View Full Version : Swap Shop
- McLeod power drop out bolster seats pair good condition
- Flip Up Windscreen
- Livorsi Diesel Tachometers
- Holley 700 CFM carbs mechanical duel feed
- 2 rotating assemblys
- Merc bravo HD helmet forsale. 150 plus shipping
- Mercury Flo Torq SSR HD Hub Kit
- Konrad drives
- Set Arnesons model A ( ASD6 ? )
- Gil Exhaust Riser Wedges
- Parts for sale
- Yard sale.
- Stainless Marine exhaust BBC
- Crower rocker arms BBC
- T & D BBC rockers
- Mirage prop left 21p
- Mirage prop left 25p
- Bravo one prop 28p left
- EMI Thunder Exhaust
- CMI Sport Tubes
- Spargi stainless steel steering wheel
- 454 gen 5 for sale
- 2 each EFI
- TRS Upper Gear Set
- 38' Aluminum Heavy Duty triple Axle Trailer Frame !
- New 3/4" Brass 12 Volt Solenoid Valves
- Hering #6 #6 5 BLADES SET
- Bravo one lower unit
- Unused Bravo XR lower
- Pair of Mercruiser SC Superchargers fresh from The Blower Shop
- TRS gimble assemblies and inner plates
- Hubber trans with Speedmaster tailstock
- Cup holders
- 87 Baja 240
- 87 Baja 240
- Gen iv stroker 496
- Distributor
- Remote trim switch
- Gaffrig Power Trim Gauges
- Tie Bar
- 2 sets of 4 blade hydromotives for sale
- Xr drive -2 sportmaster lower
- Clever Props
- Remote Oil Filter Bracket & Lines
- Gil Carb Bracket
- CMI big tube headers
- Blue Thunder book new
- Blower belt
- New wiring harness
- New ke parts for sale
- 380 K Planes/ Velocity Brand Trim Tabs
- Quickfuel 850 carb
- Used 502 Pistons and Oil Pumps
- BBC Indmar exhaust
- .842 crower SR SD hipppo rollers
- SS battery boxes
- Corsa Quick and Quiet 2
- Holley Carb Fuel Line
- TRS gimble rings
- SCX 1400 Lowers
- Spring Cleaning...
- Sutphen Dominator
- 250 blower shop blowers
- Latham parts
- Mercruiser Blackhawk parts
- Full cover for 31-32ft boat
- TRS drive.
- Mercruiser, Scarab, Manuals, KAAMA, TRS.... parts and brochures
- 6 point race harnesses Willans
- 3 Stage water Pump Keith Eickert
- Bravo 1, 23 pitch prop set for triples,
- Stainless Marine heads up trim indicator set
- Mercruiser engine wiring harnesses
- MSD boxes 1 dist
- 500EFI Pistons and 088 Heads
- Eddie Marine Fuel Switch/Valve
- Set of Mirage Plus 25P 3 Blade Props
- Mercury 496 HO with 65 hours
- Oil res bottles
- parts for sale
- Oil coolers
- Harden / livorsi gauges
- NIB ignition modules and harnesses 24/22
- Gen 6 502 long block 2k
- 2 stage water pumps
- Blower Shop Intercooler + belt
- New Parts off My Motor BBC.
- Exhaust Gil manifolds risers mufflers rings
- #6 Dry sumps for staggered with 1.5 ratio $44,000
- 4 New Corsa Mufflers
- Stellings greens with tails - leak
- 454 Weind 177 Stainless marine
- Pontoon Boat cover & poles
- Forged crank
- 2 marine machine strainers
- MSD wires-NEW
- 1 set Aqua mufflers $250 shipped
- Props several
- Bolster seats and stainless steel frames
- 9.8 4150 Rec Port Dart Intake
- Pair of 540 600s
- 3 tray aluminum battery box.
- 454 EFI intakes, gen 6 oil pans , lots of parts
- XR Lower 1.5 DWP and XR Input ujoint assy
- B&M 250 blower kit
- Bravo and TRS drives
- 489 stroker motors
- Bravo Cases std X/XR
- Whipple intakes,#6 gears,injection etc..
- Drive service tools
- Cutler injection brain and wiring
- Fresh 468 and 502
- MERCRUISER CORRECT OEM IAC and PROPER GASKET and IAC MUFFLER KIT
- Rear Engine Mounts
- TRS Gimble Housing/Inner Transom Plates
- Bravo parts std XR
- Bravo coupler
- 10 bbc Mark 4 oil pans
- Misc parts
- Comp Cam rockers BBC
- 1.36 -2 sportmaster $2500 obo
- Red Gaffrig Guages New
- Service manuals
- Rex marine clamp on trim Twins
- 4- Rolla props for speedmaster 6 drives
- Bravo 1 upper parts
- Bravo xr drive for sale
- Marine machine steering Rams. NOS
- #6 Herring Props
- Misc parts
- 2 Intercooler sea strainers
- KE 2 piece valve covers
- Teague marine XR Bravo top cap
- PARTS!! Holley 800's, Gen V 420HP short blocks Mufflers
- Thunderbolt distributors and Ignition
- BBC maney pistons pins rings brand new 4.5 bore...13 to 1
- Mercury Racing #6 Dry sump Drives 30k
- 3.3 Quad rotor whipple supercharger EFI
- Hardin marine 1 1/4 HO Dual basket strainers
- Trs drives and velvet transmissions
- 575sci tbi
- 2006 bravo 1 old style design
- 2006 Mercrusier 496 Mag HO 425 hp for sale
- Stainless marine Gen 2 V band 4
- Latham External Hydraulic Steering for Bravo One
- Pair of # 6 transom assembly’s
- Cigarette Top Gun Carpet
- Steering res bottles
- 17x28 19 spline
- 24P bravo prop
- 30P bravo props pair
- 27 hydromotives pair solid hub
- 1986 30' Chris Cat Project
- 3 PSI Blowers with Intake Carbs Pulleys
- Max Machine Worx XR upper. Fully built
- 496HO 500hrs.
