View Full Version : Wanted
- Used 454 short block
- 454 big oval ports heads
- wanted hydrolic helm strng rams
- HP500 Seawater pump brackets
- WTB Hydromotive P5-30 RH
- WTB: 35' to 40'
- Sponsor Wanted
- Valve covers that clear gil manifolds & crane golds
- Looking for hp500efi valve covers
- Need Output Houseing/ Merc trans w/TRS-HELP
- Teague Platinum XR Drive
- GIL manifolds and trs dry pipes?
- WTB: 17-19 ft. Center Console
- 525sc intercooler
- Intercooler
- engine lift plate blower bolt pattern wanted
- cylinder style coil bracket wanted
- Looking for a shaft
- marine Stero equipment
- Helm steering shaft...
- Hynautic steering cylinder
- Gil Marine battery boxes, where to buy?
- 454s,502s,or?
- WTB Transom Rings
- PAIR of TRS compl.
- WTB Keith Eickert Manifold Fittings
- Wanted Exhaust Manifolds Lower & Upper
- boarding ladder
- Stock genV or VI valve covers
- Imco 2" Lowers
- External Steering
- stering wheel
- Selling Driver Seat
- Bravo upper and lower case
- Used SSM4
- Used Alpha One
- wanted: single add-on ram hydraulic steering
- Wanted Hydraulic Steering For Twin Trs
- 6 used flushmounted rope cleats
- wanted 525 efi short block or long block
- Used 496 HO short blocks
- bravo III duo prop
- need motor mounts
- Sportmaster Lower
- merc oil pan
- need two fuel selector vavles
- Mufflers
- merc 502 stk oil pans
- Lifeline Jackets 2 Med & 1 Sml
- two water/methanol injector kits
- wide band O2 sensors
- 380 K planes
- Needed asap! Bravo Prop shaft
- WANTED: 280 K-Planes
- 575 thermostat housing
- 31m battery box. who makes 'em nice!!
- 496 Exhaust Manifold take offs....again
- Carpet Needed
- wtb: latham rear bracket for external steering
- Access Technology; Sony stereo remote
- 30 inch round pontoon for hydro hoist
- Wanted #5's or # 4's with big shaft
- 30P Bravo
- Head Sets
- Wingplate
- Sea Strainr Lids
- 25p Mirage Plus needed
- need two pairs of hp500 valve covers
- Need a Accel Gen 6 DFI or FAST system
- need two alternator brackets
- Gaffrig Gauges Oil Pressure
- Gimbal Ring
- Need parts
- wiring harness
- TRS external trim lines
- Sea pump old style
- Best prices for valves?
- Pair 500 efi's
- HP500EFI computer
- Bravo pin (rear) part #17-44166
- S. S. T-stat Housing !!!
- 3 3/8 bezel
- White Livorsi trim Gauge
- Need Dominator 1050 and other misc. parts
- Hydro QIV 24P LH small rings
- Trs Hydrolic Steering
- BBC parts
- Dry Exhaust, SM or Header Style
- bravo prop
- Oil Filter Housing T-Stat STyle
- Looking tails for Gil exhaust 454 89 Donzi
- Tall deck block wanted
- Stainless marine Dry Tails
- Wanted - Two Sets of Dana or Stainless Marine Exhaust
- remote oil filter lines
- small swim platforms
- EGT gauge and senders
- XR Sportmaster Case
- HEADERS for 2000 Merc 500 EFI
- Pump for CMI switchable tips
- dash mount trim switches
- Crane 169621 or 168731 camshafts
- Wanted - Aftermarket EFI Hardware for BBC
- 26 or 28p Bravo 1 4blade
- 14-71 Blower shop need 2
- 300 TorqueMaster Prop shaft
- Trs Drives
- k-planes
- Bravo outer transom plate
- Drop Down Bolster Seat
- PowerPlay 230 Conquest camper top
- B&M 250 Pulleys
- 2 420 mega blower intakes
- twin engine shifter
- ladder cover
- full cover
- Need a Pair 454 Magnums
- Set of tall deck intake spacers
- Cloyes Hex A Just Timing Chain Bbc
- dash redo
- Billet hardware
- Stelling Headers (Orange or Green)
- Wing Plates
- Vinyl Stickers....
