PDA
View Full Version : Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. Front engine compartment vents
  2. Wanted: Rinda Diacom Record Data File from a 502 EFI ore MPI
  3. 413-850478 or GM#12551622 cam needed
  4. WTB Bravo 1 32p props LH & RH 4 blade
  5. imco extension boxes
  6. Wanted: Bravo 1 prop shaft carriers
  7. need streeing helm
  8. Looking for stainless marine manifolds
  9. I need a xr complete with shortie or just an upper
  10. Maximus Prop labbed 34 pitch RH
  11. Anyone have a Supercharger/Blower for a 502? Wanted Whipple or Pro Charger!
  12. wanted: black steering wheel center cap
  13. drives,tabs, steering!!
  14. roller style trailer for 25/30 foot boat
  15. Need a nice freshwater bravo gimble housing
  16. WANTED TRS Transom Assemblies
  17. bravo sea water/ fuel pump
  18. XR Upper
  19. Looking for 496 Mag Power steering set up.
  20. 8-71's pair
  21. Std Intakes/ carbs
  22. Baja 250/270 cabin door needed
  23. Gaffrig oil temp gauge
  24. Wanted Merc 496 mag pcm
  25. XR upper case
  26. 088 head
  27. Wanted: Twin Engine Controls....White or Teal
  28. 1" 6 drive spacer studs only
  29. Bravo Template
  30. EMI Thunder exhaust
  31. Wanted: hp 500 carburetor (holly 800)
  32. need merc thunderbolt ignition modules v8-hp an 2 pair resonable complete exhaust fb
  33. need 2 sets stainless marine dry riser/tails
  34. 496 exhaust manifolds & 6 or 8" riser wanted. Any out there?
  35. Needed Formula Steering Wheel from an 87 or 88
  36. I need a cabin door for a Fountain.
  37. hydromotive 4 blade cleaver RH
  38. 750 Super Cat Engines
  39. WTB 2 sets of silent choice
  40. WTB: Trs gimbal ring.
  41. Need 496 Catalyitic Elbows
  42. WTB merc 496 ho cam
  43. Looking For Mechanical Trim Indicator Bracket/Clamps
  44. Hp500 procharger carb setup
  45. 1990 242ss aluminum swim platform
  46. WTD: Mercruiser Bravo vertical shaft
  47. Needed: Old style Attwood V750 pump #4207
  48. looking for complete drives and motors for 750- 850hp XR-sportmaster or imco
  49. need fuel pump housing 1999 454 efi, mounts to motor mount and holds the fuel cooler
  50. need fuel pump housing 1999 454 efi, mounts to motor mount and holds the fuel cooler
