PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 [128] 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. What is the difference betewen the Melling 10777 and 10778 oil pumps
  2. Cab Forward Cat
  3. Motor surging above 3200 rpms
  4. 5000 on 7.4
  5. TCM Merlin 509 Issues
  6. carb jetting
  7. water temp drops coming off plane??
  8. Fuel too old?
  9. Looks like I am screwed this time (transom)
  10. coolers
  11. Valve covers
  12. Too much boring? Bad heads? Overheating....
  13. Adjusting Gaffrig Mechanical Indicators
  14. Leaving boat in salt water ?
  15. Dyno VS. real world carb
  16. Best Distributor to use
  17. Isky Cams Phone #
  18. Isky Cams Phone #
  19. Time to replace shifter cables. What brand should I go with or are they the same?
  20. Replacing Guages
  21. How screwed am I?
  22. Turned engine off when in gear
  23. Bolster seat problem
  24. 525 question
  25. carb idle tuning: neutral or in gear?
  26. Dock and Gas dock girls tipping?
  27. Speedmaster III or IIIA
  28. formula
  29. Bravo ZX or XR ?
  30. TRS Drive leaking oil in the water...help??
  31. Yahoo - did you get to the TOPPS run?
  32. 496 whipple rebiuld upgrade
  33. Water flow through transom pickups
  34. Engine weight
  35. Rub Rail, can I do it myself?
  36. Bracket to move power steering pump?
  37. Steamy Exhaust
  38. 500hp opperating #
  39. compession?
  40. How Much HP??
  41. Broken hatch need help?
  42. Lake Travis Anchoring
  43. First Look at Dyno's 330's on roids!
  44. Chugging sound coming from harmonic balancer and pulley??
  45. Exhaust riser getting very hot????
  46. Bravo to X
  47. Mufflers for 496 HO!Please Help!
  48. Any news on shiftable Konrad drive?
  49. Oil Pump Pickup length for 454 magnum
  50. noticeable idle
  51. converting alpha to bravo 1
  52. Oil cooler to filter instead of Filter to oil cooler?
  53. Merc Y pipe help
  54. Need Urgent Auto A/C Help
  55. why am i blowing clutches
  56. Why do I keep tearing up props?
  57. TRS shifting question?
  58. Once and for all, WTF?
  59. Mesa Racing Engines Latest Project
  60. Donzi ZXO
  61. Replacing Carpet?
  62. How do you set Bravo gear lash
  63. multiple scum lines on one side of my boat?
  64. 525 sc power curves
  65. Gear ration 1.35 vs 1.50
  66. vent holes
  67. How much hook should I add to a porpoising 28' cruiser?
  68. Depth Gauge Transducer Mounting?
  69. 454 Mag eng HP/Torgue peak Info Needed
  70. Holy Mother of Maintenance....
  71. Anyone using these??
  72. Boat on Ebay... can I link here??
  73. For you - a list of oil filters for Mercruisers
  74. TECH-HELP - Coolant Thermostat on 588 Merlin Big-Block
  75. Can someone calculate my hp?
  76. WANTED - Engine Thermostat on 588 Merlin Big-Block
  77. Flush mount air vent fitting, where to buy??
  78. How much $$ to reskin your seats and new carpet?
  79. high oil pressure at idle
  80. Merc Serial Number ID?
  81. another outing...another challenge
  82. Need more Horses from SBC
  83. Raw water pickup depth
  84. Has anyone juiced up a Mando alternator?
  85. 525 Efi Wipple
  86. electrical wires from the controls?
  87. New Distributor
  88. HP500 Carbs - blown plug and problem in bottom end at 171 hours?
  89. '90 7.4L flame arrestor upgrade
  90. what drive shower for bravo 1
  91. #6 Drive Rebuild Recommendations
  92. Anybody installed Gaffrig billet flame arrestors on a 502 MPI?
  93. bad cam, lifter, and push rod
  94. Hydro-Hoist Hoses
  95. Anyone know a Sea Doo tech site?
  96. Can side exhaust mufflers be replaced with tips?
  97. Finally Need Break In Advice
  98. looking, bravo 24 or labbed 26 or 1.50 gears
  99. bluewater guage cable
  100. decible levels
  101. 500efi w/Vortech SC's...pro's/con's
  102. 496ci .030" over
  103. Why is my boat slowing down??
  104. 454 mag db readings?
  105. Frozen Trailer Brakes
  106. 7.4 MPI overheating....HELP!!!!
  107. When to run a cleaver?
  108. Bravo 1 shifting problems.
  109. Stellings ID info...?
  110. Sterndrive Engineering Alpha drives
  111. overheating problem
  112. Last question, Is 750 Sea Demon to small for 496
  113. Level of effort - adding trim-on-throttle
  114. Bravo Outdrive cases. How much are they worth used.
  115. how to cut a perfect 4 5/8 hole for a gauge?
  116. thermostat housing
  117. help with piston numbers
  118. Advise, Is This Cam To Big?
  119. Negative battery cable connection ?
  120. Drive/coupler noise
  121. 454 Serpentine belt
  122. Jumpstar a marine battery??
  123. 496 width
  124. Oil pressure sender location
  125. scorpions turn 4,000 instread of 5,200 RPM
  126. HP500carb. and Bravo X
  127. What's your opinion?
  128. Hot water temp
  129. carb recommendation
  130. Adding Transmission fluid?
  131. Need a Clarion Remote
  132. Help with Eickert tail pipes
  133. Oil Lbs question
  134. Merc 7,4L MPI -99, more horsepower needed
  135. CRT trim blows breakers.. help!
  136. hydraulic steering = chinewalk?!
