PDA
View Full Version : Detailing, Painting, & Fiberglass
Pages : 1 2 3 [4] 5 6 7 8 9 10 11
  1. Cougar cub damage
  2. transem material multipanel.com?
  3. fiberglass materials
  4. Need some help with paint !
  5. Cig TG Transom Replacement HELP!!!!!!!!!!!!!!!!!
  6. Redoing stringers
  7. How do you topcoat an epoxy repair? GlassDave?
  8. How far should I go?
  9. Vinylester resin transom/stringers
  10. Trailer paint?
  11. Epoxy or gelcoat?
  12. Metalic paint removal help and advise
  13. Baja colors and repair
  14. Removing decals on 17 year old boat?
  15. Anyone Do Custom Fiberglass Parts?
  16. What Color to Paint Bilge
  17. Help.....please. Gelcoat not fully cured
  18. Tech info needed on U.S. Composites Gelcoat.
  19. Is it worth it?
  20. Rustoleum over Bilgekote?
  21. Inverted Hatch scoops
  22. removing resin drops.....im a slob!
  23. Gelcoat missing
  24. Surface prep before spraying gel
  25. Smooth finish for bilge?
  26. orange peel
  27. Best thing to thicken gelcoat for spot repairs?
  28. 15'5 Ocean Express Nitro tunnel....Complete rebuild, custom paint
  29. Transom Patch TRS to Bravo
  30. shooting awlgrip
  31. Repainting stripe
  32. Transom and stringer replacement '95 Islander
  33. Cabosil for gelcoat
  34. platform grip
  35. In Gel Graphics?
  36. I'm having a hell of a time taping straight!
  37. Why does resin cure so much slower on the boat than in the cup?
  38. cabosil and vinylester in place of corebond?
  39. Sliding Door
  40. sonic crafter cutting tool deal
  41. Vinyl-ester work time
  42. Gel still wet
  43. Weighing mekp for gel question
  44. Painting grip tape
  45. Good Painters SE FL?
  46. awlgrip and bilge
  47. Interlux AWL GRIP refinish on my 1989 Donzi Black Widow - PHOTOS
  48. Which brand of wax are you using?
  49. Oops.... Gelcoat mistake ...
  50. Hey dave , ever installed steps on conv v bottom ?
  51. Donzi ZX Deck/Hull Joint
  52. boat wrap question
  53. Bottom Paint Removal
  54. respirator/eye protection etc....
  55. Fountain of Youth Products (a before & after)
  56. What to cut Transom outdrive cutout with? Jigsaw?
  57. Paint bubbles/spots
  58. Help with Cabin Paint
  59. Bottom Painting
  60. Partial Transom Replacement
  61. Gel gun
  62. Glass help with sub flooring??? Pics inside.
  63. How long for paint to cure?
  64. 24 outlaw clean up
  65. another satisfied customer! thanks glassdave!!
  66. Imron on top of dark gel?
  67. Detroit CL Fountain with yellow flames
  68. Excalibur 24 rebuild
  69. Dark Colors on a boat
  70. Dump gun technique
  71. Speedo hose hole
  72. Cost to paint a 38 Cig
  73. AWGRIP paint problem
  74. Speaker hole
  75. Wax remover/degreaser before polishing??
  76. Gelcoat gouge repair
  77. Anyone used the Farecla Profile Compounds?
  78. Hull repair
  79. Filling transom holes
  80. Best Clear for the $ ?
  81. Gelcoat or expoxy
  82. Boat painter in Texas?
  83. Fillers and fairing
  84. 20-30 yrs 5oz Kevlar 50"or 60"
  85. Painters in southern CA?
  86. Shelf life of resin and catalyst?
  87. Painting bottom of boat options
  88. 28' Cigarette Center Console Conversion
  89. Awlgrip metallic's
  90. Glass Work
  91. Restoring for a bravo
  92. Foaming Gas Tanks- Help Dave
  93. Recommendations for Electric Polisher/Buffer??
  94. How long before epoxy is not wet enough to bond?
  95. Rustoleum and hardener question
  96. Stringer Bedding?
  97. Little help from the pros...
  98. Ppg delfleet evolution
  99. Aircraft Gel coat sealent
  100. Need Recommendation on Gelcoat Wax
  101. Floor over fuel tank.
  102. Transom
  103. Modifying Engine Hatch
  104. Replaciong the transom, and thinking about trying foam composite.
  105. types of paint
  106. Boat wraps
  107. Another happy Mitcher T customer
  108. Can non-skid be wet sanded?
  109. Boat wraps
  110. Repainting Bravo 1 Lowers
  111. I need some opinions...best paint for graphics?
  112. Question for Glassdave and others
  113. Gel Coat Chip and other Sealing Issues
  114. Spar Urethane vs resin... wood
  115. thinking of attempting a project
  116. looking to build a mold for a winscreen from a existing windscreen
  117. Stress crack repair
  118. Anyone ever use Plasti Dip???
  119. How far do you go?!?!?! Glassdave help!
  120. recommendations for metallic chrome spray paint
  121. Cabin Floor Runner Replacment -- Questions/Alternatives
  122. Transom and Stringer work - 233
  123. Partial Transom replacement
  124. Custom Graphics / Decals
  125. Cutting a transom notch??
  126. OK to notch stringers for clearance?
  127. Looking for a painter & upholstery north of vero beach
  128. Paint code #
  129. Where to get matching gel coat?
  130. Wow Thanks Rob
  131. What adhesive to bond aluminum to fiberglass?
  132. dash paint//labels
  133. shifter paint
  134. Imron
  135. Gelcoat restoration
  136. Painting question
  137. how should i handle this delamination issue?