  51. Pair of 28 pitch Maximus
  52. # 6 props
  53. Sport master drive spacers
  54. Wanted Smoked Glass/LexanCabin Door80's Formula
  55. WTB Tractor headers for 525
  56. psi sensors (0-100) Merc p/n 881879T11
  57. Wanted Mefi 3 or 4 controller and harness
  58. Wtb: Bravo 32p set
  59. bbc parts
  60. 525efi cam
  61. Need two sets 1.35 of upper gears # 6
  62. Need dash and/or gauges
  63. Stainless Marine Exhaust for Small Block
  64. Need Cockpit Cover for 1994 PQ 257 Legend
  65. 088 Heads. Or set of alm heads
  66. Need low hour 5.0 MPI
  67. need two bravo 1 drives
  68. Looking for a Bravo One Outdrive Housing Upper& Lower
  69. Whipple top pulley 4 3/8 or
  70. 1986 Formula 242 LS Swim Platform
  71. Crank Driven Water Pump
  72. Trs wing plates wanted
  73. Looking For Thermostat housing for SBC
  74. wtb mercury 5 blade race props
  75. #6wet sump tools
  76. Air-Dock
  77. 502+.030 pistons
  78. XR upper cases only
  79. Looking for Bravo 1 502 Mag Engine Coupler
  80. Pair of MERCURY 700 SCI's
  81. Xr input shafts
  82. Wanted, Stellings Extension Boxes and Drivelines
  83. WTB sealed 525
  84. Holley 800 double pumper
  85. crane hi6 ignition box
  86. 31 pitch 3 blade props wanted
  87. Mini mod v hull By Sport Boat
  88. Complete 3.3 Whipple
  89. looking for 2 3.3 whipple kits
  90. gaffrig shifter/throttle part
  91. Xr gear wanted
  92. WTB Full Cover for Formula 280SS
  93. Needed: 502 EFI Lower Intake Manifold 805233A6
  94. Help! WTB Gaffrig or Livorsi Controls
  95. gen vi 500 efi parts
  96. gen 6 parts
  97. Pair 750-1000hp motors under $30K....
  98. Imco Powerflo exhaust manifold
  99. Looking for imco standoff box neutral rise with iner plate
  100. Need Gil Manifold Risers
  101. Looking For A 502 Crossover Kit
  102. TRS trim ram needed
  103. any used imco scx uppers for sale anywhere????
