PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 [161] 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Using Holley on SBC
  2. Drew Shotgun Silencer Users!
  3. Leaky pully bearing on my Whipple
  4. gas quality for initial start up?
  5. ignition timing for initial start up?
  6. Initial Start-up on hose
  7. Float Level Adjustment Holly 1050
  8. Need Help, Bent Intake Valve, Why
  9. Too Much Advance?
  10. alpha drive question( please help)
  11. Back fires and Stumbles
  12. Exhaust....
  13. flowscan or another fuel monitoring system
  14. upholstery question
  15. My Motors PART 2
  16. msd 6al box, tach don't work!!!!
  17. msd 6al box, tack don't work!!!!
  18. pro-charger carb box question
  19. 4.3/Alpha help?
  20. Marine Air Conditioning Problem?
  21. York Propeller
  22. Intake and carb setup on a 502?
  23. Fuel Pump
  24. 2much exhaust heat! what does it mean?
  25. Starting problems
  26. closed cooling
  27. Cam Break in ??? Need some advice
  28. CMI vs HP500 exhaust
  29. MSD Marine Box with HP 500 EFI
  30. Small Block Chevy Stroke Question
  31. Stereo junkies,
  32. Compression ratio?
  33. Any magneto experts out there
  34. How do I ship an engine?
  35. XR Drive mid pickups with low water pressure
  36. Scarab construction
  37. Question - How do you set up the distributor with #1 Cylinder?
  38. Unanswerable question?
  39. 1998 502efi and 454 mag efi rev limit?
  40. Broken Valve Spring and More
  41. now it's faster and more RPM's?
  42. 460 ford to bravo
  43. WARNING Napa "no crimp" terminals
  44. Merc/Sierra Impeller Part #
  45. Water temp low????
  46. 1, 2, all, off battery switches....how to correctly hook up the batteries??
  47. MSD 6AL Ignition help
  48. Recommended Dyno Shop In Charlotte Nc.??
  49. drive height for 2000 38 fountain
  50. Looking for water cross overs.
  51. Batt switch and Alternators
  52. Important info if you run Rotella Synthetic. They have a bad batch.
  53. Mirage Props with stenciling
  54. loss of fuel pressure at WOT
  55. Sportmaster clean up
  56. spare tire mount?
  57. gelcoat chip in bottom
  58. Remote Oil filter mount advice needed
  59. Exhaust manifold to riser seal
  60. Holley Carb.Fuel Pump vent hose location?
  61. how much Horsepower?
  62. Question on manifolds temp 1999 502
  63. Overheating 454
  64. revolution marine exhaust ?
  65. Stainless strain relief bushing needed
  66. Mirage 25 VS Mirage plus 25 RPM
  67. carb
  68. Whipple Problem
  69. 454 budget build - What would you do?
  70. Flushing,exhaust question
  71. steering fluid leak
  72. Dual Gauges
  73. prop swap
  74. Mechanical fuel pump-alternative to merc?
  75. Water in the oil first, now silver specks.
  76. Vinyl repair??????
  77. 502mpi coughs, then dies
  78. Knock Sensor testing??
  79. audio warning alarm question
  80. Bravo one oil consumption???
  81. Tunnel tab
  82. Temp Gauge problems again!!
  83. Bennitt Ditgital Tab Indicators
  84. Spark Plug gap , AC Delco Rapid Fire 1
  85. Bought a new laptop, need mapping software to connect GPS
  86. crane box?
  87. 502 fuel pump
  88. gps's used by apba
  89. Paging Houston Props
  90. Donzi X-18
  91. Port Engine wont turn over
  92. Crazy Okies - 1,100 HP - 23' Tunnel
  93. supercharged holley carb?
  94. prop splines,adapter?
  95. Uh oh... water in the oil
  96. msd 6m-2 wiring question
  97. 496 HO stalling????
  98. Explain to me Valve float...
  99. Valve lash?
  100. Bravo 1 steering hard
  101. Ranking Hyd. Steering Systems
  102. Lowering compression for blowers
  103. Rplacement Sportmaster's Lowers For Xr Drives
  104. Replacement Sportmaster For Xr Drives
  105. Sea Swirl Pump
  106. Intake Crossover
  107. Bravo Drive oil Capacity
  108. Help with new Holley 800
  109. Desperatly looking for part in Dallas, TX
  110. Rebuilding/Tuning Holley 4010
  111. my motors
  112. slow 42' Fountain Props???
  113. Loaded ? on Bravo 1 props
  114. mpi scan tool??
  115. Water circulation and quieter exhaust??
  116. Adding a rev-limiter
  117. carb, fuel question
  118. RH Bravo Shifter Question
  119. Holley Carbs
  120. Broken Skeg On Drive
  121. looking for the specs for a 496
  122. Best way to mount oil cooler
  123. #3ssm or 5ssm
  124. Bravo XR question
  125. poly planar cd player
  126. What prop do you recommend?
  127. extension box imco vs. land & sea
  128. Shop manual for HP500?
  129. A question about camshaft assembly lube?
  130. Float setting on Edelbrocks
  131. Life span\Hours on a 454Mag?
  132. clutch slipping?
