PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 [176] 177 178 179 180
  1. 502 MPI oil/powersteering cooler question
  2. What are these wires for?
  3. drive height
  4. Help me identify trim actuator
  5. Shoot Through Depth Sounder
  6. I just had the gears changed
  7. 200cc heads need valve job!
  8. How much 90 wt in Bravo III
  9. Servicing Question?
  10. Help. . . .496Ho Alarm! What is it?
  11. Formula31 ?????
  12. Need Your Opinion!
  13. OT: Scratched Emron repair
  14. Q-Jet question
  15. Recall on riser gaskets
  16. Electric brake conversion??
  17. HYD. Steering
  18. Gil manifolds
  19. Oil Drain Kit
  20. Trailer Surge Break ?'s
  21. Locktite on drive mounting stud?
  22. vortec adjustable fuel pressure regulator
  23. Need N/A engine ingredient help
  24. Alignment Tool Use
  25. need starters
  26. Checking Transom and Stringers
  27. Easy Question
  28. Problem is? Engine/drive x/gear
  29. Head bolt sealer?
  30. Prop nut Torque/size?
  31. Rapid Fire #1 in HP500
  32. Rex Marine Hatch Acccelerator
  33. Modified Bravo water pick-up??
  34. blistering?????
  35. Plug Reading
  36. Choice of engine bearings?
  37. rebuilt engine experiencing blow by
  38. Re-Torqe Heads?
  39. Circulating pump
  40. Spark Plugs in Aluminum BBC heads
  41. New Gauge lights
  42. 500 EFI to a 525 EFI
  43. Plugs and Jetting
  44. Drive and prop question
  45. JOhnson 225 1989
  46. Twin Disc rebuild-Katdrvr
  47. Batterey charging
  48. Here's my latest project
  49. bravo xz or dpx drive?
  50. bravo xz or dpx drive?
  51. 502 mag, Won't start, help
  52. Correct Timing Module for carb 5 HP-500
  53. need 454 magnum intake manifold
  54. Flame arrestor vs. K&N air filter..proven by the dyno!
  55. Alpha Trim Hose Replacement
  56. Need help building 400 sbc for my boat.
  57. How many hrs before synthetic
  58. High Flow Flame arrestor
  59. Land & Sea drive Extension.
  60. Gimble Bearing Help!!!!!!!
  61. Polish SS and Aluminum..
  62. Prop for 29 Fountain w/ HP500
  63. Synthetic oil in a 502 vs petroleum???
  64. Fram oil filter #'s
  65. Cooling crossover
  66. belt noise
  67. EMI exhaust and cam duration...
  68. 6-6.5 lbs boost - stock Gen VI 502
  69. Aeromotive A1000 pump-Rebuildable??
  70. cool fuel to vapor tank
  71. Question for the guys with experience installing Stellings boxes
  72. how much do i machine?
  73. Drive falls down over night
  74. Prop selection?
  75. Bravo One Trim Up Not Working
  76. Fuel Tanks
  77. "Hard Blok" question!!
  78. Trim cylinder help
  79. Optimum Trim Tab Location/Placement
  80. paging mcollinstn
  81. 2.5 offshore 1994
  82. funky bilge pump?
  83. Kaama exhaust problems
  84. Bravo gimbal ring needed
  85. mercury 250efi heavy smoking!!!!!!
  86. roller trailer question
  87. Hey puder, buy your gauges yet?
  88. 3 Blade vs 4
  89. Which trim tabs? 22' scarab
  90. My new boat has EGT Gauges??
  91. which is which
  92. Converting Bolsters
  93. Help!!!!
  94. Converting to serpentine belt????
  95. intake I put on a new intake and forgot to put in the drip pan .
  96. preping gell coat for paint????
  97. Let's argue in the chatroom
  98. Oil pressure guage
  99. Well I went to a K&N now I'm lean, I think?
  100. K-plane problems
  101. Right cam for HP 500 EFI ?
  102. Bravo Outdrive Question
  103. K plane Adjusrment
  104. Capacity of lubricant in TRS lowers?
  105. Oil Pressure
  106. Water Circulating Pump
  107. Changing Drive Oil in TRS
  108. Lubricant for TRS Lowers
  109. 454 questions
  110. Spring maintence (pun intended)
  111. HP500 EFI Oil Dilution
  112. 502 MAG Mercruiser.
  113. Plugged water line in Bravo Outdrive?
  114. Torque and HP numbers for my new motor
  115. K-Plane wiring diagram
  116. what should be 500 efi water temps be ??
  117. 500efi backfired?
  118. Need High-Five info Quick!
  119. dual batts set up
  120. Propshaft Runout ?
  121. Starboard Prop Slips
  122. K Plane Resevoir Leak
  123. Input needed on Drive Repairs / Parts
  124. water inlet ?
