PDA
View Full Version : Detailing, Painting, & Fiberglass
Pages : 1 2 3 4 [5] 6 7 8 9 10 11
  1. Cleaning up props
  2. Planning some repairs/upgrades
  3. How to replace coring
  4. Painting an 85 chris cat. Proper prep.
  5. Building new blower hatches
  6. Wet sanding, when to change discs?
  7. Floor and Structure Questions
  8. Sole fiberglass requirement?
  9. Buffing not going so well..
  10. Hey Glass Dave ?? Poly or acrylic ??
  11. paging glassdave
  12. leverage shelf life?
  13. Need Help in Houston?
  14. Stripped threads - help
  15. u bolt in front ripping threw a little
  16. Black transom and graphics
  17. buffing out a single stage paint?
  18. Boat Candy Feedback
  19. cutting crossmember in a Baja 272 (2000)
  20. Bilge paint - which paint?? So many options...
  21. Cost to paint a 31 Sonic white
  22. balsa coring
  23. Clear Gel Coat ???
  24. waxing frenzy?
  25. Custom painted flame arrestor covers?
  26. gel coat stripe?
  27. SCARAB paint codes?
  28. Laminate thickness question?
  29. 3M 5200 Deck to Hull Bonding Help
  30. Removed old decals, now what?
  31. 382 Project Boat - How to do the top sides?
  32. Good OTC non-marine wax?
  33. Fiberglass Platform Repair and Re-Gel Coat w/Pictures
  34. GlassDave need some paint help....
  35. Squid needs direction on main stringer...
  36. Nozzel question?
  37. Fiberglass Resin and Metal
  38. Epoxy Paint for bilge?
  39. Need ideas
  40. gel coat shelf life?
  41. Gel-coat/painting keel?
  42. filling trim tab holes
  43. Paint vs. Galvanize
  44. Gelcoat 101 I need all the help I can get
  45. Removing "Soot" From Paint ?
  46. Non-skid additive for gelcoat , can i spray it ?
  47. Step Removal
  48. Leverage/Spider Wax - works great.
  49. newbie question - scarf and scarf ratio
  50. transom rebuild-epoxy resin or polyester?
  51. Need glassdave to look at this crack I just found in my hull
  52. Almost ready for paint
  53. Recommendations for Gelcoat repair
  54. X-demension on 20 ft non-step v
  55. scoops?
  56. Wanting to build steps in my transom
  57. In a bit of a rut...stringer wise!
  58. how to turn a cat into an open bow????
  59. need help cleaning lime or hard water
  60. K-Plane thru-hull fitting removal
  61. hull id #s-stamped in fiberglass hull
  62. Need to attach something to the inside hull
  63. Gelo coat safe paint remover
  64. Engine Pics
  65. Paint Question...
  66. Hula Boat Care waxes
  67. Need help with gel coat
  68. Lowering my Engine Hatch
  69. transom repair-plywood
  70. Removing graphics / repainting?
  71. 353 fast tech bottom paint removal !!!!
  72. Painting Help
  73. transom repair
  74. What are keys to spraying orion silver metallics?
  75. Mobile fiberglass repair/work?
  76. Black bottom paint??
  77. deep scratch needs fixed
  78. FG foam cored hatch edging - best way?
  79. bilge finish....paint or gelcoat?
  80. Bottom painting over Imron
  81. Clear coating new aluminium intake
  82. fixing boat decals
  83. Does it matter!
  84. DIY Painting Lower Unit
  85. coarse area on bow
  86. lt blue gel coat pigment
  87. Tips for Painting assembled motor with Rust
  88. Temps
  89. post a pic
  90. Powder Coat or Paint
  91. Filling exhaust holes
  92. When to pull tape?
  93. Controlling overspray
  94. Outdrive/transom Assembly paint
  95. Screw holes wearing out...
  96. 2k surfacing primer over epoxy?
  97. duratec primer over microballoon fillers?
  98. Paint engine assembled or not???
  99. What cloth / mat to use ?
  100. stringer repair question
  101. Paint over Epoxy
  102. carpet adhesive -Removal
  103. Leverage Products
  104. Deep fairing compound
  105. Painting the stripes...
  106. The Proper Way to Paint a Hatch?
  107. Iwata Gun
  108. clearcoat scratches
  109. Square yards = gallons of resin
  110. Bilge Fairing compound??
  111. "Cigarette" and "Top Gun" cursive script logo
  112. From the mold to the trailer
  113. boat buff and wax
  114. Need Advice for an Idiot fliping XK-19
  115. transom patch, from omc to bravo
  116. fiberglass product recommendations
  117. Flaking clear coat - Help!
  118. lifting boat off the trailer for paint
  119. surface wax removal
  120. boat painting
  121. My skater 32 skater paint
  122. self etching or epoxy primer
  123. Single Stage Paint & Gun??
  124. orange hellfire
  125. Hydrohoist bottom paint
  126. 3m Premium filler
  127. new paint shop Dutton MI
  128. Filling holes in stringers
  129. Repairing imperfections on sides of boat
  130. Epoxy and 410 filler
  131. Easier way or product for painting small pieces?
  132. fix for where hatch hinges bolt??
