View Full Version : Wanted
- WTB Cabin Hatch/door Formula 336
- need a thunderbolt 4 distributor&ignition module
- main head studs
- CMI Headers
- Drive/tab indicator needed.
- ISO Mercruiser Thunderbolt IV Distributor
- Gen VI 454 oil lines , filter adapter
- Complete Wiring harness for 502
- Trim Tabs, exhaust system , hydro steering
- In line power steering filter
- Efi intakes
- Correct Quadrajet for 365 magnum 454
- Bravo standard length studs 2"
- #6 side by side tie bar
- TRS tie bar 35
- Wanted merc rev 4 23p
- Wanted 502 exhaust manifolds any condition
- Cigarette windscreen
- 502 EFI Gen 5 V-Belt Pulleys
- Mercury Max 5 32 pitch propellers
- Holley 9022 Marine carb.
- Looking for cast iron 496 manifolds and risers
- Wanted: Later style Bravo inner transom plate
- Looking for a pair of V8-22 Modules
- Heads
- WTB livorsi controls
- Bell housing cooler stb side
- TRS lower
- SSM 4 tailstock trans mount
- Add on hydraulic steering to full hydraulic
- Wanted Pair of Superchargers
- Small blocks!!!
- ITS or Bravo 1 transom
- Mercruiser / Gil Exhaust Manifolds
- 35 foot or longer trailers
- Hammond Challenger V2150
- Imco Trs wingplate
- WTB: Formula 272 SR1
- In search of newer 353 Fastech Sub 300k
- 2 stage water pumps
- Openbow with OB
- 4" Stainless Steel Exhaust Flappers
- Hering LH 5 - blade 15.8X30.5P 20*
- Ssm 6 plug in tail stock
- WTB Hydromotive P5 Pair 29 or 30 pitch
- WTB Livorsi gauges
- Wanted a good 177 blower
- Crane 731-741 cam wanted
- Sea Strainer
- Mercury 525 Port Valve Cover.
- WTB: Merc Racing 1350 drive
- Vessel View 903 8M0129544
- Single Verado 275 30
- procharger pully
- Looking For An IMCO SCX Upper
- Mercury 525 efi or 500 efi
- bravo 1 1:50 upper or upper gears
- WANTED 500 efi or 525
- Crane Cam #131311
- Bravo 1 pinion gear
- Bravo XZ gear kit
- Bravo 1XR + Bravo transom assy.
- ITS transoms or hydraulic steering
- ISO BBC exhaust and risers
- Imco Drive shaft bravo XR Extensionbox
- ISO, Keith Eickert Engine Plates, Bam Cyborg Transmissions, Bam Bellhousings
- looking for 20/24 cigarette
- ISO alum heads
- ISO Trailer 38ft+
- #6 Studs and oil tubes
- 30 bravo 1
- Wtb thunderbolt (15 1/4 x 19") quicksilver rh propeller, qs5006x
- Mercruiser Staggered motor mounts
- WTB: Gen4 Heads Large oval port style 049/781 etc
- Steering helm
- K Plane Transom Plate
- Trim Tab Switches For Single Throttle
- Pair of 731 Camshafts
- WTB 8.1L / 496 cylinder heads
- ISO BBC Tall valve covers angled for exhaust clearance
- Big tube Stelling headers black
- Rochester fuel injector
- WTB accon pop up cleats
- Pro Charger parts needed
- WTB Gooseneck trailer 37' boat
- Prochargers or 575s
- ISO stock 502 Longblock
- Hydraulic steering
- ITS laong shaft
- WTB 38 Boat Trailer
- Valve Cover 500 EFI
- Carb whipple??
- Procharger AW504 Intercooler
- BBC brackets, components needed
- 8 mm Blower pulleys
- Heat exchanger bracket
- 3Assm
- Holley 4150 SS flame arrestor
- BB Gen 5/6 10 qt. Oil pan
- Merc BB crank pulley, alt/ps brackets, bravo coupler, remote oil filter mount
- Gen 5, 6 crankshaft
- Blackhawk Bearing Carrier and Driveshaft
- 28'' apache hull only
- 4.5 mufflers
- Fountain 48EC hard top
- 525 cam
- Hydromotive p5-x
- ISO Livorsi Hour Meter - Baja OEM
- Flame arrestor
- ISO Konrad
- #6 tilt housing .
- Drive indicator parts needed ...
- New BBC take off heads
- looking for crower bb rods
- Pair of helm seats
- Engine bracket
- Imco -3 lower and Rev 4 prop
- External Steering, Dual Ram, Single Bravo, any Brand
- ISO Single 500 efi piston
- ISO Drive Oil Reservoirs
- 380S K Planes
- Molnar Power Adder Rods
- wanted Bpm or ASD 8 thrust tube assembly
- Livorsi L3E-115 gauge wanted
- SSM6 service manuals.
