View Full Version : Wanted
- Trailer
- Mercruiser Round Drive resoviour bottle.
- Looking for a top mount single lever throttle/ shifter with shift interlock
- wtb No. 6 drives
- Hering 5 blade 17 x 35 x 18r rh
- WTB intercomm system headsets
- WTB: Power Steering Hose Set (NEWER Metric Style)
- Wanted MerCruiser brackets pullys ect
- 525efi cams
- Hydraulic steering complete set up for single bravo
- WTB steering ram wing
- Fountain Fever 29 HULL
- Complete Swim Step Strap
- Looking for WTB LS manifold/headers
- Maltese Magnum parts
- Advertising Literature Wanted
- Wtb: Staggered risers for gil exhaust. Speedmaster.
- WTB 2-piece Valve Covers and 14 qt oil pan
- 3 drive
- wanted mercruiser wire harness for 1997 350 engine
- Rudder system
- WTB: 502 shortblock near PA/MD/NJ
- WTB : 4" switchable exhaust tips like TCM or Eddies
- Wanted: Staggered engine mounts (mercury 849310t 849335t)
- WTP Mercury 300 Optimax pair
- Land and Sea Extension box - Bravo Drive
- Looking for a pair of #5 speedmaster drives in ontario canada
- WTB: Bravo HP Coupler
- WTB 380 K-plane plates only
- WTB....Bravo 1 drive shower.
- Bravo 1 4 blade 30P Left hand rotation Prop
- looking for a good deal ob a pair of carbs. 850 to 950 cfm in size
- Truecharge 20+
- Looking for CMi tails
- USA39 Aronow
- B&M Blower SBC intake manifold
- ISO: looking for a pair of performance manifolds
- Parts
- Gen v 454 mag
- WANTED -Super clean Baja 29 Outlaw low hours
- 496 Alum Exhaust Manifolds
- Looking for one Offshore Solid Motor Mount
- Pair of 502 roller cam sets
- WTB Bravo 1 Upper Cases
- Wanted 502 BBC parts. Pistons, cam, roller rockers ect
- WTB: Apache Cleats
- Wtb old broken or corroded #3A 5 or 6 propshaft
- WTB: 30 pitch left hand Mercury 5 blade outboard Cleaver
- Bravo 1 Trim Cylinders
- Looking for a used extension box for a bravo
- merc 6.2 rotating assy
- WTB : 1" spacer for Bravo 1 drive
- Wanted-cmi "s" style tailpipes for single bravo
- Blower shop intercooler housings
- whipple 3.3 or 4.0 merc 525 kits
- Bravo 30s
- TRS Gimbal Gasket Set
- 454 motor plate- mount
- # 6 35 - 37 props
- Looking for K-Planes
- Looking for full cover for Baja Shooter 27.
- Looking for a pair of #6 Dry Sump drives
- Air Dock
- Looking for full cover for 38 top gun.
- Wtb: 502 engine block
- Wtb: Port side gunnel single throttle/shift assembly.
- Wanted BBC Weiand 177 Blower
- looking for a bam deep sump driveline
- Hydraulic TRS Steering
- gil or stainless marine exhaust
- WANTED: staggered exhaust for speedmaster (trade Gil offshore?)
- Drew marine stabilizer
- SSM iii iv v Extension box
- looking for 502 mag exhaust
- Fastech 271 cover
- Hp500 intake
- Need a Gen 4 head
- Gil Risers
- Wtb: Bravo shift plate
- WTB: GOOD IAC for Merc. 7.4LX Engine (454 Mpi)
- Wtb used Merc ITS extension box
- Wanted 2 9/16 studs
- Trailer
- Trailer
- Looking for a 741 cam
- MEFI 3 Needed!
- 3.3 or 4L efi whipples
- WTB: TIPS 4" x 10" outside boat
- In search of used zz572s for sale
- Full cover to fit a 42 fountain Lightning.
- Wanted 502 mag mpi cam
- Looking transom mount for hydraulic steering to match the one I have
- looking for a pair of mirage 27 s
- Livorsi 2" clock needed
- Wanted bbc gen 6 oil pans
- B&M 420's
- 26 p LH bravo 1 or hydromotive
- gen vi big block parts needed
- Formula 311 window frame..
- WTB: BBC Hyd. Roller Lifters Retrofit
- Looking for Rayjay turbos
- WTB: Snap In Carpet For '96 302 Baja
- WTB 502 Mag complete engine
- Wtb: Volvo to bravo transom adaptor
- ISO A Pair of nice Oval Single Carb Flame Arrestors
- wtb 32 pitch RH bravo1 4 blade prop
- iso. imco lower
- 38 Fountain 1997 and newer under $60k
- xr replaceable tower
- WTB: bravo 1 1.5, aftermarket BBC exhaust, BBC coupler
- bravo xr upper sweptback upper
- 2 pr. 280 Merc aluminum valve covers
- Pair 16 inch drop Arneson ASD-8 or ASD-10
- speedmaster
- stainless marine manifolds
- wanted: two (2) BBC bravo couplers
- anybody got a 3-Step Under-Mount Slide/Out Folding Coated Aluminum Ladder FS:
- 28 skater with 300xs or no power
- Mechanical Drive/Tab Indicator
- Tie bar mounts for SSM IV or V
- Gen VI 502 Block
- xr upper gears
- 28 or 30 p prop wtb
- WTB Mercury Racing 525EFI
- 27 Pachanga
- MEFI 3 computers wanted
- gen 6 454 std bore block needed
- WTB 25 Spline props
- WTB 25 spline used Props
- wanted , 20- 22 ft eliminator , donzi , or cougar for around 20k
- ISO Trailer for Baja 36 Outlaw.
