View Full Version : Wanted
- wtb HP 500
- Mercury 2.5 L Offshore 280 horsepower twin outboards
- Stand Off Boxes
- Need Mercruiser BBC Throttle Body or Info
- life line
- Aluminum Trailer for 42 Cigarette No Steps
- ssm inner transon plates
- 47 Fountain Trailer
- Ilmore mounts
- Emi Thunder Brackets
- Blower Kits.
- WTB - 496 HO Engine
- Single engine GAUGE setup
- Merc 525 efi with headers
- Winter Project
- Merc Racing 600 sci and/or 700 sci
- 2 sets of gen-x 525 headers
- Blowers
- 19 Spline Props for Speedmaster 4
- refridgerator
- dumas scarab !!!!!!!!!!!!
- Bravo 1 trim cylinders
- Help locating parts
- gimble ring
- WTB 5400 MSD Pill
- Holley 750 CFM Double Pumpers (pair)
- 454 crank pullys
- 2 pair of cmi 525 headers.....
- sb gil pans
- #6 plugin trans
- Sea Strainers
- Complete Used External Steering Add on r Full
- Wanted; Side by side front motor plates..
- 525 efi wiring harness, relays, and fuses...
- Looking for rh & lh 27p 3 blade props
- 525 efi trigger wheels and pulleys
- formula hull side windows trim
- looking for imco -2 lower with verticle shaft
- shore power cord
- 380 K-planes (plates only)
- Whipples Or Prochargers
- Looking for a 34ft Phantom
- Drive and Tab Indicators
- drive and tab indicators
- NXT Transom Ass. & Drives
- 28" Hydromotive Q-IVs
- 06/ Myco tire and rim
- two outdrive stands
- WTB a MRC2-01 Stereo Remote Control
- B1 coupler
- Wanted: Bravo Lower Cases LWP
- Fresh water weiand blower intake manifold
- Wanted: 2 Merc Racing 700sci's. Don't need drives or tranny's.
- Gear and throttle controls
- Torque plate coupler B1
- V6 ignition module
- WTB 42 fountain cover
- WTB bolster seats
- WTB cockpit cover for Donzi 22
- WTB small block performance manifolds
- 2 sets of bbc exhaust with short risers for silent gil,imco, stainless marine , dana
- looking for a p5 prop,or other transom lifting prop.
- Two sets Cmi dry tails with merc flanges
- WTB 830 Holley
- Lots of Parts needed
- WTB radar arch 260 Stinger
- Above Dash GPS Mount Box?
- formula bolster seats wanted
- IN Side Storage warehouse ?
- looking for 1inch imco mid section
- cat hull
- Throttle/Shift/Trim controller
- gen VI block and heads
- Looking for Hydraulic Steering
- need scs crash boxes
- Bravo Helmit housing
- HP 500 Cams
- 16 Inch Wheels
- closed cooling systems
- Side mount whipple crankshaft pulley
- 2- HP500 carb motors
- HP 500 pistons
- WTB Cigatette front bolsters
- Gen6 stock oil pan
- WTB LAMBOGHINI marine engine parts
- Flame Arrestors,Endenbrock Carbs
- need old style #6 gimble drive line
- IMCO Power Flow Small Block
- 502 Mainfolds & Risers
- 250 blowers
- complete 525 efi takeoffs
- 525 coolant reserviors
- WTB Lift for 42 fountain
- WTB intake
- Key west rooms or condo
- WTB: HP500 carb, EFI or Bulldog
- # 6 bellhousings
- I Need A Hp 500
- wtb: 32P RH Bravo
- 700 Mercury SCI Wanted
- Best price on drive couplers
- B&M 250 chillers
- Hp 500
- Need Two #6 Gimbal Rings (new)
- Need a BBC distributor
- 496 cast S-pipes
- WTB Imco extension shafts
- 14x17 rh ss merc prop
- Gill or equiv. manifolds
- WTB throttles and helm pump
- Mechanical tab & drive
- WTB Whipple Kits for 500/525 EFIs
- 4" Exhaust Tips
- pair of drop box arnesons.....
- Pair of 525EFI ECM's
- Hydromotive Quad 4
- Wanted 10 k back In lift at the LOTO.
- Wanted Quick fuel 850 cfm carb
- Procharger cogged belt pulley 56 tooth.
- ilmor viper motors
- Trailer For 25 Talon
- Wanted: 454/502 MAG MPI Whipple System
- 496 ho engine covers WANTED.....
