View Full Version : Swap Shop
- Hydromotive 26 P5X L & R Stock
- Mercury Bravo Props L & R 26 Pitch, also 28 Pitch Labbed & Hub kits
- Gauges for twins with GPS speedo and sender
- Drives,Stainless Marine tails,crossovers,valve covers,pulleyss, fuel pumps,etc
- Trs inner transom plates
- Couplers
- (2) KE 2 stage water pumps for sale
- (2) 5 Blade Hering props 15.9 x 33 16R 4000.00 O/BO
- Imco SR-8-1-14 Steering Ram
- 088 heads
- 2 502 MPI motors complete
- Big Tube Lightning Headers
- White Gaffrig controls Twins w/ trim
- 1986 272 LS part out 2000 tow master trailer
- CMI SBC Headers NEW
- 750 cobra motors for a pair of 525's or similar
- 496 Mag HO parts needed
- props for sale or trade
- Top Gun cover
- Bravo transom assembly, Corsa quick and quiet II, y pipe
- Tandem oil cooler 2x19, GenV valve covers
- Starbrite spray boat cleaner
- JL Marine M8.80 Coax Speakers
- (2) Pair Used Chevrolet Big Block MSD Ignition with Distributor
- lightning performance marine fresh water headers
- Baja 38 Special part out
- 34" 5 blade herrings
- Edelbrock carbs-750 cfm
- Labbed Bravo 1 22p props for sale - perfect condition.
- Merlin Marine Intake Manifold 4150 9.800
- Gaffrig Single Oval flame arrestor, SS, 4150, 18.75"L x 10"W x 5"T
- Standard Holley Super Suck 2" Spacer with studs
- Quick Fuel 850 Carb
- Holley Marine 750 carb
- parts and more
- CMI E-Tops for BBC
- Gen IV BBC HR Camshaft
- Whipple Motown SBC 406 Fresh
- Hp 500 thermostat housing
- HP 500 fuel pump/cooler
- Hp 500 HD coupler
- 26p Right hand bravo one props
- 1995 bravo transom assemblies.
- Mirage 27 prop non plus
- Pair of 2008 Ilmore 625HP 75hrs 50K obo with Headers
- Eddie marine battery boxes
- Air Actuated Mufflers
- Project done ---Fiberglass Cloth - 17 oz Biaxial with 3/4 oz Mat Backing 50" wide
- KAAMA Exhaust manifolds and tails 2 sets! ---> $200 manifolds, $200 tails, Plus ride
- 280 volvo aq outdrive
- Crusader 8.2L XLi RTO
- IMCO steering wing plates for alpha $250shipped
- Pair of 1" prop hubs
- Baja Marine Leather Race Jacket
- 1997 Baja Boss 252 no motor
- parts list
- Rebuilt 7.4 Mercruiser long block with new dual plane intake
- Attn: STACKS
- CMI E-tops and tail pipes, procharger big red BOV
- CMI Sport Tubes - Need Repair
- 4" HPI mufflers
- B&M 174 Blowers BBC Polished, buy 1 or Both........
- Procharger inter cooler AW504 used for sale
- Flywheels and HD couplers
- SpeedMaster Wing Plates and Tie bar
- 1" drive spacers - Bravo 1 & XR (pair)
- DUI distributors
- Weiand Xcelerator BBC Intake Manifolds-Pair
- XR outdrive and gimble
- 525 blower
- Latham marine
- Imco SCX upper black " Deal of The Year"
- Turbo Props one set
- Misc accessories from 38' Fountain Lightning
- Fountain 38' Lighting Cockpit Carpet - Red - New
- MINT TRS parts Ohio
- 280 k planes and pumps
- 575SCI ** Mechanic Special**
- Bravo 1 XR Drive
- Cleaning out garage misc parts . Check it out...