- Mercury 502/500hp Parts for sale:
- Need Oil Filter Relocation set up
- Looking for two pairs of CMI E-tops
- Gen6 502 block
- Wanted: Pair of 5 or 6 Blade 22" or 23" Pitch #6 Splined Props (R&L)
- Budget exhaust
- k- plane trim cyl
- WTB Thunderbolt IV Ignition.
- B&M 250 Blower
- LWP Lower B1
- WTB Thermostat housing
- Good used GEN IV 454 block
- Misc parts
- All the
- Max Machine drive, Or any high Hp Drive
- I.T.S Drive Alignment Tool
- Hydraulic Steering
- wanted 2 pair transom mount mufflers
- WTB 4.5" clamp on mufflers
- Throttle Controls...
- WTB Hydromotive quad 4's
- tiebar
- WTB Trailer for topgun
- need four cmi 4 1/2 mufflers
- 4" Clamp On Mufflers
- 6" Gil Rise tails for staggered
- BBC aluminum heads
- Hp500 parts
- Stainless water pick ups
- wanted timing chain cover gen 6 BBC
- need carbs
- BDS roots blower EFI system
- hp 500 Exhaust Manifold Gil or Mercruiser
- Solid front motor mount
- New Governor
- Imco Drive Cap For External Steering
- Valves: 2.25 and 1.88
- looking for risers
- Wanted: Mechanical Drive and Tab Indicators
- 496 aluminum manifolds
- Who Makes / Sells Stainless 15 -20-gal Tanks For Meth
- wanted to trade or buy EMI Flame Arrestors
- Y pipe block off plate for Bravo
- 454 Efi
- Wanted, Alum trl for 33', & swim platform, muflrs.
- blower intake manifolds
- imco extension box alignment tool
- PAIR OF MERCURY 250 EFI's
- Harden Marine T1000 Aluminum Exhaust Manfolds
- puke tank
- single bravo add-on ram wanted
- sea pump pulley that also runs power steering
- gil mounts
- silent thunder lower panel wanted
- Merc # 805361t1 V-6 Ign Module
- Merlin BBC heads
- hp 500
- Whipple superchargers top mount for 500 EFI
- Rocker covers
- 1999-2000 454 mag
- Intercom system
- Holley HP 4150 80558
- Kuhl Dual Carb Adapter
- big block take outs
- Aluminum trailer 24ft
- Intercooler for a 525sc
- Wanted - Bowtie #14044807
- Looking for Imco lowers 2 trade
- ac
- need nose cone for bravo 1
- Bravo 1 prop 22p
- BG Marine Demon 850 Carb
- Trim Indacator Bracket
- speed master #6 gears 1.5 ratio erly style welded type
- two ss lifting hooks for back of boat
- Wanted Aluminum Swim Platform
- cross over and t-stat housing
- TRS nose cone
- ignition amplifier
- Looking for a boat trailer
- Need 50# injectors for 502mpi intake
- Skater trailer 24ft
- steering
- Looking For 2 IMCO +3 Bravo Boxes
- 525 Efi intake manifolds and plenums
- Where to Order Lifeline Jackets??
- 5'1-5'7 Blonde 115-125pnds
- New Style Top Cap For Bravo
- MSD 8560 distributor
- Hydromotive Quad IV-X 22p
- Gen V 454 block wanted.
- 454 exhaust manifolds
- Lifeline Chute Jacket
- need two used latham rams
- Need 28 Maximus X 2
- 71 superchiller wanted
- need bbc ss water pump crossovers
- 30 Maximus labbed props
- Stainless t-stat housing Sierra 18-1989
- 1071 Blower Kit
- 502 rotating assembly
- Oil pan
- WTB: HP500EFI, HP525EFI, HP575SCi take-outs---need 2.
- Wtb: M1sc Or M3sc Procharger
- bravo one 1.5 ratio upper gear set
- Set of 23P or 25P props
- wanted manifolds and risers
- need staggered motor mounts
- bbc parts
- Looking for Borg warner trannys w/bellhousing/tailstock/driveplate
- Edelbrock Heads
- Free Resume' Website
- Need pair of running take outs 400hp range.....
- still looking for TRS parts
- Wanted Hydraulic Steering And Exhaust
- Bravo upper cases
- Gen VI 502 Short Block
- Bravo1 lower unit standard vertical shaft
- Bravo1 lower unit case (low water pickup)
- Engine Hatch opener
- Throttle/ Shifter
- looking for pair blower shop intercooler housing
- 22x22 white bomar hatch
- Custom steering wheel wanted
- external add-on ram wanted
- cig battery boxes