- Wanted.... 496HO ECM ASAP....
- trailer needed
- Cat tie bar
- Wanted CMI TRS rope seal tails
- 38 Top Gun trailer wanted
- Looking for twin POWER, 600+
- pair fuel pumps for 700hp....
- pair sea strainers with flush, not the bronze ones...
- 38 Scarab Excel
- Wtb: Asap: Stelling Headers "green"
- Bravo Lower Case empty
- Big tube headers (single)
- Test Equiptment
- WTB Winter project 24'-28' Cat no power
- -2 sportmaster
- Looking for / pricing complete bravo XR assy
- bennett trim switch
- bravo upper needed
- LF Project boat, twins, 30' and above, TRS
- Looking for Project Boat
- WANTED Cav Plate Ext for Bravo III
- wanted wet or dry tails for hp 500 cmi etops
- need MPI Intakes
- !!!!The 31' Quest !!!!
- WTB: 2 Bravo HP Gimbal Rings
- Pair of 17x30 five blades
- Bravo Shorty - 1.5 or case only
- Stock take outs complete
- 502 Gen 6 blocks
- extension box
- livorsi dash wedge needed
- Borg Warner 72c
- 17-35 Props
- Need 2 alternator brackets , and two 3 belt pulleys
- 2 inch bravo spacer
- i am in need of a Bravo gimbal ring
- pair of stock 502 ecm's
- 26/28 single engine hulls NO power
- two pair cmi distribution tubes
- two sets dominator fuel feed lines and throttle brackets
- pair of big oval dominator flame arrestors
- wtb..emi dry tails..
- 42 Fountain Gauge
- mirage props needed
- 29 pitch mirage
- WTB 2.75" whipple pulleys
- Bravo Gimbal assembly
- hose
- Props Mirage Plus....
- Props
- 365 Merc Mag (carb) fuel pump
- stellings ext box #6
- Bravo 1 Gimbal
- merc trs deals
- 2 " imco
- XR upper gear set
- WTB water pump pulley
- sea pump
- polished stainless tips. 6" or so
- Needed one elbow for a 1987 ford 460 cobra part #982674
- 2 300 verado engine cowls
- need a bravo upper complete 1.5 ratio
- westerpeke gas gen
- Wanted 24x7 hull, solid
- 18X35 #6 props
- Current Garmin Plotter and Access.
- 525 Cylinder heads and cooling parts
- WTB Aluminum cat trailer
- Alternator- oil pump bracket
- -1 Imco Case
- Holley/B&M Blower Pulleys
- 26 or 27 hydromotive
- Velvet Drive(trs) Wanted
- WANTED 5 blade LEFT HERING SSM 6 16.5 x36
- trs steering cap
- keith eickert cast manifolds
- Wtb Hp500 Valve Covers
- HP500 Connecting rods
- Single Engine race lay up hull Less power
- 26p Bravo I Rh
- WTB: Lowrance Depth Gauge Transducer
- WTB set HP500 heads and oil pan
- WTB Blower shop 871's for HP 500's
- WANTED!! cougar cub or mini cat boat
- WTB #5 Extension Boxes
- surface drive
- used skater seats
- 27 Pitch 4 Blade?
- Wtb Psi Blowers
- Gaffrig
- EFI fuel pumps
- windshield
- manifolds
- WTB trailer for 30' Black Thunder
- 500hp's
- TRS - USED or w/warrenty
- mufflers wanted
- 5 or 6 blade props needed
- wanted gen IV oil pan
- throttle / shifter
- Drive showers
- Need a set of Bravo 1 28P
- hp 500 sea water pump p# 807151a31
- 4" I/D SS 90 degree elbows
- Wanted: 17.5" x 35 Pitch 5 Blades
- Remote oil filters
- 34p 3 blade merc outboard props wanted
- WANTED: B&M 250 dual carb mounting plate
- 4 inch clamp on mufflers
- Oil Pans
- Merc exhaust y pipe SBC
- XR universal joints
- SSM 6 Hering
- BBC 4.25 crank
- Imco -1 lowers need 2
- WTB: 7.3 Powerstroke tuner/chip
- 990 or 188 casting off a mk IV
- pair of 24. bravo 1s or pair of 26 s labbed down
- ssm #4 or#3 lower gears1.125wanted
- imco steering
- Wanted #6 Gimble parts
- Lookin for a pair of sea strainer
- lokoking for Bravo III prop
- WTB Mercury and Innovation 496's any condition
- Hatch Ram
