View Full Version : Wanted
- 496 piston/rods
- Need a 26P Labbed Bravo 1 Set or Equivalent for XR Drives
- ISO Ignition and wire harness bracket # 8164703
- WTB- Rayjay/ Gale Banks / M&W turbo systems
- WTB- TRS wing plates
- 3 slot indicator panel
- Looking to swap XR drives
- ISO Steering Parts
- dual cooler bellhousings.
- WTB 10” SSM extension box
- ISO Gauges
- Stainless Marine Bravo thru transom tailpipes
- Bravo 2 Prop
- Iso good HP coupler
- WTB: Sportmaster -2 Lower
- Engine hatch scoops/intake vents for Scarab
- Mercury Vessel View
- Wanted: Water Outlet Dividers
- Bravo drives 1.50 and more
- Need a good lower MerCruiser Tr case
- Arneson ASD #8 Surface Drives !!
- X-power outdrive
- Thermostate housing
- Raylar 496 parts
- WTB 2 Procharger or whipple kits for 454 mag Mpis
- 4" Angle Cut Exhaust Tips
- 5.8 Volvo penta lower intake
- Bravo 1 Prop, 24P
- huber trans
- wtb 10 qt + gen 5/6 oil pan
- Mercury Cleaver Wanted
- oil thermostat
- Tubular swim platform for a 98 Baja 24 Outlaw
- Bravo 1 rear / back caps stocm
- ext boxes
- WTB Weldon DB2025-A Fuel Pumps
- 525SC Mercury fuel line to fit 4500 Holley
- Gen 6 502 motor
- WTB Imco TB-34 triangle steering bracket
- Ltb Aluminum fuel saddle tanks
- Wtb Aluminum saddle tanks
- IMCO steering arms
- SSMii
- IMCO inner transom plate
- I want a kit like the photo
- exhaust bbc
- wtb,sea strainer
- WTB ITS transom assembly
- WTB 12’ of Rub Rail for a 99 32’ Fountain
- WTB Mercruiser HD Offshore Front Motor Mount Plates
- WTB: Headers & External Hydraulic Steering
- Bravo Tools ....
- 454 Block
- ISO New style Spargi Baja steering wheel
- Wtb stelling ex box side cover
- WTB Edelbrock 7562, throttle brackets, oil thermostat, crane fireball hi-6m & other
- power steering pump
- Tall deck intake and 4150 flame aresstor
- power steering reservoir
- 4 blower carbs
- Flame arrestor
- 850 cfm marine carb
- ISO XR ITS Top Ca & XR ITS U-Joint Assembly/Shaft
- PROPS!!! ISO 3 or a Set of 22p Brovos 1s or 23 Rev 4s. ASAP.
- Wanted - P-5X Props - 31-32 pitch - Who's got a set to sell?
- 1 set SM Hi-Torque manifolds
- WTB headers
- Looking for mercury pcm 555 manual for 496 engine
- wanted: 2 drives
- Wanted: Mirage 29P Props
- 500 efi damper
- XR vertical shaft -2 shorty Wanted
- Eickert dual cooler bell housings
- Iso mds marine 6m
- Looking to buy Blower 2 Complete
- Looking for 454/502 side whipple crank pulley (v-belt)
- Mechanical fuel pumps needed
- Flat Deck 38' Scarab Radar Arch
- WTB Bravo 1 Lower
- Garmin 5212
- WTB: Bravo 3 Lower
- Need Gimble Gasket SSM III
- Imco -3’s
- WTB Trailer for 26ft Boat
- WTB Full gauge set for twins
- Oval Flame arrestor
- Look for Imco SC or Sportmaster Lower Housing!housin
- Buy trade sell
- WTB 575sci Wiring Harness
- WTB Mercury ECM 555
- huber
- Iso labbed 25 mirage plus or 24 bravo i
- need a camshaft for my 540
- Kaama hydraulic steering rams
- Bravo prop and lower
- WTB: Pair of 150-200 4 stroke outboards 25"
- WTB: $$$$ Set of good “used” CMI 496 E stock headers.
- Front and rear TRS pivot pin
- Wtb bravo 1/2” drive spacers
- -1 Vertical Shaft
- #6
- Gen 6 hyd. roller cam
- 454 engine wanted
- Donzi 28 sportsman wanted
- 2 stage sea pumps
- Bbc
- WTB OEM 600SCI Supercharger Pulley
- 38' cover
- Gil risers
- Need one of this...thing
- 525 EFI, PCM wanted
- Wanted
- bbc super chiller
- 525 efi steer reservoir
- Port side 525efi header
- Bravo or MAximus
- SSM IIIA drives
- 741 or 731 camshaft
- Kenwood Head Unit
- 2-ASD-7 wanted
- 525 CMI Bravo tails
- ALL MPI / EFI Wiring Harnesses WANTED
- ISO 28P Bravo 1 RH
- Mercury Blackhawk Drive
- Looking for a good set of 088 or 990 GM big Block heads
- I need a complete power steering pump.
