View Full Version : Wanted
- WANTED Carrillo 6.385" H-beam BBC rod (split set)
- Looking for 34 pitch labbed bravo prop
- WTB or WTT Low Profile Frame Windshield 27 Fountain
- Triple axle trailer LOTO/STL
- HELP! - NEED MEFI 3 COMPUTER FOR HP500 EFI- Whos got one?
- ISO rh trs
- Fountain Winshield wanted for 1993 35 Lightning
- WTB SSM 3A OUTDRIVE right hand clockwise spin. GIMBLE BELL HOUSING, TRANSOM ASSEMBLY
- Looking for gaffrig/livorsi gauges
- ISO: drop out bolsters
- WTB - 4" Exhaust Tips w/ large flange
- WTB: Hydromotive Quad IV, 22p props
- wtb: hydromotive quad iv props
- WTB 24P Bravo 1 4 blade RH
- WTB SSM Drive Plate
- Wtb 38-42 staggered fountain
- WTB Mercruiser 502 idler puller assembly
- 088 heads
- Wanted low time 525 EFI or 500 EFI
- Imco input shaft for 12" Extension Box 1,328 cup dia
- WTB: 500efi or 525efi throttle body
- WANTED SBC Gentry/Race Aero Twin Turbo water cooled exhaust
- WTB Bravo 1 24p pair rh/lh
- ISO aeromotive regulator
- ssm3a 26 spline props needed
- WTB Crane Cam 741 and Hydraulic lifters to match
- Pair of swept back XR drives
- ISO 1ea ARP SS 12pt 3/8 x 1 1/2 and 1 1/4 #16 thread .
- CMI clamp kit 36190
- ISO: 2 Pair of MKIV BBC rectangular port heads 188
- Need 3 injectors for HP 500EFI - Anybody got some laying around?
- Wanted: Pair of 26p Bravo 1 Props
- Looking for a 25 power play sportdeck (outboard)
- wanted, 19 spline prop shaft SSM any condition
- Donzi classic 'sweet 16' seat cushions!
- Bravo tie bar and saddles
- Wanting to purchase 29' Fountain Fever
- Wanted speedmaster #3 4 blade props 31 pitch 19 spine.
- Wanted Speedmaster #3 drive RH 1.48 ratio
- WANTED : Procharger for 500efi
- I need a single GIL exhaust manifold ASAP!
- ISO Bravo XR 1.50 lower gears
- ISO raw water pump and injectors
- Looking for a 36 cigarette widebody
- Guages
- Guages
- WTB Sportsman -2 Lower
- Wanted:30-35 Foot step hull catamaran with twin bigblocks
- Need 2 intake manifolds for 5.7Mag Gen +
- Decals for #5 drive
- Wtb 30 pitch lh merc labbed bravo and 30 pitch stock rh bravo
- Dominator throttle brackets
- Iso wtb bravo transom cutout template or jig
- ISO: -3 Imco SC complete Drive or -3 Lower with verticle shaft
- Wanted: Teague adjustable water p/u, triple water dump
- Holley 800 CFM carburetors
- fountain bolt on side intake grills
- ISO: 1, 2, or 3 used Merc ITS Transom Assemblies
- 2000 38 Scarab AVS
- WTB 500efi throttle body
- Who Has A Formula 353 Fastech Available...
- WTB Labbed Bravo1 RH 30P
- Bolster seats
- ISO 2 sets CMI dry tails flange seal BBC bravo std height
- WTB- Maximus 34P
- Looking for 2 sets of cmi etop dry pipes for bravo application.
- Looking for a Fountain Fever 27' or 29' or a Sunsation 288
- ISO HP500 Carb Intake
- Wanted, old leaking intercoolers
- Wanted, RH Bravo, 4 blade 30P
- Starboard Side Power Steering Brackets
- WTB - 90* Barbed Fittings
- Xr input / driveshafts
- Looking for 1 stelling box
- mercruiser 420 style finned valve covers
- Maximus or hering 32 /33 pitch
- 380 trim tabs?
- Looking for some 280 Tabs
- ISO 1 Pair MKIV BBC rectangular port heads
- Looking for HD engine coupler
- 454/502 Gen VI Dipstick Tube
- Gaffrig mechanical oil pressure gauges
- B3 30 pitch props
- cigarette mistress / top gun projects for sale ?
- 454/502 MAG stock flame arrestors
- Gen base pan HP500 intake
- ISO bravo 1 28
- WTB: 525EFI Service Manual with Service Bulletins
- valve covers
- 502 reverse rotation camshaft hyd roller
- Mercruiser 496 HO Steering Wanted
- WANTED 496 Mercruiser FLAME ARRESTORS
- WTB - 92-95 wellcraft Nova dash pieces
- 950 Quickfuel
- ISO Stainless Marine manifolds and risers for SBC
- Wanted controls
- Looking for 4.5 clamp on mufflers...anyone???
- Gil Dry risers
- project hulls under 10k....
- Looking for 26 Bravo 1 Prop
- ISO two sets of high preformance heads for HP500 carb motors
- ISO 502 Block
- Donzi Classic 18 or 16/ Sweet 16
- Wanted: Broken/Pitted/Spalled/Worn Bravo XR Upper Gears
- WANTED - set of gauges dual engine
- WTB pair 525EFI or 575SCI
- Looking for bravo xr upper good condition
- Wanted - Dewald 4 blade Cleavers. 15 X 32
- Warning- scanner using OSO
- Wanted 502 gen 6 block
- WTB 15.5 x 34 5 blade Herings
- WANTED 30' Chris Cat race boat
- 540-588 short blocks wanted
- 100mph life jackets, gps/chartplotter,
- offshore mounts
- 16ft Ride Guide steering cables
- Old teleflex blue face water temp 100-240 dots
- Oval Arrestor, Single 4150
- Bell Housing Oil Cooler Covers
- WANTED white isotta carlotta steering wheel
- WANTED white gauges
- Wtb cmi e tops
- WTB Sea Strainer
- Wanted: Cracked 502 block(s)
- wanted: SSMIIIA lowers
- WANTED, Tilt helm for Hyd set up/ Momo Ponza wheel
- 16 rib pulleys / tensioner for 600sc
- Bravo 1 stronger top cap.
