PDA
View Full Version : Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. 600 series trim tabs
  2. Wtb dry tails
  3. Bravo 1.36 ratio lowers wanted pair
  4. External steering reservoir
  5. WTB Double Bolster Seat
  6. Search Stainless Exhaust System for Merc 350 MAG Carburator, spacer an flamearestor
  7. Wtb 575sci pulleys
  8. WTB isotta steering wheel or similar
  9. LIFELINE life jackets / vests let me know what you have
  10. ISO Sbc sea pump brackets for v belt
  11. Procharger pulleys
  12. WANTED Duoprop DPS-M (1.68 ratio)
  13. 5 Blade props #6 speedmaster 31 X 16.5 X 18* or somewhere in that range merc hering
  14. Wtb 2 mpi distributors
  15. WTB Junk Bravo Swept back upper.
  16. Heat Exchanger
  17. Whipple Supercharger
  18. Wanted set of 525 600 700 cyl heads
  19. wanted Stainless Marine bbc manifolds
  20. Wanted: SBC exhaust manifolds and risers
  21. WTB Complete Drop in engine minus exhaust
  22. Char Lynn helm
  23. wanted 6.2 rotating assembly
  24. Wtb. Water pickups, drive plates, drive shaft and more.
  25. XR upper gears
  26. 3208 caterpillar rear main seal installation tool
  27. Wanted: 496 Magnum 375 hp parts (most electric parts needed)
  28. Engine mounts, stagger set-up...
  29. Good usuable Bravo gimbal ring
  30. Bravo Y pipe
  31. Wtb ITS top cap, rear cap, and driveshaft.
  32. Bbc y pipe w/ flappers part#807130a4
  33. Bravo lower case needed
  34. Wtb: Cash ready single ram add on bravo one
  35. ISO used Mercury ITS Transom Assembly
  36. ISO 2 fuel logs for Holley dominator carbs
  37. Wanted : LH 30p hydromotive p5x
  38. swim platform
  39. seawater pump with fuel pump mounting
  40. BBC MPI Sea Pump Mounting Bracket
  41. Exhaust manifolds or headers
  42. Gaffrig Gauges
  43. Need Quick Disconnect fittings for drive lube
  44. SBC cast iron High Rise intake
  45. looking for 30+ foot twin out board cat (spectre ,motion, etc...)
  46. looking for transom mounted water pickups (pair)
  47. 496 polished pulley set (cp performance or?)
