View Full Version : Wanted
- CMI E-top Wet Tails for Standard Bravo....
- 4.3L intake and exhaust
- Need a 454 mag
- Hydro P5X
- imco lower housing
- Need HP500 Shift Bracket
- cmi headers for bbc needed
- Flywheel oil coolers x2
- PROPS Needed!!!
- Bravo one Prop 26P
- shifter
- WTB Gauges Gafrig/Livorsi 1 motor.
- Wtb: looking for a nice condition B1 or B1X Upper Unit
- 575sci Intake Manifolds
- Gen 5 502 push rods
- WTB: Bravo 1 upper unit 1.50
- Speedmaster
- WTB Heads for 2001 454 MPI Gen 6
- Sea pumps, water pumps, power steering pumps
- Portable generator
- b&m 174 blower
- Pair of Sea Strainers
- Merc 500 EFI ecu/computer
- Anyone have a sbc intake manifold they are looking to get rid of?
- Code scanner
- merc 700's.....
- Imco super fuel valve
- Emi headers
- delphi mefi 3
- Water Hoses
- 88 19' Pachanga windsheild
- 500 efi ecm bracket
- 30 or 32 pitch RH bravo prop
- Bravo couplers
- Bravo 30p props
- 3" bravo drive spacer
- Need BBC 454 or 502
- full cover
- Hydromotive propeller
- wtb: Bravo 1 upper gears
- 525 efi valve covers
- SSM III / IV Trim Ram
- 38 cig trailer
- 24'-27' single engine hull
- WTB Navionics Gold Map Card (South)
- Livorski Polished Billet Knobs
- rub rail
- looking for 500efi's 525efi's or blown 575's possible trade?
- Sea strainers
- drop out bolster seats
- bravo setup tie bar 36in
- WTB Complete Bravo 1 Set-up, would prefer newer style (post 90')
- WTB Bravo ITS cowling cover
- project hull wanted
- volvo penta trim rams
- Volvo Penta DPX R
- Sea Water Pump
- XR Sportmaster Lowers
- pr labbed 32 bravo 1 props
- Edelbrock heads BBC
- trs props
- Lower Unit Thread Chaser
- Wtb 23 pitch mirage plus
- 19 Spline 4 Blade Props for Speedmaster WTB
- XZ upper
- Can Anyone Help Me with this???
- looking for labbed 26's
- 454 alt and starters
- Looking for 575SCI blowers for trip set up.. or similar EFI blowers for trip set up.
- 1071 0r bigger blowers
- 700 sci
- Stainless HEADERS and RISES for 502 MAG MPI's needed
- Tranny cooler for 86 scarab with trs drives
- Exhaust Tips 4 Inch internal flap, 1 set
- Water Pump Pully for 1998 525 SC
- looking to buy boat cover
- 23 pitch mirage plus
- Bennett trim tab soilnoid (RED)
- TRS parts
- WTB/Trade - SBC Circulating pumps/pulleys
- wtb-cigarette 20 project boat
- WTB: pair of Mirage 23p
- engine and boat harnesses needed
- Wanted 2 B&M 420 mega blowers
- WTB Stainless BBC T Stat housings for bypass
- Bravo 1 Prop
- Wanted Mercury CNC 16.5" x 37P #6 Props
- Mercury Exhaust Plate
- Looking for 31' trailer
- WTB BBC headers and tails. Complete.
- Looking for a jet boat.
- 24p mirage prop Lh ,rh
- Honda EU2000I Generator
- Bravo Upper Steering Arm
- WTB 32 bravo prop Lh
- air pump for gaffrig exhast
- WANTED: Donzi Sweet 16 (or perhaps boat very similar)
- Drive Resevoir
- Wanted! Left hand 23p mirage!
- Wanted MEFI 5 & MEFI 6 ECM
- Looking for 2 thunderbolt distributors
- WTB: Late model 225 or 250 HP Outboard
- bravo ones
- imco 1.36 lower -0... 1 1/4"
- 500 EFI CMI Silent Choice inv. + 525 EFI Heads
- Superchargers for HP 500's
- GEN 6 STD bore block.
- Need a 496 or 383 close to Louisiana
- 2 inch shorties
- Looking for 26p for Bravo 1
- Pair of 17x30
- mechanical trim indicators for 30 ft boat
- wtb Bravo XR or equal
- 525efi heads
- Short block(s) WANTED 502 & up
- 22 Bravo 1 rh
- Nib
- Pair of 17x33P 5 blades....
- Looking for 502 MPI flame arrestor
- 380 Trim tabs
- bravo 1 30pitch LH
- big block circulation pump and coupler studs
- wanted 2 sets gill risers
- Need 2 Sealed Power Forged Pistons 2465 .030
- WTB Imco superfuel valve
- Any Volvo Penta rigged V-24s?
