PDA
View Full Version : Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48
  1. Wanted 2} 525
  2. WTB alternator bracket to clear manifolds for bbc
  3. need gen 6 oil pan 10-14quart
  4. Need 502 Block
  5. need two bravo one 24's opposite rotation
  6. Wanted : 440 Chrys. Reverse Cam
  7. MEFI-4B ECU's
  8. looking for silent choice - TRS bbc
  9. Lower/Upper Intake needed MCM 350 MAG MPI
  10. isotta wheel
  11. Looking for 2 dual cooler bellhousings.
  12. 28 r bravo 1 4 blade
  13. Looking for Stainless exhaust or similar style
  14. WTB bravo 2 bellhousings
  15. lookin for Bravo X or stronger
  16. Wanted 177 blower intake manifold BBC
  17. 525 or 600 sc flame arrestor
  18. wanted 360 Chry heads
  19. Dominator throttle linkage plate
  20. Looking for a used tall windshield... or some parts... any laying around?
  21. Looking for Bravo 1, 4 blade props.
  22. Wanted New K-Planes
  23. wanted 2 bbc crossovers
  24. prochargers M-1sc 454mag mpi or brackets
  25. Dominator blower carb..
  26. wanted air gap bbc intake
  27. Set of Hydro 30" P-5X Props
  28. wanted staggered front engine mount
  29. BBC rear engine plate wanted!!
  30. Wanted complete add on steering system
  31. 2 Sets of Stainless Marine BBC Risors
  32. Ohio Prop Shop
  33. arneson steering cylinder
  34. 3man seating wanted
  35. WANTED: Engine for 24 Sunsation Rocket
  36. Wanted: Bravo Parts
  37. I need 2 sets of heads
  38. Big Blocks Needed
  39. Intake Plenum for 500EFI
  40. 280 tab
  41. Stainless marine Plus 3 tails hp longs or dry.
  42. Stroker Rotating Assembly
  43. TRS riser for merc manifolds
  44. Isotta Carlotta steering wheel
  45. side mnt pro or whipple chargers
  46. Seapump W/Fuelp.Circulation W.Pump Termost.Housing
  47. 750 holley
  48. 454 EFI Exhaust
  49. (2) oil coolers for 700hp........
  50. Bravo HP transom assembly...complete
  51. WTB Whipple Crank Pulley
  52. trim indicator
  53. wtb: bravo single add-on hydraulic steering kit.
  54. wanted 496 496ho 500 525 complete
  55. XR Uppers
  56. wtb (2) side mnt pro chargers for 454 mag mpi
  57. 502 engine needed
  58. Looking For A 502
  59. windshield wind deflectors
  60. pair standard length imco lowers
  61. trs performance exhaust
  62. 22 Donzi classic
  63. heads up trim indicator
  64. Wanted Trailer for my 311
  65. Big Block Intake
  66. Seawater pump Bracket for a 500EFI
  67. serpentine belt pullys
  68. ITS Transom assembly
  69. (4) pin style cleats for fenders
  70. (2) Combo oil/trannny coolers for 700hp motors....
  71. mercury/mercruiser trim pump
  72. MSD Ignition
  73. 496HO seawater pump pulley
  74. A pair of NXT drives and gimbals with trans
  75. Blower scoops
  76. Need 500 Hp Flame Arrester W/id Plate
  77. Hp 500 Carb Parts
  78. trim tab actuator/cylender needed
  79. Copper Nickel Pipe Welders (Tig)
  80. Merc Racing conecting rods
  81. RC Boat Hull
  82. xr/xz drives
  83. (2) 1050 dom carbs and 2 std deck intakes.......
  84. Mercury Racing Valve Covers
  85. Need Props
  86. VDO 220 Degree Water Temp Gauge
  87. 32 maximus
  88. super chiller for 6/71 8/71
  89. Lee intercooler cooper nickel core replacements
  90. 500 Block
  91. Need 500 EFI Parts
  92. 17-17.25 x 28-31P 4 blades
  93. Bravo 1 upper
  94. Jersey skiff or Garvey
  95. Shifter cable mount bracket, Huber Velvet drive
  96. V6 ignition modules
  97. XR Upper
  98. IMCO or Stelling Extension Boxes
  99. imco extesion boxes
  100. Looking For Holly 850 Carb
  101. 26-28 Race boat
  102. 509 short block
  103. Procharger
  104. Smartcraft
  105. Dart 320 race heads
  106. Need 2 Gaffrig gauges with warning lights
  107. Actuators for silent choice
  108. plastic mounts for trim indicators
  109. 100mph gps speedo
  110. 3 v blower pulley
  111. Livorsi Water Pressure Gauge
  112. 2 sets of Gibson 4.5 turn downs
  113. Merc power steering pump.
  114. 454 330HP flywheel
  115. Anybody have a pair of IMCO POWERFLOW manifolds ??
  116. Latham Steering Studs Only (KPLT-7914)
  117. WTB CMI headers with tails. Bravo BBC
  118. WTB-rear motor mounts ....
  119. asd/borg 1721
  120. imco standard lowers
  121. superchargers WTB
  122. 496HO or 525 Wanted....
