PDA
View Full Version : Wanted
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. Cord Winder
  2. Mercury verado 350/400 pair
  3. 454 MAG EFI MEFI 3 wire harness needed !!
  4. ISO 496ho 454 502 mag
  5. 2” imco sc spacer
  6. 525sc flame arrestor
  7. 29p RH MIRAGE PLUS
  8. Remote oil filter mount
  9. Searching: Merctrans seal kit #63222A1
  10. Dana marine HP 1100 tabs
  11. Looking for bare go fast
  12. Bbc motor mounts
  13. Elbows for 496 exhaust manifolds
  14. WTB - 2 Sets Stainless Marine Elbows & Pipes
  15. Wtb dana marine HP 1100 tabs
  16. ISO bravo xr used upper gear set 19/16
  17. 1" Bravo Drive Spacers
  18. WANTED 20 cigarette
  19. powersteering Resivoir
  20. WTB PS Reservoir & Bracket 500EFI
  21. WTB-Eliminator seats
  22. WTB: 17.5" x 35 x 18r right hand rotation
  23. WTB: 17.5" X 37 X 18r props
  24. WTB - SBC Stainless Marine Exhaust Manifold
  25. WTB SSM #5 drives
  26. Windscreen / Windshield Donzi 35 Zr Wanted
  27. Buddy looking for a prop
  28. Pair of bell housings & Flex Plates?
  29. Quick Fuel carb
  30. 28 bravo one prop
  31. Worst Case Scenario engine shopping
  32. NEEDED:420 B&M intake.
  33. Looking for a Bblades 4-speed 24p Right
  34. Tabs - looking for another one of these
  35. Superchillers
  36. Bblades 24
  37. ISO bravo 1 prop
  38. ISO imco extension box
  39. MEFI 3 ECM Needed
  40. Mefi 3 ecm - needed
  41. Bravo 1 Trim Cylinders
  42. WTB Matched pair of 4150 carbs for 500" big block
  43. CMI E-Top tailpipes
  44. Stelling stand off box's
  45. Wanted - exhaust tips 4' angle cut
  46. Wanted B1 spacers
  47. 80s Nova Spyder Windsheild
  48. WTB - Pair of 800cfm Holley carbs
  49. Looking for a SM GEN 3 riser
  50. 496 manifolds
  51. ISO Gen VI Mercruiser 502 front assembly
  52. ISO a pair of blowers.
  53. 1 inch imco spacer for an imco -2 lower
  54. 12" Extension box Engine Alignment Tool.
  55. 71 series blower intake manifolds
  56. WTB DTS MERCURY CONTROLS for TWIN ENGINE
  57. Imco Tilt cover.
  58. ISO Sea stainer cylinders 858E
  59. ISO hp gimbal assembly
  60. Headsets and/or control box.
  61. 380 k planes
  62. Oil coolers, helm other parts needed
  63. Wanted: pair Hering 13.75x30 20 Degree Props
  64. Imo Tilt column cover.
  65. Cigarette key floaties
  66. low profile flame arrestor
  67. #4 polygon front driveshaft
  68. HP500 EFI valve covers
  69. 27 avantis and 27 Excaliburs
  70. Wanted: pair of complete engines
  71. Bblade 4 speed 24 RH
  72. 2 pc valve covers
  73. WTB gen 6 502 block
  74. 8 plate oil coolers
  75. Point Me In The Right Direction
  76. Trailer for a 34 Scarab III
  77. Wanted 1/4 Canopies
  78. Need a 4 Blade cleaver with some rake
  79. 496, 500efi,502s
  80. Wanted used ITS
  81. WTB HP500 parts
  82. WTB, hydromotive p5x
  83. WTB 2 575sci wiring harness and 2 drive pulleys
  84. Bbc, edelbrock rpm 7164 intake.
  85. 525 EFI tailpipes
  86. Bolsters
  87. CMI's
  88. 28 to 30 FT Trailer
  89. 454 Magnum
  90. Wtb stelling headers
  91. Wtb (2) hp mercury bellhousings
  92. pistons speed pro
  93. anyone have some exhaust tails? Cigarette
  94. Prop adapters
  95. 380 tab plates
  96. wtb: scs shiftable crashbox's
  97. 1071's pair complete
  98. wtb bam 1350's or?
