- Upgrading 502'so to 525's
- Whats it worth? Early 80's Scarab
- Fiberglass work in CT
- 500 EFI Upgrades
- 500 EFI Upgrades
- Vinyl Flooring help needed!
- Should i replace sensors before installing new long block?
- Few Questions on installing Procharger on new Long Block 502
- Hull Blueprinting
- 88 Formula F223 LS repower
- Powdercoat - Mercury Racing Blue
- Front Dash replacement
- New Guages
- Re-Chroming
- Trim tab actuator
- Backup Bilge Pump
- Replacement throttle control
- Lower unit/ Outboard Paint
- vinyl headliner material
- redoing interior and hatch 1999 Scarab AVS 33
- 88 baja 226 sport 454 mag upgrades?
- 5.3 LS into a Four Winns U17 - Build Thread
- 1996 27zx interior removal?
- 1977 Scarab 300 resto&tech advice needed.
- Cabin head liner and walls
- Upholstery (seat) needed
- Any 21'-26' project hulls for sale?
- Any 525 intakes for sale
- Boat Wraps?
- Engine Hatch Mirror - Design
- Power steering line hits new headers ??
- Header pipes hit air cleaner???
- Stupid small river rat resto mod
- LED cabin lighting upgrade
- 33 Outlaw cockpit/dash update!
- 1985 402 SR1 resto mod.
- Need help with Outboard mod from twin to triples
- Stock 454 With Headers?
- 1988 Sunsation Rocket restoration
- Riser Gaskets
- ohio Donzi
- Looking at a buddies boat, stringers bad
- 34 Fountain CC mild re-fit into a sports/bowrider
- More out of Verado 150
- Baja 40 SST twin 725 Ilmors
- Is a 2 bolt 454 block worth building?
- The return of the "Schiada Sea's"
- 38 KV Scarab restoration
- Dash layout
- Who can weld Stainless CMI Headers
- looking for any parts from a 1982 Chris Craft stinger 260.
- Scarab Panther Engine Upgrade - Height Clearance
- TRS to SSM5 UPGRADE
- What valve covers??
- 1991 Black Thunder 320 resto.
- Converting Merc control box to Hardin Marine Throttle
- 2006 B&H Performance boat Project
- Formula 242 LS rebuild - Lake Havasu, AZ area
- 1989 24 Aronow Project "Half Speed"
- Graphics
- Who sells composite sheet goods like coosa around the lake of the ozarks
- Powerquest Engine Blower Ventilation Design
- Skater stickers for boat trailer wanted
- 24 Jaws Back on track
- Hinges
- Help?
- Formula 330 Outboard conversion
- 38 fountain fever
- New Sunsation vinyl installed
- 46' Cougar, need some expert advice
- How cani buld more hP with my stock mercury 525 efi?
- Powerquest 380 Avenger Refurb
- 454 Mag modded Or stroked with non forged internals ?
- Looked, didn't find a Hydrodyne section.....
- 88 Pachanga 32
- Cuddy hatch! Where to purchase?
- 35 fountain throttles
- Strange Cockpit vinyl....not sure what its called.
- 1997 formula fastech 353 is will twin sbc work??
- Oh well!! Now a 454 head gasket leak!!
- what to replace while motor is out?
- Cigarette emblem , interior
- paging glassdave
- 89 scarab 38 update freeshen motors 510;s
- Swapping old 260 mercruiser for cracked 305 Volvo
- CAMI Terra Wind Amphibious Motorcoach
- Post your cabin upgrade photos
- 1964 Formula Thunderbird Tri-Hull
- Winter upgrades, fresh outta the oven.
- 89 Formula 357 Restoration
- Sbc crate long block, recomendations
- Whipple Supercharger with Holley EFI Computer ?
- Repower or rebuild bbc whats available?
- What color to paint new engine?
- Anybody know where to get these? (Recessed cupholders)
- Turbocharging a Mercruiser 502, guidance required.
- Upgrading 1988 Formula 311
- Upgrading a 260hp 350
- 55 foot power cat project
- Whats involved in a new floor?
- Hull liner monkey fur
- Convert windshield to fairing?
- 1/4 bolster
- New project boat
- Performance upgrades for a 7.4 mercruiser?
- Estimate on interior work
- 180 Dart Iron Eagle heads
- Formula 242LS back from the brink
- glastron carlson signature 19 project
- Blueprint engine
- 454 carbed motor to 454 mag EFI complete motor swap
- 1964 Thunderbird Tri-hull
- Any advantage to stagger without moving engines together?
- '99 scarab airvents
- Warlock seat fabric ????/
- wind screen
- Arrow 630 flatdeck
- Chevy 350 (5.7L) 260 HP vortec upgrade
- Captains call conversion
- Looking for a little advice. Looking for someone to referb a boat
- Want to beef up my stock 454 a little?
- Engine build recommendations 454/502/or BOOST
- Cary 32 Resto...
- Chris Craft 210 Scorpion RestoMod project WITH supercharged LS1
- 350 Vortec Piston Selection for Ideal Compression and Quench...
