View Full Version : Wanted
- Trs upper swivel pin and related parts
- WTB Mercury Revolutions4 25P prop
- Oldsmobile valve covers WTB
- Livorsi/Gaffrig GPS Speedometer needed 3 3/8"
- looking for a #3 tail stock
- looking for 2 gaffrig trim gauges
- Looking for a boat to slap a 454 in.
- WTB BBC MSD Distributor
- wanted 26 left
- Wanted 540
- 496 exhaust
- gen4 454
- Gen 4 rear sump marine pans
- K Planes with Pumps
- Drop-out Bolsters
- Wanted : Mercury 300xs engines , dead or alive any length considered
- WTB Standard length Sportmast lowers
- Looking for a Blue Motor Sea Pump Pulley
- 28 pitch bravo one 4 blade props stock non labbed
- Dash
- Looking For Big Block Valve Covers
- WTB oem 1989 Baja sport 280 black rub rail
- CMI E-TOP Bravo Tails
- looking for 2 imco steering rams
- Looking for Mercruiser alpha one ss
- Engine plates
- Shift Controls
- Stainless Marine Risers
- "Brazilian" power steering hoses
- 525 air cleaners
- 525 efi upper and lower intake,fuel rails,injectors,and throttle body
- Mercruiser Class 1 Valve Covers
- Wanted 4 Lever Zero Effort Controls
- gil manifolds
- Prop 27p rh
- 16k-20k lb cheap/yard trailer
- WTB Alpha counter rotate drive, gen 1
- Need 2 350 mpi intake manifolds #861422
- Looking for ITS Gimbal or Imco with steering
- One Set of Newer 1471 Superchargers
- Stellings Number 6 Stand Off Box - Part # 60905
- Drive Shower for Bravo 1
- Polished/chrome thottles
- WTB - 250 blower kit or 420 Mega Blower kit
- 454 or 350 mag
- Wanted CMI Etops polished with 15" tail pipes for Bravo One pair
- 38ft avs
- anyone know this guy or has his tel#
- Need 25-26' Trailer
- wanted
- Wanted Delphi ECM 16237009
- Looking for speed master number v extension boxes and carriers
- 525 EFI Crossover
- U shaped rubber hoses that go from the exhaust riser to the exhaust manifolds
- Gauges for twins needed immediately
- WANTED! Hydromotive QIV 30p RH
- looking for 250 b&m blower std deck.
- dominator carbs
- Anchor locker door 312
- Boat wheel
- 525 efi port side header
- WTB wrist pin retaining clip
- Trailer for a 1991 357 Formula
- 21-25 Cat wanted
- Cmi split tube
- +12' Bravo yokes (input shafts) for extension boxes
- looking for 502's
- WTB gauge sets
- WTB 2" shorty lower unit
- Bravo 28" pitch
- 1988 Scarab Concept
- Wtb docking lights for my 270 laser Powerquest.
- fuel rails
- Boat trailer large enough for a 47 Fountain Lighting
- Looking for swim platform or swim steps
- Looking For a XR Upper Swetpback?
- carb needed
- 2004 38’ Awesome War cat (outboards)
- Merc power steering hoses
- Gen IV sea pump with bracket
- Wanted sea water pump with fuel pump
- Looking for a B&M 250 Supercharger bbc intake
- Stock 502 mag piston & rod
- WTB mechanical trim actuators
- External sterning hoses
- Wanter 454 330 HP
- Msd rpm modules
- Wtb old flat deck hull 35 36 38...whats out there..
- Pair of drop in big blocks stock or a little more reasonable
- Merc 600sc blower belt tensioner
- Looking for trailer to fit 29' Formula Fastech
- Digital GPS speedometer.
- Looking for a pair of Imco SCX or SCX-4s
- Looking for Bravo extension box & driveshaft
- Wanted -1- 502 PISTON Stock bore Gen VI.
- Wanted: Nice Steering Wheel
- WTB Stelling Bravo Extension Boxes
- WTB: Set of 7 Gauges (Baja 226)
- Looking for valve springs 525efi
- WANTED!! Mercury/Kienhaefer K-Plane trim cylinders...
