View Full Version : Prop Talk
Pages :
1
2
3
4]
5
6
7
8
9
10
11
12
13
14
15
- Prop for cigarette 28
- prop for a superboat
- Any suggestions on a better prop?
- Thumbs up to Hydromotive!
- What is the best prop for a 205 35 Fountain ex
- Prop blowout, can some one explain ?
- Who has the best prices on bravo 1 xs 29 pitch?
- formula 233 w/ 351w and alpha what prop????
- slip and fall
- opinions on this prop advise?
- Drive Height/Prop Help
- 24 p&d
- 42 fountain prop help
- Attn bblades!!!
- Hub issues
- 454 alpha one drive, what prop size
- what to expect? Mistress 600 hp....BBlades???
- should I be running a bigger prop?
- Bblades
- 3900rpm at W.O.T
- Prop Selection help! 30 Oulaw with 600SCI
- Help! Please! 88 Four Winns Liberator 211
- New boat mirage 217 w/502
- left and right hand props on a baja boss 302
- Hydro help
- What prop for 26ft Regal Leisure Cat? with a 250 EFI Mercury
- Need a 24P Hydromotive lefty with removable hub or 1 1/4 prop shaft.
- Hubs for 4 blade Bravo props??
- New lowers..back to the drawing board
- Besides Bblades, who else have any of you had success with labbing?
- Bravo prop and Bravo prop LAB
- Need to take advantage of my raised power level
- Question about prop value and application
- Bravo XR prop installation question
- alu prop
- Bring back that shine...
- prop rotation - performance difference when rotating inward vs outward
- Changing to left hand.
- Need help choosing props
- 38 donzi zr MPH
- Checkmate Enforcer Prop Choice - Need roughly 500-600 rpm increase
- 78 NOVA 250XL W/ twin 406s
- F350 on a 233 formula prop choice?????
- your opinions in this set up
- Volvo DPX drive/ E series prop help
- need a no lift prop
- 24 monza 300 promax what prop?
- What props do I need
- Prop slip 4 or 5 blade
- 5100 RPM's?
- laser #48-16548-a46 can be installs to alpha1?thanks
- Need educated guess for right prop for 21' Chris Craft with 600hp
- Clueless on prop selection
- did i had right prop for my boats?
- Looking for prop
- Bravo 1 FS prop
- Repower - trying to size the props with no sistership to compare.
- 15 X 20 4 BLADE CLEAVER on a TRS LH single
- BBLADES Boating News
- Props turned in on Donzi 38zx
- bravo 1 prop
- 28 scarab xlt props
- props size - help please
- Florida 4 Blade Prop Swap? Left 4 Right Spin?
- Bravo 1 30p RH Wanted
- prop help
- Cig Bullet Propping
- 280 Silencer Prop / Mods help.
- Prop for 27ft Squadron XII/Cig
- Prop size for a Sonic 386 w/502 Stock MPI's?
- What prop for Pro Charged 253 Checkmate
- prop size for 24x7 carrera
- Prop size 26 sonic prowler 502 mpi
- Prop Size recommendations - 18' Baja
- How much should rpms change from no trim to full trim
- 240 baja speed
- diameter vs pitch etc on surface drives
- Big diameter props on big vees??
- where do I start
- which Rev4 prop?
- BBLADES Quarterly Newsletter
- Maximus or P5X on 280 Silencer?
- Best Prop for Baja 272
- 42 Fountain 600 sci pkg.
- Reduce rpms with Maximus prop
- Good News Prop purchase
- The age old question; What Prop do I need?
- BBlades I need your help.
- 32 Maximus
- what prop should I use ???
- Prop problems
- labbed bravos
- BBLADES Winter Special 2014
- Fastest prop info. 35 lightning?
- High rake 5 blade prop?
- tekkin out on props (newbie)
- What is a good slip %
- Prop recomendation after engine rebuild
- BBLADES December Special
- Herring v Maximus?
- Prop slip %
- 26 Corsa Speed
- Paging bblades
- What a sweet augmented pair …
- Turning props inward...faster?
- Under propped???
- Triple Engine Prop Sizing
- Bravo 1, Hydromotive, or Revolution 4
- Donzi 38ZR w/700sci, prop blowout
- Bravo1 prop pitch VS speed
- BBLADES Heads to Key West
- Tempest Plus Props
- Prop or x dimension?
- 5 MPH more out of baja
- cup
- stolen props Long Island NY
- HELP. New boat, prop issues need education!
- Bad top end
- Oem ss propeller cobalt
- BBlades, I need a new cover.
- Prop/performance help
- Props For 2002 Fountain Lightning 35'
- prop advice 88 formula 29 pc
- Trying P5X's on Fountain
- Mirage vs mirage plus?
- Prop Help Caravelle Interceptor 232
- 32 fever prop info
- Mercury prop hub question for flo-torque II
- Props for Fountain 38 Lightning...
