View Full Version : Wanted
- Twin Disc MG502 trans
- Spacer
- top Light Scarab29
- WTB- one 454 Mag (forged) STD bore piston PN 3999295
- 525sc factory blower complete setup WANTED
- WTB Shore power breaker panel
- WTB!!!!! -2 iMCO LOWER 1.50 RATIO
- -3 shorty wanted.
- Imco standard lower case -1 vertical shaft
- Looking for a stellings box for bravo ....help
- looking for fire bottle set up, halon
- Corsa Diverters
- Stellings extension box
- shop trailer
- Hp transom
- Engine lifting eye's
- 7/8 steering wheel adapter
- Need 502 short block !
- ISO 525EFI cam or crane 741 Gen6 BBC
- Whipple Low Profile Innercooler for 871 to 1471
- McLeod BolsterSeat Parts or Arches
- Looking for a #6 boat or project boat.
- Sea pump pulley v belt
- Cigarette Gladiator Trailer
- Looking for the plain old 502 MPI plasitic flame arrestors. Anyone have a pair? Thx
- 2 wire trim pump
- Hp 500 carb air cleaners
- Crane 741 or 500EFI Cams
- WTB Need Crank and pistons 454
- SSM IIIA- V Gimbal housing/Bell Housing Needed
- 502 gen 5-6 block
- Livorsi GPS 3 3/8
- 731, 741, or 525 efi cam
- 26p Bravo 1 and 25p P5x both RH
- ISO a pair of XR upper gears
- 350 Exhaust
- 1.5 Lower gears for XR
- ISO good steel splined bravo coupler
- Sea pump bracket
- Myco trailer for a 42 Fountain, preferably a dually. Have 38,42,47 trailers to trade
- s c x
- Livorsi Gauge Wanted (Oil Temp)
- WTB: 454 MAG Performance Manifold/Risers
- Looking for external steering ram hardware Latham
- Looking for 98 Outlaw 36 dash plates
- Looking for used Isotta Carlotta wheel
- Looking for High Back Sit Down Style Buckets
- Latham ram
- 2 540-572 short blocks
- 4" Exhaust Tips
- 2 HP couplers needed
- WTB Bravo 4 blade 26p prop
- Mercury racing or Hardin AL front offshore mount
- WTB Merc 525 efi carbon fiber coolant res. cover
- looking for XR lower for my bravo one
- Crossover block off plates
- Dominator Flame Arrestor
- looking for a 26 corsa / martini or anything close up to 30 ft
- Gaffrig 4 5/8 speedo
- 525 efi camshaft
- Wanted a set of sea pump fuel pump combos to fit 500efi's
- WTB IMCO -3 Lower and Vertical Shaft
- WANTED: Windshield Formula 292 SR1
- Need 2 cross over kits for B.B.
- Whipple hp 500efi
- single offshore plate
- Looking for a nice 26P RH rotation prop
- BBC stud girdles
- 1250 dominators
- Ssm3 props wanted
- shop trailer
- In search of 177 intercooler
- Cigarette Top Gun 38 parts
- 42 fountain big step project
- #6 Driveline transom assy.
- B&M 250 blower
- Superchiller for B&M 420
- Two sets of headers and tails needed
- Looking for 1 standard length sport master lower and also looking for 2 -2 sportmaste
- Looking 2 imco gimbal rings no junk
- Pair of boost referenced 1050's
- ECU and coil mount 600SCI
- Pair of 454's wanted
- Looking for M-1 Procharger for BBC EFI
- Gen 5/6 sea pump with fuel pump provision
- Iso aeromotive a1000 fuel pumps x2, 502 stock cam, fuel regulators
- cannon plug brackets
- 5 blade maximus
- Weiand 177 intake manifolds (2) BBC
- Staggered #6 headers
- Maximus 34P wanted
- 525efi or possibly pair of 741 cams wanted
- WTB Cmi or aftermarket exhaust for bbc
- 120 MPH Monster Speedos
- Need power steering pump from 330 trs going to put on 81 scarab.
- Engine hatches
- merc vengeance prop
- Engine hatch
- 500 or 525 EFI Cam
- Trim indicators,guages.
- WTB Bravo Clutchs and shift fork
- looking for a bumpy stick....
- Search 525 Tailpipe with silent chose
- WTB - Engine Hatch
- Baja Outlaw Hull Wanted
- 502 blocks
- gen 6 bbc timing chain cover
- Looking for a pair of 24p hydromotive Quad IV-X
- Wanted.. Mercruiser 496 HO ECM
- Wanted 496HO
- Search Tailpipes for 525 EFI
- Wanted 525 computer
- wtb pair mercruiser 350mag mpi or 6,2mag mpi
- Lower Drive Shaft (-2)
- WTB 525 EFI Closed Loop Cooling System for 500 EFI
- BBC valve covers
- WTB: mercury SSM outdrive trim pumps
- v drive oil pan for gen5/6.
