View Full Version : General Q & A
- Mercury Racing 525 Exhaust?
- Need carb help
- Help me with diverters
- ZZ502 cam options
- Dual carb blower linkage problems.
- 1997 454 MAG MPI w/VST - Runs Perfect for Hours, Then Dies and Won't Restart. I'm Com
- Velocity weight?
- 502 mark IV flywheel or ring gear
- 7.4 Mag MPI no start when hot
- 741 cam
- Solid transom shield mounts.
- 502 Mag Mpi Life Expectancy
- Can Anyone Identify these Sea Strainers
- Merc Racing 85-90 gear lube lack of availability
- Worth the effort?
- Emi thunder exhaust.
- SBC sticking valves
- remanufactured bravo 1 out drives
- Merc 496 Fuel Line Connection
- outdrive finish protection
- Underwater exhaust, not enough water pressure?
- Shift Interrupt Switch Help
- Hydraulic Steering Help
- Merc 8.2 ECT sea water pump impeller replacement
- 540 BBC Cam specs for water Reversion - IS it a problem?
- Sunsation 288 with Bravo One X
- Odd ball question
- Need guidance on bilge ventilation, please.
- Gil replacement exhaust manifold
- 383 igntion timing
- Fort Lauderdale Maintenance
- Power steering fittings hose Bravo
- Oil Cooler Cleaning and Filter Location
- Closed cooling raw water side slow to drain
- Manifold dump + dry exhaust?
- Bravo Gimbal - Re-designed Water Intake Hose?
- Needing Stringer Repair/Rebuild Referrals
- Removing 34 yr old fuel hoses.
- VP DP-SM Outdrive Cooling Question
- 383 mag mpis, water strainer install tips?
- Single wire alternator question
- Thunderbolt V.
- Bad fuel end of last season, what to do next?
- Drilling thru reat seat fiberglass
- twin pump hydraulic steering issues
- Any tuned pipe/collector length suggestions for E tops?
- By passing bravo shift bracket plate.
- Exhaust/muffler decision.... 525EFI
- 8.2L engine knowledge
- Mercruiser PowerShift question
- weiand 177 on a 454
- Thru transom dry exhaust.
- New engine will not throttle up past 1500 RPMs
- 496 Flame Arrestor
- 98 500hp
- Gen 6 502 efi fuel pump question.
- ZZ502 110 LSA in 454 Reversion issues?
- Imco and Mayfair Hydraulic steering
- Thru-Hull Fitting for Switchable Mufflers
- Bow tie blocks
- hydraulic valve adjustment procedure
- Repeal of 2009 EPA Greenhouse Gas Endangerment Finding
- Scan tool for Ilmor 625 V10
- 8.2 Mag Question ECU
- Swim Platform Measurements
- Taking bets on these screws / bolts
- Belt driven raw water fuel pump assembly
- Replacement vinyl help
- Mercury Racing 500 EFI
- Anyone know anything about this intake
- Small B&M supercharger rebuild
- Quad rotor engine oil feed to superchargers
- 1988 Chris Craft Catalina 426 engine question
- Help me understand valve guide clearances
- Used mercruiser engine... can someone help me identify it? (and other questions)
- Cam for Stock 575 SCI
- Dual power steering pump hook up
- HP500 Carb Replacement Lifters
- 496 Head Bolt Length
- Rebuild or Replace trim pump
- Trim Tabs, Clear coat or Powder coat?
- IMCO Extension on small ModVP / Tunnel?
- Labor rates, parts, service
- Header collector size/Sharpe?
- Fuel Pump Recommendation
- New oil from Driven
- Fountain baffles
- BBC 509cid high comp, pump gas, lysholm 3300ax?
- Looking for decoding 454 block stamping numbers and suffix.
- Battery question of the day
- Spark plug access?
- Holley Terminator x vs dominator v2?
- EFI Fuel Pump Bracket
- Use powertrim pump for trim tabs
- Compression test
- Stuck IMCO lower
- help with cam choice for BBC and SBC
- 496 Rocker Arm Stud
- Interesting Mercury engine
- General Pushrod/Rocker Theory
- Drive Stud Washer Question
- Mercruiser 502 380 hp vs 502 430 hp difference ?"
- LS 6.2 marinisation
- Water pressure through block
- The basics of setting up a Holley and MSD system
- Exhaust manifolds upgrade
- 500EFI flame arresters
- Mercruiser 496 MAG HO Fuel Injectors
- Oil filler cap stuck on 496 mag HO. How to remove?
- Broken Exhaust Dam Flapper
- Oil Thermostat 575 540 Tall Deck??
- Battery cable end terminals source.
- Which camshaft with my setup? (SBC 350)
- Valve Cover fitment
- 383 Compression ratio
- Ford guys... O2 Placement
- Old school l 88 454 mags, needing more HP
- Boat position on trailer
- Fit up problems for splines velvet drive
- Engine builders....cam suggestions
- Water intake hose questions.