- IMCO Lower Splash Plates
- 4'' exhaust turndowns
- Mercury Vesselview suncover needed
- Full 35 Fountain boat cover
- SM gen3 risers
- Gil DRY TAILS
- wanted one bolster seat
- X-Haust Muffler Mercruiser
- Full hydraulic steering trs drives
- Imcon sc lowers
- Scx upper wtb.
- Need a imco 01-3549 extended input shaft 1.218 bearing cap dia ASAP
- WTB: 34P 4 blade Hering Prop Set
- WTB MAXIMUS 26p lt and rt
- looking for Q-IV or P-5 props
- Looking for the Merc Extension ITS Cover
- Looking for props
- Looking for props
- WTB Fastech Rear Ladder Cover...
- Exhaust Needed
- Looking for a 502 Long Block-TX
- Looking for 1996 Crownline 225ccr canvas!!!!
- Beware: Alpha SS scam
- WTB Old cleaver. Cracked ok. Any size ok
- Looking for drive showers
- Mercury Maximus Propeller needed.
- Wanted #5 drive
- SSM 6 Transom Jig
- 525 sc intake manifold
- WTB Exhaust Manifolds w/ +3" Risers
- Bravo tie bar
- Race canopy
- Merc Racing 600 SC super charger pulleys - Top
- Steering pump cap 1/4" fitting
- WTB: 30P Bravo 1 Props
- CMI tails for 525 EFI
- Merc 496 Manifolds & Risers
- Need 454+ Rotating assembly
- WTB Bravo One 27/32 Thin Floor Gears
- Engine Hatch Hinges
- Tie Bar Nuts
- (Wanted) GruffTuff Box Anchor
- Wanted bravo 1 upper (donation needed)
- imco sc spacer
- Fountain front deck hatch
- WTB pair of bravo drive showers
- Looking for recessed cleats
- Smart craft sc 5000
- Looking for Diacom Rinda Mefi 5 trouble shooting software error codes
- WTB 28p bravo 1 4 blade RH
- Diacom software
- Sbc aluminum exhaust manifolds
- WTB: Pair 28-30p Big Ear Chopper Props
- Seal kit Merctrans 11
- ISO TRS Trim Cylinders
- WTB Hydromotive P5x RH 24-26 Pitch
- 496 Mag 375HP Camshaft
- Raylar 496 parts
- XR lower driven gear from upper gear set
- 350 MAG MPI engine
- Thermostat housing
- 272 Baja Cockpit Cover
- Need 1 single engine V front mount plate
- WTB #6 prop 32-35" R18
- In search of a ECM16237009
- WTB Crane 731 cam(s) and edelbrock 7562 air gap performer dual plane rec port
- Looking for Scarab 33 AVS carpet, cover, manuals, etc...
- 7.4 mpi
- Cmi headers
- ISO: Mercury Racing 377 Scorpion Motors
- WTB 25p or 27p mirage plus RH
- IMCO SCX4 Upper
- IMCO SC Lower
- Magnum Life line stanchions
- Wtb 30 pitch labbed lh bravo
- Mercury 575 intake manifold
- One XR upper gear
- 454 mag EFi heads 088's
- 8" Latham rams
- Bennett ST16 Tabs & Hinges
- Set of bravo 30p 4 blades
- Wanted: Trailer for a Formula 400SS
- 19 spline props
- Need Guage Pods 2 1/16" and 3 3/8"
- WTB 19 to 26 SPLINE ADAPTER
- Need 21 p mirage prop
- Reservior
- Set of Bravo 22 pitch
- #4 speedmaster gimble housing
- Props for TRS 23 or 24"s
- WTB XR finned top cap
- WTB Imco entended drive shaft
- Looking for diverter bar for silent choice
- XZ upper grear set
- WTB service/repair manuals for...
- Wanted vdo tach older style
- HP6 remote filter mount
- ISO - Military Style Trim Switches
- Bell housing chevy 454
- Land and Sea Torque shift prop
- Need bravo xr , xz or x upper.
- Wanted 23P RH Mirage Plus
- WTB- Formula Bolsters
- 454 mag Vst
- Wanted 25p mirage prop
- pair of 350 great shape only
- 2000 500 EFI brackets and pulleys
- Need an xr upper
- Blower 1071 through 1471 Or whipple a pair
- Mayfair wing plate
- 496HO Camshaft
- Looking for 2 sets of 4”/3.5” 316L tails
- Bam or Huber 11 plate Transmission
- 525alum head
- Power steering pump cap
- Bare hull or project boat
- ISO TRS Mercruiser Transmission
- Need two shifter brackets for 72C trans
- looking for two hp Gimbles and bell housings
- 454 Mag
- Pair of 454 (7.4 Mercruiser) 330HP Engines
- water inlet (black)
- Alpha SS wanted.