- AED 950 HO 4150 Carb. Must sell sold the boat.
- Aluminum Valve Covers
- Hydraulic Steering Tramsom Brackets w/ thru hull tubes
- Corsa Captains Call for big block
- 380 k planes
- IMCO steering Rams imco back caps
- Iskenderian 292Mega Cam
- Crossover Kit - Big Block Chevy Port Inlet
- Bravo 1 24" pitch for sale
- MerCruiser Sea Pump with Fuel Pump Gen 5/6
- Supercharger Carburetor Top Plate Adapters 7163
- WTB Hardin Marine Front Motor Mount
- Life Line Sport Poker Run Vests
- LS Truck coils 585 ,Mefi 4B Weldon and Aeromotive 1000 Mallory regulators
- 2 Carter mech pumps for sea pump mount
- Engine Quest 320 BBC Heads (Pro Topline/RHS)
- New tbs 250 blower complete with intercooler.
- Triple Cummins marine diesel 480hp with Arneson surface drives
- ASD7m drives
- CMI Tailpiles - Dry to tip (angled) *Price Reduced*
- CMI tailpipes - Dry 6" from tips *Price Reduced*
- Used #6 dry sumps and gimbles Staggered 1.5 ratio
- Misc Bravo parts
- 1 pair leaky CMI’s cheap $500 w tails
- Set of je pistons 4.60 with wrist pins
- King Demon 1050 CFM Marine Carbs
- (2) pair cmi and bravo tails
- Bravo Lower Shimming Tool
- Bravo 1 Props
- Merc Brazil Valve setup for external cylinder
- JE Forged Pistons With GM Forged Rods
- Left over from 502 MPI
- PSI 206B Complete Blower setup BLOW OUT PRICE - $8000 Shipped
- CMI LS Sport tubes
- Bravo 1 32" pair $600
- Shop Prop Clearout
- 700HP blower engines
- Cigarette cockpit/cabin lights
- 280 K Planes for parts
- Used #6 Drysump 1.5 Staggered with Gimbles
- mercruiser 500 ignition module
- New M6 Drives and Gimbles 1.35 Ratio
- Bravo Nose Cone
- BBC Dart aluminum marine heads (marine) 325 cc
- Wts bravo swept back 1:5 $2,500
- BBC 588/670 hp just rebuilt and dynoed
- Exhaust Silencers
- Mech trim indicator parts
- BBC E-TOP CMI headers with tailpipes
- Lightning headers??
- Set of CMI headers for Staggered 700EFi
- #3 transom assy w/new inner plates
- IGN-1A smart coils - strongest output coils on the market
- BBC hi output heat exchanger..700 plus shipping
- Bravo HPTransom Assembly
- Mercury 380 Carbon Fiber Racing K Planes
- Swim platform for 40' Magnum! Very large !
- Pair Bravo 4 blade props 14.5x28. Size
- Large Exhaust Risers !! Only 15 min of run time !!
- Tempest Surface Drive Rudders . Heavy Duty !
- Arneson ASD 8 dovetail solid mounts !!
- Hydromotive Q-IV 26P 15.5" HC-CL26R
- New TRS PARTS
- Gil oil coolers BBC
- 14-71 STD Helix Bowers stripped blower
- Bravo 1 28P RH Labbed by BBlades
- Mercury Zero Effort Controls for Single Engine
- Complete mercruiser efi from 454mag
- K Planes 280 bottom plates
- B&M 250 blower parts
- Pair of white Gaffrig boost gauges
- Quick Fuel 850m and various mech pumps.
- Custom Boat Cover for 34' Fountain
- Mecury 115hp 4 stroke Tilt & Trim Unit
- 380 Velocity Tabs/ K Planes
- Nice Aluminum Sea Strainer
- (3) Stelling Green header sets
- Scat 6.385 Rods
- B & M 250 Blowers
- Cam and lifters
- Cigarette 20' needs complete restoration. Trade for 31' bullet in need of restoration
- Imco extension boxes, hyd steering, bravo package
- Mercury Thermostats w/cross over
- Pro Chargers
- Mercruiser Fuel injection
- 1" Bravo spacers
- hering props
- CMI Tails Flange 4” Offset for Bravo $300
- Race Headers !! 2- sets good shape !!
- Whipple thermostat housing off 3.3 efi
- 1988 30’ Scarab Panther part out
