PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 [138] 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Camshaft identification ???
  2. Oil Temp Sender Positioning
  3. Steam/Smoke coming from port motor?
  4. Carb Rust?
  5. HP 500's
  6. Engin Balancing Question?
  7. Cam Help
  8. More Horse Power
  9. Inner tie-bar needed???
  10. 502 vs 454
  11. feedback on cobra blower motors...
  12. Bow Lights
  13. Dumb question: Merc 496 Mag vs. Chevy 3500HD 496 HO truck motor????
  14. Polishing Aluminum diamond plate?
  15. Pro and cons on turning a crank
  16. Drive oil remote reservoir hose
  17. Volvo Penta Ocean Series Drives
  18. Max torque of an XR?
  19. AFR or Canfield Heads
  20. fuel distribution problem
  21. News on Performance Marine Display at Sema
  22. MSD Marine Engine Protector
  23. ITS steering
  24. feed back on dean nickerson's carb work
  25. what the best intercooler for the money?
  26. 496 (375hp) reliability and speed.
  27. B max parts
  28. Which Engine / Drive Coupler?
  29. 496 HO closed cooling questions
  30. which plug wires?????
  31. Corsa Exhaust question
  32. water injection on blower motors?
  33. GenV or Gen VI oil pan
  34. Steering arm Question
  35. Blower Ingnition Questions
  36. What is a reliable primer pump?
  37. Extension Boxes
  38. exhaust silent choice or mufflers
  39. Fuel Economy?
  40. 500 bull dogs motor
  41. Mercathode Wiring
  42. What type of oil for a HP500 (carb)
  43. Outdrives
  44. Hydromotive P5X results are in
  45. Engine Mounts?
  46. Distance between headers
  47. 500 EFI Upgrade
  48. overheating
  49. Raw Water pump Impeller wear?
  50. Rev. Limiter and Thunderbolt Ign.
  51. Mirage propellers
  52. HP 500 bottom end
  53. Bravo 3 Zincs
  54. 1985 35 Apache
  55. Keikhafer Throttle Loose-adjustment
  56. Wedge plates???
  57. bravo 1 clutch question
  58. Imco H.D. Gimbal Ring
  59. Gash in lower unit gear housing
  60. Need More Boost!!!!!
  61. Got the new 540 on the dyno today
  62. Helper Air bags?
  63. Stud girdles???
  64. 496 engine rings
  65. No Oil Pressure after oil change to Synthetic?
  66. SSM #6 Drive Spacers
  67. 1988 350MAG Rebuild
  68. Iron Heads
  69. Polishing the lower unit on Speedmaster IIs
  70. water hose size
  71. Multi-Engine/Single drive setups
  72. K Plane Cable Replacement...
  73. wandering boat,play in steering
  74. Engne Builders - How much HP before you need a better block?
  75. Marinize 496 truck engine
  76. Sealand Vacu flush
  77. rebuilding Merc silent choice
  78. mounting an oil cooler
  79. Hook on a 27 Fountain?
  80. converting a bravo to #6???
  81. Range of pitch for SSM props
  82. Amsoil, what a waste of my money
  83. D*mn Mildew!!!
  84. Fairing fabrication/windshield cut down
  85. Sea Level Jets 500 mags
  86. Carb adjust??
  87. Twin Prop Shaft Rotation
  88. fender covers
  89. should I remove the engines with transmissions or not?
  90. Does a Crane"741" Cam With Silent Choice Cause Water Reversion?
  91. Mercury 1000SC
  92. Help With Helm Pump
  93. Engine swap 454 to 496
  94. What book has wiring diagrams for 496 motor?
  95. Hull stains are a b*tch!!!
  96. 496 closed cooling question ???
  97. 800CFM Quadrajet
  98. Best Prop??
  99. Completed the compression test on my '85 merc 260
  100. Source for replacement "J" Tube
  101. Need help with garage door height
  102. Omc Cooling System
  103. Edelbrock. Marine carbs / Road carbs (#1410 Vs #4111)
  104. Donzi ZF35 trim tab guages not working?
  105. Labbed ? on 34 pitch 502mag efi
  106. Alpha 1 - CR Lower
  107. Low engine temp (130)when running boat in water
  108. Flywheel
  109. 502 mag forged or cast pistons,crank,rods?
  110. Closed Cooling System Limitations
  111. Sema Show -Las Vegas Nov. 2-5th
  112. 454 Intake?
  113. 2001 496 parts
  114. How much does a TRS out drive weigh?
  115. advice for exhaust ...
  116. Drive Showers
  117. Where do I get Pirelli Flooring
  118. Alpha One impeller flow.
  119. no thermostats
  120. Stainless exhaust with silent choice
  121. fraudulent procharger ad
  122. OMG!! a ski boat passed me at 70mph
  123. Removal of stock steering cable ?
  124. Dart Iron eagle's- other changes needed??
  125. Idle problem after startup, 350 mag
  126. hp500 spray paint?