  137. How to put a new impeller in Raw Water Pump??
  138. Mercruiser Magnum 350 Project
  139. sea water pumps ?
  140. Milkshake oil!!!!!!!!!!!!!!!!!!!!!!!!
  141. 496HO PCM Reprgramming???
  142. Blower motor dry sump belt gaurd
  143. 502MPI rev limit??
  144. Down Again
  145. Solid Powerboats
  146. power steering fluid:what to use?
  147. Oil In Bilge
  148. Amp & Speaker wiring question
  149. best price on a 502?
  150. Fountain Lightning
  151. Mufflers!
  152. Ok, Build me a bullet proof Bravo XR upper
  153. ePaint White Bottom Paint--www.ePaint.net
  154. cam for 454 mag
  155. Alpha Conversion
  156. Piston oilers
  157. FREE!! Valvoline SYNPOWER Oil treatment
  158. I am stroked, 6.135 or 6.385 ROD ???
  159. Procharger Head needed
  160. External Belt Driven Fuel Pumps, why is it...................????
  161. How to grease Bravo drive?
  162. Desktop Dyno
  163. fiberglass windshield for scarab 26
  164. want to buy: 1:1 BW 72c or case/planetary
  165. What Is The Best Bravo Drive Coller?
  166. fiberglass windshield for scarab 26
  167. cam shafts for a HP 500 EFI, need help fast
  168. excessive exhuast steam
  169. a-z prop
  170. paging wags (AFR head info wanted)
  171. Sea strainer gasket
  172. Chevy V-8 casting numbers
  173. Help! I am geting water up the tail pipes
  174. Hard shifting
  175. Boost Cooler?
  176. Capping Y pipe
  177. 454mag to 496 volvo
  178. LS 1 BATBOAT PROJECT by Mesa
  179. ITS plumbing question
  180. Back firing thru plemium on 500 efi??
  181. Do I have a problem??
  182. Can I use a 454 H.O. crate engine with out any changes?
  183. Serial # again...
  184. Crane Rockers
  185. Amsoil Marine gear lube
  186. Blower troubles!!!!!!!!!!!!!!!
  187. additional anode install
  188. "To Change Or Not To Change....."
  189. Leaky Keith Eickert valve covers
  190. help..quickly please -- merc II cooler
  191. can I remove deck hand rails?
  192. swim platforms
  193. What gaskets, bearings, rings and oil pump to use?
  194. Fuel pressure fluctuations Procharger M-1 7.4 MPI
  195. How about this cam selection ?
  196. How do you change a power valve?
  197. Merc #5 question
  198. Tie bar?
  199. Hooking up trim indicator
  200. violent bow lift and drop after bravo 3 replaced for bravo 1
  201. Tow Pig/K&N filter on a TBI???
  202. strong universals for a Bravo III
  203. 140 deg thermostats
  204. Prop shaft TRS
  205. Fuel Pressure Gauge
  206. XR Drive Maintenance
  207. Who has the best prices on Edelbrock heads and in stock?
  208. Tach recall problem
  209. porpousing with a rocker bottom "how to sand it out?"
  210. Manifold and Riser continuity test?
  211. Help! Need Help!!
  212. Mechanical Oil Gauge Fitting ??
  213. Silent choice/cut offs suggestions for 496magHO
  214. Engine oil drain hose to bilge plug, anyone sell them??
  215. Hydrocruiser....need input please.
  216. 7.4L valve covers
  217. 7.4L max rpm ?
  218. Fuel Pressure on 525's
  219. 7.4MPI with M-1procharger loading up @ 4200RPM & 2PSI
  220. Best twin turbo motor manufacturer?
  221. Dyno results at Crockett Marine
  222. Older EFI Wiring Help Needed
  223. Engine temp is high on new engine
  224. How do you check a marine battery?
  225. Engine Flushing
  226. Fuel gauge problem
  227. 1990 26 Nova St Stepped Version
  228. Will a 454 Mark IV transfer to Gen VI?
  229. One down and one to go
  230. How to decarbon pistons
  231. 496 MAG whine/howl/whistle noise?
  232. Please help an electrical idiot (battery rewire)
  233. 1994 454mag conversion to newer MPI???
  234. prop help
  235. Tach jumps at hi RPMS. HELP!
  236. Need a TRS trans end universal joint yoke
  237. Bravo 3X Stern Drive Help
  238. Sea water pump
  239. Black Carbon Plugs
  240. Smartcraft Code reader?
  241. B&M 174 / WEAIND 177 WITH D.U.I. (HEI).WILL IT FIT?
  242. 454 magnum power loss between 2000-4000rpms
  243. Does anyone still sell a 502 Mercruiser carb engine?
  244. Timing setting with a decent cam..
  245. pro charger
  246. 454 mag rebuild question
  247. EFI over fueling.
  248. Strange noises
  249. Hard to crank over when warm (heat soak?)
  250. Odd looking 502 head gaskets wrong ones?
