View Full Version : Wanted
- Wanted : 525sc flame arrestor also 25p mirage plus prop
- wanted junk jabsco pump
- cmi split top uppers wanted
- WANTED TO BUY: IMCO hydraulic steering mounts for an IMCO extension box
- Wtb: 4 in thru hull w ith flappers
- Vdo blank gauge
- Need B&M 250 bbc intake
- 2 inch shotie
- 38 scarab trailer
- bravo 1 26 rh for sale or trade for bravo 1 28 rh
- Planning on selling your Sliding Box Anchor?
- extension boxes for #3-5 speedmasters
- Fuel filter heads 1/2 NPT
- Wanted: High Altitude pulley for 525sc
- 525 SC Help
- 575sci weiand 256 snout
- 1 inch drive spacer
- hydromotive 28 pitch p5x
- HP500s
- Lewmar Windlass Concept1 (69000177) Wanted
- 23p mirage plus rh for bravo 1
- ISO..... Spectre boat 1/4 canopies
- ISO. ....Spectre poker run 1/4 canopies.
- Wheels & tires for a triaxle
- Hp 500 intake
- bravo its shafts
- Mirage plus? (2)
- Stainless marine gen 3
- Flywheel gen 6
- WTB oil Pan 496mag ho
- Hering 5 blades xr props 30-31
- Wanted (NEED!!!!!)
- Looking 4 A 575 SCi top half
- ISO Hardin Marine Drive Shower
- Need No 6 six blade 28 to 30 pitch props
- wtb 4 balde ssm props
- Anchor locker door
- Upper XR gear set needed
- Donzi Z25 Hatch Hinges Pictures Dimensions
- looking for boat minus motors
- Looking for Cmi e top tails what's out there?
- Mark IV Heads, Intake, Oil Pan
- Pair of large diameter (18-24") 5 or 6 blades, must be 26 spline shafts.
- Checkmate decals
- Trs transom assemblies
- Billet Tabs/Planes
- Wanted- 496 Mag Ho pullout
- 1.88 / 2.19 valves
- ISO TRS hydraulic steering
- power steering cooler
- Hp gimbal, Steering, IMCO drive wanted.
- 496 Y Pipe
- marine machine
- need two sets of starggered motor plates
- Transom Beauty rings
- HP 500 Intake and Carb
- B&M 250 parts needed..
- Hp500 cam
- 088 cylinder heads
- Need a pair of Hardin cyclone headers
- TRS Y pipes wanted
- Wanted 2 sets of Big Tube headers for Bravo Top Gun
- Wanted Big Tube headers for Bravo Top Gun
- Profile literature, owners manual, sales brochures etc.
- 10-14 QT Gen V/VI BBC Oil Pan
- New 600 SCI Bobtail
- 750 cfm vac secondary Holley
- looking for 525 efi parts
- Looking For A 4.25 Forged Crank 1pc seal
- Wtb 3 3/8 gps speedometer white back
- superchiller
- WTB a Pair of Drew Shotguns 4 or 4.5
- need Weind 6140 blower intakes
- Looking for Macleod Bolsters
- Wanted Scarab 29 starboard ( right ) windshield glass or complete windshield
- need baja 260 starboard curved windshield. 90-96. or whole windshield similar
- need baja 26 starboard curved windshield. 90-96. or whole windshield similar
- Looking to buy a sand strainer
- XR Drive Shower
- WTB Keith Eickert Exhaust Manifolds
- Looking for imco drive shafts
- Stainless Marine Gen III manifolds
- Looking for Isotto steering wheel style "Carlotta "
- manifolds
- helm post/steering post
- 502/525 EFi intakes
- Drive Shaft Parts
- Wtb: Bravo one prop shaft
- ISO 42 stepped Fountain without power....
- looking for 2x 700 sci stage 2 or 3 computer upgrade
- pair of 871 superchargers / intakes
- Cmi tail pipes
- Mercury or Hering 16.5x38x18 or 16.5x40x18 5 blade propellers
- 10.2 tall deck 4.500 block
- Speedmaster V complete pair
- I need help please
- wtb gen 5/6 oil pan
- CMI Split Top Riser needed
- Sonic Arch for a 45'
- need a speedmaster tail stock
- Wtb 2 holly 850 carbs
- Rod and Piston Mercruiser 496
- need two latham streeing ram
- Bravo Transom Assemble ad 1:50:1 Upper Bravo Gear Set
- 454/502 Mag Camshaft GM # 12551622 Got One Laying Around?
- Wanted 088 heads and rotating forged assembly
- drives
- B&M 420 Mega Blower Pullies
- 525 oil cooler
- External steering hardware Lantham or?
- Looking for 2 500hp either efi or carb
- SS Transom Mount Trim Pump Bracket
- Airfilter 525 EFI
- WTB 502 MPI or 454 Mag or HP500
- need a speen master #3 gimble
- Wanted alph ss
- CMI Tails
- Smartcraft Vesselview Rim Livorsi Purple SCVVRPU
- Crane 741 or 525 efi cams
- WTB: Swim Platform, Swim Step(s) or???