  48. Bravo 1 22
  49. looking for a few L2399NF TRW pistons
  50. Looking for a boat minus power
  51. wtb windshield for 42 fountain lighting
  52. Merc 4 hose thermostat housings
  53. Gil exhaust parts
  54. Wtb: Mercruiser racing 454 trs engine mount plates
  55. Looking for 2 merctrans KC oil coolers
  56. Wanted gil riser
  57. Wtb green tag driveline trans.
  58. Wiring Harness for Carb & Alternator/PS Bracket
  59. Looking for a set of Bravo Transom Assemblies, and XR drives
  60. wtb: MKIV 454 Forged Crankshaft
  61. Wtb 2 power steering pump serpentine
  62. WTB: Flame arrestor for Merc 6.2
  63. Need kiekhaefer k-plane trim tab (nuts)
  64. WTB Header for a 525 Stagger
  65. ISO: Merc 600SC intake
  66. WTB Side mount Whipple for MPI motor
  67. ISO a 651 crane camshaft
  68. Wtb imco shorties
  69. Wanted 420 Megablower
  70. Wtb: raw water pump
  71. boat trailer 38 ft baltimore
  72. WTB Vertical Shaft for -2 Imco , XR prop shaft and carrier
  73. hydraulic steering cap imco mayfair
  74. Trailer that could fit 30 Scarab
  75. External Steering set-up
  76. Wtb (2) complete SCX imco uppers
  77. Wtb (2) complete SCX imco uppers
  78. bravo parts
  79. 2 bravo XR with sportmaster lowers
  80. WTB trailer for a 89 Formula 242LS
  81. bravo 1 lower case
  82. WTB - prop cases
  83. Intake Carb Crank 3 grove pulley
  84. Cmi wet tailpipes 4" wanted
  85. Bravo Transom Assembly
  86. WTB: Mercathode outdrive portion
  87. WTB Pair of Crossovers
  88. 168731 or 500efi cam
  89. WTB: New Bravo HP transom assembly
  90. WTB K-Planes 150s complete in good shape, also pumps
  91. WTB: Medium Lifeline competition vest pn170
  92. Wanted 20-25ft warlock cat
  93. Gen IV 454 Complete Engine
  94. WTB Hydraulic Reservoir
  95. Used 19 spline to 26 spline prop shaft adapters
  96. Would like to trade 280 k-planes for 380's
  97. Cuddy Door & Frame
  98. Procharger
  99. Wanted gil tails
  100. TRS LH Prop Shaft
  101. BBC heads
  102. Wanted: Power Steering pump for 500 EFI
  103. Cmi tailpipes
  104. xr 1.36 lower gear set
  105. WTB 6.2mpi stock cam
  106. Tunnel tab wanted, Dana Monster tab?
  107. Wanted Gil Dry Tails
  108. In search of a 16 rib idler for a 250 b&m supercharger
  109. In search of genVI parts
  110. OPA Class 6 Sponsor WANTED
  111. wanted 6.2 rotating assy
  112. Need a Gen 6 502 block
  113. WTB SSM 3 upper gear 15 tooth straight cut
  114. WTB: set of Bravo upper gears 1.5 ratio
  115. WANTED : TRS VELVET DRIVE 72C TRANSMISSION (has to be heavy duty version.)
  116. WTB box anchor
  117. Wanted IMCO -2 Lower
  118. WTT: IMCO Std for IMCO -2
  119. Wanted: SBC Exhaust- Dry riser/IMCO Power Flow Style
  120. Victor jr intakes, 800 holleys & exhaust
  121. Idler pulley and bracket for Gen 5 or 6 Fuel/Water Pump
  122. Looking for a Merc 525efi Longblock
  123. WTB Hydromotive P5's in 34 or 35 pitch (NO P5X's)
  124. WTB- GPS Antenna- Livorsi or Similar for GPS Speedo
  125. looking for both vent windows for the side of an 86 formula 242 flat windshield
  126. WTB: CMI Sport Tubes Straight Exit
  127. XR Drive Swept Rear Cap
  128. Looking for a black Covico steering wheel.
  129. looking for apache rope cleat
  130. Trailer for 312 Formula Fastech
  131. gen 6 525 efi cam
  132. TRS Casing
  133. ISO: Any one parting out a 33 outlaw, engine hatch, 3 man rear bench, ect
  134. WTB MSD Dist 85551
  135. hot boat back issue needed. please help
  136. Offshore Mount for Single
  137. Bravo 3 lower case
  138. Latham Medium Duty Clevices
  139. 525 intakes
  140. 3V crank pulley needed.
  141. Latham steering cylinders
  142. Whipple intercooler
  143. Wanted-Trailer for 39' Midnight Express
  144. Bravo transom cutout jig
  145. Drive spacers
  146. Wanted: 30 or 31 pitch 5 blades
  147. Mercury 250 pro xs powerhead
  148. Looking for quad rotor 3.3 or 4L Whipple
  149. ISO LABBED 27 Mirage or Mirage pls LH & RH set
  150. cmi dry tail
  151. Big Block Ford Bellhousing Velvet drive
  152. looking for full cover for my top gun
  153. wanted wing plates for speedmaster 3
  154. Bravo HP gimbal ring
  155. K plane pumps
  156. XR Prop Shaft
  157. Wing plates
  158. ISO 1 BBC Polished hp500 "style" or dart intake
  159. 35-42 fountain, needing work or power
  160. 500 EFI high flow flame arrestor vortech / az speed / Teague / Hardin Marine.....
