View Full Version : Wanted
- Pair of 25" or longer driveshafts....
- Bravo service manual #28
- 2 inch shotie
- WTB Merc 3 blade cleaver RH 14.5x32 or 34P
- crossovers
- ISO of 500EFI ECM Stock
- BABB speakers/covers?
- need a 454 mag mk4 piston-rod. even number cyl bank. std bore
- Engine mount race style
- Needed Cmi bravo tails
- Wanted: valve covers to clear stud girdles AND exhaust.
- cyclone headers
- 454 502 Sea Pump Bracket for Serpentine Belt Drive
- Dominator 1050, emi, gil, imco manifolds
- bimini for formula 353
- Trailer borrow or buy near LOTO
- WTB - Box Anchor
- 29 kryptonite
- 2 tall deck blocks and 2 stroker cranks
- Two 540 rotating assemblies (standard deck)
- Distributor
- GPS speed-o
- Swim platform - top gun
- two 420 B&m super chillers
- 502 merc mag camshaft -- take out
- Wanted Holley 9022 800 cfm carb
- Bravo lower case needed.
- emi exhaust
- aluminum Skater trailer
- BBC b&m 420 intake std.deck
- Need a Merc 3 blade Cleaver 14.5x32 or 34P RH
- 525efi Computer/ ECM
- wanted bravo 1 sea water pump with fuel pump
- 2009 Fountain 42 cockpit cover
- Gen 6 502
- Needed: XR finned top cap
- looking for two engine wire harness with brackets
- cat project or 32 to 42 v project
- 34 pitch Maximus props 5 blade
- Wanting to buy red baja steering wheel.
- Iso bravo props
- Wanted high back bucket seats, Skater, Spectre, D Wright style
- Shotguns
- WTB NICE Bravo 1 X Drives - Need a Pair
- Big tube headers for bravo set up
- Help!
- CMI big tube strait back headers
- Wanted trim ring
- 088 head
- Looking for the person who bought the 99 American offshore listed on OSO this morning
- Need props
- Whipple for 525 EFI
- Looking for BBC IMCO or EMI exhaust
- Gimbal Ring
- WANTED~ Clean trailer for a 28 Skater
- WTB: Triple Axle Trailer for 1998 Fountin 35 Lightning
- wtb ss silent choice risers
- super chillers. need 2 B&m 420 chillers
- 500 EFI or 502 MPI wiring
- Gil tail pipe wedges.
- galvanized tandem axle trailer
- WTB 1.5 ratio B1 lower with LWP
- Marine Machine Steer Cylinder Parts
- Big block headers
- Looking for early gen 5 oil lines
- CMI BBC Header Stainless distribution Tubes
- ISO Bravo 1 4x28
- Gil style oil pan
- Wanted Engine Brackets
- selectable mufflers
- Looking For Exhaust Pipe
- zero effort cable end
- Merc 575 Sci
- K-plane lower pin for 33C cable connection
- WTB purple Livorsi, Ponza steering wheel.
- 20,000 # trailer for 45 Excalibur
- Weiand 177 Intake
- Twin bravo 1 tie-bar
- looking for headers
- Full Bravo setup-Pair
- Closed cooling SBC
- Trailer for a 35 Fountain
- PAIR of MIRAGE 3 blade 23" pitch Props
- 4" transom exhaust / silencers / mufflers for 85 Scarab III
- HP500 dart intake
- Pair of lightning header for bravo set up
- Looking for Blue Mercury Racing Engine
- WTB Mercury Rev4 23P prop
- 525 valve covers wanted
- Rub rail
- Looking for a swin step ladder for 04 nordic rage
- 300 tempest flame arrestor
- Wanted: Triple axle trailer-1998 fountain 35 lightning_lake of the ozarks area
- Looking for Monster gauges!
- Exhaust Block off plate bravo-alpha transom assy
- Xr lower
- Still looking RIGHTHAND #2
- 2005 36ft nortech! need strait back headers extention pipes
- WTB AFR 357cc CNC Heads
- 500 EFI intakes
- wtb tie bar lifters
- Bravo XR prop shaft cover?
- Thunderbolt module
- Looking for SSM 2 props
- Nortech 36 wet exhaust! im needing dry exhaust
- Merctrans manual/cable shift brackets
- need pr 1" spacers for #6's
- cuddy window Baja 235 force HELP
- Gaffrig white 8k tach
- looking for sea pumps alt ps brackets and 3 groove lower pullys
- Looking for a trim pump.