- 454 Pistons
- High back seats
- corsa silent choice
- trs y pipe
- Pair of 5 blade 18X33 18* Rake...
- Carrillo rods
- wiring harness for 500 EFI
- tie bar clevis joints
- Long bravo yokes for extension boxes AND boxes.
- -3 Imco lower...... Complete or any parts.
- Hp Gimbal housings needed
- 4.25 stoke crank
- Land and sea Sternjack Alpha drive
- Web 2 pc bbc valve covers
- 3.3 whipples
- Wtb clean 088 heads
- Bravo Extension Box & Steering (Complete)
- Wanted: Scarab 377 flatdeck or 38KV for parts
- drive shower lines
- 500 efi cam
- CMI Tops
- ISO bravo rear cap
- 600 or 700sci?
- gen vi block
- 1970-1972 elcamino
- throttle advance solenoids
- looking for 2 ( lh+rh) 35p maximus to imco 1-7/16 axle
- #3-4-5 drill jig
- WTB 32-34p L&R set 5 blades
- tie bar saddles bravo
- Bravo one propshaft
- BBC Tall Deck Block
- 5 blade props for No. 6 drives
- 34 p hydro or bravo 5 blades
- Power steering lines
- 5' stainless beauty rings
- 502 takeout engine
- trim indicator actuators for #5 SSM
- wanted ssm6 tie bar saddles
- 1 BBC imco power flow manifold (single manifold)
- BBC - Tunnel ram - tall deck
- Wanted Imco dcx drive
- Bravo hp engine couplers wanted
- IMCO - Extended input shaft for extension box. I need the one for X drive ( larger )
- 1" spacers for #6 drives
- imco long input shafts
- raw water pump with fuel pump
- wtb; 454 2399f .060 pistons ,
- Wanted: Gil Tall Risers
- ISO 350/5.7 Vortec 4-bbl. intake
- wtb 502 mpi setup complete
- Imco drive spacers
- Gen VI 10qt Oil Pan
- wtb. huber or bam transmissions.
- Extension boxes and xr or sc drives wanted
- wtb oil cooler and lines looking for 2
- 502 pistons
- Maximus 24p L&R
- driveline driveshaft covers
- WANTED EMI/KE or other HEADERS /RISERS 350SBC
- gen VI 502 block
- 10.2 tall deck BOWTIE block
- Borg Warner 72c transmission
- m1 procharger box
- WANTED: CALLIES , 1-piece Seal, Forged 4340 Steel, 4.250 in. Stroke
- Capilano 1275V Hydraulic Helm
- wanted 2 sets cmi headers
- Cheap 38 fountain trailer
- Raw water pump for 5.0l bravo wanted
- WTB: single engine controls, used.
- B&M 420 input shaft and coupler
- 525EFI Cam
- I.T.S steering valve block assemblies
- Trim and carburetor
- 575sci complete TB
- WTB EFI Whipple Blower - Can be any size quad or 4.0 / 5.0 single
- WTB - Merc Racing (500efi 525efi etc...) Power Steering pump, and alt bracket
- WTB - Merc Blue Pulleys - Any condition
- wanted trw piston 3999295
- bbc performance marine book
- CMI Tails - Bravo Application
- WTB Pair of SBC's.....reasonable
- wanted 38 top gun ts less power
- silent choice exhaust
- WTB x-xr uppers
- Imco stand off box 24 inch imput shaft bravo
- the elusive b&m blower pulley
- Speedmaster 18 inch extension boxes
- Wtb: Trim pump
- Baja 210 Sunsport Early
- Bravo complete, or upper, external hyd. setup
- 380 k planes wanted
- VST pump needed
- Looking for bravo, blackhawk, speedmaster, surface drive parts, tools, stands etc
- Bonner 16 inch drop box.......
- Acculift linear actuator parts?
- Looking for starboard front full staggered engine mount
- WTB: 3 groove crank pulley with 6 bolt blower pulley hub
- Trailer for a 38' V
- 575sci idler pulley blue
- Exhaust
- 330 good running takeout
- stainless marine gen 3 -- 2 pair needed
- raw water pump
- SSM II lower complete left hand
- Waterpump crossover and thermostat housing for BB
- power steering reservoirs
- Looking for a hydraulic steering resivoire,
- 30 Pitch Hydromotive P5X - STOCK
- Full cover
- Wtb 454 gen vi block
- looking for a pair of bravo engine couplers
- Need windshield for 1990 Formula 357 SR1
- WTB 454 parts
- Gen III risers
- Top Gun Staggered Hatch
- need a set off 454 push rods tri state area
- Wanted 200 2.4 mercury outboards 25" shaft
- Wanted 8.1 496 manifolds/Alum.
- WTB gm bbc 088 heads
- I'm looking for Gill dry tail pipes.
- Taco Marine Rub Rail section 07 Formula 330ss
- Looking for Full guage set up, or Dash for twin Fountain 32 Fever.
- Wanted SBC EMI stainless risers
- Looking for a deal on some twin disc mg502 transmissions
- ISO 2" Spacer for Bravo XR
- WTB 2007 330ss cockpit tables
- wtb 2 850 holly's
- TRS boxes
