 15R
- Bravo 1 labbed 33 props
- Black Hawk drive.
- Hydromotive p5x 30 pitch right hand...blueprinted and balanced 750
- 4ea Livorsi Optima battery Boxes
- 28 ft obsession complete less engines
- Imco SCX Lower with propeller ++
- TRS Nose Cone
- Big trim tabs
- NXT Upper
- Mercury Racing Electric Fuel Pumps for 1025SCI, 1075SCI & 1200SCI Engines
- Stock Bravo 1 32p props excellent condition
- promax pair for sale
- Sea strainer
- small block performance parts
- Throttle / Shifter Cable 25ft
- Lots of Props
- 525 EFI Intake Powder Coated Silver $1100
- 4 Corsa Exhaust Tips
- 2 Ea Garmin 7212 gps Chartplotters
- Stiletto 13 3/4 x 23 pitch
- 26 spline 3 blade Lh props
- eagle rod 6.535
- eagle rod 6.535
- Cigarette C Path Compass
- 1991 scarab 34 excel 8500
- Bolster Seat Stands
- 525 hp efi rods and pistons
- Cleaver props 18x33 for #6
- 705 cubic inch 1400hp motors
- 2000 Formula 271 FASTech Silent Thunder Box Curbside Alert
- 3 inch steering hub
- Water dumps
- Trs drive plates
- Alpha 1 shift bracket w/spring guide new $25
- Mercruiser trim pump and misc. brackets $75 all
- #6 Mercury drive rebuild tools
- Pair of #3 speed master with big shafts
- Fuel Fill
- Mercury 150XL For Parts
- Volvo DPX Trim Cylinders
- HD helmets
- Nickerson Holley 4150 Carb $350 OBO
- Myco trailer lights
- Flame arrestors
- Mercury HP500 Holley 4150 Flange 800 CFM Carb
- Pair of #3A speed master drives
- Pair of 632ci 700hp
- 96 Myco trailer 37-39HTR GALVANIZE
- Imco lower unit
- Boating Magazines For Sale
- Holley red fuel pumps and regulators
- Gaffrig twin engine gauges
- 42’ Fountain parts OHIO
- Mercury Outboard FLUSH HOSE TO ENGINE CONNECTOR 56-820386A55
- Crane cam ignition
- Hering prop
- Switchable mufflers
- Props
- Holley mechanical fuel pump new
- Crower HI-REV KIT Big BLOCK New
- Comp cams stud girdle new Bbc
- Trailer tire and rim
- Aluminum tripple axle
- Myco triple axle from 38 top gun
- Bravo parts
- 72 LHP electric shift driveline transmissions
- Parts for sale
- Bravo Upper Gear Sets
- New CMI Mufflers and #6 Trim motors
- quadrotor 3.3's
- Dart big m with piston squirters 55mm cams 937 lifter bores
- Lake Michigan C-MAP Card
- Acme 21" x 31 pitch props L&R pair
- Gaffrig Single Engine Controls
- 2 Cigarette wiring harness from Gladiator
- Stainless marine bbc chevy manifolds one set 1,000
- 540 bbc 150 hrs have two of them 10,000 for both
- Mercury 500 hp 540 cu/in Bulldog Longblock for Sale - $8,500
- 1991 scarab 34 excel 10,000
- Fresh Teague 800 EFI for sale or trade down to 525's
- (2) Bravo XR Upper Units For Sale
- MISC Big Block Parts / wiring harnesses ect ect
- Procharger M1 SC 500EFI
- Mercury Revolution 4 prop. 21 pitch. Excellent condition, $400
- Labbed Mercury Mirage Plus Props
- Mercury props, new in box - Fury, Bravo, Enertia
- control shifter and throttle
- MSD ignition and autronics ecu
- ISO 3 3/8 gaffrig tach
- DPX Trim Cylinders and more!
- 11 plate transmissions w/#6 plug-in tailstocks
- ISO Donzi 35 ZR windscreen
- 2 bravo1 props 48-831919 32 lh
- Blackhawk Drive and Props
- Bravo parts lot $250 all
- CP Performance Oil Cooler and mounts NEW
- Volvo Penta Bell Housing
- #5SSM drives
- Mercury Racing 1200hp 17.25x35 5bbl props
- CMI 525 EFI Mercury Racing Headers $1700 OBO
- Faria Gauges
- Mercury Racing 4 Blade LH / Speedmaster Prop
- Mdercruiser 454 BLOCK 4 bolt standard bore excelent cond.