- WTB: Inflatable Boat -- 8-9 foot rated for small outboard 4-6 horse.
- Imco driveshaft for ext. Box
- WANTED: Mechanical Trim Actuator/s Bravo and Bennett
- 7.4 Plastic top covers
- Alpha 1 gen 1 drive
- Looking for a set of 496's
- Looking for Windshield for 1986 Formula 206 Spider
- Looking for a 1998-1999 42 fountain hull
- B+M blower
- WTB Mercruiser Gen 6 BBC left side manifold
- Looking for Scarab 38KV parts
- Wanted! Scarab 38KV steering wheel
- WTB: Bravo 1 standard Lower Case/5" straight exhaust tip
- Crane gold roller rocker 1.8
- Looking for #6 Hull 38 or bigger
- Looking for a tunnel tab for 30 Spectre
- e2 props for volvo dpx drive
- 502's- 509's
- pro charger m-4 3v pulley
- latham throttles
- WTB Dropout Bolsters
- Port side PS pump and bracket
- Sea strainer for chiller
- Imco -2 shorty lowers
- Anyone have a Merc round reservoir laying around?
- Formula Windshield
- WTB hydroulic steering
- looking for a complete drop inn 496 502 efi
- Windshield
- pair of front motor mount plates
- 34-36' outboard project hull
- WTB: Standard Stainless Marine risers with O2 bungs installed
- Gen VI reverse rot. roller cam
- 500 efi parts
- Wanted - 500 efi parts
- WTB - Mercury ITS Box Cover (Cowl Assembly)
- EXHAUST manifolds headers plus long tails small block chev mercruiser
- Trs drive set wanted
- Latham trottles
- Wanted. Old junk mercruiser quadrajet
- Wanted Gil Dry Raisers
- WTB: Sea Strainers
- Swim ladder Formula
- WTB Tab and drive trim actuators
- Wanted: 79 Formula Interceptor Port Hole WIndow
- WTB IMCO alignment Tool for extension box
- Competition throttles
- Donzi 28zx Scorpion
- ISO to buy /rent / borrow a TRS Alignment tool ... Thanks
- MSD tach adapters 8920
- WTB 525 Headers
- 3 groove crank pulley
- wanted need stock 496 mercruiser risers
- Looking for a Single Engine T/S Control
- Swim platform for 1998 checkmate convincor 253
- Bravo one add on external hydraulic single ram kit.
- Small center console without power
- Steering parts
- Nxt prop
- WTB: Hatch lift actuator for Baja Outlaw 24
- (2) engine wiring harnesses
- WTB - CMI Sport Tube Headers
- Just testing the waters 36'+ hull no power
- Wtb oil filter block off plate
- WTB Latham Helm unit
- WTB #5SSM spur gears
- r tech carbed blow through intercooler
- Wanting performance exhaust 454
- WTB HP500 Flame Arrestors, Carb, GIL Manifolds
- Wanted two Bravo One Transom assemblies
- WTB XR 1.5 Upper gears or complete
- looking for a full cover
- misc parts looking for
- imco powerflow manifolds wanted
- Good VST wanted
- Looking for a mpi version 5 and 6 ECM
- WTB: Hydromotive QIV 27p RH
- Need 1 xr prop hub, xr shaft and carrier
- Needed !!!! 2 good used stock type bravo one gears 1.5 ratio.
- Single engine cat or V bottom NO power
- 3 groove blower acc pulleys
- Looking for a procharger 324 polished intercooler
- 28 or 29 prop
- Looking for 26 p bravo 1 props L&R
- gil offshore engine mounts
- 32 pitch Bravo I prop RH
- Wtb- powerplay 33 center console
- WTB Drive shower and swim plat form
- Looking for a 1 inch spacer for an NXT drive.
- Anyone got a 330?
- Cigarette battery boxes
- new style top gun hatch
- bravo 1 trim indicaor ss stops
- lenco actuators
- Imco -3 lower
- warlock performance marine hydraulic steering
- Sc imco lower (housing only) std
- Need Several Big BLock Parts 502 ASAP PLease
- spacers
- Need BBC parts asap. JE 700 piston Gen v 502
- Lh 26 5 blade Maximus
- Wtb footrest
- looking for some trs plug in crashboxes
- T Bolt 5 plug and harness
- 454 gen 4 penut port heads
- Bravo 1 or XR 1.50 Ratio
- 28 Lh Bravo 1
- Hydromotive Quad IV 27RH
- WTB: 30 pitch Bravo 1 pair L and R
- WTB: Bravo HP Trim Indicator
- WTB: Bravo Shift Plate
- Shifter/ throttle set up and Dominator Flame arrestor
- ISO power steering pump 500EFI
- AC Brand Bow Light
- lh 28 pitch bravo 1
- Needed set of 525 efi headers
- WTB Throttle body from either a 454 Mag EFI or a 502 mag EFI.