  133. 350 Magnum (carb) questions
  134. water pressure gauge
  135. 502 & 496 heads . will they fit on the same block
  136. What water temp on 1999 502MAG
  137. 496 & 502 exhaust , are they the same???
  138. High water pressure-----Need help!
  139. gill exhaust
  140. Bravo lower unit
  141. Need wiring diagrams. Can anybody help?
  142. Help Carb Guys!!
  143. Throttle Knob - Trim ?
  144. Power steering pump
  145. Engine Rebuild?
  146. help...jetting Holly 830 CFM annular carbs
  147. MERC 2.4 Carb & 6 years
  148. calculating top speed with prop calculator?
  149. Electric fuel pump
  150. injection to carb
  151. what gains from this combination?
  152. Small Block performance upgrade suggestions?
  153. Tailstock bearing lubrication?
  154. Oil & Filters for 496 HO's
  155. Sea Water Pump Service - need advice
  156. Thermostat Replacement
  157. 496 car motor
  158. Fuel Pressure On Holly Carb
  159. 496HO, high rpm miss ????Any ideas?
  160. Hynautic Steering Question
  161. Got my plugs changed!
  162. Cylinder Head Gurus-Question?
  163. Holley 830cfm
  164. baja,s how fast
  165. turbo charger design
  166. Brake bleeding question
  167. Ignition cutout... hard wave?
  168. Help Trs Outdrive
  169. Mercruiser SCANNER...Where can I buy one?
  170. MPI loading up, runs like crap...HELP!
  171. Morse control cable code
  172. burning rubber/plastic smell
  173. holley 750?
  174. WPM Steering and latham cap??
  175. spring startup
  176. Need tech. help 96 tahoe
  177. Crack at back of boat
  178. Newer boat purchse? Nose Cone Installed!!!
  179. Setting base timing on 454 EFI
  180. Imco External Steering install
  181. Thanks Houston Prop
  182. OT: Rancho Shocks: Anyone use them ?
  183. More questions on IAC's
  184. wind deflectors
  185. extention box
  186. Kaama Prop Queation
  187. Carb Size for 454 Mag
  188. engine just shuts down?
  189. Blower fastener torque, motor "rolling, rich"
  190. Gimble hinge pins?
  191. Carb Spacers, anyone using them?
  192. Bravo Coupler Torque
  193. oil pressure?
  194. sbc water pump backplate gasket?
  195. x dimentions
  196. Hydraulic Steering Install
  197. Bravo one torque
  198. 32 Fever Proppage - Factory Stock
  199. Fountain Whiteout Powdercoat
  200. silent choice?
  201. How much RPM drop from out to in gear?
  202. Bobby Daniels...thanks for the parts!
  203. Marine Assault Quad Rotor 540 Project
  204. Promax 300 w/SVS & High Flow Reed Plate = preliminary results
  205. Burining oil...Best place to buy new motor?
  206. Gaffrig Tach misread
  207. Anybody know of a good place to buy Holley marine carbs?
  208. Still Having problems with the PROBLEM CHILD-Lean/miss/stumble/backfire!!!!
  209. tabs
  210. I Lost a Bearing Buddy Again....Help!!!
  211. Need help w/ gauges
  212. Magnum ignition with 525SC
  213. cam advice
  214. Quad Whipple Belt Help Please
  215. Ignition advance and plugs for 383
  216. Hydromotive Questions / Issues?
  217. Boat vibrates at idle when exhaust is open
  218. alpha gen 1 VS. alpha gen 2
  219. Cam degree Question
  220. new boat purchase advice? kinda long..
  221. Merc spline grease on propshaft?
  222. TRW Pistons
  223. OK, finally...
  224. "Proper" kill switch wiring
  225. engine serial numbers
  226. I am finally getting somewhere....
  227. Do I need an oil cooler?
  228. weiand supercharger
  229. Backfire thru carb
  230. water temp cut off switch
  231. Yamaha sterndrives
  232. Drive Rotation
  233. Help with oil reading of 496HO
  234. stock merc. 502efi manifolds mods.?
  235. drive indicator actuator???
  236. morse cables on bravo shift bracket???
  237. Out drive oil foaming
  238. one piece rubber oil pan gaskets?
  239. msd box
  240. Correct Fuel Pressure for 377 Scorpion
  241. Rev limiter??
  242. Fuel consumption, gph question
  243. 1:36 or 1:50 ? 31 Scarab
  244. Gen VI Head Bolts
  245. Tip work in Houston...
  246. Prop Question
  247. Seeking Prop Experts - advise needed
  248. Trim on Throttle??
  249. Centrifugal Guys; Question…
  250. Timing ?? for EFI Whipple users
