View Full Version : Wanted
- 5 Blade prop
- Wanted Myco trailer for 38 Scarab
- Rinda #94020 adapter
- Gaffrig GPS Antenna
- tunnel tab
- B&M 420 mega blower parts
- WANTED: Full Boat cover for 32' Fountain
- Lightning headers or something similar wanted
- ISO K-plane 380
- Controls
- Looking for a set Valve covers Hawk power
- ISO the wing plate pictures for ssmII driveshaft app
- HP500 oil pan
- Hyd helm
- 4.25 crankshaft WTB
- Wanted 850 double pumper
- Wanted: B&M 250 intakes. Bbc standard deck
- 250 or 420 blowers
- Wanted 26P Bravo1 4 blade Prop
- ISO Rinda #94006 Diagnostic Adapter
- Wanted 502 block
- Wanted OMC 4.3L Block and exhaust manifolds
- Gaffrig II OR Livorsi II white oil temperature gauge
- Single Hydraulic Steering Ram & Transom mount
- DDT Scanner wanted
- ITS inner transom plate
- WTB BB chevy crankshaft 4.25 502 gen 5/6 only. new or used
- Wtb exhaust manifolds
- pair 28 maximus
- 500EFI accessories or complete non running motor
- BRAVO XR 32" PROPS 5 BLADES LH and RH Props NEEDED
- Need a 1998 22zx engine cover or ideas
- WTB: AFR 305CC Heads for BBC 502
- weiand
- 280 380 trim tabs new style rams
- Ssm 3a
- #6 tie bar mounts wet sump 6
- WTB 3 drive showers!
- latham wing back cap for bravo
- MK iv 454 block
- Wanted - CMI Bravo Tails
- Hydromotive QIV 26 LEFT HAND with 1.25 shaft (or interchangeable hub)
- Stellings extensionboxes wanted
- Cigarette grab handles
- wanted 2 sets 496 exhaust manifolds
- short deck blower intake 10-71
- throttle& shifter
- 4.50 Bore BBC Pistons - 10.5:1
- Looking for 2 Std length XR lowers with 1.36 gears. No salt water.
- Wanted bravo drives
- Wanted: 250/420 b&m blower intake manifold
- Wanted Hydrohoist Boat Lift - 2005 Formula 400ss (20k lb capacity)
- Livorsi triple gauge warning system GW3GS
- throttles 4 twins
- resevoir
- #6 tie bar
- WTB Shorty Lower Bravo -2 or -3
- JL speakers
- Gauges
- #6 or Arneson prop needed
- K planes
- wanted 1970 to 1972 elcamino
- Need 9/10" stroke steering rams
- stock bravo 1 propshaft
- WTB - IMCO neutral standoff box
- COMPLETE 502 MPI or 525 EFI
- Gaffrig 4523 White GPS Speedometer 3 3/8" 90 mph
- Shifter/throttle for single engine wanted
- Throttle/shifter wanted for single engine boat
- Gil wet risers for trs
- Wtb hp 500 efi whipple
- Single Engine Throttle/Shifter
- U-cool oil coolers?
- Dana marine 02 censor plates
- Dry risers to the tip that will fit my Dana marine flow torque manifolds.
- 23' Hull With/ Withuot trailer
- HP500 whipple setup
- Dart BBC Heads
- Mercury Smartcraft
- 525EFI bellhousing
- Hp bravo coupler
- Windshield
- (2) XR upper cases
- Ssmii
- Wanted Whipple 3.0 Liter Center Mount
- Sea pump with fuel pump
- Weldon 1100a fuel pumps
- Imco power flow exhaust manifold upstate ny
- Looking for a 350 for my friends boat, motor is toast
- gen6 454 or 502 mpi cams.
- Intercooler for "b&m 174"
- 525 headers needed
- Wtb: Hardin marine extreme or 2 piece valve covers bbc
- Red Turn Downs
- 731 741 cam
- Compass
- Closed Cooling for 2 BBC
- WTB sbc exhaust
- WTB sea strainers
- full cover 33'-35'
- WTB hatch
- Engine Wire Harness
- 502 EFi lower intakes
- wanted 25p mirage props left and right.
- Gimbal housing
- Hatch Lift Actuator
- b&m blower intake wanted. Bbc 420 blower
- Gen III stainless marine manifolds
- 2 1 inch bravo prop hubs
- 7.4l 454 and outdrive
- Hydromotive QIV 27 or 28, looking for LH but may buy pair. P5 26 or 27 may work also
- HP 500 carb reasonable
- Project
- Bravo mechanical drive indicator actuator needed
- Edelbrock Victor Jr 2902 and 850 carb
- Bravo 1 low water pick up muff
- LH 25p Hydromotive Q4
- complete 500 or 525 EFI intakes
- 1989 quicksilver throttle handle
- bin files
- bbc heads
- Wanted IMCO Uppers
- Looking for water pick up
- I need two sets of CMI E-top headers for a 454 mag set up
- Side exit exhaust tips
- Interior for Formula 242 LS
- looking for JE700 Mark IV 502 pistons
- RH Rev 4 23 P or Bravo 1 24P
- Billet trim switch!!!!!!
