- Gel Coat in bilge
- Need some insight on if cracks in top deck are structural or just cosmetics Scarab 43
- Looking for a bottom paint that can be used to touch up Micorn 66
- Advice for applying Interlux 2000e and Micron 66
- Transom Rot Repair
- coosa board for engine hatch
- Expoxyglass Board Repair?
- "roll and tip" with interlux paint?
- Installing a Fiberglass Hatch Scoop
- Oxidized gelcoat voodoo?
- Gel-Cote
- Replacing stringer, Chainsawed out wood, how to remove remainder and grind?
- Bilge Work Question
- Trailer Paint
- Awlgrip paint.
- PPG Concept paint code to match Phantom Black
- Add more pigment with duratec additive? Dave?
- Painter in Orlando area
- bondo?
- Gelcote or paint
- Clear bra
- We disagree. How fast do you move the grinder when grinding glass for stringers?
- Searching all night, where is glass daves transom layup drawing he posted?
- Easiest way to fix stripped out screw holes
- Matching white gelcoat?
- Gelcoat Scar Repair - Need A Shop Near Evansville, IN
- Pic: Are these limber holes properly resined?
- Black gelcoat
- Wetting technic for 1708
- baltek AIREX core glassdave.
- Benefits of making a mold?
- replacing main stringer and transom
- Small repair... Help!
- Painting rubrail
- Sealing wood with Resin
- Paint question
- Graphics Rendering
- hey!
- Looking for a painter in Sarasota, FL
- Wacky idea: Adding a core to a solid glass boat ?
- Rotten bulkhead HELP!
- where is everyone getting there fiberglass materials
- 88 Pachanga 32 fiberglass repairs
- 404 filler vs dowels for thru bolt holes
- Using West Systems. how much to grind old fiberglass?
- I have a couple gel coat questions, any help appreciated
- Keel Scuffs from center bunks - what to use?
- When cutting out stringers and bulkheads, is a trailer enough support?
- Deck project help
- Blisters On Scarab III
- Another buffing/waxing thread...
- fiberglass work on 40fter in cold
- Ugly corner cockpit crack appeared this weekend.....Advise on what should be done?
- Anyone used Plasti dip on your boat?
- Donzi Transom
- Fiberglass Repair Shop Tools
- Matching gel
- Hot to refinish anodized parts
- How to SCARF join a stringer?
- All white 33avs Scarab new paint need ideas...
- Boat Materials Thread
- Wish to make a lighter swim pad on a Scarab 33AVS
- Vinyl paint
- Gel coat work ft Myers Cape Coral fl area
- Best Companies for Transom & Fiberglass Repair East Coast????
- Please help me with this color!
- baja colors
- paging glass dave
- Gelcoat Overspray removal NEED HELP!
- Paint removal
- True material cost of re-gel coating a 38 special?
- Re-gel bottom of 26 daytona
- 90 TopGun fiberglass repair
- Removing Pine Tree Sap?
- Need Advice on how to make some releifs in the underside of my engine comartment hatc
- Moisture question
- How flammable are fiberglass resin fumes
- Spider Cracks and Small Holes in Hull Advice Needed
- Transom Fitting
- Removing bottom paint video... Saw this on my classic car.
- 99' 32' Fountain Fever - wet sand
- Glassdave: rotisserie picture(s)
- Should I adress blisters or ignore them?
- Cause and Concern??
- AAA Marine Fiberglass Repair Gelcoat Repair Boat Detailing Boat Painting Bottom Paint
- 27PC Transom Repair
- were to get blisters fix in the atlanta area
- a customer of mine bought this boat and didn't even look at the bottom
- Attn: GlassDave (Bilge paint and fiberglass)
- Hey GlassDave ? on repair of chips on lifting strakes
- getting rid of white chalkie substance on fiberglass
- Clear non skid
- Sealing holes drilled in transom/hull
- removing paint from a polished blower
- Clear coat over gel
- GlassDave question---again!
- Proper Gelcoat Repair Sanding Sequence?
- Formula hull chip help....
- 32' Fountain Fever Paint
- Newbie Q for Glassdave
- gel coat clear duratec ?s
- Bottom Paint back to Gelcoat?
- gelcoat
- Paint Codes?
- Thinking about getting my boat painted or possibly wrapped.
- Just got a quote to paint boat, SHOCKED!
- Filling holes to match gel coat
- Royal Blue Wax
- white bottom paint
- what to use
- Drilling 3" hole above rub rail - Advice Needed
- Checkmate seat help
- price to convert boat to midcabin open bow
- please evaluate these pics for me
- Cost of Epoxy Laminates vs. VinylEster Laminates
- Refinishing drives
- Fiberglass Work
- guage panel repair
- Can I Fill Bolt Holes with Just Gel?
