View Full Version : Swap Shop
- Konrad 540 HP Drive Package
- 2 inch shortie lower unit for bravo drives
- New XR uppers
- Dennis Moore Book Swap Bbc for Sbc
- 454 MK IV forged steel crank/ 7/16 dimple rods TRW L2453F.030 blower/turbo pistons
- Hydromotive 34 p5
- Ngk 7
- CMI Sport Tubes Headers 525, 600 and 700
- Hydromotive P5 34
- AEM CD-7LG Carbon 7" Digital Racing Dash Display w/ Logging & Internal GPS
- Big Block Chevy Marine Performance by Dennis Moore
- WTS/WTT 4" Corsa Mufflers
- 500 efi intakes/fuel rails/ throttle bodies
- Mercruiser Gear Lube (3) & Salt Terminator
- NEW Bravo 1 Anodes (3)
- Bravo 1 Trim Sensors (2)
- NEW Marine Carpet
- Mercruiser Manual(s) Chapman Piloting Book
- Mercruiser Misc. Motor & Drive Parts
- Mercruiser Riser Gaskets and Misc. Exhaust Parts
- Corsa Exhaust Actuator
- Mercruiser Motor Mounts
- Need a drive line trans
- Fenders & Prop Bags
- Rinda Codemate & MEFI 1 Scanner
- Trade Mefi3 for Mefi4
- Anchor, Swivel, Chain, Rode Kit
- Mercury Racing 600 SCI bravo XR Drive on Extension box
- 13.5” steering wheel with 3/4” shaft stainless
- 6 blue water switchs waterproof push button
- Holley dual sync distributor 565-204
- Holley Smart Coil Brackets
- Mercury racing gateway cables and jbox 525 efi conversion gauges to nmea 2000
- Pair of nmea 2000 pressure sensors
- Low hour 2 x bravo 1 drives 1.50
- Factory Mercruiser 540 Engine Drop in Ready
- PerTronix Flame-Thrower EST Distributor
- Pair of Keith Eickert Exhaust
- Keith Eickert 2 piece Valve Covers
- Factory Low Hour Mercruiser 540
- 94005 Adapter for Techmate/Diacom
- Mercury racing zero effort racing throttle triple
- Bravo 3 22"
- No-clog super strainer
- 5" Dry mufflers
- Super Muff
- LH & RH Bravo props 24p
- Used #6 Prop Shafts
- BBC Carillo rods set
- Older Bravo 1 upper
- Serpentine power steering pulley NOS , $40.00 shipped
- Trim pump
- 2 Sets of 525 EFI Connecting Rods
- Hydromotive P5 33x15
- Old 454 engine parts
- 500efi wiring harness for sale
- Stelling yellow pair no leaks
- Valve spring oilers
- Mercury Racing 525 Mefi 3
- #6 gimbal ring
- (2) 35-38ft steel trailer triple axel trailers
- 353 Fastech snap in carpet
- Hydromotive 5 blades
- Pair of Bravo I 32P Props
- 2 x 525 EFI ECM & Harness Assy
- Mercury Racing Bravo 1 32p Prop
- Misc. 502 parts and 21P RH Mirage plus props
- Teague 10an polished thermostat housings
- Pair 500 hp 454’s
- Bravo 1 32p RH
- 42 Fountain stagered tails new CMI
- new BBC soild roller cam
- TRS transom and merc 2 trans x2
- Merc Maxximus 30 P 5 blades
- Bravo 1 30p RH BBlades Labbed
- Mercury 525 Intake Manifold
- Verado 5.4 hd 1.75 lower units with Bob nose cones left right
- Performance boat parts for sale #2
- Steering Wheel and Shaft Adapters
- 2 sets of stainless marine dry exhaust
- swim platform
- Imco SCX4 Drives
- Set Rolla cleavers
- New Mercury HP transom Assembly
- ISO 500 EFI cam
- Mercury 525/600sci/700sci Coolant Tank Covers
- Oil Cooler 3"x30" with fittings and mounts
- Full Valve Train Parts: Billet Roller cam, Crane Gold Rockers, Smith Bro Pushrods ect
- Imco dual downshaft lower 1.34
- 502 short block
- CMI/Mercury Split Tube Headers
- Stock 502 gen 6 hyd. roller cam & new timing chain $150
- New Mercruiser Mercury Bravo XZ Drive 1.50 ratio
- Bravo 1 upper core
- Mercury HP transom assembly
- EMI thunder exhaust w/ long risers
- 280 K Plane Lower Plates
- Merc II trans pair
- Bravo One Stellings extension boxes
- Pair of Mercury 540 Engines
- Fresh NXT Trans With Cooler
- Mercury TRS Drives
- Mercruiser Mercury Bravo XZ Drive 1.50
- Misc props 3 and 4 blade trs bravo
- BAM 2404 Dry Sump 1500 Marine Transmission
- 1972 Mercruiser III drive, transom Ass, and velvet drive all original
- Parting out 1988 Formula 242LS
- 502 700 shortblock
- Kieth eickert lightning exhaust
- Pair of 502s
- Misc items
- MSD Black Distributor #83663
- Pair of 572 blower engines
- Mercury XR Upper Gear Sets
- Bravo 1 - 1.5 Ratio
- ASD8 / Single Drive Full Assembly
- Gill exhaust
- SSM V Drives, Extension Boxes w/ gimbals, Latham wing plates, 3” drive spacers
- 500 Bulldog Flame Arrestor Plaques NOS
- Sea strainers
- ATI Super Damper
- Teague Marine 1450 HP Quad Rotor Whipplecharged Engine
- Mercury 500EFI Engine Plates
- Gill manifolds
- 1075 3 Stage water pumps
- Westerbeke 3.0 BPMG (19 hours) Like new $4500
- Mercury Maximus 31P Righthand prop
- Batboat replica for sale
- Cigarette Mistress
- McLeod Bolsters
- Bravo 1 drives (4)
- 454 marine engine gen 4
- Continental boat trailer with drive guard 34-35’ 18,000 lb
- Marine machine hydraulic steering BRAVO
- Mercury 525efi stage 2 whipple $23000
- Latham Sea Strainer
- Sierra Trim Sender Kit - Mercruiser
- Suzuki watergrip props
- 26P - Mercury Maximus 5 Blade For Sale
- Bravo Couplers
- Bravo bellhousings
- BBC HP blue accessories
- 280 K planes with pumps
- Keith Eickert 2 stage pump and distribution components
- Looking for a 27' or bigger hull that needs power...