- Well, it all started as just a new floor and interior.
- I'm back, it was time to repower
- Velocity 22 Resurrection
- Repower 95 305 with a 96 up 350 Vortec?
- 1075's Re-build
- Repower Advice
- 1989 Power Play Integra 185 Restoration Project
- 1979 hammond
- Just bought a 1988 Formula 272
- 87' Apache Scout Restoration
- 19' sea ray pachanga 4.3l good boat???
- 1990 Powerplay Integra Upgrade Upholstery
- would Like to beef up my 454
- 10 Meter Updating
- Electrical: Two engines one crank battery (MBCM-12)
- Motors and Paint
- freshwater cooling system
- Windshield
- Who's got a Liberator ?
- 22 donzi restoration
- Vinyl Floor Replacement
- 1985 scarab 1
- Cigarette 20 Exterior Hardware Replacement - Lift Bow/Stern lift Ring Hook-ups
- 1988 Power Play integra 187 need windshield
- Advice/Information on Exhaust Tips Replacing Corsa Mufflers
- Vinyl or interior shops aroun Orlando
- 02 Galaxy 2014 Refurb & Update
- Throttle upgrade-Formula 242LS
- Fuel Access ideas
- Carpet Opinions - Corinthian Purple (Iris) vs. basic 20oz carpets
- cabin door frame
- Pachanga 22 Alpha to Bravo swap
- Side Mount Throttle
- Mistress -82 restoration
- Restoring interior on fountain
- Trim pumps question - replace plastic resevior with steel canisters
- Nova Marine 24 CC Update....finally......
- Fountain Windscreens
- '77 wellcraft nova 250 offshore restoration
- Looking for a boat shop in Oklahoma or Mo
- HP 500 Carb to FI conversion
- A little different my "I/O pontoon build"
- 1995 obsession cat facelift
- 1998 Active Thunder 37 Triple Resto
- Wellcraft Nova Spyder 26 - restoration & outboard conversion
- Cuddy cushion material?
- Upgraded velvet drive
- scarab websites
- Engine compartment Stringers
- carbon fiber look
- IMP 310 Rebuild/modification
- 93 Mirage 232 Trovare build
- scarab with rotten transom
- replacing baja interior
- 30 ft Panther Gas Tank Replacement
- Stinger 390x Repower
- Upolstery Western New York Area
- Cougar Cub Rebuild
- 88 Seebold 236 restoration
- Top gun hatch
- I need a Fountain Cabin door
- Donzi 22 Classic
- windshield Baja 232
- lexan wind deflector
- Need to pull headline down in a 38 scarab what holds it up?
- Vinyl upholstery
- hatch 2001 Baja
- Full covers ??
- Am I crazy of could this work, chaparral 2300 sx sport mid cabin bow rider
- Interior budget
- 89 scarab 21 excel rebuild
- Converting a 350 to Diesel
- Cigarette bullet resto
- 1987 larson senza complete restoration
- 1979 Formula 255 Liberator Restoration Summary.
- chaparral 2300sx re birth/ stringers bulk heads floor and transom
- Gaffrrig
- Old button cover snap holes
- Cabin lights
- Seacast
- Summary and link to 1986 Formula 272 LS rebuild thread in Formula section
- Anyone with a nice Baja 235 force
- 502 long blocks. Best place to buy?
- Hose replacement
- project baja 235 force need interior help
- 330hp 454 upgrades
- Marine Vinyl used by the Perfomance boat companies?
- rinker 212
- 2000 Wellcraft Excalibur 23 windscreen
- Post photo's of your bilge.
- question about fiberglass in transom
- Carlson cvx 20 foot jet boat converting to 429
- Fuel pump modified 330 454 Gen V
- TH Marine Underwater LEDs
- hp after rebuild merc 502
- *** HOT ROD OX66's ***
- Newbie 21' scarab build
- crownline engine upgrade\swap
- QUESTION on CAM OPTIONS
- Bolster seats
- 23' warlock world class imco steering ram installation ?
- 1974 SeaCraft 20 Racing Boat?
- Price for cabin restoration??
- New to this need lots of advice i have tons of questions.
- wind deflector for Fountain ?
- Eliminator 250 Eagle XP build has started
- Stainless Marine VS EMI Exhaust
- 454 magnum EFI performance
- Hidden fasteners for side panels?
- Marine vinyl ???
- Vinyl Upholstery cleaning/protectant products
- Old Motor Dead New Motor Problems
- Lay-In Carpeting material suppliers
- Formula 311 Engine Swap
- Helm / steering shaft adapter
- Scarab 38 kv Kamma
- 1994 Nordic Escape Cockpit Rebuild
- 84 Formula 242 Deck off Restoration
- merc 502 horsepower?
- Complete 42 Fountain Restoration
- Step pads?? Hydroturf?
- Lilly Sport Boats 1999 26 Scarab Dash Redo
- baja upholstery
- Upholstery shops in north east ?
- Villain in need of major help