- Motor & Drive
- 42' Fountain Stagger Gil Tails
- Vortech Superchargers
- Mark IV 468 Part out
- Bravo1 Upper, 1.50 ratio, Newly Rebuilt
- 1992 staggered 42' executioner 25k
- Bravo I prop 26 pitch RH
- PCM data box for mercruiser 496 Mag DTS
- Livorsi Monster Gauges
- Exhaust Tips - Stainless Steel Angled
- 2003 Aluminum Myco for sale w/drive guard
- Bolster seats forsale
- Kiekhaefer/Mercury Racing Throttles/Controls
- #5 SSM drives, Stellings box's & Latham steering
- Mercury 300xs Cowlings
- 2 hydromotive 27 pitch
- 2- NOS 10051107 GM Bowtie Blocks & JE Forged Pistons
- Latham wingplates & steering cylinders for Speedmaster drives.
- Demon carburator 1095 cfm with air cleaner and fuel rail
- Cmi Etop headers
- Bravo I prop 28 pitch LH
- 4 Gibson Clamp on Exhaust for Sale
- 502 Rotating Assembly
- Pair of Herring Offshore Racing Props
- class 5 or 6 Race Boat
- 2 502ci/ 567hp/ 588lbs torque fully dressed motors
- #6 5 blade 18x33LH prop for sale
- Merc II Trans Manual Shift Bracket
- 2005 Mercury 300X Drop on Power Head (LOW HOUR VIRGIN MOTOR)
- New Gaffrig gauges water psi, boost, fuel
- Looking for larger bomar hatch for 87 formula 272
- FOR SALE: Boyd Racing Engines from Jim Lee's 46 Skater Freedom.
- Hydromotive P5x 32 left and right
- Cobra 24' 1975
- Trans Coolers
- 2006 mer racing 250 xs drop on powerhead , true 5 orig hours 7800
- Mercury 850hp props
- Formula 272 hull trailer for sale
- 575sci complete with Cmi headers, fresh zero hours since rebuild
- Mercury #6 drives , Zero time since refresh
- Livorsi Throttle Mount Trim Switch Brand New
- 14 ft mini hawk baby red cigarette.
- Gil Tails
- 2 Complete Bravo 3 Duoprop Drives
- #6 DrySump Lower Case
- WTT: Have Mirage + 27 RH Want 25 Mirage + RH
- New OceanLED Amphibians A12 Underwater LED - Bright White
- For sale: Bravo 1 lower case with low water pickup
- Single Ram Hyd. Steering $850
- Assorted parts
- 454/502 GM forged 4" stroke crankshaft
- 2000 502 MAG MPI moving to carb setup - lots to sell, including heads and prop
- Corsa Stainless Hi HP Mufflers
- Merc racing valve covers 7 1/4 ATI Balancers CRANE HI-6 OLD STYLE
- 540 Dart tall deck block , pistons , rods ,etc $2500
- 2 Bravo One Upper Cases
- Finned Top Cap, Brand New
- Bravo One Helmet
- Teague Billet Top Cap
- Complete XR Upper
- Redhorse AN Fitting 1090-08-1 and 1090-10-1
- 2 pair of 496 mag risers 8.25" height
- Teague Oil Bypass (NIB)
- BBC Gen V Oil Cooler with lines and bracket
- 39 Top Gun Cockpit Cover For Sale
- Dan Olsen BBC large capacity oil pan
- (1) Pair New TRS Lower Units
- Flame arrestor
- bravo 4 blade 28 pitch - pair
- Thunderbolt IV ignition module
- NEW shotgun drew marine mufflers
- Ocean LED color changing light XP8 brand new.
- Cleaning out shop (moving).
- XR Drive Gears/Clutch
- transom exhaust ring seals
- Gen 5 & 6 Thermostatically Controlled Engine Block Oil Adapter
- Brand New Flow-Torq Hub Assembly
- For Sale. CMI Big Tube Headers. 2 Sets. $3000.00
- XR Prop Shaft
- fuel pump
- Teague/XR Upper Case
- 3 brand new XR 16 tooth pinion gears
- cmi big tube exhaust
- For Sale: Jim Lee / Tyson Garvin 2 Speed Transmission. Fresh, Work Great!