- Number VI boxes
- Mercury 500 EFI I/O for sale
- 42 fully rigged hull
- BBC Block Oil Filter Cap Conversion Kit
- Mercury #6 plug ins
- 2017 Westerbeke 5.0KW MCGA EFI Generator
- Mefi 3 009 ECM
- Blower carbs
- New old stock Gill sea strainers
- TRS SSM 2 Drives, Gimbals, Cleaver Props
- Imco 1:36 Drives.
- Big block valve covers and tall deck spacers
- Captains Call 4 Integrated Swim Platforms Exhaust Diverters & Tips
- Hydraulic steering system for bravo trs ssm
- Pair of bravo drives 1.5 ratio
- Big block Chevy 502’s (pair) drop in OHIO
- 2x Bravo 1 $4000 & big block mag 6 exhaust $3000 B/O
- Merc circulating water pump assemblies
- Mercruiser thermostat housings - 500 efi
- 1100s
- Formula Fastech 382 Grab Bar
- Pair of dry sump 6s and gimballs
- Finned valve covers
- Bbc oilers
- BBC Roller Rockers
- BBC Canton remote oil filter adapters
- Crank Driven raw water pumps
- Free exhaust tips with flaps. (4 )
- New/fresh 588 inch bbc quad rotor drop in ready $30k
- Lenco race tabs/New-complete set up
- Mercury 1075sci Flywheel Housing
- Rebuilt pair 525 EFI complete
- Various parts
- Mercruiser 8.2L HO ECM PCM Module DTS 430HP computer
- Mercury 1075SCi flywheel and damper plate
- XR Upper Gear Sets
- Merc 1500hp props
- new gen 4 4 bolt 454 block fully blueprint machined
- BBC Canton Oil Pans and Pick Ups
- Billet Cigarette Fuel/Water Serarators
- Bravo Bulkhead Oil Fitting
- Pair of Maximus 24” props
- Baja Force 235 bucket seats
- HP500 lifting eyes
- 2 Gaffrig/Livorsi fuel pressure gauges
- 3/4” water dumps
- Offshore mounts and mounting plates
- SBC crossover
- MSD ignition setup
- Cmi bbc exhaust
- gearbox, damper plate and propeller
- Throttle Up 5 Blades 17.50x30P 16 Rake
- HD damper plate and flywheel .
- Drives And Mercury parts
- 2012 Donzi 43ZR Parts
- Mercury Racing 1075Sci Parts
- late model GM valve Covers one Pair
- New 380 K Tabs
- 280 K-Planes
- Bravo 1 lower unit
- SSM #4 Drives 1.41 19 Spline
- TBiv v6-14 modules and a coil
- Cmi big tubes
- Pair of 4 blade #6 props 17x30
- Mefi -4 B computers
- Grab handles new
- 6- 4” exhaust tips
- Bravo shift brackets
- Power steering resivoir
- 3 bravo trim indicators
- 2 thermostatic oil filter housings and brackets
- 3 helms
- Krc power steering pump
- 42 legacy tail pipes
- Propeller - Hoss HPD 26P
- 427 mercruiser standard and opposite rotation
- Weldon fuel pumps
- 500 efi cam and comp linkbar lifters
- #6 or #8 DRIVE STANDS
- Bunch of different parts see pictures
- 24" L and R Bravo 1's for sale
- NOS Blackhawk Case and Bearing Carrier Assembly
- psi screw 206 B
- Holley Pro dominatior intake and 2 Holley 1150’s with NOS fogger
- Mercury Vesselview Multi Link and cables
- Daytona Sensors
- 5” exhaust tips
- Small parts $25 ea. $100 All
- Bravo 1 & Hydromotive props
- Imco Stern Advantage Stern Jack Style
- rebuilt 454 mpi complete drop in bravo set up
- complete drop in merc 420's alum heads blowers dominators
- Livorsi Oil PSI gauges
- Bravo 1 Lower - LWP
- Mercury Revolution 4, 25P Right hand $475
- 32p and 30p lab finished Bravo 1 props for sale
- Holley stuff
- fuel pumps/regulators
- 2 Pair Stainless Marine Manifolds and Risers
- Anyone have any interest in a GM 395 cam?
- Mercury #6 one inch spacers
- Imco 12" extension box setup
- Bravo One Sweptback Upper