- fuel and fillup
- HP465 - fouling spark plugs.
- 502 Mag engine electrics availability ?
- Valve cover condensation problem
- Latham "Add-On" System
- Getting analog guages to work
- 500 EFI and Cool fuel system
- 1992 HP465 Ignition Update
- 1992 HP465 Springs valves recommendation
- Convert to closed loop cooling ops for flush
- Thermostat Differences - Closed Cooling/Raw Water Cooled
- Steering cylinder removal
- 1988 engine synchronization
- The most desired stelling header model?
- Looking for someone to Dyno my build
- summit 8802 or LT1 hot cam
- Oil pan suggestions
- Considering going from 500 efi to intakes and carbs
- MSD Crank Trigger system...
- Here we go, THE OIL QUESTION
- Selling a boat and Survey came back with high moisture
- 454 Flywheel Differences
- Dual dominator
- Drop down bolster failure
- EC 502 starter issue
- Lucas oils?
- Help identifying Opcon/imco supercharger.
- exhaust manifold recommendations
- Reversion?
- Lead time on engine builds
- hi!!
- 454 build opinions
- Help picking stud girdles
- Paging Marc from Bam
- Electric Fuel Pump Conversion
- Digital to analog converter wiring
- Water in K-Plane Trim Tab Pump
- 380S K Planes
- 10:1 cr sbc
- Daytona Sensors Help
- 500HP Carb issues
- AQ290 DP Upper Shaft Movement
- aluminum heads SBC
- Any use for Lightning Headers with a few rust spots?
- carter AFB/weber 9780S rebuild help
- 496HO pan to pickup clearence
- 1995 eliminator daytona work with imco set back box
- 496 ho Rattling Sound
- Trs power steering
- 330 horse 454 upgrades to 420hp merc specs
- Steering hose on 700sci
- Why does Merc flare the ends on the thermostat water hoses?
- Hardin Marine thermostat housing leak
- Which cam???
- Temp gauge issues
- 240/24 Baja outlaw wizard needed!
- Blown head gasket causes?
- 92 Sea Ray 400 EC with 489s delay in getting oil to rockers
- EFI Ignition Timing Table Advance at Idle?
- 2001 MerCruiser 496 mag HO.
- Jegs Power Valves?
- Better Oil Filter option for my 6.2’s…?
- 1990 warlock 23 world class
- Extension box question
- 496 air drain system leaking?
- Exhaust gaskets
- Merc gen 4 454 Mag no water exiting
- 3.7 runs then stalls, hissing carburetor
- Guages powering up but not reading
- Cylinder Head ID
- 502 flywheel ring gear
- 1996 350mag mpi Gen+
- Where to Paint Mercury Racing Lowers
- Wix racing oil filter and bbc oil bypass
- HELP - 1985 Bayliner - First boat
- What brand of fuel pump is this?
- Cooling system cleaner
- Aftermarket 4-wire corsa solenoids
- 700sci with NXT info
- Blew a mayfair steering hose
- Older 175 Mercury XRI any guys here shed some light?
- Engine hesitation at cruise speed
- Gallery Pictures
- 40hp 2 stroke carb help needed
- Will this work?
- Mercruiser unavailable hose
- Weak Charging System....?
- 454 Mag/502 valve seals
- Captains call for SSM drives?
- BBC intake flow
- Anyone have any experience or details on the Allmond Rocker Arms?
- 454 mag mpi sputtering and stalling
- Newby
- Push Length Valve Witness Marks- thoughts
- Advice for helm pump sizing
- Starter issue
- Mefi 3 vs Mefi 4
- Cleaning a dirty bilge drain
- HP 500 EFI head gasket failure
- Carburetor J-Tube jetting heads up
- ECU Tuning
- Need trim tab advice
- 502 Mercruiser MPI Fuel pump
- question for the outboard experts
- Propeller Performance question
- notched transom
- Assembling 8.1L 502
- MSD iginition control problems with Mercruiser 350 MAG MPI
- Need a plastic 1.25 barbed coupling with drain
- Baja Corsa Exhaust
- Found some free hp on my blown big block!
- How long to remove and install a motor
- 4" exhaust close offs
- 5.7 Mag MPI Rebuild or New Long Block?
- 5.7 vortec cam upgrade or stay stock?
- Too much fuel on idle with Whipple supercharger system
- Prestolite trim pumps
- X Dimension
- Trim wire seals
- 496 ho temp issues
- Quicksilver 85 90 extreme gear oil
- "PORT SYNC" and "STBD SYNC" switches on dash on a Scarab???????
- New style Bravo Engine alignment
- Scarab Owners Manual
- 502 Fuel Injection
- 7.4l mag efi need help
- Blown 565 compression question