  123. 88 Nova Spyder
  124. Aluminum Myco
  125. Wanted 3 man bolster race seat
  126. Crossover's
  127. WTB Single Bravo Dual Ram Steering
  128. needed 2 corsa exhaust solinoids
  129. Wanted 22p bravo one RH
  130. wanted
  131. Bravo RH 28 Prop
  132. 2 big oval flame arrestors
  133. 2 dui distributors
  134. 2 victor jr std deck
  135. K-plane lines and switches.
  136. psi blower
  137. Small block engine harness
  138. 500EFI Blue Power Steering Pulley - Serpentine
  139. 2 single plane intakes 10.2 oval port
  140. Arneson shafts and Trim cylinder
  141. WTB used bravo upper 1.50 or complete used drive
  142. Need a stock 1.50 bravo upper or complete drive
  143. WTB: -2 Imco lower case
  144. WTB Single engine go fast w/o power
  145. WTB 2 Offshore Motor Mounts
  146. 42 fountain or??
  147. WTB: Bravo Extension Boxes & CMI E-Tops
  148. 34P Bravos Wanted
  149. Looking for throttles / shifters for twin engines
  150. 496 ho packages "Wanted"
  151. Wanted blown up 496 ho and hydr. steering
  152. WANTED Injectors '98 model 502 MPI, new or used
  153. WTB Bravo XZ's
  154. #4ssm propshaft
  155. Larry Smith Scarab 26' CV
  156. SSM 3 blade props
  157. 97 502 Mag ECM
  158. 496 HO complete exterior
  159. Superchillers for B&M blowers
  160. #4 ssm 1.50 or 1.58
  161. 4.5" Mufflers
  162. merc scan tool
  163. 300xs
  164. boat hull
  165. 502 Magnum EFI
  166. Looking for 4 L or 5 L whipple efi
  167. Looking for 2 bravo gimbals and 2 454
  168. #6 Dry sumps
  169. HP 500 motor mount's
  170. WTB: 2" IMCO shorties, XR's
  171. WTB BB Motor wiring Harness
  172. Super Duty Headlight
  173. Need 2 intercoolers for 177 Blowers
  174. Magnum bucket seats
  175. Triple Engine OB bracket
  176. Hp 500 540CI Bull Dogs
  177. WTB bravo bellhousings?
  178. pair of 700-800hp motors in need of work
  179. Need two lowers Speedmasters II for TRS drives
  180. 8/71 intakes
  181. L@@king For Oil Coolers
  182. L@@king For M-4 Prochargers
  183. Fuel filter housings
  184. pair of 18 X 27-30P 4,5,6 blade props...
  185. Dennis Moores book
  186. misc. parts needed
  187. Mercury oil hose
  188. Bbc 7/16 Rods
  189. Prop Boxes
  190. 29 3 Blade or close?
  191. bravo extension boxes
  192. I need a pair of 2.3 or 3.3 whipples
  193. Herrings 4 Blade 32s or a set of 5blade 31s
  194. Pair of merc 700 wanted.
  195. Small Cat
  196. 14-71 Blower shop blowers
  197. WTB various items
  198. sbc exhaust
  199. WTB: Oil Pan for Gen 6
  200. Tandem axle trailer.
  201. WTB Mercury ignition box
  202. 502 Block
  203. WTB #6 Drives and Gimbles
  204. Oil Pan Wanted
  205. BBC Valve Covers
  206. Need a 28 or 29 RH 3B or 27 4B Prop
  207. 380S k plane plates
  208. 21.5ft Cover
  209. Good intake exhaust needed
  210. B & M Supercharger Pulley
  211. bravo upper
  212. 2 Pair 345CC aluminum heads....on a budget
  213. set #6 17.5 x 32 5 blade props
  214. Herring Prop Cases
  215. Imco Standard SC Lowers
  216. Need 1 Kiekhaefer prop holder
  217. Various Gaffrig Gauges
  218. Looking for a set of 280 k planes and hydaulic steering set up
  219. wanted 496 ho motors 200hours or less
  220. Tail Pipe Wedges
  221. Seeking a Procharger for a 7.4mpi
  222. Need 2 throttle and 2 shift control.
  223. HUBER /Bam 1450 Driveline Transmission
  224. Imco SCX or Bmax ht drives
  225. WTB hydromotive 31p5 pair
  226. Tail pipe pieces
  227. 500 EFI Cams
  228. Need A 502 Block
  229. drive spacers
  230. Whipples
  231. 600sci
  232. Trans and dual cooler bellhousing
  233. Arneson SD1000 CV Joint Needed
  234. Need #6 Wet Sump Gimbal Parts
  235. 23p rh mirage plus flo torque stock
  236. Myco Trailer for 38 Donzi
  237. 1985-1987 Monte Carlo SS w/T Tops
  238. sea pump wanted
  239. WTB GEN II Alpha Drive
  240. CMI Tails - flat flange, any configuration
  241. Grab Handles (2)
  242. WTB: Bravo 24P RH and Bravo 1 Lower case...
  243. WTB White Fountain Steering Wheel
  244. Needed ASAP! Merlin heads 1-043
  245. Blow thru carb
  246. Trailer needed for 50 Hustler
  247. wtb- pair of hp500 stainless risers wet gil stelling ?
  248. #6 herrings 16 1/2 X 33
  249. Wanted: Arneson ASD-8 BONNER
  250. 525