- 29P Mirage....What is the 4 Blade equivalent??
- Merc Rev 4 Wanted - RH 25p
- 38 special
- Prop labbing
- prop turned grey
- Breaking Maximus props on a 38zr
- bravo 1 32p prop slip
- bow lift
- Formula 255 Liberator Prop study
- 2002 29' Outlaw T/496 Mags Prop Help
- Bblades is a Class act !!!!!!
- Baja 250 Sport 600 hp Having trouble finding the right prop!!!
- 600hp 22' Scarab XR/-1 propping
- Need - Revolution 4 21p RH prop. Anyone have one?
- Help propping a older 24 x 7 - Sunsation Rocket w/ BBC 500HP - Rev4??
- how thick is leading edge of a factory 28 bravo?
- Feedback on Long Island Propeller?
- 35 Cigarette Mistress 600hp propping Question..
- Need prop size help f26 dcb
- WTB - PAIR of Revolution 4 Props 21 Pitch
- Need props for 30' Scarab, 454s, TRS
- 4 blade vs 5 blade ?
- 32 Herings
- Damaged/Broken Props > How did you do it? Post Pics.
- Need help figuring out what prop to run!
- Is my pick up causing slip? pics attached.
- Need prop suggestions/alternatives for Cigarette style hull (36' with blower motors)
- I'm starting to think prop might be issue...
- What do I do to std props
- Blade Guards
- Were to start
- prop suggest
- This one has got me stumped!!!!! One for the prop gods!!!!
- Mirage 217 intruder from scratch
- Would these net the same RPM?: 17.5 X 35P 4 blade VS 16.5 X 35P 5 blade
- Back Up Props for Outboard F26
- identify lab props Help marks
- what size prop for 3600 Nor tech?
- what size props?
- prop selection
- Prop Selection Help
- Fixed Hub and Not Fixed??
- Baja Force 51 mph
- What prop to try next
- Should I buy a 2 blade prop?
- LOTO Shootout Prop Advice
- Labbed 32 vs labbed 34 ???
- Is this pick-up causing slip?
- Can someone help please? Identifying the company that labbed my props?
- Kaama props
- prop help please
- Do they make a 840389K06 hub kit for the 1" shaft
- Experts Speak Up !!!
- Prop clearance
- are these props right??
- Bblades
- 35 Outlaw prop update
- Looking for the best Prop for my boat
- Best prop
- BBLADES builds champions
- I have a starting point
- Mirage Plus 23 v Bravo 1 22
- Magnum 70 Trying to Achieve 60 Knots
- Can I get to 70 mph?
- Trying to identify my prop ...hydromotive?
- 1998 27 Fever with 496 Strocker prop help!
- Merc Props
- whats wrong with my velocity
- 1000 rpm from labbing?
- 5 blade maxmuson scrab 22
- ***OSO Prop Contest – brought to you by BBLADES***
- Donzi ZX 28 scorpion ..... Prop?
- 35 Outlaw stock 26P prop question
- stumped?? picked up 800 rpms with 2" of pitch while heavier.
- Looking for replacement props
- 91 predator viper 24' tons of prop slip. *help*
- better prop?
- need prop help. Donzi 21z
- 01 25 outlaw 496 mag
- Lab Finished Bravo 1 props "Mazco" stamp
- Bravo one question for Brett
- 242 LS prop question
- 29p5x
- Bblades trying to reach you on phone
- Bravo 3 props
- Need opinion...
- Herring? 6 blades
- Looking for a 20 pitch
- BBlades need some help
- prop suggest
- Whole lotta prop slip. Why?
- Props for Procharged Donzi 28zx
- Spinelli Props
- 37 Outerlimits Help
- Volvo DPX running at high altitude
- How to prop Baja 35 Outlaw with T-525efi
- Looking for a prop recommendation for my 1994 Sunsation Aggressor
- BBlades Special Delivery
- '89 292 454 Magnums prop and rpm
- 29 Nordic MCOB stock 502 high slip
- Liberator 241
- 87 baja 265 force prop?
- Spare prop for SSM3 4 blade, 31P 17 3/4 diameter - What is comparable in 5 or 3?
- Wtb 24p p5x rh
- 5750 rpm at 97mph, too much?
- Prop size blown 27 fever
- 21P or 23P Mirage Plus for 26 Scarab
- powerquest legend 260 prop
- 5-blades of sadness coming soon
- Is this the reason for low speed and 24% + slip??? photos of prop
- cracked prop, Looking for the best replacement
- 28 magic with 525 and 26p bravo
- Prop size in formula where do I start
- BBLADES Bravo 1/Bravo Sportmaster spacer plate test program
- 25' daytona 1100hp prop setup?
- Brett bblades I need help with zt280.
- Prop hubs
- prop pitch and dia
- hydromotive vs. bravo 1
- 38 flatdeck props