- PSI B or D blower wanted
- Throttle control switches
- Stock 502 Thermostat housing
- Wtb 525 efi parts & accessories
- WTB 380 mercury k plane trim tab
- Wtb 12" or bigger chartplotter
- Looking for Project Hull
- imco extension box
- 525 efi valve covers
- WTB 1150 Dominator Carb
- remote PS resevoir
- 27'-29' high performance boat
- wanted engines,apache 41
- Gil dry tails
- mercruiser xr internals
- Stellings Tails
- Wtb: Gaffrig 270* sweep trim gauge
- Cyclone Shorty Header
- Blackhawk drive
- 496 block needed
- mercury carb engine wiring harness
- Mg502
- Looking for a pair of HP500 Valve covers
- Full hydraulic steering dual ram bravo set up
- Corsa diverter solenoid mounting parts.
- Eickert Tails
- Cafe cabin door
- Thunder bolt V-6 34 module
- any thing midnight express inc. - mxj looking to buy
- WTB Acc brackets wiring harness oil adaptor
- Mercriuser 496 HO ECM.
- Small piece of Corinthian riviera red carpet
- wtb Whipple stage 1 intercooler for the PORT-INJECTED BIG BLOCK MANIFOLD
- WTB Whipple Moac intercooler
- Looking for 500efi cams and a set of 30p bravo or hydromotive props
- Mercruiser 8.2L Mag EC exhaust manifolds and collectors
- WTB 1.35 or 1. 24 gears for # 6 Drives
- HP500 intake manifold
- HP 500 valve covers
- MEFI 1 starting harness
- Gen V 502 standard deck
- need two bravo hp gimble assemblies
- Front motor mount
- Dual carb plates for 250 blower
- HP 500 air cleaners
- 502 motor
- Motors
- Stepped hull boat without power 42-47 Fountain, Outermits, Top gun
- WTB - Morse Steering Cable - Command 2
- 43 Nortech tailpipes
- want to buy 3 man bolster with drop down seats
- Need engine hatch vents for 43 Scarab AVS
- Need trailer for 43 Scarab
- Steering cap bravo std back dual ram single
- Used 16K lb. Hydrohoist
- Mooneyham 10-71 and mooneyham 10-71 td intake manifold ...
- Transmission cooler plate
- Imco AEC-5 Steering cap
- Wtb Intercooler for PSI supercharger
- Wtb... billet oval flame arrestor for dominator carb
- Looking for a pair of large skeg ASD8 thrust tubes.
- WTB, 26 spline SSMIV shaft
- Single gauge set Livorsi, Gaffrig.Auto meter
- Project wanted
- WTB - Diverters
- LH 28 Bravo (Stock) Propeller Needed
- 525 power steering pulley
- Oil pan Gen 5/6 10-14 qt.
- Dual water pickup/DWP bravo case
- Latham twin throttles with two switches
- Wanted Gaffrig Depth Sounder
- 1991 formula 292 sr-1 engine hatch needed
- 24/7
- WTB - pair of damaged 26 spline speed master prop shafts
- WTB 26 or 28 OB cleaver
- 5 blade no.6 shaft props
- 454 needed!
- Spark advance module wanted...
- bbc alumheads, 950-1050cfm carb
- Wtb intercooler
- Manifolds and risers wanted
- MercTrans ll for parts
- Looking for a cheap stock gen4 454??anything anyone?
- WTB 28' skater
- Hair Dryer for the roo
- WTB Nose Cone 711 HC-OMCD
- 8 Qt Gen VI Oil Pan
- Throttle lever
- Dual carbs (4) for twin 250 blowers
- Engine hatch lifts
- Looking for a pair of 420's
- 1981 Scarab S Type parts needed. Port teak locker door.
- 525 efi service manual
- Wanted: Pair of hp 500's / 525 sc carb motors
- Props
- Misc pieces to buy or trade
- ISO- ITS Gimbal/ Transom Assembly in need of rebuild
- Gil dry tails
- WANTED - Bimini Top/Enclosure for Sonic 31 SS
- WTB 250 B&M Blower
- 1-26 or labed 27 4 blade hydoes
- IMCO -1 Lower case
- Blower / Supercharger
- Sea water pump pulley
- MERCRUISER 502 thrttle linkage
- Merc ignition module
- Looking for a 26pitch 4 blade
- Wtb cmi tails for bravo application
- wanted 2 whipple intakes with intercoolers
- Wanted Hydromotive 28 P5
- MAXIMUS 34p
- WTB Bravo Prop Shaft (Horizontal)
- inner steering system needed
- Blower shop 871
- service manual
- LH Prop 34- 38 pitch ,5 or 6 blade, 26 tooth spline # 6 drive
- Wtb pair of bravo 1 drives
- Props SSM 17" x 32 Pitch
- WTB Merc. water pressure relief valve.
- 91 Scarab 38 Excel
- EMI big thunder
- Wanted Mercruiser Blackhawk drive
- bravo sea water pump with fuel pump opening
- looking for HP525efi 2. generation 0M956>
- Bravo 3 props
- 29 Fountain No Power
- Speedmaster SSM IV Parts
- V6 Modules
- looking for streeing helm