  127. Ecu mods on stock engines
  128. Transom Assy Rebuild Tools
  129. Hydraulic steering problems,, help
  130. HELP looking for 502 ?
  131. Top end of a 42 Fountain with triple 525efi?
  132. dominator jetting
  133. Identify This Carb???
  134. Cool fuel regulator location-why???
  135. RM Builder. . .Calll Me. . .I have
  136. What causes fuel pressure to rise to the point of needing a regulator?
  137. TRS Trim Problem
  138. Smartcraft Questions
  139. "Garage Queen" not coming up to RPM
  140. parting out 92 42 apache.
  141. Blue Printing Dominators- WHO??
  142. Fuel pressure questions? scan tools?
  143. Darin hits it again
  144. which eliminator would you buy?
  145. 2xYanmar 6LY2(M)STE
  146. Stereo question
  147. mcloud bolsters
  148. Crap, just when I think I'm good to go
  149. Cleavers on Bravo 1 drives?
  150. B&M vs Procharger for 540??
  151. High Idle Problem?
  152. Red Line Heavy Shockproof Gear Lube
  153. Valve Diameter & Lash Caps
  154. Mufflers
  155. Warrining buzzer quit ??
  156. Does anyone know this Carrera?
  157. Used 502's
  158. Freezing point for Sterile Water & 91% Alcohol??
  159. Help, want to change Fuel/ water sep but can't get the darn thing off
  160. Stainless Bolts ?
  161. Speed problem?????
  162. Wouldn't it be great....
  163. 575SCi fuel pressure specs?
  164. Which Heads for 500 EFI's ?
  165. engine flush kits
  166. Lifter ?
  167. Engine hatch wont open
  168. Voltage spike?
  169. X dimension ?
  170. small block vortech heads.
  171. engine flush
  172. What happened to Timucin??
  173. Reliability Upgrades for HP500EFI?
  174. Stroked 454 Or 502 ?
  175. Steering is stiff at idle
  176. 525SC Blower Pulley
  177. Pro and cons of a PROCHARGER
  178. 502 Mag??
  179. Pistons and cam shafts for HP500
  180. 525 sc's
  181. cam help: 502 with AFR 305cc heads
  182. 502 mag whipple
  183. Any ford techs out there. Wiring problems!!
  184. Whipple Questions
  185. Pyrometers
  186. Metal Flakes in XR Drives
  187. what to change in the offseason
  188. Performance mods for 502
  189. New 500HP for $4500 w/0 hrs???
  190. Mercury mod vp efi engine horsepower?
  191. Where to buy a 454 Mag rebuild kit?
  192. What's the best way to seal block-off plates?
  193. P.S.I. Blowers
  194. 502 stumbles and poofs through carb - Help!
  195. K-Plane tab service
  196. Omc Shifting
  197. metal on oil drain plug
  198. Drive not going down
  199. super coolers
  200. whipple charger on a new hop525efi?
  201. mobile 1 oil filter pn#?
  202. Any disadvantage to Arneson drives?
  203. Merc 320 tpi sbc ??
  204. Winterizing 351 Ford-Help with Parts
  205. Cost of retro to Roller cams?
  206. Helicoil/Stellings extension box
  207. Transom Help
  208. 454 thermostat ?
  209. How do I find out my cams profile? Part #
  210. motor swap
  211. Cougar US1 38
  212. Average Shop hours to swap motor ...
  213. Right props for 32 caliber baja 525sc?
  214. Best prop for Top Gun T/S
  215. The real poop on 500hp's
  216. Need 2 Breathe......
  217. crate motor options
  218. JimV... I need flow # on stk GM heads
  219. valve job time, parts question
  220. Water in Bildge ?
  221. Injector,oxygen Sensor Help
  222. Merc Transom mounted Water Pick-ups & hose boots??
  223. Please explain the advantage of a "Water Crossover"
  224. Port side motor hitting rev limiter
  225. Valve or Rings Bad
  226. #5 drive prop shaft change and tools
  227. Stainless Prop Cleaning
  228. steamy 502 exhaust
  229. How do I winterize my 496 MAG
  230. Urgent! Engine stand ??
  231. Carbs, mechanical or vaccum secondaries...
  232. Thermostat And 502 Mpi
  233. 454 magnum vs 420 engine
  234. 525 Electrical Problem
  235. Looking for #6 props for friend
  236. engine not getting ot temp on the hose
  237. Annual HP525EFI Maintenance
  238. 7.4-310 MPI mods
  239. Run it cold???
  240. Thermostat and Winterizing 494?
  241. hyd steering question
  242. Bravo Shift Cable Push Or Pull?
  243. Trouble with 496 HO!
  244. Oval port or rectangular port intake???
  245. Anyone else blow apart a drive saver for a Stellings box
  246. Engine Flush on tear down????
  247. Cabin Heater usinf FW cooling?
  248. Flushing drive pumps
  249. Winterizing the HP525
  250. 140 merc