  161. WTB a pair of 500 EFI motors. Or 502 Mag EFI. 2000 or newer.
  162. Looking for Merc part # 863208a3 Water Press. Relief Valve
  163. wtb stainless marine manifold
  164. Wanted 2 sets 496 manifolds & risers.
  165. Looking for a batter charger
  166. large capacity bbc oil pan
  167. gen6 502 block
  168. 36 Cigarette Gladiator Whats out there thats not listed for sale?
  169. Bravo Transom Assemblies WTB
  170. Hydromotive P5X 28
  171. 575 SCI Flame Arrestor Wanted
  172. WTB Labbed Mirage 27's
  173. dry cmi tails
  174. 1 GM 990 Head.
  175. Extension Boxes
  176. K Planes less Plates
  177. ISO oval arrestor twin 4150
  178. ISO Flame Arrestor, Oval, single 4150, matching the one in my picture
  179. WTB Double Bolster
  180. 2.3 Liter carberated whipple.
  181. Two 250 blower kits.
  182. Wtb two (2) 741 crane cam camshafts #139021
  183. Need 1 (one) 088 casting head
  184. K-Planes 380 Plates only
  185. 525sc
  186. Merc service manual 39
  187. Seats for Sit Down Application
  188. 88 wellcraft switchs
  189. Ecm
  190. MSD mounting brackets
  191. BMAX upper
  192. WTB Gil Risers
  193. WTB- Gil / Mercruiser exhaust manifolds
  194. Looking for Exhaust tip!!
  195. WTB twin 454s
  196. Speedmaster 3a's
  197. Wtb: Mechanical trim actuator for bravo drive
  198. Bravo single steering ram
  199. WTB: TRS Transom Assy's
  200. Bravo 1 propshaft
  201. WTB Merc Prop
  202. 7.4 / 454 stock oil coolers
  203. WTB - Complete set up - 5.7 engine, bravo 1 tramson assy and outdrive for project
  204. Aluminum 496 Manifoulds
  205. Need a Trailer for a 29 Fountain
  206. Wanted: Tail pipes for Outerlimits 47 GTX Staggered
  207. Arneson ASD 8 or 10 chains and sprockets
  208. WTB 496 complete
  209. WTB pair of Mercury Optimax 300s
  210. ISO 3 axle trailer for my 88 Scarab III 34'
  211. WTB 24 Pitch Maximus, Right Hand stock
  212. WTB 26-28ft. boat/trailer without motor & drive
  213. - 2 shorty lower unit wanted...
  214. Imco Scx. - 4
  215. Gen 6 502
  216. imco
  217. WTB Bravo 1 std Lowers
  218. steel trailer for formula 353
  219. ISO Prop Shaft and carrier
  220. WTB #6 Gimbal Ring
  221. Complete cool fuel unit
  222. 3ssm
  223. Wanted: Trailer for 34' boat in midwest.
  224. wanted its parts
  225. iso windshield or fairing for 1997 fountain lightning
  226. bell housings
  227. arneson wanted
  228. 502 short blocks
  229. WTB Drew marine Sidewinder Steering Stabilizer Dual ram
  230. mefi 2 ecm
  231. Water Crossover and Thermostat housing
  232. Bravo Bell Housing and Single Engine Offshore Mount Plate
  233. wanted- cigarette hull and trailer---- no engines... wide body, top gun, mistress ?
  234. WTB: Stellings headers "tie bars" to connect tailpipes to header collectors
  235. WTB : 4" switchable exhaust tips like TCM or Eddies
  236. WTB Mercury 500Efi 525efi 575 complete drop in
  237. Cleavers
  238. Needing Gil/ Hardin marine tailpipe wedges
  239. HP Bravo coupler
  240. Performance Exhaust for 7.4 Merc
  241. WTB cooling crossovers w/ bypass for SBC. Need 2 sets
  242. WTB performance exhaust for SBC. Need 2 sets
  243. Dart 308 iron Eagles
  244. Need Bravo for display only
  245. Performance Exhauste for 7.4 Mercs.
  246. Different stainless risers or offsets to make mine work Gil/bulldog 500 bbc
  247. WTB Hyd steering ram mounts used with ext boxs
  248. 10 pin harness
  249. Looking for a set of motor mounts
  250. crane gold