- Best place to buy Resin.
- Sunsation blue paint code?
- Glassdave "COLORPRO" and XTINOVATIONS experience
- 88 baja 240 rebuild
- Help!! new transom and bulkhead got wet
- Fiberglass crack help
- Fiberglassing stringers
- Looking for good fiberglass shop/person in Arizona
- How do I clean and brighten my fiberglass/gel coat non-slip areas on the deck?
- Is there any "off the shelf" Tints for Gelcoat?
- Trim Tab screws ...3 striped out ....advice ..Please ?
- Painting My Windshield
- Spider crack repair
- Downtime for new paint?
- Looking for a boat painter in Central/Northern Cali
- Straighten out style lines?
- Lag bolt stripped out fiberglass. How to fix?
- Roll & Tip Painting
- Baja Cuddy Bilge Pump Redo
- Baja engine bay stringer replacement question
- Water Transfer Printing
- Print through on deck how to fix
- engine paint
- Bottom of hull paint?
- Rustoleum engine room redo
- West Systems bonding epoxy
- Cigarette Bullet Deck
- rope burn
- Fixing Gel Coat Chip
- FOY Vibra Cut
- New gel coat cure time
- Powerquest 280 hull question
- HELP! Brown stains from lake
- Fiberglass scoop for quad whipple super charger
- Stripped out lag bolt holes in glass, need help??
- Gelcoat over filler?
- Adhesive for hull decals?
- Anyone used 3M Perfect-it Rubbing Compound?
- THumbs up to Fiberglass guys.....
- Convincor custom fiberglass swim platform
- Looking for old gelcoat boats in So Fla for compound tests.
- Paging GlassDave
- Adding drop in bow rider in Daytona
- Any one with some 99U Imron pitch black
- Endura or Gel on bottom??
- sandblasting motors
- Rubber coin flooring
- blueprinting bottom
- Imron protection recommendations....
- Yellowing gel
- Polyester paint over epoxy primer
- Polar shine 35 VS Aqua buff
- Materials
- Glasstron Carlson CVX 16 Transom
- Baja center floor repair
- boat paint
- Bilge coating is chipping off
- Awlgrip sag
- Buff, polish,wax info. Link
- My transom cut out... what epxoy?
- Thoughts on this simple paint idea
- Using finite element analysis FEA on a Formula 302
- filling rotten Stringers with "Nidabond"?
- Need opinions on painting assembly
- Can anyone steer me to some weight saving posts/articles such stringers transom etc
- Fiber glassing bulkheads in cabin
- Outdrive painting
- Filling Cuddy Deck Window Hatches
- Gel coat buffing and polishing
- Best tool to cut out new transom wood?
- Looking for 3M Hookit 6" wet sanding disc. Which one?
- Powder coating
- Removal of paint
- Need advice on removing a painted stripe.
- Bunk trailer and stringer removal
- Bottom reapir
- 26 ft American Offshore Paint and Graphics
- 35 motion catamaran hull flex????
- 3M Nida-Bond and Corebond the same product?
- Paging GlassDave Paging GlassDave
- Question for Painters / GlassDave
- Out drive paint info
- Looking for a boat painter - Long Island
- old sticker and adhesive removal! cake!!
- Boat painter
- materials
- 89 Scarab lll, Transom, Stringer, Paint, .......ect
- filling holes
- Transom and Stringer Replacement
- Best bottom wax?
- Baja 38
- 73" scale model Cigarette flatdeck
- Too late to foam stringers??
- Fully bonding in Transom
- Footrests? Anyobdy on here make them?
- Vinyl/Upholstery question
- Transom replacement full vs partial
- Filling holes in Pirelli flooring???
- How do you fix this??? Minor Keel damage.....
- To bed or not bed stringers that is the question
- thinking of changing from Triple to twin - Any good stringer folks in Florida??
- paint help
- Dave hunter
- Cleaning bilge
- Bildge paint
- Rebuilding the stringers and floor system
- 88 Baja resin type?
- Engine compartment Stringers 89 Panther
- Help with stringers?
- Modifying fiberglass hatch scoop for more clearance?
- Q&A session. Any input welcome
- Bonding floor to stringers
- Cabin stinger parts list??
- Fiberglass patch and stress cracks
- correct paint
- vinylester stringer & transom ?'s
- sudsbury fiberglass boat cleaner
- Taping off gelcoat
- fiberglass person needed
- Por 15
- Pics For Glass Dave
- Where is Glassdave located
- can I cut this?
- Rebuilding my glass/gel floor - properly
- Rotary Buffing Boat
- Where do I start? New Paint....
- Learning to work with fibreglass?
- HELP!!!!! With transom repair.
- Wet sand or buff?
- fiberglass caulk
- gel coat repair revisited