- Bravo couplers
- #6 drives and gimbals
- V belt salt water pump pulley
- Merc "330" decal
- WTB- Bravo coupler
- Merc 500 HP Plastic Flywheel Cover
- CMI etop headers 496
- Intercooler sea strainers
- looking for a pr of 525 efi intakes
- Wanted - Automatic Fire Extinguishers
- sea pumps with fuel pump and bracket
- WTB 502 block and caps gen 4
- Heads up Indicators WTB
- Billet Flame arresters
- 500hp corsa muffler tips
- Wtb mercury wet sump 6 gimbal
- Looking for a nice set of EMI Thunders for 502
- wtb aluminum 496 exhaust
- Looking to buy American Offshore 31'
- Looking for a 5/8 heim
- wtb trim ind
- Merc Thermostat Assemblies
- wtb....22p bravo one or hydromotive
- Who had the red blocks and cranks
- 500HP fuel rail and injectors
- 500 intake carb air cleaner
- Gauge bezel
- K Planes & Hydro steering
- K-Plane indicator cable pass through fitting
- WTB CMI tail pipes
- hydromotive 23
- F-311 Parts
- stainless marine bbc exh manifolds
- looking for white bolsters
- 454 drop in's or????
- Bennett ST12 Trim Tab Plates/Trade for ST16?
- Bravo drive spacers
- wanted
- WTB 502 piston(s)
- Wtb oem merc. Helm
- stern light for magnum
- 4" exhaust tips
- stainless marine manafolds
- wanted L+R speedy #2's
- 24' Trailer
- Stellings Green Header....
- Floating lift 16000-18000 lbs
- 21p mirage plus
- b&m 174 blower INTAKE ONLY
- Hp500 oil Cooler Brackets
- 6lug 16inch alum rims
- 1" SSM spacers
- Blower pulley 7psi
- WTB Purple steering wheel
- red steering wheel/billet stuff wanted.
- Used Bravo One Drive
- trailer for 42' OL
- 3 man front bolsters
- Lookiong for 300xs cowl , damaged cond ok
- WTB helm post and adapter
- 26 - 28 single cat, possible V (Less Power, trailer)
- Latham Wing Plate 300xs
- WTB: Closed Cooling systems
- charger
- wtb Captains chairs/pedestals/ equipment cabinet
- gil dry pipes for bravo
- WTB Herring Props
- Experienced Manager and Technicians Wanted
- W.T.B. single ram hydraulic steering for bravo
- Oval Flame Arrestors for 4150's
- 1" Bravo One spacer
- HD SSM Drive plates couplers dampers
- 4'' clamp on mufflers
- WANTED: 29-32 single with or without power!
- any one have any seadoo parts ?
- BBC Heads
- pair of oil coolers
- OMC King Cobra LH / CCW prop! pref. 24+ pitch
- Oil filter mounts
- 28 and 30 bravo props
- looking for set 30over forged pistons for 502/509
- WTB... 496 HO, entire motor, computer set up!!
- 525 sea water pumps
- Risers set for Trs
- Gen 6 pushrods
- Seats
- Mini pickle fork boat
- Isotta steering wheel
- 5.7L 350ci Late Model Rear Engine Bushing Mounts NEEDED
- 5.7L 350ci late model Engine Coupler NEEDED
- 5.7L 350ci Late model Alternator NEEDED
- 5.7L 350ci Late Model Starter NEEDED
- 5.7L 350ci late model Flywheel NEEDED
- throttle/shifter for twins
- WTB Bennett joystick
- Billet oval arresters for single carb
- Wanted - Pair of Bravo 1's
- Need oval air cleaners
- Trim Limit Sender for TRS/Anodes
- v6 ignition module
- Stainless Marine Manifolds SBC
- WANTED clamp on trim switch
- 1" hose "Y"
- WTB 1" hose Y
- Gil or Hardin Marine Gil replacement manifolds
- Looking for B&M 250 blower and other parts.
- WTB BrakeRite-II Severe Duty Electric / Hydraulic DISC Actuator Kit
- 26-28' Cat
- Trim pump
- WTB: Blue Steering Wheel, Bezels
- Wtb 500efi
- Wanted, stainless recessed cleats.
- Trip axle trailer for a 33 footer...
- Standard risers for Trs
- Wtb: Gill manifold bolts (long and short)
- 1988 merc outboard
- gil manifold BB
- bravo transom assembly- WTB
- mercruiser coupler BBC
- Air Gap Intake
- need bravo gimble
- Drive shower Bravo 1