- right hand 32p bravo 1 4blade prop
- 4 Back caps for external steering/tie bars
- 4 Trim Pumps
- XR Gears, Input Shafts, Housing's
- Number 6 prop 16.75 x 38 18 rake
- Throttle mounted livorsi trim switch
- Bravo 1 25P Factory Labbed
- 6 16x7 zero offset 6x5.5 bolt pattern
- 2 CMI SS silent choice for Bravo
- MYco Aluminum cradle
- gimbal ring
- 454 with Blower came out of Baja $3250.00
- 2" flip to fuel fill
- Bravo gimbal misc. parts.
- Perko flush valve
- Imco transom assembly with steering
- Trailer Brake Parts
- Hp transom assy complete w rams, hoses shift cable and brand new inner plate
- Livorsi 6 Bolt Steering Wheel
- Looking to trade for smaller #6 prop or sell this one.
- TRS drives
- Corsa Exhaust tips with baffles, 2 pair
- Gaffrig 90 MPH GPS Speedo
- XR with Imco Lower
- 1995 502s. 1 hurt. 1 running when removed.
- Selling 1973 Cigarette 28ss
- Drop down bolsters $200
- silver ponza steering wheel
- Mayfair power steering reservoir
- Kiekhaefer trottles
- Shifter
- WTS 2008 Venture VATB 7225 aluminum float-0on trailer
- Silent thunder platform
- Clean 253 checkmate less power
- Gaffrig gauge set single engine
- 1999 Merc 350 Mag Mpi Fresh Rebuild
- Bravo one inner transome plate
- Gimbal bellows
- Aqua Power Ltd transom mount mufflers 4"
- Hp 500 parts
- Carver lightweight water repelent and UV resistant cover for 30' boat
- Crane Gold Rockers - 1.7
- OceanLED A12 Underwater LED - Bright White
- Kaama boots
- WTT 26p Hydramotive p- 5x for 24p Maximus
- Velvet Drive Liberty Series
- Stelling headers/tails/Gatling Mufflers
- Fountain 10-Meter Cockpit, padded engine hatches, cabin
- 8 Plate Remote Oil or Transmission Cooler Assemblies
- Pair of 4" Mufflers
- Fountain 10-Meter fuel tanks
- Mercury 280S K-Planes
- Pair of Hydromotive Quad IV 29" Pitch Props
- Borg Warner / Huber 72C transmissions
- PARTS - motor accessories ignition and headers
- Holley DP 850 red series
- Bravo shifter plate
- Various Parts
- Trim tabs with thru hull fitting and pumps
- Misc part
- Mercruiser Power Trim Hoses NEW
- Battery Switches NEW
- Hardin style hatch scoop "new"
- Hardin Stainless fittings
- small block stuff. alum exhaust, dart heads perf intakes gen 1 alfa 1 transom
- Misc. Parts for tall deck 572
- Mint pair of mc cloud power bolster seats
- refreshed 502 long blocks
- Matched pair Bravo 4 blade 30P
- Carb adapter plate, 71 series
- Bravo 1 22p LH/RH $550.00 plus ride
- Tiger Wireless headsets
- Gaffrig Single Engine Controls
- Two sets CMI switchable mufflers
- Props for sale LH+RH 28, 32, 34,
- Imco powerflow plus
- 1989 bravo one out drive
- 6 blade hering props
- Cmi e tops with tails
- Complete 708 CID Short Blocks
- New OceanLED Amphibians A12 - White
- 95 fountain 27' value - trade
- 30 pitch bravo 1 mercury racing labbed prop
- Gil manifolds and risers. Trade for cmi
- Crane bbc 1.7 Gold Rocker Arms
- Msd rev limiter
