View Full Version : Wanted
- v6-14 ignition module
- Wanted: 575 Intake Manifold (New)
- Wanted, Rear Motor Plates, twin V-Bottom
- Latham Steering Cylinder/Ram
- Intercooler cores
- Pro Charger
- Skater 46' Search
- WTB: PAIR of 28P Maximus or 30P Bravos
- CMI Etops Tails Needed
- 380-S Plates only
- Conv Top
- Neutral balance 168 tooth flywheel
- Pair of 496HO's
- Carbon Graphite sheets
- Bravo 28 hydromotives
- motors
- 900 SC CMI Headers
- looking for bravo 1 coupler
- Used battery box
- looking for complete HP500...
- Mercruiser Tool
- Need Stellings Extension boxes
- wanted drop in 454 365 hp motor
- 1" Bravo Spacer needed
- Used labbed 32 bravo 1
- Aftermarket mufflers for 99 Checkmate ZT 280
- Wanted-various Merc Brackets/pulley
- Volvo 5.7's and Duoprop's
- Looking for 502 Block and Heads
- Priority Valve
- input shaft #6
- need spare set of #3 speedmaster props
- Need a manley Piston
- Misc engine parts
- Used single small block motor plate
- Sumped 1550 tranny
- Tall deck intake and roller cam for N/A
- Bravo 1:50
- 35 cafe racer hatch port side
- Mercury K-plane indicator cards????
- Sportmaster spacers
- K Plane Hydraulic Lines
- 23P or 25P Mirage RH - Labbed
- 2001 496 ho mag.
- baja 25 outlaw
- Heavy duty starters needed
- Mercury Labbed Bravo 1 28pitch RH prop
- Muffler tips
- Blue Neopreme Impellers
- Swim Platform Brace for 90Nova ST
- Need CMI e-tops
- Clamp on mufflers 4"
- Looking for a 35',36' motion or spectre
- 2x Roller Package Wanted
- Fuel Pump and Reg support 1000 H.P.
- Hydraulic Ram
- Bravo XR ITS Upper
- Gates blower belt
- Polished BBC intake manifold
- Wanted HP 500 Parts
- Lifting straps ?
- 2 sets 4.5 dia Clamp on Gibson mufflers
- Stock 28P Bravo 1 Props
- crossovers/t-stat housings
- 30p Maximus Wanted
- Good 454 take outs...???
- Exhaust system
- 500 Efi Ecm
- Cruisair Carry-On Air
- Used headers......must be able to fit 34 inch center to center
- wiring harness
- Hyd Steering helm w/tilt
- 16.75 x 35 5 blades for # 6
- 502 parts
- choppers wanted
- 525 valve covers
- 1050 dominators
- Cmi Tailpipes for a 500Efi New or Used in Good Shape
- Looking for a pair of 30" Bravo's - stock
- Looking for dipsticks on trimmpump
- Dry headers for TRS set up.......
- Pair of 28" Bravo's
- trim pump old
- Need 3" stainless gas cap
- Looking to move up- Sell/Trade 26 Velocity
- 496 Exhaust Manifold/Riser Aluminum
- Carb Needed-
- S. Master/Bravo prop hub needed
- Baja windshied
- 24P LH B1 4 Blade
- looking for 525s complete New england
- prochargers
- Need Big Block Chevy Engine Drive Coupler
- TRS trans mount springs
- 300 Opti Steering Needed
- Speedo Needed Asap Gaffrig
- 502 Gen 5 flywheels
- Dominator linkage and fuel lines
- Old K-plane cylinders
- Aluminum Trailer for 30' Cat
- intakes and carbs
- 454...
- Bravo one upper case!!
- Merc Fuel Line
- 4 blade bravo
- Prop ??
- Gil Exhaust Manifolds
- CMI Header for 500efi
- Thermostat housing & crossover
- Starboard side P.S. mount (GM pump)
- looking for a 28-30 pitch
- kiekhaefer trim pump
- 3.0 liter Sportmaster housing
- Looking for 088 Heads
- black hawk wing plate.