- Alpha wing plates
- 19 pitch
- WTB- crower billet rods
- Bravo trim cylinders 98703/98704
- oil pan wanted
- v drive parts
- Wtb 34 cleavers pair
- WANTED WTB sbc chev parts exhaust intake cams rockers
- IMCO Risers
- Need dual carb flame arrestor 4150's with 9 3/8" center to center
- Need dual carb flame arrester 9 3/8 centers for tunnel ram
- Wanted-wtb sbc merc parts exhaust engine
- idler pulley assembly and bracket
- Bravo 1 Cavitation Plate Anode Cap
- EMI Manifold for Big Block
- Looking for stainless headers for 502
- bravo steering caps
- Bravo shift plate
- QUICKFUEL 850 BLOWER CARBS x4
- BBC 4.250 forged cranks and 6.385 rods.
- wtb 2 10qt gen 5 oil pans
- wtb 300x wing plates
- WTB. Crusader 454/502 gen6 oil pan
- 500 EFI plug wires
- looking for lab finished 27 pitch 3 blade bravo prop or something similar!
- COVER for 38 Top Gun WAnted
- WTB Imco Standoff box wings and Bravo 30 Props
- wtb stelling black 2 sets
- Mercury Racing 420 Superchargers
- ISO Bravo 1 XR DWP Lower
- k plane trim cylinders
- WTB Gauge Bezel
- Stock or near Stock 502 Exhaust
- WTB P/S bracket and rec W/P pulley HP500
- WTB boost gauge
- 280 k planes
- Any 502s forsale or equive
- Boat Cover
- NEEDED DPX-R For Sale? 1.68 ratio
- Hyd Tilt helm
- 4.5" gaffrig switchable mufflers
- #5 or 6 boat, complete or needing work
- ISO pair of 28 hydromotives
- merc 177 2.85 upper pulley
- EFI ignition coil
- weiand 256 pulleys
- Wanted Brodix tall deck Hvh intake bbc
- 525efi Bravo Tails wanted
- Looking for 1 sportmaster standard length
- 380 K-plane bottom plates
- Wtb Imco steering cap
- Headers
- 37 pitch Hering 5 blade props
- Looking for 2 sets of EMI thunder BBC w/ Stainless Risers
- Remote oil filter kit for newer 4.3 Mercruiser
- any 502 blocks out there?
- Wanted: K Planes
- 350 vortec intake manifold
- Hydrohoist Wanted -12,000lbs.
- Drive reservior bottle.
- 525 efi power steering oil cooler
- Wanted: 2 complete Bravo I propeller hub kits merc brand
- ISO A PAir of 950cfm Carbs
- Searching for gaffrig/Livorsi gauges
- WANTED: LH 34P 15 5/8" Maximus Prop Stock!
- Looking for a bravo 4 blade 28 p RH prop
- Looking for 5 blade props 30p or 31p
- 19 to 26 adaptors
- WTB: 28 Skater
- 1999 Cigarette Top Gun cover
- 177 Snout needed
- Mirage Plus 23p (standard rotation) wanted
- Bravo trim mechanical indicator
- Two into one turn down exhaust
- Blackhawk wanted
- Looking for 1,2, or 3 used Merc ITS Transom Assemblies
- wtb a pair of 10-18 velvet drives for a twin engine boat
- Gen 4 oil pans
- 380 K Planes
- WTB, 27" Blackhawk props
- Mercury 525 head
- need bravo I 28 pitch prop set ready to buy now! not labbed please
- ISO Helm for hydraulic steering
- ISO IMCO Powerflow Accesories
- Fuel filter bracket for HP500
- Looking for a bravo 1 four blade 28 pitch prop.
- GPS speedo to replace liquid filled fountain speedo
- CMI E-Top Tails
- Stainless Marine Thermostat Housing
- Iso white race fairing
- WTB: 454 Oval Port Heads
- Spectra 24SCS -Powerplay 25- Kryptonite 23 or 27 Center Console Wanted FINDERS FEE
- Looking to buy speedometer
- bbc gen 5-6 10 qt + oil pan
- Search for CMI Silentchoice tailpipes!
- Mercruiser oem cooling setups
- Stainless trim rings
- Power steering pump Alternator bracket
- bbc weiand 256 blower intakemanifold
- imco extension drive shaft xr drive
- Down turn / Underwater Exhaust?
- trim sender covers
- Crower solid roller lifters
- Halon bottle / system
- Dual carb spark arrestors
- looking for 2 inch shortie lowers
- group 31 battery box
- ISO BBC Gen V/Vi 805 Flywheel
- Wanted Used set of Dewald 34x15 props
- ISO BBC Eddie/Hardin Angle Valve covers
- 496ho headers
- WTB P5X Props
- MSD Rev Modules
- Imco driveshaft
- Lovett 900 Bildge pump
- Dual Cooler Bell Housing
- Thunderbolt module
- Fountain dash panel needed
- Imco scx
- S pipe
- Mirage plus 25p 3blade
