PDA
View Full Version : Detailing, Painting, & Fiberglass
Pages : 1 2 3 4 5 [6] 7 8 9 10 11
  1. painting a stand up ski..
  2. Removing tabbing, glass??
  3. Bottom paint removal chesapeake bay area
  4. Outboard transom repair??
  5. Any Body Use Shine On Boat and RV Restorer
  6. help with muddy water stains..
  7. how to fill holes in transom for outboard conversion
  8. Removing painted on lettering?
  9. How to look for rot/wet core?
  10. acetone and gel
  11. Bottom Paint Peeling
  12. Custom painter at LOTO ?
  13. Scratches on Bottom
  14. Awesome video documentation of complete overhaul
  15. Repairing rot
  16. how to remove bow roller marks
  17. Leverage vs. Vitero
  18. Refinishing advice needed
  19. blistering on botton
  20. twin to single conversion on a CAT
  21. Where to Locate Dolly for painting a 38 Foot Boat?
  22. glass & paint guy wanted between n.y.c & maine
  23. question about marine paint and clearcoat
  24. Vinyl Graphics Designer Recommendations
  25. Gelcoat safe solvents
  26. Looking for a Wrap guy near Philadelphia
  27. Any good fiberglass guys in Michigan or Indiana?
  28. Rocket repaint
  29. can i have some advice on grit sizes for painting my boat?
  30. weekend paint job
  31. Boat wrap, gelcoat, paint...?
  32. Spraying Gelcoat
  33. Removing spray on bedliner
  34. Pro's and Con's for this Wolfgang Paint Sealer
  35. Couple of problem areas, Glassdave please advise!
  36. Cougar Cub=Glassdave Help
  37. Vibra Cut
  38. Epoxy adhesion question?
  39. How to bring boat paint back to life???
  40. repainting trailer????
  41. Quick Detailer/Cleaner
  42. Custom Paint??
  43. trailer paint
  44. Fiberglass current products
  45. epoxy paint
  46. CARLOS A PAEZ boat builder
  47. How to keep resin from curing/sticking to roller?
  48. Going price for GEL COAT repair ?
  49. BTS protectant/sealant?
  50. Question about. deck not straight
  51. Meguiar's 105 Compound
  52. Transom Work in Chicagoland
  53. Oxidized aluminum, prep to paint?
  54. How to get this off paint
  55. bonding hull & deck question?
  56. The Re-Birth of an Apache Scout
  57. Wetsand/Polish price per foot?
  58. Showing off some Fountain of Youth after pics
  59. Bottom Paint
  60. So has anyone used the Permanon on a boat?
  61. Wheeling Questions, First Time
  62. What material glove for Vinylester
  63. linex on outdrive
  64. painting spray on bedliner ?
  65. Painting caulk/sealant
  66. Best "wax" ever!!!
  67. what do you think ? bottom coating
  68. Gel Coat Crack Repair?
  69. Deck coating....need some help ASAP
  70. How layers of 1708 - 1/4"
  71. How to repair small holes in the transom?
  72. Hatch and Bench Seat Rebuild
  73. Delamination
  74. Airbrush my hatch cover
  75. 1979 pantera 24 Imron paint job pics
  76. How to clean carpet glue up from cuddy
  77. Spider cracks and pox marks
  78. piling damaged glass and gelcoat......repair help?
  79. epoxy and ultraviolet exposure
  80. Painting cockpit floor
  81. base/clear or single stage
  82. How much Gel
  83. spider cracks
  84. interlux bilgekote
  85. refinishing glass with oxidation, seat base,minor repair help needed aswell!!
  86. How can I safely rub out boat with Decals/Stickers?
  87. How to remove anti-fouling paint
  88. fiberglass HELP 1708
  89. Best tool for cutting fiberglass
  90. What to paint a lift tube with?
  91. Whats the latest and greatest compound?
  92. Off Topic-Body work guys
  93. deck and hull side bonding
  94. Stringer!
  95. What's it gonna cost?
  96. glassing the cockppit floor to the hull???
  97. boat wrap?
  98. Coosa Board question
  99. Paint over powdercoat
  100. New fiberglass construction shop?
  101. Does the 20 foot sutphen have a cored hull?
  102. hull painting
  103. MDO Plywood vs. Marine Ply vs. Coosa Board
  104. Painting alum checkerplate
  105. Chipped Fiberglass
  106. Turtle wax ice
  107. Painting: floor, gunnels, and interior sides.
  108. Gouges on the hull bottom
  109. engine compartment
  110. Installing depth sounder need help
  111. what do I paint the bottom with?
  112. Through hull water pickup epoxy
  113. Graphics Question PPG BCCC system
  114. paint for side of the boat, under soem water
  115. Gelcoat
  116. resin?
