PDA
View Full Version : Do It Yourself, Boating on a Budget
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. 500 EFI Fuel Rail Schrader Valve Connection
  2. Stainless marine dry exhaust plumbing?
  3. BBC Hardin marine oil pan project
  4. A little play in the outdrive still
  5. Mercruiser 454mag -1991 updating help.
  6. Build your own crane for stern drive
  7. Sci 575 head replacement.
  8. 489 build sheet?
  9. Liberty cyl heads
  10. Gasket Sheet for Brake Fluid?
  11. 1988 gm 350s omc 860 hrs over heat maybe
  12. We move in fuel injection and putting on a carburetor what do I have to do with the d
  13. 489 Stroker
  14. Gen 6 540 or Blueprint 632 in Magnum 27, Reversion?
  15. Melling oil pump / oil pan
  16. 489 Stroker
  17. Hydraulic Steering Issues
  18. Hardin marine stainless sea water / fuel pump
  19. 502 build-AFR 325 Enforcer head questions
  20. Cam Identification
  21. TRS sloppy steering issue
  22. Gen VI lifter type, push rods, and retainers
  23. Ignition Modification or Replacement
  24. How to diagnose air leak along water pump
  25. 1990 454/Bravo 1 impeller change
  26. I/o having trouble sucking up water
  27. 502 catalytic exhaust removal
  28. Fuel stabilizers
  29. 2007 496 ho guardian alarm over 3000rmp
  30. Hynautiq Oildyne trim tab pump
  31. Intermittent Engine Problem
  32. Sea Water Pump Pulley
  33. 525efi maintenance - 300hrs
  34. Engine Paint
  35. lambogini engines in a 35ft cig?
  36. 502MPI vent
  37. Electric Fuel Pumps
  38. Need Verado help please
  39. Oil lines for gen 4 454 Mag-Is is ok to replace with braided lines?
  40. NXT power steering bleeding
  41. Alternatives to foam around fuel tanks
  42. Sending 8.1 heads to the shop.
  43. Dry exhaust water dumps
  44. welding a skeg
  45. Block hugger headers & LSA
  46. 454 Knocking - Top End??
  47. OMC King Cobra Fluid
  48. Wire Diagrams for 496 Merc
  49. 502 efi doesn’t run
  50. Stepped Transom Water Pickup
  51. Mercruiser 7.4 Rear Engine Mount Reinstsllatiom
  52. TRS 454 to 350 Volvo Penta 270
  53. Hydraulic hose crimping sleeves?
  54. Crusader 454 Head Installation
  55. Aluminum Trim
  56. Seawater pump impeller change - 454 MPI
  57. 1995 454 Magnum EFI Stumbling and rough cold start
  58. 496ho manifolds on 454
  59. 1992 Formula 302 SR Windscreen DIY Tips n tricks wanted.
  60. Sudden oil pressure decrease
  61. L-29 head porting
  62. Latham steering cap and cylinder version questions
  63. Trim Tab removal, how to remove and reseal
  64. Bravo upper rebuild questions
  65. Merc 454 cast iron exhaust manifolds @ 500 hrs
  66. Intake Manifold Questions
  67. Mercury 500 EFI Noise..
  68. Merc 7.4 / 454 Burning a LOT of Oil
  69. 496ho no power to ignition, no beep
  70. Power steering fluid leak
  71. 1978 Superboat Project Help
  72. 502 MPI Converting to Carburetor
  73. 1985 mercruiser 3.0 alpha 1 gen 1 out drive engines bad what engines will fit
  74. 540 Gen V1 rear mounted oil cooler
  75. Cam and lifter choice 548ci
  76. Sea strainer is a game changer for winterizing.
  77. 540 Remote oil filter/ thermostat
  78. custom gauge manufacturers
  79. Mercruiser 496 Exhaust Manifolds - Aftermarket?
  80. Alpha one gen 1 Acorn anodes rotting
  81. HP500 Carb Flame Arrestor Fuel Vent
  82. Stock alpha one X-Demention?
  83. Sbc 350 Rebuild
  84. Problems with ignition/ carb / being able to shift on this boat
  85. how to connect a MSD 6AL to a Thunderbolt dist with no Tbolt amplifier
  86. anybody recognize this kind of ignition amplifier box??
  87. 454 honing or boring for oversize
  88. Trying to get a carbed TT draw thru to idle below 1100 rpm but it wont
  89. 330 on roids cam
  90. 502 rebuild and upgrades
  91. Gm 105a cs130 alternators?
  92. Cutting out both motors when trying to plane out on P-29
  93. Acculift Actuators
  94. Bubbles in cooling?
  95. Boat Stands/ Jack
  96. Steering wheel unit removal ? How to
  97. Dry exhaust mufflers
  98. twin I6 SC 400R's lost RPM from 7000 to 6300 max?
  99. Can base timing jump permanently?
  100. Why are the trim tab hydraulic tubes so short on these K planes
  101. Engine Stall under load/planing. 86 7.4’s
  102. 525 EFI random idle surge
  103. Mercruiser 350 MPI rebuild
  104. Seven Marine 627 Powerheads
  105. Anomalous engine merc 260 vol2
  106. Dana Power Hatch bolts spinning when tightening
  107. Anomalous engine merc 260
  108. MSD RTR Dizzy Died, anybody running a Pertronix
  109. oil cooler thermostat setup
  110. Intercooler water pick up + seastrainer
  111. Bravo gimbal rings-differences among the years
  112. 502 efi gen v flat tappet to hydrolic roller
  113. Exhaust tips
  114. 540 Camshaft needed
  115. 454MPI 330hp repair old EFI, convert to Holley HP or go carburetor
  116. Sierra Cap and Rotor for MPI- Quality?
  117. Homemade swim step 280 K plane
  118. Kill Switch not working
  119. OCD folks only with hydraulic steering
  120. Fuel Filter on CARTER CARB
  121. ECU error code 81?
  122. Switching quicksilver controls to kiekhaefer zero effort
  123. Full Hydraulic Steering System Operation
  124. LS style throttle bodys
  125. Bilge lighting?
  126. Is rust in manifols normal after sitting for the winter
  127. 300X Help?
