PDA
View Full Version : Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. Want to Buy: Bravo Exhaust
  2. want a 30 pitch bravo 1
  3. low mount alt bracket
  4. drive oil resovoirs
  5. Wanted 2 5/8 livorsi/gaffrig water temp gauge
  6. Wanted: Merc 496 exhaust manifolds and risers
  7. Wanted: Front Starboard Windshield for 2004 Fountain Executioner
  8. 500 efi oil Dipstick
  9. 21 p mirage plus
  10. 454
  11. Eickert Dual Cool Bellhousings
  12. Imco -2 case
  13. SS 5/8 UNF female heim joint
  14. need 496 dts shift actuator bracket
  15. Captain Call Wires
  16. Bravo One Power Steering Actuator
  17. Need Vent Covers for a Fountain
  18. Mechanic Wanted
  19. 4" exhaust tip flappers (internal)
  20. XR propshaft "twisted"
  21. I.T.S. intergrated transom yoke
  22. Flat deck cabin door
  23. Hydraulic steering
  24. Hex oil pump driveshaft needed ASAP
  25. need ASAP impco long extension shaft and u joints
  26. Wanted 15hp outboard motor in miamia area
  27. Wanted, 17 x 33 or 34, 18 degree rake, prop set
  28. TG blower hatch needed!!!!
  29. WTB TBS Intercooler for 8/10-71
  30. wtb bravo one lower
  31. 18x27 4blade 26 spline props
  32. cmi tails wanted
  33. stock center rise manifolds
  34. Cockpit cover
  35. wanted hyd 8" steering ram
  36. Mercruiser pressure relief valve
  37. WANTED Ocean Express 15.5 Nitro
  38. Thunderbolt IV ignition module
  39. ssm gimbles
  40. fuel pressure gauge
  41. alpha transom saaembly
  42. Wanted: Merc 496 exhaust manifolds and risers
  43. Tilton top mount starters
  44. Wanted Throttles
  45. wanted 800 sc intake manifold
  46. need IMCO bravo double stacked caps (1 or both)
  47. swim platform
  48. add on steering
  49. WTB Imco Super Fuel 6 Port Valve
  50. bravo trim pins
  51. 26 4 blade prop
  52. Need a shifter part
  53. Oil filter adapter
  54. B&M Blower Pullies
  55. Wtb single steering acuator
  56. exhaust reducer
  57. #6 s
  58. wanted imco tilt steering setup
  59. 26 Hydromotive props
  60. Wanted big block ford parts
  61. TRS Shimming Tools
  62. Lifeline poker run jackets
  63. stainless marine risers
  64. looking for a set of single controls
  65. Charlynn helm pump for #6 drives
  66. Looking for a pair of deck hatches for a 19.5 x 19.5 cutout
  67. Imco long driveshaft. New style xr u joints
  68. WTB prop
  69. Superchillers for 177 B&M
  70. WTB Two Hardin marine sand strainers
  71. 30p bravo 1
  72. wanted 29 fountain 2006 or newer
  73. Looking for solid hull less power, MA area
  74. WTB Victor Jr. Intake for BBC
  75. WTB: Vintage Mercruiser jacket
  76. pair of hp500, 540 bulldogs, or 500efi
  77. set of bravo 1 24 pitch 4 blades
  78. Stelling parts
  79. single engine billet front and rear mounts
  80. Need one trs gimbal ass.
  81. CMI e-top headers
  82. 3 PSI Pulley
  83. looking for a ssm#5
  84. WTB Vintage Cigarette Steering Wheel Center
  85. Wanted : Formula 382 cockpit cover
  86. looking for a dual port stainless thermo housing
  87. CMI sport tubes
  88. XR Lowers
  89. Wtb hydro hoist
  90. wanted
  91. bezles
  92. cheap complete 454
  93. Whipple superchargers for HP 500
  94. Gooseneck Trailer
  95. Crash Box
  96. Crank pulley for whipple/500 efi serpintine
  97. Kaama parts
  98. Bravo helmet bell housing
  99. pair 26p bravo ones
  100. WTB Need pair of small block bravo couplers
  101. Thru hull fittings
  102. Gm zz502 head
  103. High back seats
  104. MERC Bravo SQ fill bottle
  105. livorsi oil temperature gauges
  106. 382 Fastech Cover
  107. Headers
  108. Bravo one drive complete 1.50 ratio
  109. Dry Sump Tanks
  110. 16 rib pullies
  111. MSD REV-Limit Modules ??
  112. hyd helm
  113. WTB #6 wet sump drives
  114. Add-on hydraulic steering for TRS
  115. Wtb full cover for a cigarette top gun
  116. Pair mcleod bolster
  117. oil cooler brackets 3"
  118. 3" Imco shortie
  119. Hardin Marine Mufflers XPM525
  120. bravo 1's
  121. Hydraulic steering assy. or parts
  122. wanted 29 fountain
  123. need a 454 (complete motor) or bigger
  124. Donzi Shelby
  125. bravo gimbal mount jack shaft drive shaft adapters
  126. WTB Bimini and Cockpit Cover
  127. Baja sport 280 mooring cover
  128. Boat trailer
  129. bolsters
  130. SSM 3, 4 or 5 Extention boxes
  131. White military rocker switches
  132. Electric Hatch Lifts
  133. Blower scoops or Chillers......
  134. cover for a Baja 280 sport
  135. 24 or 25 outlaw motor hatch hinges..