  138. removing painted graphics from on top of gel coat
  139. Any good boat painters in ct??
  140. painting engine
  141. Question for Glassdave
  142. advice on paint guns
  143. How do you make a mold?
  144. Bilge Cleaning - Gel Coat
  145. Bottom of hull repairable? What is it?
  146. Help with paint flaking off??
  147. removing graphics
  148. Need a good repair guy
  149. Anyone with bottom paint(micron CSC,trilux II)
  150. filling gouge (hole) in cowling?
  151. skater style bustle
  152. Painting k plan help
  153. What white for complete respray
  154. acceptable moisture meter %
  155. Anybody know why you can't gelcoat Interlux Watertite Epoxy Filler
  156. Yellowing Non skid gel coat was white
  157. What materials/manufacturers do you use and why?
  158. New Guy Sorta
  159. New Imron Marine vs. PPG Concept
  160. Looking to buy a set of jacks
  161. painting a 30 plus foot boat
  162. Bottom paint removal & gel coat repair (pics)
  163. Best way of removing bottom paint
  164. Engine hatch "latch"?
  165. new gun
  166. Bulkhead rotten in 29 Fountain
  167. Skater Gel-coat
  168. sticky edges?
  169. Pulled off K plane, got a few layers of glass, now what?
  170. To clean black plastic hatches?
  171. paint film thickness
  172. Polisher/Buffer Equipment Recomendation
  173. Nor Cal Boat Painters?
  174. Gel or Paint
  175. At what point do you call a transom rotted?
  176. bilge sanding tools?
  177. How should I access and attack this transom?
  178. gel coat bottom but no wetsanding or buffing
  179. Making a B28 dash & screen moulding from scratch!
  180. Refinishing TRS drives
  181. epoxy for transducers?
  182. wax or no wax for sanding mixture
  183. Fiberglass/Gel Coat Repair
  184. How to prep an engine for paint?
  185. painting small parts
  186. Removing bilge paint from screws?
  187. Safe paint stripper for polyester boat?
  188. wet look
  189. awlgrip or imron
  190. BOAT PAINTERS: have questions
  191. Poly flake gel
  192. to Core or not to Core
  193. Primer colors?
  194. Pinstripes Yes or No
  195. Respirator question
  196. Paint /gel coat what to use
  197. wet sanding to remove yellowing
  198. epoxy filler shrinking
  199. Wet sanding, what am I doing wrong?
  200. aqua buff
  201. floor
  202. Anchor damage in hull - Glassdave maybe?
  203. question for glass dave.
  204. need someone to paint a boat
  205. 83 33 fountain 10 meter
  206. epoxy primer
  207. Soda blasting help/tips?
  208. premade fiberglass panel?
  209. how much gel?
  210. 45+ year old fiberglass
  211. Buffing Gel with Metal Polish?
  212. Best bodo for filling
  213. I need some Fiberglass help PLEASE!
  214. Alexseal
  215. Boat Candy Speed Gloss
  216. Donzi 28zx Broken Lateral Stringers in Bilge
  217. silicone wax/polish removal
  218. newby questions for a complete hull refinish
  219. options 4 bottom paint
  220. speaker pod suggestions??
  221. formula 271
  222. how to touch up small cuts in fiberglass from winch?
  223. 38 AVS transom and stringer problem
  224. Picking up the pieces....need floor advice
  225. "Blueprinting" bottom
  226. Putting in new stringers, Can I leave a little tabbing? Plus more Q's
  227. Orbital buffer questions
  228. Hull layup schedule.
  229. Buffing out a boat
  230. Looking for wooden boat resto shop on east coast
  231. Douglas Fir vs. Plywood for Stringers
  232. removing surface wax from cured resin?
  233. Anyone have any experience with ALC soda blasters?
  234. Need a little polish advice
  235. plywood for floor in 24 outlaw
  236. vinyl wrap question
  237. boat painter -needed (long island ny)
  238. Converting Dual engine Sonic to single engine
  239. Blending a scratch/ gouge
  240. How to re-gelcoat a textured surface
  241. How long between layups without sanding
  242. baja graphics
  243. Vinyl Graphics - help me decide...
  244. Painting my boat quick question
  245. How to clean fiberglassing tools
  246. best oxidation compound?
  247. Happy Birthday GLASSDAVE !!
  248. Fountain of Youth Products
  249. Brown water stains
  250. Gelcoat safe paint strippers