  128. Need help 454 mag mpi gen 5
  129. Transom exhaust holes sbc to bbc.
  130. Remote mount oil filter and lines
  131. Considering purchasing a 1987 Wellcraft Scarab Panther 30'
  132. Mercruiser 454 Mag Reversion?
  133. 525EFI decal
  134. Mercury trim lines with -an fittings and stainless braided hose
  135. Need trim limit testing help please.
  136. Full hydraulic steering question
  137. Should I use a Merc 377 MPI system?
  138. 5.7 Vortec CR
  139. Never assume factory assembly is GTG.
  140. Engine water pump, needed or not.
  141. CMI E top header flange-anyone know what flange to use?
  142. HP500 Valve Springs
  143. 350 SBC updates?
  144. How to check sniper EFI fuel pressure
  145. gen 4 454 420hp HO
  146. Bore and stroke?
  147. What year 454 Block
  148. What Exhaust manifold bolts recomended
  149. Water intake hose
  150. Daytona CD1
  151. m3 procharger intercooler
  152. Pistons and coatings
  153. Bilge Blower vent tubing options
  154. Adding a console
  155. Imco/Mayfair ad-steering installation project
  156. ARP Bolts to convert Gen6 to Crane Golds
  157. Wanted bad MFI 1 computer
  158. New Steering Cable Install Issues
  159. Lack of Spark, or Fuel?
  160. GM Marine Crate Motors from eBay - Missing Low-End Torque?
  161. Pressure testing stainless marine manifolds and tails?
  162. 496 stroker
  163. Oil Pressure Warning Light, No Spark
  164. Pulling merc 5.7 without lifting eyes
  165. Rabbit hole with first 350 rebuild.
  166. BBC only spins 180 degrees? Any ideas?
  167. Hatches
  168. Injector question.
  169. Coupler replacement
  170. Merc 5.7 idles very rich
  171. How to Remove Grease From Upholstery?
  172. 502 mag mpi cutting out
  173. 502 Mag Oil Sender wire question.
  174. Silicone exhaust couplers...
  175. Most economic way to replace gimbal ring?
  176. Anyone by Dighton MA
  177. Blind bolt holes Gen V BBC, intake and heads
  178. Raw Water Pump hose fell off
  179. Merc 502 MPI spark plugs
  180. Testing the steering
  181. 460/429 385 series fuel pump
  182. Bravo 3 Shift cable
  183. New season, New problems 😣
  184. Oil remote thermostat...
  185. Anchor locker protection
  186. 502 MPI Upgrades??
  187. 86 454 Valve Covers
  188. Another VST thread
  189. Raylar 540
  190. Scat 9000 cast crank broke 383 SBC
  191. 502 Mag Mpi Whipple Rebuild
  192. High Pressure Power Steering Hose
  193. Custom oil pan level question
  194. To foam or not to foam
  195. cannot find 3/8 thru hull fittings?
  196. Arch removal from Sonic
  197. Slightly bent rod?
  198. Crusader 454
  199. leaking sending unit. How to fix it for good the right way?
  200. Piston ring material
  201. Replacing a 454 GEN IV engince core with a GEN V
  202. Boating on budget - no such thing anymore
  203. Need to identify the trim pump motor
  204. NXT drive bellows
  205. 454 build and tuning issue
  206. K-Plane Mounting NOVA
  207. Relocate power steering pump???
  208. Hole cut in bilge floor for pump
  209. 496 raw water pump scoring?
  210. exhaust valves by LS3
  211. Livorsi decals for shifter controls
  212. Installing motors
  213. Trim Pump Relay Bus
  214. Power steering pump modification?
  215. Spark plug color
  216. Bravo 1 conversion to Bravo X.. anyone done it?
  217. Ignition system question.
  218. 8.2 Mag EC Engine Questions & Confusion
  219. Power steering combining valve trouble
  220. Mechanical drive indicators installation help
  221. Extending factory 496 risers
  222. MEFI 1 or MEFi 3
  223. Anyone make O2 sensor plates for Eddie Marine exhaust ?
  224. Am I sucking up water? pics included
  225. 345cc dart iron eagle head any good for boat?
  226. Sea strainer location
  227. Mercruiser Mag 8.2 HO “Mercury Fault 3 Sea Pump Pressure Low”
  228. (NJ) What scan tool for 2011 Mercruiser 8.2 Mag H.O.’s? And other advice…
  229. Digital Dash Cover
  230. Engine boxing/ shipping
  231. Oil line routing question???
  232. 575sci msd 6m2 wiring
  233. Serpentine roots blower crank pulley mod
  234. I need a new stock or mild performance cam for 330hp
  235. How much to trailer a 40-footer 145 miles?
  236. Yamaha Outboard Lower Unit Fluid Fill Question/Advice
  237. What timing chain set for a Gen IV?
  238. engine mounts are the billet ones worth the extra cost
  239. Evercoat gelcoat scratch patch
  240. O-ring for 575sci
  241. Cover girl cabin
  242. Valves
  243. Transom assembly is it savable or junk?
  244. Curious: why cant HT502 be marine?
  245. 502 running
  246. Flame arrestor mesh
  247. Kiekhaefer seal
  248. MSD All in 1 Distributor
  249. Weird electrical issue, any ideas?
  250. LS swap