- Imco scx lower
- Pro-Topline heads new 320cc runners
- Garmin 7607xsv **2 units** Brand New in Box
- Garmin 7610xsv
- 454 drop in motor , approx. 600hp
- 90 TG Hull 4sale
- T-Stat Housing Merc 4 Port w/Balls
- Thunderbolt IV V8-20R
- Imco scx
- 4 bravo trim cylinders $100
- Brand New- TACO GS-500 Pro-series Outrigger Kit
- Stainless marine manifolds/tails
- Chart Plotter Standard Horizon CP170c
- Top Gun blower hatch
- Stainless lift plates
- Fountain billet battery covers
- 3 Fountain life jackets
- Whipple quadrotors
- Free
- 600 SCI flame arresters
- Tilt wheel adapter
- Hering
- HP500 carb OEM ignition and knock modules
- Bravo parts
- livorsi GPS speedo
- Lighting Headers BBC
- BBC 565 Blower ready long blocks
- 2 - 1,000HP Blower Motors 572’s with bravo bell housings
- Headers 2 sets . Great shape
- Oil cooler
- Dart tall deck 4500 flange intakes $350 pr.
- Sun deck lift
- Spark arresters
- Hering Props
- Gill exhaust manifold bbc
- Mercury 2" SPACERS for #6 Drive
- Sportmaster -2 lower
- Hardin Marine Raw Sea Water Pump ISO
- Free
- 500efi intake and parts, misc plumbing and gauges.
- Bam 1550 Dry sump
- full stagger Stellings with tailpipes
- pair of #6 Dry sump
- bilge pump, bilge blowers, Gaffrig water temp
- Mercury Active Trim Kit
- Transom Mount Water Pickups
- Mercruiser Trim Pistons Alpha 1 Gen 2
- Bravo Port Side Trim Ram Brand New
- Mercury Racing Labbed 23p rev 4 14.625" dia
- Mercury Maximus 5 blades 24p 15.625" dia stock
- FS: PA 2 Project Big Block Marine Engines CHEAP
- Gil Bravo Wet risers
- Donzi early 90's bucket seats $175
- Bravo Trim rams
- 454 Mag Parts/ Garage Cleanout
- 1/2” bravo imco / sportmaster spacer
- Hp500 / Bulldog valve covers
- Holley 9022 800 cfm carb
- 2-Autometer 2 5/8 0-15 PSI Fuel Pressure gauges, Full Sweep style, includes sender.
- Simrad GO5 GPS
- 454 marine magnum new rebuilt $6500
- 4,5" V-Band Clamp
- 5- Blade Throttle Up SSM VI propellers. 17.5 X 30 X 16 degree rake
- 2- Eddie Marine Optima D-34 Stringer mount billet battery boxes with covers
- 1- Eddie Marine Optima D-34 battery box
- 2-Eddie Marine Optima D-31 Battery boxes
- Garage clean out
- Brand New Gaffrig bolt on trim switch
- Corsa Marine Exhaust Tips/Mufflers (2 sets)
- 700 hp motor 540 BBC
- Bell-housing mercury
- Hydraulic twin ram steering
- Standard Horizon 175C chartplotter
- Edelbrock victor Tunnel ram
- Danforth High Speed Constellation Compass $250
- 2 Livorsi 2" Water pressure gages New $100
- 2 brand new gaffrig 2" amp meters all black 60.00
- 2" tall Zieneth flame arrestor 50.00
- Mercury 3.0L 250hp ouboard cowl 2003
- Sea Pumps
- Gil air actuated mufflers for twins
- 29P Mirage Plus L+R x 3
- Brodix 2001A intake fresh water never ported 350$
- bulldog 540 parts
- 25p LH Revolution Rev4 prop
- Hydromotive P5X Props 26p
- MercTrans II rebuilt
- Brodix 2005 tall deck intake manifold fresh water only
- fender holder bumper billet
- TRS Trim Cylinders
- 1250 Dominator Built by Nickerson
- 27p Mirage Plus LH like New
- 800 SC blower setups complete
- Single Mercury Dry Sump #6 Outdrive - Needs Upper Gears
- 575 sci Superchargers
- Mercury Enertia ECO 16x21 NIB
- New stroker crankshaft
- Fresh rebuilt XR Drive for sale
- Big Tube CMI headers 2 Pair
- CMI. Headers. For full Stag.
- 1982 Merc Tower of Power 115
- Outerlimits Leather Jacket
- 2 502 magnums and bravo drives complete packages
- 0 zero hour huber 1450 plugin $3000
- Pair of ssm#4 and transom assemblies
- Imco AEC-7 steering cap