  104. In need of hydraulic ram eye/connectors to bravo drives/Imco mounts (ASAP)
  105. Exhaust tip needed!!
  106. 4" mufflers
  107. Project hull
  108. WTB - EMI SS long risers
  109. WTB : Latham Back Cap - Bravo
  110. Bow light for formula
  111. NEED 2 HP Transoms Assy.
  112. verado supercharger
  113. WTB Thunderbolt IV V6-14 module
  114. WTB Swim Platform Ladder for 1988 - 1991 formula sr1
  115. WANTED: 2004-2006 Baja Outlaw 29' or 30'
  116. 50 60 70 yamaha
  117. WTB raw water strainers Pair. Bravo 1 sea pumps
  118. WTB or trade a Maximus for a P-5 Hydromotive
  119. Hydraulic steering pump or helm
  120. Props maximus 5 blade 30
  121. Livorsi single engine throttle and shift
  122. imco parts
  123. TRS Bellhousing
  124. Cylinder head msd ignition coil mounting
  125. Wtb 32 props
  126. WTB -Merc 850 or 1075 face plate
  127. Pair of 750 Supercat motors...
  128. Hyrdomotive 26 p RH for TRS
  129. trs wing plate
  130. WTB: BBC Crossover
  131. Stainless Marine Exhaust...
  132. Looking For Bravo 1 Parts (Upper/Lower, Transome Assy)
  133. 990 or 088 head or a pair of heads for a mark iv
  134. Bravo 1 lower LWP
  135. 2000 38 fountain lightning windshield
  136. Twin 200 outboards
  137. AL Trailer for 38 TG
  138. Wanted Sterlings with Big Chief Heads
  139. Bravo 1 Drive shower
  140. Hydraulic Steering for TRS
  141. Merc HP 500 Gil Exhaust Pipes Needed!!!
  142. Wtb: cmi headers for 502/bravo setup
  143. 502 pistons 525EFI
  144. Looking for a pair of 28 five blades
  145. 500EFI throttle body
  146. WTB 575sci 500EFI 525EFI parts and accessories
  147. Mini Hawk
  148. Gimbal Bell Housing.
  149. power steering pump
  150. Mercruiser Rev Limit Ignition by Firepower
  151. WTB: PSI Screw "B" Rotor front cover.
  152. BBC Bravo Coupler
  153. Exhaust for twin 454's twins trs setup
  154. Short or long block
  155. Twin Set of Gauges
  156. WANTED: 500EFIs, HP500s, possibly 525EFI
  157. wtb hawaiian 28 jetboat project
  158. switchable tip
  159. Blower Belts Needed
  160. Gil Offshore/Hardin Marine/hp500 525sc exhaust manifolds
  161. Switch Box For Thunderbolt ignition 332-2986A27 2986A27
  162. WTB: 24' Pantera
  163. WTB 2 or 3 stage sea water water pumps
  164. Race Boat wanted under 30 Feet.
  165. 502 complete procharger set up
  166. WTB XR lower(s) or Complete drive
  167. Wtb - xr lowers
  168. Wtb - trs lh drive
  169. trade labbed 32 bravo 1 props, rt. and lft. 15" dia. for stock 32's
  170. 23 mirage plus LH and RH wanted
  171. ASD-7 Kits/Parts
  172. Looking for a Formula 1988 Steering Wheel
  173. Wanted mercruiser bravo iii
  174. Pair of 5 blades: 16.5 X 35P 15 degree rake...
  175. Wanted Gen6 454 or 502
  176. Wanted Gen 6 454 or 502
  177. WTB 4-stroke 250-350 dual outboards
  178. wtb ecm: mefi 3 or mefi 4 ecm
  179. Mercruiser 821997 hp hinge pin
  180. Wanted- pair of 4blades 25p
  181. pilot bearing
  182. WTB: gen 4 bb chevy oil pan 10 qt plus
  183. Holley Carb 0-9022
  184. Air Dock
  185. Wanted 256 weiand charger parts and pieces or just wanting to get rid of yours.
  186. TRS SS Tie bar -34 1/2" center to center
  187. WTB 496 mag pcm
  188. Wanted ladder for aluminum swim platform
  189. trs bellhousing oil coolers
  190. WANTED: Switch for Corsa Silent Choice
  191. WTB 2 - Coupler drive shafts for #6 drives
  192. 38 Fountain Lightning Bimini cover with posts
  193. Stellings Black header
  194. Wanted Extra set of Mercury Computers
  195. Exhaust for 2 454's
  196. Wanted: 454/502 Headers
  197. 1/2 Bravo Spacer
  198. Bravo drive coupler
  199. Looking for a B&M 250 upper pulley 155173
  200. WTB Blowers for Rectangle Port 454
  201. 1" drive spacer for bravo
  202. WTB: A pr. of left/right hand Herring 16.5x28-18 props
  203. MSD Marine pills wanted
  204. 502 mags
  205. WTB: 26P Bravo 1 Prop
  206. Throttles shiffters
  207. WTB 2-Keith Eickert Dual Stage Water Pump side mount brackets
  208. Edelbrock 7562
  209. Looking for a Mercruiser 454 Sea Water/fuel Pump Part #46-807151A8
  210. Performance exhaust wanted
  211. wanted a pair of b/b drop in motors
  212. 1" 6 drive spacer dry sump kit
  213. 29 Mirage 3 Blade Wanted
  214. Male power/up/down plug for mercruiser power trim pump
  215. WTB- pair Bravo one 26p props
  216. Wanted Captins call
  217. Oil Pan for HP500 or comperable?
  218. Wanted - Silent Choice (Captains switch) for a Small Block Chevy and Bravo one outdri
  219. Wanted - Silent Choice (Captains switch) for Bravo one Small Block
  220. scx 1" or 1.5" spacer
  221. Throttle lever w/ built in trim switch
  222. cat diesels
  223. diesels
  224. HYD steering / throttle
  225. Wanted: Bravo 1 28P LH
  226. Prop wanted: Hydromotive quad iv lh26p
  227. Clean 1.5 ratio gears needed
  228. 351 iron intake
  229. hour meter
  230. looking for some 5 star mercedes wheels
  231. Gill Riser Spacer Blocks
  232. looking for speedmaster inner gimbleplates
  233. Factory speedo for 98 Baja Hammer
  234. Wanted Land & Sea Stern Jack or IMCO Stern Advantage.
  235. 502, 500 efi parts needed
  236. Gil manifolds
  237. merc racing hp500 efi injectors
  238. merc racing hp500 efi injectors
  239. WTB (4) Gen VI Heads
  240. Search 2 Marine diesel Engines
  241. WTB- Bravo one or Hydromotive 26p 4 blades pair
  242. Need two #6 drive stands, two snap on engine dollies
  243. WTB TRS RH Lower
  244. Steering ram
  245. Cmi water tubes
  246. gen 4 454 block needed
  247. Looking for K-Planes
  248. Parting out
  249. Bravo XR Sportmaster case
  250. Bravo Transom assembly