- Stellings Black tube headers
- Need Stern Jack shift cable
- Pair of 28 Maximus or 30 Bravos- Excellent Conditions Only
- 510 ci , 650 + HP , 10 hours for sale
- Stainless Marine Risers
- 575SCi blower
- Sea water pump
- Used Marine Machine strainer
- p5x 28 pitch rh/lh
- Trade a 23' LH Mirage for a 25' LH
- New 24P Bravo 1 Labbed RH, Small Shaft
- Kiekhaefer or Livorsi 4 slot indicator
- SSM 3,4,5 Wing plate
- driveshaft flange
- Hatch inserts
- Distributor Housing
- Looking for Oil bleeder tank
- Stainless Marine Gen III Exhaust
- mercury oil tank hose
- fuel injection
- A set of exhuast manifolds for a 2000 7.4 MPI
- 4.25 forged crank
- 2 inch shorty for a Bravo
- Jabsco mount
- Crank Wanted - 4.375 (4 3/8)
- 35' 36' motion-spectre wanted
- Rear Engine Mounts
- #6 wet sump lowers
- gil risers wanted
- Weiand 256 drive pulleys wanted.
- Bravo Tansom Assy
- Bravo spacer kit
- Enderle dual carb linkage stud
- VI Speedmaster Wet Sump Drives
- weiand 256 / 575sci throttle body adapter plate
- gaffrig spedo white
- Tach
- 3 3/8 GPS 120MPH speedo
- looking for matched set of volvo 8.1's - complete
- volvo 5.7 320HP complete
- Wanted Spedo
- Performance sea strainer
- KE 2-pc Valve covers
- matched pair of 34P bavo 1's
- Need a hitch for a 97-03 Ford F-150
- 13 or 15 Boston Whaler, upstate New York
- I need a prop
- imco shaft
- Customer Looking For Boats ''official Tread''
- 7.4 Injectors
- WANTED SET OF BLOWER PULLEYS 48s 3inch
- Carpet Wanted
- Lifeline vests
- External Hydraulic Steering for Bravo
- Wanted Crane HI-6M ignition box
- Want to trade down my 598ci to a Merc 496 complete running or not.
- OK ..this needs to go NOW
- wanted: 2 complete ignition systems w/ limiters
- 1.36 gears
- looking for 1.50:1 gears
- wanted set of stock 525 efi covers
- stainless marine risers
- Looking for IMCO SC with gimbal
- I NEED A HEAD #14097088 Gen V 454
- wtb tall deck intakes........
- silent choice for 500 EFI with headers
- 380S K-Planes
- WANTED Partner in Raceboat
- #6 props needed
- Wanted Hurricane headers big dry tails
- looking for a set of big block exhaust manifolds
- Arneson Props
- Need an Alpha 1 lower complete
- Merlin block
- performance manifolds
- CMI headers
- tall deck block wanted
- Imco
- Wanted power steering oil reservoir
- Quadrajet
- Wanted: Bravo Trim Actuators for Mechanical Indicators
- Valve Cover Emblems
- SSM #3-5 Wing Plates
- Looking for a xl capsule suit
- blocks
- Latham Top Plate for steering XR dive
- 87 Stingray Maxim 1
- Intercoolers needed
- Mercruiser crank pulley
- wiring harness
- WANTED SET HERING 38s 5 BLADE - # 6s
- 1999 to 2003 F250 or F350 or Chev
- Looking for two mech. fuel pumps........
- 28P Bravo 1 4 blade or 27P Mirage Plus 3 blade
- 7.4 Injectors
- Looking for tranny engine mounts for a trs set up......
- I want to down size!!
- Bravo shortie lower case
- Wanted SSM3 transom housing or broken assy
- 222 stinger windsheild
- Anyone an Attwood dealer?
- Bravo rear cap, replaces the hydralic steering cap
- TRS drives??
- 454 Mpi Fuel Injector
- Procharger Mounting Brackets
- Merc IV Module
- angled exhaust tips
- Two Pair 4" Full Time Mufflers
- CMI E-Top Tailpipes (Old style)
- Wanted Bravo 1 or Bravo X complete drive
- Bell housings??
- wanted water relief valves
- I need a 540 with low hours.....
- land and sea stern jack wanted
- Need TRS lower Housings
- 4 Bbl + Intake Manifold 350 Merc
- Wanted: 2 Bravo Extension Boxes
- Imco HD gimal ring and helmet
- Wanted: BLACKHAWK DRIVE
- intakes
- Little motor for little boy
- Bravo I Transom Assembly
- bravo xr lower
- 35 fountain classic full cover
- 30' full cover
- Need 2 Oil temperature guages
- need top gun full cover
- In Need of #6 Props 17 to 18 X 30 to 31 5 blade
- Headsets
- Trim pumps for Bravo XR
- crossovers...
- high flow sea water pumps
- wanted: 427 tall deck block
- Used 454 short block
- 454 big oval ports heads