  99. Scarab 1986 era bolster seat
  100. Lifeline lifejacket and Helmet.
  101. 500 EFI Wiring Harness
  102. WTB Hardin sand Strainer
  103. 600c trim tabs
  104. Stainless Marine Risers
  105. Merctrans mechanical shift assemblies
  106. Velocity 410 Manual Wanted
  107. ISO: Wipple 8.3 top feed for carb or Rear feed FI
  108. WTB, Prop help please
  109. Wtb. b&m blower pulley
  110. WTB Stainless marine manifolds
  111. Drive Shafts
  112. Wtb.. 10 rib crank pulley
  113. Extension box
  114. WTB: 25/26p hydromtoive P5X
  115. #6 Props 5 Blades
  116. Nxt drives
  117. Wanted a pair of SSM VI or V drives
  118. ITS / XR cover cowl.
  119. WTB Heatexchanger brackets
  120. 2 sets of valve covers
  121. Vessel View Link module or 903 display
  122. Hydraulic Steering for 7'8" beam
  123. dart big big m standard deck block and heads
  124. Transom eye lift
  125. AutoPilot
  126. 502 cool fuel
  127. WTB : 26 or 27 rev4 15” dia
  128. WTB extension box or ITS
  129. Top Gun style wind deflectors
  130. 2007 Volvo Penta GXi ECM #3889007
  131. Looking for a Bmax complete upper gear case 1.30 ratio
  132. Calling SickStinger, Mike
  133. gps speedometer
  134. keith eickert oil pan
  135. Stainless marine Gen 3
  136. WTB - Mini Eliminator
  137. Wanted Steering system
  138. 4 pipe thermostat
  139. Wind Deflector
  140. WTB 1.60 RH Sportmaster straight skeg lower unit 300R
  141. 350 Mag MPI "cool fuel" housing
  142. W: Bravo drive spacer
  143. 525 headers
  144. Trailer
  145. Serpentine belt setup
  146. IMCO steering ram
  147. Looking for 2 engines 700hp and up
  148. WTB SSM #4 or #5 L.H. 1:41 ratio drive
  149. WTB Rinda techmate pro
  150. WTB: Kieth Eckert exhaust for BBC
  151. 4.5" clamp on mufflers
  152. WTB- 3.0 lt sport master lower unit
  153. WTB Whipples. Used
  154. Tie bar
  155. WTB 502 MAG MPI stock cam
  156. WTB. Exhaust manifolds -wet
  157. 502 mag mpi / 454 mag mpi WANTED
  158. Bravo spacers
  159. Imco scx
  160. Any first generation Livorsi/Gaffrig SmartCraft gauges laying around?
  161. ISO Bravo Y Pipe Block off plate
  162. 380 plates
  163. ISO #3 SSM parts
  164. Need 28'' RH bravo 1 prop or 26'' p5x hydromotive prop rh
  165. Pantera 24-28 W/WO power
  166. Looking for mercury 450R lower unit
  167. 34 bravo
  168. Livorsi Gauges & Throttle Shifter Controls
  169. Stock GM 502 hyd. roller cam
  170. Crane Cam Roller Lifter
  171. WTB 280 K planes/billet tabs with electronic senders
  172. IMCO or Speedmaster -2 Lower
  173. Looking for a side mount whipple supercharger for a 454 mefi mag
  174. 1.65:1 upper gear set bravo one
  175. ISO 2 Sets cmi Etop tails
  176. Jackshaft wanted shot in the dark...
  177. 28P Bravo Prop
  178. ITS Input Shaft for GKN U-Joint
  179. Looking for Mechanical Trim Sender Actuator
  180. WANTED formula 382 fastech no motor drive or with innovation 600
  181. Whipple quad rotor or 8.3 efi pair
  182. Wanted: Whipple 3.875" 10 rib pulley
  183. ISO: IMCO BB POWERFLOW portside
  184. Stelling headers
  185. Looking for old style Wellcraft McGill Euro on/off switch
  186. HP500 or HP525 Intake/plenum/fuel system
  187. Mercury 300R AMS 25"
  188. Procharger M3SC
  189. Inboard technician
  190. Bravo Spacers
  191. Wanted b&m 2 speed transmission
  192. WTB hp500 valve covers
  193. Cockpit Cover
  194. wanted : stainless marine gen 2 bbc
  195. WTB Mirage Plus 21s set
  196. ISO Holley 9022 800cfm
  197. ISO - Throttle/Shifter Pod
  198. XR ITS Drive
  199. Livorsi 4 handle throttle shifter controls
  200. Full hydraulic steering
  201. 3A lower gear case
  202. ISO hp gimbal assembly
  203. 19 spline props
  204. looking for Jesel sportsman rocker stands
  205. Sportsmaster 1.35 Lower Gear Set
  206. 18 x 28 4 blade
  207. Roots Blower Carburetors
  208. Mark iv 454 Peanut port heads
  209. Sea stainers
  210. Mechanical trim tab indicator ends that connect to the trim tabs
  211. Maximus 32
  212. "Clean" IMCO -2 SC Lower
  213. WTB: Mercury 300XS powerhead or longblock
  214. Latham Marine Bravo steering brackets/ end caps
  215. Engines wanted
  216. Engines wanted
  217. Two groove raw water pump pulley 900sc or Hardin
  218. Drive shafts.
  219. Midnight Express 37 / Go Fast Charter Boat Project Hull Wanted
  220. Cmi e-top accessories bracket
  221. 380 tab bottom plates with 1/2 hinge pin
  222. seawater pump bracket and idler Gen vi
  223. 1996 Scarab 26 Side Vent Cover
  224. AGI Box 8M3300001
  225. 2 stage sea pumps
  226. Hardin sand strainer
  227. 30P bravo one RH
  228. Swim steps
  229. Hp transom assembly
  230. Hardin thermostat housing/ crossover
  231. Looking for SSM wing plates
  232. Looking for 5 blade cleaver or hering props
  233. Wanted Bmax Upper
  234. Looking for RH 27 pitch bravo and set of headers
  235. Edelbrock Rpm Airgap
  236. WTB: RH 23P 4 Blade Prop
  237. Merc 420 Sea Water Pump Pulley
  238. looking for Bravo one 32p labbed possible trade
  239. ISO of 454’s or other options?
  240. Mefi1 computer that is not working
  241. WTB: mercury enertia eco 23p RH
  242. Looking for bare block
  243. seeking 5 blade props
  244. 500HP 502 Diamond racing piston stock
  245. looking for gen5/6 502 block
  246. Morse Docking lights
  247. Group 31 battery trays/hold downs
  248. BBC high rise intakes and hp500 carbs
  249. #6 props LH and RH
  250. Wtb water temp gauges with sensor