  136. 31ft cover
  137. Hydromotive nose cone pre 90's bravo
  138. 049 Cylinder Head
  139. WANTED TRS Tail Stock Tailstock WANTED
  140. Wanted EMI Thunder SBC Manifolds
  141. B&M 2 speeds
  142. Knock Sensor for Gaffrig/Anson Torbo Systems
  143. Transom jig and drill
  144. 1.5" fuel fill hose, 4" exhaust tube, hatch ram
  145. thunderbolt IV engine harness/ ingiton .amp
  146. transom water pickup
  147. Marine Machine single engine shift/throttle
  148. Gen 6
  149. Gen6 (502)
  150. Crank pulley serpentine
  151. Wtb crossover
  152. wtb xr 2" drive spacer
  153. Looking for headers
  154. Bellhousing
  155. Rocker switches for k planes
  156. SSM #3 Upper gear set (1.33 ratio)
  157. 5" exhaust flappers wanted
  158. Bravo trim pump
  159. 454 Near Ft Lauderdale, FL
  160. Bravo Steering back cap
  161. WTB Fuel Pressure Gauges
  162. Drive showers
  163. Bravo XR 1" Drive Spacer
  164. Thermostat housing or top for bb mercruiser
  165. Mini Mod Vp style Tunnel Hull by ( Sport Boat )
  166. Bravo inner transom brkt
  167. 4.25 forged crank wanted
  168. Breather Assembly for Mercury 850/1075
  169. bravo one nose cone
  170. comp springs
  171. Need dual controls
  172. Need some 5" exhaust hose scraps pieces
  173. Bravo Transom Assembly
  174. Needed Used trailer or need to rent a trailer
  175. smallblock performance exhaust oil pan carb
  176. Stock steel SB oil pans
  177. 496ho , hp500 or hp525
  178. Remote oil filter part needed
  179. Clamp on 4" mufflers
  180. Steering cylinder for #6 drive
  181. pop up cleat
  182. Vc spacers
  183. hardin marine boost gauge
  184. Starboard GIL manifold needed
  185. Latham power steering reservoir
  186. Puke Tank
  187. TRS Hinge bolts
  188. Keith Eckert Oil Fill Plug - Old style, black anodized
  189. Trim pump
  190. Lots of parts wanted.....
  191. Livorsi GPS Antenna
  192. Short deck blower intakes
  193. 671 intercoolers
  194. Hydraulic steering system
  195. Prop covers
  196. Pro charger parts
  197. 420 HP merc parts
  198. NEED 2 HP Transoms Assy.
  199. looking for a Bravo HP drive coupler
  200. 1'' bravo spacer
  201. grab handles
  202. Looking for a rh 26pitch bravo one
  203. Looking for an old Corsa 4-wire wiring harness (captain's choice)
  204. 1/2" Bravo Spacer
  205. Single Throttle setup
  206. 3" standard stainless steering column for hydraulic helm
  207. Silent Choice
  208. #6 5 Blade 18Dx28 Pitch-High Rake
  209. WTB Whipple MOAC intercooler. WTS Whipple standard intercooler
  210. WTB 088 heads and TRS gimble
  211. cams, intakes, carbs to wake up my 330's
  212. #6 tail stock
  213. Wanted: 3.5 Pulley for Weiand 575sci
  214. 2 dominators and 2 intakes
  215. mercruiser crank studs
  216. Headers
  217. WTB: Gaffrig by Livorsi 35PSI Water Pressure Gauge - White (2)
  218. wtb: trim actuator cup. bolts onto trim cylinder
  219. Trailer for 35 fountain
  220. HP bravo coupler needed!!!
  221. 92-95 wellcraft nova windshield
  222. 4.500 je piston
  223. Transom Assy - Bravo
  224. WTB AC DC Refrigerator
  225. WTB: #5 lower case
  226. WTB - Stainless Tilt Helm
  227. Swim platform Mistress/Cafe??
  228. Wanted: 380 k plane (plates only)
  229. WTB Aluminum Myco, or Manning Trailer for T?S Cigarette
  230. needs some gauges what you got ?
  231. 38 to 47 with no power wanted
  232. Set of Forged JE piston 4.25 bore 9:1 compr
  233. Isotta Steering Wheel
  234. Merc 500 serp. pulleys
  235. Hardin sand strainers
  236. Imco 6 port fuel valves
  237. Looking for a 27 Excalibur hull w/ no power
  238. Wanted - Eddie Marine manifolds and risers for BBC
  239. Two 454's Complete
  240. 27 fountain no power
  241. 29 Fountain NO POWER
  242. Two blue 377 Scorpions
  243. WTB: Stellings Adjustable Extension Box
  244. Baja 36 bolster
  245. bravo busted,or no good upper units
  246. 2 525sc blower set up's
  247. alum heads for a bbc
  248. trim pump brackets/selinoids
  249. merc riser extensions or merc style risers
  250. merc shift plates