  133. what is everyone using as a fillet material
  134. Deck Removal?
  135. Removing thru hull depth finder. Fixing the hole?
  136. Gelcoat to far gone-PAINT
  137. Filling Compound for Aluminum
  138. painting - costs?
  139. I/O to O/B conversion questions
  140. Paint Advive Please???
  141. MTI Paint
  142. Wet sand help.
  143. Bolster redo? Kinda plain now
  144. BAD fiberglass job on The Bachelor tonight?
  145. what kind of fiberglass resin
  146. Bring the color back out
  147. Converting a Single F16 Canopy Race into a 4 Person Canopy Pleasure
  148. Anyone using sketchup to design parts?
  149. Scratches on bottom.
  150. what type of plywood is everyone using
  151. what type of plywood is everyone using
  152. Drilling a hole thru the transom?
  153. how many layers of glass
  154. What type of vinyl for marine graphics?
  155. painting a stripe...do i need to clear over it?
  156. Clear Coat
  157. Painting
  158. Best way/ tool to cut speaker holes in cockpit?
  159. Delamination
  160. No Paint Here
  161. Bilge paint recommendation
  162. anyone used aeromarine epoxy resin
  163. Donzi 16 Blackhawk
  164. glass over a sub box thats mdf ?
  165. another one for glass dave, or anyone !
  166. Painting Galvanized Trailer
  167. Paint job video?
  168. Heather will not show my posts or threads.
  169. Fitting a Raymarine E7 in my dash
  170. Bondo and sandpaper
  171. 24 7 pantera floor repair question
  172. No bracing between stringers?
  173. Awlcraft 2000 coverage
  174. fiberglass work
  175. Looking for car door style trim for fiberglass edges
  176. painting drives
  177. Gauge panel
  178. Notched Transom purpose?
  179. I know that this isn't a boat question but it has to do with fiber glass
  180. priming epoxy repair
  181. Glass Fiber Shortage???
  182. Repairing transom after trim tab removal
  183. Props For Glass Dave Great Work!!!!
  184. Glassdave
  185. Cabin refinish
  186. my winter project
  187. new boats painted
  188. Partial or full transom replacement???
  189. epoxy and mat compatibility
  190. Ghosting process
  191. transom replace
  192. Would epoxy work best?
  193. Carbon Fiber Question
  194. Removing Painted on Graphics
  195. PPG paint to match gelcoat
  196. primers?
  197. Donzi Z25 keel damage from beaching
  198. Need some glassing advice guys
  199. glass dave
  200. surface wax
  201. Glossy Bottom Paint
  202. Building a new engine hatch - any pointers?
  203. Transom advice
  204. tree fell on my boat. Fiberglass?
  205. Duplicolor metalcast
  206. glass dave this ones 4 u
  207. glass dave this ones 4 u
  208. high build surfacing primer
  209. wrap removed
  210. replacing the transom in my 415 Stinger, looking for advice
  211. fiberglass repair in Maryland
  212. Modifying strakes on a 24x7 hull (24 Pantera)?
  213. A quick question on fabric and a picture
  214. How hard is Fiberglass for the DIY??
  215. Ready to paint my bilge, narrowed it down But Need part #s
  216. Best core material for windscreen to replace windshield
  217. 38 scarab Hull material questions
  218. thickened epoxy or rage gold for fairing
  219. Restoring Gelcoat -versus- Painting (?) Pro's & Con's
  220. Rough sanding....what's next?
  221. New England paint shop.
  222. best clear to use
  223. What do I replace these stringers with?
  224. Imron??
  225. removing 3m5200 or the like
  226. Best Gel / Glass Guys in the MidAtlantic Area!
  227. wet sanding any buffing gel coat
  228. Paint Vs Gel Coat ???
  229. Fiberglass repair in the midwest area
  230. How can you tell
  231. black stains on gel from gas vent
  232. Ohio boat painter?
  233. Another Hula Boat Care fan
  234. Carnuba or not to Carnuba?
  235. Removing Adhesive From Paint
  236. So I searched and researched I think I am ready?
  237. Fiberglass
  238. Help with hull problems.
  239. Not your usual dirty water stain question
  240. Regelling a 28' cig. How much should it cost?
  241. Hula Boat Care
  242. strong adhesive/epoxy
  243. fountain bildge paint
  244. stress cracks in gel coat
  245. Imron or awlgrip ??
  246. Any Body Got a Snap On Buffer
  247. Building Race Hatches.
  248. Touch ups?
  249. Hula Boat Care Fan
  250. Touch Ups?
