View Full Version : Wanted
- Water Pressure Gauges
- Need Sea Strainers
- alpha tie bar
- need sea water/fuel pump for big block
- Need Block!
- Looking for a carb for a 420
- bell housing and sea pump brackets
- WTB gen 6 502 heads
- Looking for 454 Gen V
- Need Bravo One Props 22-24 P
- 850,1075,1200 flex plates for the flywheel
- Intercooler Strainers
- Looking for two pair of exhaust
- WTB: pair of outboards
- CMI tails for single bravo
- Tails for merc manifolds wanted
- wtb standard stainless marine riser
- WTB Trailer to Fit 25 Powerplay
- 17.5x26 4 blade 26 spline
- WTB set of 16" aluminum wheels for trailer
- Bravo forward mount kit,full or partial
- Rectangular port BBC heads for a MK IV
- Chart Card for Lowrance LMS-320
- I need a lower volvo penta sx-c1 1.66 ratio
- WTB Smart craft Race View
- wtb old school bolsters
- Trs lower unit urgently needed
- 454/502 EFI flame arresrtors
- Dual external steering needed
- wtb mirage plus 23 flo torque left
- WTB: Gaffrig Water Pressure gauges
- carb spacers wanted...
- wtb: bolster seats for a 1993 baja outlaw
- Looking for TRS Helmet
- Bravo 36 pitch left hand prop
- 496 or 525
- looking for Trs bell housing
- 4.25 BBC 2 piece rear main crank
- 525 Efi's Wanted Complete
- WTB Hering 5-blade 29 RH
- Anybody have a anchor shade for sale
- Mercury 465 Remote Oil Filter Setup
- Merc HP525efi parts needed
- Livorsi Water pressure gauge
- Wanted - 1 Fresh Water Cooling System
- WTB: Kiekhaefer throttle J cable ends
- WTB: single engine CAT hull
- WTB - Merc Saginaw PS Ram / Actuator
- wtb 4"shotgun mufflers
- Wtb Rh 28p B1
- WTB - trailer for 25' Powerplay
- Need Props , 17.5/17x29 4 Blades Merc
- wtb: indicators, drive lube res. etc.
- Full Cover for a 38' Top Gun
- yamaha 5.7 cooler
- oil pan
- 500 EFI powersteering pump
- 23 and 25 mirage props
- looking for crownline windshield
- looking for a rare windshield
- Bravo Drive Cover
- Need an engine hatch for magnum maltese
- 2 sets CMI tailpipes........
- Looking for a Gen VI 502
- 454mpi plastic engine covers
- hp 500 carb
- seats
- pair of Arneson 1721 or asd6
- oval flame arrestor
- bummer.... sold one and need another
- Pair of scx uppers
- 1.5/1.47 Gen. 1 Alpha
- XR upper gears
- air cylinder for silent choice
- WTB Mirage 27P props.
- props covers
- Full Cover For Top Gun
- Speedo Pickup tube
- 1997 volvo penta sx lower?
- CMI Tailpipes
- Pair of 600SCi or 700SCI
- Need Pivot Pin and bushings for Bravo X Drive
- thermostatic oil cooler ....
- oil filter adapter
- Aluminum Heads
- #5 large shaft drive
- XR gear
- Bravo couplers
- cmi headers
- (2) throttle cable brackets and fuel lines for demon carbs...
- K-plane shims/locks found on fountains
- Drive Trim Indicator
- HP 500 power steering pump
- jl m 7.7
- 496 Fuel Pump Kit
- Hydraulic Steering Wanted
- Sea water pumps
- trs bw c72 yoke assm - shaft
- WTB: 1" Bravo Spacer
- trim indicator,ACTUATOR, 846063A 1
- Gil Exhaust
- 4 blade 28's props
- 6 lug trailer wheels / tires
- Trim cable parts needed
- 280 Trim Tab Rams
- 525efi Oil Pan
- 496 Manifolds
- Looking for a pair of 4 blade 24p or maybe 25p for Bravo/TRS
- NEED XR or XZ Drive upper or complete!!!!
- Msd 6m-2
- Gaffrig 3 3/8" Gauge needed
- need 90' of rub rail for my 40 Scarab
- large oval port 454 heads
- Outboard Tach and gauges
- Dual quad air cleaner?