- WANTED: Tails for CMI Sport Tube Headers
- Pr of 1000's
- WTB: 502 Carb engine wire harness
- 502 block
- Hydromotive. P-5X
- Wanted BB Cast aluminum oil pan 10 QT
- Wanted Mercruiser Thunder bolt Ignition Module or Modules
- looking for some nice single engine side controls
- stelling tail pipes
- Wanted- boat trailer 38 ft
- Gauges for twins
- WTB Garmin GPSMAP 188C
- ***Need a pair of CMI E-Top tail pipes for Std. Bravo***
- 525 EFI or Mercury Racing Valve Covers
- Angled valve covers
- B&M 250 Whole or parts
- Wtb: bbc supercharger 250 6-71 procharger etc. or trade for bravo 1
- 1.8 Roller Rockers BBC
- NEED HELP !!!!! Stelling/Mercury Extension Boxes #6 Drive
- Livorsi/Hardin/KE/CP Sport tech drive shower wanted
- 97 Donzi 27 zx bow hatch
- Volvo f 5 props
- WTB Hering Props
- Need various parts mpi to carb conversion
- Wanted: Gen VI short block 454-502
- WTB Spark Arrestor for Dominator Flange
- Livorsi Mega carbon fiber
- Wtb: Teague/ Hardin or Merc. racing Sea Strainer
- 525sc 177 weiand
- Looking for a set of .30 over 502 pistons
- Imco powerflow bbc manifolds
- looking for a drop in 5.7
- 1999 hp 500 manual
- WTB Aluminum 496 Exhaust manifold
- WTB 2 -2" Imco shorties
- 496 HO Engine Cover
- need gill trs risers
- Intercoolers 6-71 blowers
- Air scoops
- WTB: Bravo XR upper swept back - any condition
- Wtb 24-27
- Looking for a sea water pump mounting bracket
- Bravo steering bracket and rams
- bbc valve covers
- Need 2 steering caps / brackets bravo
- BBC headers for dyno use
- POWER STEERIng bracket
- Garmin 5212
- wanted: 525 efi parts
- imco +3 extension box wanted
- Wtb roller rockers
- WTB: Whipple 500 EFI Kits
- need some race thottles and shifters
- BBC roller rockers
- 2 closed cooling kit for 502s with serp belts
- need two sea pumps
- k plane trim tab parts
- gen 6
- need long risers for imco power flow
- bravo 1 -2 lowers
- 496 rods
- EFI systems
- Cockpit cover for a Baja 33 outlaw
- Stelling Green headers 1 set
- Gaffrig 8x3 flame arrestor for 4150 base
- WTB Imco 6 port fuel valve
- 500hp cam
- Imcomarine extension box
- Stellings extension box
- Myco, Manning Trailer Wanted
- Imco SC upper
- I need a pair 454,502,525???!!!
- wtb spectre seats the new style
- WTB: Imco or Mayfair extension boxes
- 3.3, 4.0, 4.5 Quad whipples
- Need (2) dual standard carb intakes for bbc
- Ready to Boat Again
- Corsa mufflers
- WTB: LOTO lake map/chip for my Lowrance GPS
- grab handle/rails
- WTB: Pair of 4 blade 24P or 25P props
- Dead 496s , NEED 2
- 2 piece trim cylinder...
- Wtb trim tabs cylinders stainless steel
- 525 EFI cam and one set of CMI Etops plus some other stuff Please Help!
- Baja 280 Sport Dash panels
- WTT: 1100 hp mustang for powerboat
- Gauges
- WTB Dry Exhaust or...
- If you are going to post here, please be serious and realistic.
- Side by side bolster seat
- 2 complete blower set ups
- WTB 24-30ft minus power or twin engine race boat
- Cat trailer.....
- 25p mercury mirage
- MSD Rev limit modules
- Monza 24 - Early 70's
- Aluminum 496 manifolds and 6 inch risers
- Complete engine/drive package
- alpha 1 lower case
- Kiekhaefer Controls
- 496 ho
- Aftermarket exhaust bbc for up to 600hp
- 500 hp efi nameplate placard
- FORMULA Silent Thunder Exaust Box
- Wanted 27' activator hull
- Imco power steering relocation bracket (04-9355) instructions
- Electric chain hoist
- WTB 2 sets of gil long risers
- WTB livorsi/autometer platinum face/mega rim monster gauges
- Merc 850 SCI or 1075 SCI
- mechanical fuel pump that goes on the water pump needed
- 383 SBC 375HP or More WANTED!!!
- TRS Drives wanted
- Single engine throttle/shifter
- 8.1 HP3 Vortec Cylinder Heads
- W T B Mercruiser 525
- Formula Silent Thunder Rectangular Tips
- 24' - 27' single near TX
- Silent choice solenoid
- Trailer for 24 baja outlaw
- Looking for a clean TG T/S in the $100-150k range.
- 89 formula boat cabin pillows
- Gen.iv 8qt Oil Pan
- Big yellow 41 Apache cat in NJ, it was stuffed in a race
- Looking for a nice set of BBC valve covers
- STILL Looking for merc 496 dts pcm
- Flat bottom Blower Hatch!!!
- Wanted:Trailer for a Formula 400SS to store on at marina. Wieghs about 19K/step haul.
- fountain or cigarette project
- 8.1 496 Inboard wiring harness
- Corsa diverters
- 8.1 liter risers needed
- Headers and Captins Call
- ITS transom assembly
- looking for 2 intercooler sand strainers
- Looking to buy a gen iv 454 to rebuild
- Alpha One Gen 2 - Counter Rotation - Lower unit or parts
- WTB: Alpha One G2 Lower unit CR 2:0
- WTB Hardin Marine Cross Over Bypass Kits
- WTB MSD 8560 Distributors
- wtb 500 efi seawater pulley
- stainless marine gen iii manifolds
- wtb 500efi seawater pump with bracket and serpentine pulley
- GEN V/VI cast alum oil pan
- Wtb 2 sets of vortec heads for 350 mags motors.
- WANTED: Looking for drop down / drop out / stand up bolster seats
- headers
- Oil Tubes & Dipsticks
- Pair of 454's