- Maximus 32p 15 5/8
- Need a Garmin GSD 22
- 525 EFI Cam
- White, Red or Chrome Twin throttles and shifters
- bravo driveline bearing assemblys
- 525 Supercharger SC Blower
- need a working pcm or euc as some call it for 496 mag ho
- WTB: A lot of stuff, Outdrive,Transom,gimble,steering etc.
- 2 imco -2 lowers
- 61 or 62 8 MM blower pulleys
- WTB: Boat lift
- Sbc exhaust 2 sets
- wanted drive couplers and bellhousings
- Gm small block whipplecharger system - carburated
- efi intake
- Serpentine belt accessory drive bracket set
- Looking for a project boat...
- Skater cover 32b
- Stock Bravo I 4 blade LH 26p prop
- 3.3 EFI quad whipple
- Power steering hose
- wanted 1983 formua fs-3 ls seat
- Shortys'
- Exhaust or headers.
- cover
- 502 mpi magnum supercharger
- external steering system
- WANTED MEFI 3 wire harness
- Swim Platform for 1995 Baja 32 Caliber
- Need a head
- smallblock manifolds/risers
- offshore mount setup bbc
- Wanted pair of hydromotive 27 5 blades p5 or p5x or 26 maximus 5 blade
- Looking for Pair of fresh 454s or 502s
- Wtb small block oil pan
- Intake manifolds wanted for 454/502 Merc # 861300A-2
- Headers wanted
- WTB: K-19 hynautic steering ram
- M1 Stock cam
- ISO 28p bravo one RH prop
- Imco SCX , SC and GIL manifolds
- Latham steering wing plate/ cylinder mount for bravo needed
- Bravo X lower
- HP500 (carbed) valve covers
- External steering cylinders
- 502 mag mpi roller cam
- Looking for a hull preferably rigged.
- Pro charger
- WTB 454 rectangle port heads
- Volvo sx drive
- GM 454 Mag pistons. 3999295
- Wanted: Bravo drive shower, 454 Mag Spark arrestor, Tune up kit, impeller
- Wanted Bam Dry Sump Super Cyborg transmissions
- Need a stock aluminum intake 365/385/420 set up
- big block harness
- 38Ft trailer
- 2x Bravo Rear Caps
- 5.7 engine harness
- Mechanical fuel pumps
- drop down Bolsters
- bolster seats
- looking for a pair of 29 6 blade props right and left hand for 1 1/4" prop shaft.
- Freshwater cooling kit BBC
- Pair of 18x32 or 33 pitch 5 blades...
- Bravo1 nosecone
- CMI sporttubes or GEN-X headers
- Need 575 sci computer (6999)
- Exhaust manifolds
- TRS Wingplate - dual cylinder version
- WANTED 30ft Catamaran Trailer for Awesome Cat / American Offshore Chris Cat Shadow
- Need 502 / 500hp
- I NEED A GEN 4 block with 4 bolt main
- gen 5 water pump pulley
- 26--30 ft boat with out power and single engine setup what's out there?
- Looking for ONE stand off box
- Crossover thermostat housing
- Archor locker door
- imco -2 shortie housing
- Wanted: 1.5 bravo lower WITH low water pickup
- 6 blade prop. 28 or 29 pitch
- V6 module and thunderbolt 4 dist. bbc
- WTB: Good clean 496 Mag HO
- Pair 28 hydro p5x
- Want Alpha One gimbal bearing puller, installer, and alignment tool. Paging whoya
- Motor wanted
- Wanted 7.4 MPI engine covers.
- Weiand blower intake
- 26p left and right hand props.
- need tie bar alpha 1
- Need Rh & Lh Bravo 1 props 24P
- 525SC parts
- Boxes for #5 drives
- This is a long shot, but looking for LSX Swap Parts
- Bravo coupler lower to upper
- need a set of bravo I 22 pitch props
- 502 MPI Accessory Bracket
- Looking for Mirage Plus 23p or 25p RH
- ISO mirage plus 3 blade 23p 14 5/8 diameter
- Swim step platform
- Windshield glass for 85 242 LS
- Grab Handle
- Wanted: Large gps speedo w/ white background
- Cheap performance manifold
- Anyone have a complete external hydraulic steering set up for sale?
- gauges
- Carling Breakers
- LH stern lifting prop, 5 blade preferred 26 to 30 pitch
- 12volt engine hatch actuator/lift
- OSO !!! 2006 250HP 4 stroke Yamaha Power Head
- Formula 242 Silent Thunder Platform/Swim Ladder
- Used bravo 1 drive
- Looking for a set of racing seats for my race boat. Old skater seats
- 6" accon pop up cleats needed
- HP 500 flame arresters
- Looking for Mirage plus 23p
- Flo-torq solid hub kit
- Looking for a BBC Crossover & Housing
- Wtb: Bbc heads
- Wtb IMCO Extreme SCR Drives
- Gen 6 Block