  125. S/s Corsa Slant Tail Pipes
  126. Reliability & Dependability 500hp w/Procharger
  127. Correct props for KAAMA
  128. How do I get rid of porpoising problem?
  129. Maintainence Tidbit
  130. bravo one gimbal pins
  131. Imco WPM or Latham
  132. Merc 50hp 4-stroke, low rpm???
  133. Water pick ups????
  134. Check those motormounts!
  135. What is your opinion of a IMP 255 Eleganza???
  136. Which blower is this and...
  137. 454lx Mpi-502mpi
  138. Aluminum Trailers Bunks
  139. Mercury Marine back ordered my parts HELP!!!!
  140. '93 Merc 2.5 - timing question
  141. Starter electrical nut size
  142. What oil filter should I be using?
  143. Turbo Prop ?
  144. Surface drive Tech
  145. Flywheel aluminum, billet steel, or stock???
  146. Blown Oil Cooler
  147. Speedo not working
  148. Evinrude V8s
  149. fuel pressure "bounce"
  150. Power steering leak??
  151. Modifying Flame Arrestor?
  152. Fuel Sending Unit sick
  153. Anoides?
  154. Engine storage
  155. Lubricating Indicator Cables
  156. Another water pressure problem
  157. 454 intake manifold passage
  158. Flame Arrestor Questions
  159. high volume machanical fuel pump?
  160. Dustin - whipple adjustable Boost bypass?
  161. compresion ratio
  162. Changing Drive Oil on Bravo XZ
  163. What cam for a 540
  164. Installing transom mount water pickup
  165. What does it mean when...
  166. Wiring Help!!!!
  167. IMCO shortie on Eliminator Eagle XP 236????
  168. Blow thru carbs
  169. wanted: raw h20 bracket 502 bravo
  170. 1993 30hp Evinrude? how to drop the lower unit?
  171. Alpha upper
  172. oil capacity for 330's?
  173. OUTdrive gear lube
  174. Paint under zincs?
  175. Stainless braided hose question
  176. One trim pump on two outdrives
  177. Prop diameter ?
  178. Thunderbolt Ignition & timing questions
  179. 502 Tbi Plate?
  180. Testing Valve Springs
  181. Electric Engine Hatch Lift/Motor
  182. 350 mag spark plug gap?
  183. WPM Brazil valve leaks!!
  184. Heavy duty gimbol ring with standard bell housing ????
  185. K-plane position
  186. Drive position indicator adjustments
  187. Sparl Plug Wires with Crane Hi6M
  188. Leak down test
  189. 502 Mag Power Curve
  190. Mirrored plex glass on engine hatch
  191. K-Planes
  192. Insurance on TWINS!!!, (single engine guys need not reply)
  193. Fuel pessure issues with HP 500
  194. 97' 454 Mag MPI stalling?
  195. Results of Flow Testing - Improved Intercooler Configuration for Centrifugal Blowers
  196. How do you know if a Harmonic Balancer is bad
  197. distributorless ignition
  198. New Merc 6.0 motor???
  199. Volvo 600 Dpx?
  200. How to mount a sea strainer?
  201. Oil plug to hose change over?????
  202. prop for 24 ft hp500 set up?
  203. finish on Mercury labbed props?
  204. How to prevent reversion from taking place?
  205. Need help fast!
  206. Hey cat-guys!!!
  207. Marine Alternators - screened?
  208. elbows?
  209. Break in oil for stock 7.4 330-350??
  210. HELP!! Clymer/Merc 1992-1996 Manual need scan of Tbolt 5 ignition
  211. Shared water system on twins?
  212. Thunderbolt IV Ignition Box
  213. Remote Oil Filter Setup
  214. 25hp Mercury?
  215. Water Pressure relief Valve
  216. Old Volvo Drive will not shift???
  217. Billet Top Cap for Bravo
  218. Proper RPM/Prop Size
  219. Help needed for cutting mirror--plex
  220. Penzoil 25/50 Racing Oil
  221. 2 drive showers?
  222. Harmonic Balancer Help!!
  223. Questions For Cooling And Steering
  224. Synthetic Oil ?
  225. Fuel Tank
  226. Looking for HP500 valve covers New or used how much?
  227. No room for supercharger!
  228. Another steering?? Sloppy steering box
  229. what noises does your engine make when you have reversion?
  230. waterproofing
  231. Drive alignment tool
  232. Y-pipe flappers
  233. Seats ???
  234. Ignition advance at idle SBC w/Vortec Heads
  235. Outdrive Gear Oil
  236. Help boys!! I F%&ked up.....
  237. IMCO Extreme SC Upgrade Project.
  238. What sizes to K-planes come in ?
  239. Ever seen a bent steering cable rod?
  240. Timing Gears
  241. Bravo steering slop
  242. HP 500 carb
  243. TRS installation??
  244. Proper way to check oil level?
  245. Merlin Marine Head 310 cc runner
  246. Tec Question
  247. Gelcoat Thickness?
  248. Exhaust Manifold Problems?
  249. 2000 7.4L T.B. gasket mismatch
  250. Flywheel housing