- Bell housing oil cooler lids
- 24p bravo prop, billet top cap
- Puke Tank Overflow Oil
- Need mount brackets for water pumps
- Gaffrig mufflers
- 575SCI superchargers
- Cougar Cub Mini Boat !! Wanted
- Mufflers
- 19 pitch
- wtb stainless marine short risers
- WTB:Latham power steering reservoir
- Power steering pump for 575SCi
- WTB Full Stero System & MISC ITEMS
- bravo one prop shaft
- Serpentine crank pulleys
- 700SCI's
- 525EFI's
- CMI Bravo Tails
- Dom. Flame Arrestors
- Oil filter housing
- Big Block Flywheel
- Need a pair of Bravo X uppers
- Swim Platform
- cmi sport tube headers
- Flame Arrestors
- Drive shaft covers
- Bravo 1 24p RH
- Stern light w female coupler
- Need to Find a B&M 250 Supercharger Flame arrestor
- WTB 17 1/2 27-28p four blade
- Sony Faceplate
- WTB Fastech 382 cabin contents
- WTB Bravo gimble ring
- need v6 module
- Parts Needed To Finish Project
- need help
- need 2 bravo trim actuators
- wanted gen 4 bb.
- 454/425 HP Valve Cover
- Merc Distributor block off plugs
- 2 dual cooler bellhousings with coolers...
- Want to trade...Need 30P Maximus
- WTB a pair of -2 Bravo lowers
- trs tailstock bearing for BW
- 1075 mercury upper pullies
- Drop Down Bolsters
- Bravo 1 L&R 26p's
- CMI Rope Seal Tailpipes
- alpha speed master
- Need exhaust for BBC
- CMI or stelling headers for small block
- captains call / silent choice
- Rudder
- 10-14 Quart oil Pans
- Oval Port Intake
- tubular platform for a cig
- looking for bravo sportmaster lower
- 380 k-plane plates.....
- Need 2 standard length sportmaster cases
- 2 throttle linkage brackets to fit 1050 demons...
- XZ Decal Set
- Wanted Bravo 1 4 Blade Props
- 2 stage water pump
- electric over hydraulic actuator
- Looking to buy Plotter Asap
- Xr Gears Wanted
- Gil exhaust
- Bravo 1 Upper complete
- Prop Boxes
- Looking for a pair of stock bravo ones drive
- Looking for oil pan 10,12,or14 quart pan
- WTB 23 Mirage Plus RT & LT
- Two Trim Pumps
- Need A Computer For A 08 Dts 350mag
- Wtb
- WTB: Y-Pipe block off plate
- 1/2 inch bravo xr spacers
- WTB Hydromotive Quad IV props 23
- bravo steering cap ext steering
- Peltor helmets
- 2 Headsets Needed
- NEED BBC Exhaust!
- Alternator
- trim pumps and trim/drive indicator panel
- cmi exhaust tail
- wtb stainless marine exhaust
- WTB Trailer
- twin throttle/shifter
- transom mount steering extension for external steering rams
- fuel filter head
- 5"polished stainless pipe
- #6 Inner Transom Plate
- WTB: 28P or 30P Bravo 1 prop (Right)
- pair 700-800hp motors in need of work....
- Dart 308 head
- Bell housing
- 32 4 blade bravo's
- xr upper gear set
- Stainless Prop
- Heads up Trim indicator
- TSTAT housing
- P5x prop
- M1 Procharger wanted
- WTB...single plane oval port intake for bbc.
- wanted 525 pcm
- 502mpi wiring harness with mefi3.
- wtb hardin gps speedo receiver
- WTB: 23'-26' Hull Only
- Cavitation plates
- Steering wheel
- Water pick ups
- Konrad 540 extension boxes with transmission
- CMI parts wanted...
- emi Shift, Ignition and Oil filter Brackets
- Need steering Post and helm
- Need 2 bravo gimbals
- Sea Strainers
- HP bell housing
- pair of tired or blown up blower motors 650hp or bigger...
- I Need a Used set of 525 Headers...
- CMI Groove Clamps Wanted
- imco steering parts
- 500 EFI throttle body
- 27' to 32' powerboat that needs work
- looking for used bravo gimbal housing
- WTB HP500 Intake
- Fountain Windshield/screen trim
- Evinrude v8 CR left lower unit
- bbc harness
- 2'' shorty vertical shaft for bravo
- need more parts for a 496
- Looking for a Imco Cuper fuel valve