- Bravo I prop, 24 p RH
- Wanted XR top cap
- WTB lathem 4 lever controls
- Extension box (Neutral) for Bravo 1 setup
- WTB Pair of 5/6 blade, 17 or bigger diameter, 21° or more rake
- 380K Plane
- ISO (2) 3.3L carb whipples
- Matching BBC Pair
- Flame arrestor
- GBB marine mufflers
- ISO hydraulic ram steering
- Looking for SBC performance exhaust
- WTB 2 Pair Stainless Marine manifolds
- 525 efi cams
- Fountain Fever - cabin interior pieces
- 540 + blower engines
- WTB BBC 10.2 Tall Deck Dual Plane Intake Manifold
- Gen 6 camshaft belt drive
- ISO azimuth 1000 compass cover
- Search sportmaster or imco -0 case no internal
- BBC Hydraulic roller cam
- #6 5 blade
- Bravo flywheel engine housing and coupler
- WTB: Aluminum Swim Platform
- WTB Isotta Carlotta Orange wheel
- ISO Bravo XR Upper Gears
- -2 sport master case
- Mercuriser 525 SC Intakes.
- Wtb 502 heads
- Iso: 17.5 x 35 x 18*
- 2 Pair CMI Gen X headers for 525/600/700
- Work Overalls Mercury
- power steering pump
- BBC parts
- Headers BBC
- ITS Drive Line
- Looking for fuel reservoir 96/97 Volvo penta 5.0
- ISO: Letham Spacer
- Tempest Plus 23P RH
- 07 or newer 353 Fastech 525 EFi
- Pin cleats wanted
- ISO a low hour used Mercury 350 or 400
- WTB 2 complete 500efi harnesses and ecms
- looking for
- SSM #3 drive
- Looking for trailer
- looking for 20 cigarette
- Bolster Seats
- looking for front of BBC - Alt, brackets, water pump...
- Furuno DFF1-UHD
- Eco Enertia 16x17.5 pitch
- WTB: supercharger for Mercury 500efi
- Oil Cooler Brackets
- Sea pump
- Origo 6000 Oven Stove
- 5 blade props for Bravo XR
- Looking for Latham steering end cap for Bravo
- 174 or 250 Supercharger
- bushings for speedmaster
- trim pump
- Racing intercom system
- WTB: used 35-40' Trailer
- Bulkheads
- 5.7 B III TBI ecm
- WTB: Velvet 72L-HP Drive
- #6 PROP needed 17.5 X 38 6 blade 18° Rake
- 2 stage sea pump
- 36 Spectre cat
- Wanted 575sci blower parts
- Front Vertical drive shaft 3a or 5
- Want to buy! Quad Bracket!!
- Pitch Gauge
- Windshield 34 sorcerer
- 250+ Mercury Outboards (Twins)
- WTB 1986 Formula 242 LS Windshield
- Bravo 1 26 Left Hand
- Looking for large props cleavers #6 #8 herring or mercury
- b&m 250/420 blower manifold
- WTB Hydromotive 4 Blade 26p pair.
- used Mercury #6 standard length studs and oil tube
- Bravo 1, 4 blade, 24 pitch, RH
- Looking for dual carb flame arrestor
- 188 and 990 head
- Trade -2 IMCO SCX for -2 IMCO SC
- ssm 3A
- Offshore solid engine mount for single
- stainless marine
- Wanted 454 magnum
- Gil Tall Risers for HP500
- SCX lower trade for -2 SC Lower
- mcleod bolster seats
- ISO Mercury HD transom assembly
- WTB: 454 / 502 MPI Lower intake manifold
- WTB #6 Prop Shafts
- Hydromotive P5X
- Bravo sport master.
- WTB: 4 Blade RH 28P Bravo 1 prop
- Pair 5/6 blade, 17.5-18, 21 or bigger rake, any pitch
- CMI Headers
- Looking for prop cover
- Gil Exhaust Manifolds
- Crane gold 1.7 rockers
- Scx
- Mercruiser Thunderbolt IV ignition V8-HP needed
- 1 or 2 Comp 1320 roller rocker
- ISO mefi3 16237009 ECM's
- ISO CMI Headers
- WTB good mercury racing 525 heads
- used SSM #5 prop shafts
- gimbals speedmaster
- 2 sets of CMI headers
- wtb 21-24 baja 22 pachanga 206 or 223 formula
- Hydromotive Quad IV
- Spacers
- WTB: gm block 10243880 2 bolt main block
- 19 to 26 spline propshaft adaptors
- ISO Full Hydraulic steering
- ITS Transom
- WTB: B&M 250 blower pulleys
- Hydromotive Q-IV props 27 or 28
- Left hand shifter
- trade -2 for std length imco
- WTB 210 Boston Whaler Ventura
- Scx