- WTB - Twin Offshore Mounts
- WANTED ---- Thunderbolt ignition module
- Wanted EMI, Revolution Marine, or Stainless Marine exhaust system
- Wing plates or Lantham bolt on steering mounts
- exhaust risers
- Wanted: Merc Bravo 454 502 raw Sea Water Pump complete assy (PN 46-807151A8)
- need pr 1 1/2" spacers for #6's
- Need boat to go to Lake Placid Florida from Illinois
- 496 Auto-Tension Brackets For Serp
- Cmi elbow tops
- standard bore, 4 bolt 454 mark IV block
- Wtb- mark IV BBC iron rect port heads
- Wanted - Delphi ECM 16237009 MEFI 3
- single stage raw water pump
- Mercury 200 or 225 Optimax 2 Stroke or 200 Verado 4cyl 20" shaft Smartcraft DTS
- Merc 525sc lower pulley
- Looking for sets of either blue or red bezels for a twin setup
- 2 or 4 pressure relief valves/pop off valves/blow off valves
- Trim Switches
- 27p Mirage plus wanted
- fountain white 3 spoke steering wheel
- 25' trailer needed NY
- Looking for a HP500
- swap exhaust on 2005 3600 nortech.
- hose barbs
- Wanted gil offshore exhaust risers
- Wtb - a pair of sea strainers
- WTB 8.1-496 exhaust manifolds
- WTB Small outboard
- WTB 16 rib serp. pulleys & belts for a 420 megablower
- WTB #5SSM extension box's
- Need an SSM 3-5 helmet
- WTB- BBC mark IV rectangular port iron heads
- wanted 1 set gibson mufflers
- Mercury Racing 525efi/ Blown up botttom end or stock in need of rebuild
- ISO 2 bravo transom assembly block off plates
- Team G tall deck intake manifold
- Cmi exhaust with dry tails
- Wanted group 24 battery box for formula
- 4.3 merc
- iso 2 pair of bbc tall vavle covers
- Wanted set of newer style bolster seats
- WTB, a pair of 500EFI, 525EFI, 600sci, 700sci
- 525 EFI Crossover
- looking for bmax uppers or imco scx uppers
- Need pistons... again.
- 28 pitch bravo 1 rh
- 21P stainless prop for Alpha
- 26 Bravo1 4 Blade RH
- WTB: Trailer
- WTB 28' Skater mooring cover
- emi risers
- Bravo One 4 Blade 22P RH
- Arneson 17-20 17-21 asd6 parts.
- BBC Valve Cover Spacers
- WTB set of STELLINGS headers NEED ASAP!!!
- Myco aluminum for 32 Skater
- Bravo drive shower
- Drive Lube Reservoir
- Anyone have 496 aluminum manifolds with risers for sale reasonable ?
- HP 500 (502) Harmonic balancer / damper
- Full cover for a 42 Fountain, I've got a 32 to trade....
- Boat Cover 32 to 36 ft
- Looking for 30p rh Bravo prop
- Shotguns
- Need a set of Cleaver #6 34 x 17 1/4's or 17 1/2's - or even 35's - same dia.
- ISO trailer
- Looking for motor and/or drive
- Looking For some Reliable Big Power
- 049 or 781
- top mount starters
- Looking to buy 22-24' older boat.
- WTB Used/New EMI Long tube standard Riser
- 1 pair of BBC solid roller lifters
- WTB Imco 1" spacer for -2 imco spacer # 01-8101
- WTB: HP500 remote filter block with thermostat
- WTB: Sea Strainers, a matched pair
- Livorsi Antenna
- Stellings downturn "Gray" headers
- Bravo 3 lower unit tools
- BB Oil pan gen 5/6 stock
- Fireboy-Xintex
- T-Stat housing
- 2 xr lower cases lwp only
- Cmi tailpipes
- WTB- IMCO 300xs Steering parts
- Whipple kit
- Hydromotive P5 31 Pitch Prop
- Wanted Garmin 7608 xsv and GT40 Transducer
- 29 baja outlaw left deck hatch
- 29 outlaw left deck hatch
- Oil thermostat
- Bare 188/990 Heads
- Procharger Blowoff Valve
- Stainless Marine exhaust best pricing??
- Junk Chrysler Iron Blocks
- Wanted parts
- gps speedo
- control cable ends
- WTB 17x38 Hering
- sea strainer
- 575sci thermostat housings
- Looking for a pair of 500 hp's
- gaffring white face gagues
- 427 Tall Deck Intake
- Bravo 1x upper gear set
- Tandem oil cooler
- 454 block
- Twin Bravo Hyd Steering
- Looking for 2 clean bravo shift brackets
- Cmi e top tails needed
- SSM 1" Spacers
- WTB - Myco or Manning trailer for 39 Top Gun
- Blue raw water pump and power steering pump pulley - any conditiin
- Raw water pump bracket
- Merc power steering pump - 525efi 500efi etc
- 1967 427 bbc tripower casting 351 date code L or A
- WTB - Latham Parts
- Flame arrestors
- Rinda- Techmate
- WTB: PowerQuest 280SC
- jesel timing belt setup
- trans coolers
- ISO 800 Holley and or BBC Dart intake oval port and large arrestor
- Ssmii
- 502mpi flame arrestor
- Bravo power steering pump
- Oil Cooler from HP500
- Extended driveshaft for bravo imco set up
- WTB Livorsi data tach
- Desperate for K Planes
- IMCO bravo steering cap
- Bravo transom assembly
- 4" tips with flappers.
- Merc 502 Headers, dry to the tip
- 496 heat exchanger