  117. Before and After Glass Daves Work!!
  118. Detail price?
  119. ?? for Glassdave
  120. Transducer removal
  121. Gel Coat DIY Help and Through Hole Patch Help
  122. How do you tell if its paint or gel?
  123. Wet sand and wheel?
  124. Good place to buy cleaning supplies
  125. patch gas tank
  126. Black FG - pros & cons
  127. Bolster base and rail finishes
  128. Looking for buffer/wet sander/detailer Tampa Florida
  129. Powerdercoating a 502 intake plenum
  130. Random Orbital Buffers vs DA
  131. Steel trailer what paint??
  132. where to find taller hood scoops 32 skater
  133. Buffers?
  134. resurrecting a 1985 Baja force 220
  135. Caulk Cleaner?
  136. stringer replacment
  137. removing graphics ???????
  138. Anyone Know Who Does This?
  139. Painting Plastic Engine Cover
  140. Changing Graphic Colors
  141. re-installing fuel tank help
  142. Fiberglass Work??
  143. wet sanding with a DA?
  144. Drilling a hole for a through hole fitting
  145. DA sanding
  146. Gelcoat buffing/sanding question
  147. De-waxer
  148. Bulkhead Repair w/ no access
  149. Its laquer
  150. Wood Grain Gel coat
  151. fibreglassing floor
  152. What type of Rubrail needed?
  153. bottom of boat
  154. 311 cabin stringers
  155. Help GlassDave!
  156. prepping a re-gelcoated boat for paint
  157. A Little Gel Coat Help Please...
  158. transom replace
  159. A few paint prep questions??
  160. Rust Guy??
  161. Bottom Paint
  162. Advice on repainting floor
  163. Gelcoat or Paint
  164. Gouges on the keel
  165. Flooring questions
  166. Adhearing vinyl to fiberglass????
  167. Need prelam panels made.
  168. Finishing over Epoxy
  169. How many gallons of paint?????? 33 Powerplay???
  170. Donzi Grumble Green color match and recommended paint? (PPG?)
  171. gelcoat clean up
  172. Carbon vs Fibre glass
  173. small gelcoat repair help
  174. Best paint
  175. Painting transom questions about quote
  176. New stripes ? Need Help Pic one
  177. Gel Coating a Cast Iron clawfoot Bathtub
  178. checkmate 253 template
  179. Crack repair
  180. duraglass, tigerhair?
  181. Glassn' on a scoop?!
  182. Best way to seal through hull bolt holes on transom
  183. Interlux BilgeKote -- Use/Opinions?
  184. Is aircraft stripper safe for removing paint on a boat???
  185. New Project - Need help estimating design and materials
  186. Engine painting questions...
  187. Fountain template
  188. mystery product needed
  189. Removing Saddle Tanks
  190. Seadoo help
  191. filling in deck hatches on a cored boat, what glass is best??
  192. Blister repair
  193. Please Help - Need graffix ideas
  194. Looking for advice on prep work before painting
  195. Question on Interlux Perfection
  196. oxidation mayhem
  197. Molding steps for dash
  198. boat painting
  199. Formula Glove Box Lid
  200. Preparing old boat for paint
  201. dual engine hull to a single engine???
  202. flooring
  203. Looking for a good fiberglass in NJ
  204. Removing bow lights?
  205. Looking gelcoat/fiberglass referral in Virginia
  206. Fiberglass Repair & Clear Coat
  207. how to cut 7/8" hole in fiberglass side panel?
  208. Shurhold 3100
  209. Should I bottom Paint?
  210. 233 stringer replacement- cloth help
  211. Need some corecell A500 1 inch, whos got some??
  212. Glass dust & the grinder
  213. Any one interested in the progress
  214. fiberglass work on a 272 formula
  215. Fairing out 1700
  216. painting drive primer
  217. Question for GlassDave
  218. Blueprinting the bottom?
  219. Bilge painting
  220. Guide Coat
  221. Thru hull sealant
  222. can clear coat be repaired
  223. Cigarette Paint Codes
  224. PolyGard Gelcoat
  225. Gel coat shelf life
  226. Boat renderings
  227. Cost to have a 21 foot Scarab painted?
  228. Project for GlassDave??????
  229. removing anti growth paint
  230. can you tint a neutral gel coat white?
  231. Painting new graphics
  232. paint or wrap durability?
  233. Will yellowing/off white color wet sand out?
  234. filling a hole from a thru hull fitting for a pump out toilet
  235. fiberglass hole filling
  236. hey guys let me know
  237. Best hull cleaner I've used
  238. exterior ply wood
  239. Drilling a 2.5 inch hole in a stringer
  240. Plugs in transom
  241. Transom cutout fill in
  242. Looking for boat painter in NJ or Md
  243. Sonic 31SS crack along walkway....what to do??
  244. Finally decided on taking the job of building my own windscreen for my 1996 272 baja
  245. brand of resin
  246. Resto questions
  247. need 1700 in noth east ohio
  248. Removing water out of gas tank
  249. 3M Fine Line Tape Usage Suggestions
  250. Hull Widening ??? .. Why And How ?
