PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 [107] 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Upgrades to 502 MPI's
  2. Is this cam too much for a marine 502?
  3. Pcm ??? for you efi guys
  4. Hand pump for Amsoil Outdrive Oil
  5. MEFI4A ECU Problem- Fuel Pump
  6. Trailer lug torque
  7. Anyone ever try?
  8. Noise in motor/ black oil/water
  9. EFI Losing Prime
  10. Procharger with Eickert Headers
  11. Fountain EXECUTIONER vs LIGHTNING
  12. different winterizing question
  13. Imco Extreme Advantage Sc Drive Questions
  14. Has anyone ordered from 'Stem to Stern' lately?
  15. Cold air intake system for 496 engines can add 8-12% HP.
  16. Exhaust Drain Plugs
  17. Freezing 496 Mag
  18. Auto bilge pump switch
  19. Can slightl worn bravo gimbal assemblies be re-bushed?
  20. 496 mercruiser
  21. Highest compression on 93 octane
  22. who sells old Cusader parts?
  23. Wireless Kill Switch
  24. 575 headache
  25. Rotted Exhaust Bolts ?
  26. EFI Fuel pump dead. Why?
  27. Help Design My Next Motor
  28. Plastic washers and (help me find)...
  29. foot rests
  30. Trying to recover from an engine scam
  31. Quick answer needed: trailer bearing
  32. ECU Reprograming
  33. Bravo propshaft question....Help !!!!!
  34. Which prop
  35. water reversion and muffler tips
  36. 502 ram jet cam
  37. Ext. box question and leaks...
  38. 598 - which heads and cam for 750hp
  39. Gimble bearing came out with drive. Why?
  40. Prop
  41. Anyone need....
  42. Raylar's 496 Exhaust mods??
  43. Looking for Thermostat housing
  44. 500efi rebuilds
  45. stock rods and crank, what HP can they handle
  46. 177 Vs 250 blower, any gaing in HP
  47. High Perf. Engine Parts vs Parts
  48. M.S.D. starter /savers
  49. Which roller cam for a 575sci rebuild?
  50. Interesting observation
  51. calling Al from Addictive water sports in Tampa, FL
  52. what exactly is resizing rods???
  53. Prop Rotation!?
  54. Steel Crank Turned .040 ?
  55. switching from a mefi3 to mefi4
  56. need some motor input
  57. Riser Gaskets for 496??
  58. How to change thermostat on 496HO?
  59. Noise violations????
  60. blower belt slipping
  61. merc 377 up grades
  62. 525SC Mercs Upgrade - Any packages available?
  63. wide band o2
  64. Question about Small Block Exhaust systems. (350/300hp Magnum)
  65. OMC Ignition 90 350 King Cobra
  66. 454 Mag MPI ran great ..... but only to 4000rpm
  67. dirve oil pump
  68. Stabil what's really in it ?
  69. Anodising
  70. Power upgrade
  71. Can someone tell me what this is???
  72. XR drive
  73. Engine upgrade
  74. Reversion Question- Again
  75. char-lynn helm
  76. Marine alternator
  77. Battery Boxes
  78. Bravo 1 X leak - thoughts?
  79. VHF radio with intercon HELP
  80. 525 question
  81. Cooling Questions
  82. KE Roller Rocker Arms - Anybody?
  83. Oil leaking Bravo One
  84. Need spaekers, Help
  85. quick winterizing question
  86. reversion and intake manifolds
  87. throttle/gear shift removal ?
  88. Oil Smell
  89. Parts
  90. Pumping Gas Tanks Dry
  91. zero effort
  92. Need a flywheel for a Mark IV 454 TRS
  93. jetting blower motor
  94. Stock 500 EFI E- tops?
  95. What's it worth?
  96. 496 HO not starting any ideas
  97. Broken Rocker arm adjusting nut-500efi
  98. Do you think this boat on EBAY can do 80MPH?
  99. NEED HOUSTON EFI inboard Volvo MECHANIC
  100. Sema.
  101. What size carb do I need.
  102. Will a 1/2 Ton Chain Fall.....
  103. Merc Outboard Bore Job
  104. 454 Gen IV losing oil pressure
  105. Water proofing cockpit cover
  106. prop wrench
  107. yet another cam/head question..
  108. Help! Rocker Arm Question for 502 Gen 6 (1998)
  109. Over Head Cam ford motor suggestions
  110. Winterizing Question
  111. Mach 1
  112. Sbrt
  113. 502whipple with bravo 1
  114. Bolsters
  115. 496 truck block, What is it worth
  116. Mobil 1 V-Twin
  117. Separating the Bravo lower
  118. Anything specail about SRX MERCRUISER ENGINES
  119. cam choices
  120. Ok, what do I look at next?
  121. Reading Plugs Tech info
  122. msd starter saver
  123. 72 vevet drive
  124. calling Tyler and Raylar ? for you
  125. CMIs - have them fixed or buy new exhaust?
  126. Another winterizing question
  127. Winterization Question
  128. predator marine logo
  129. 496 Exhaust water routing??
  130. Electric vs Mech Fuel Pumps
  131. transom cut out question
  132. Draining EMI thunder exhaust?
  133. 502 efi oil removal?
  134. What do you think about these lower gears..
  135. This just cost me some money!!
  136. 496 engine throttle response ?
  137. Holley Manual Fuel Pump ?
  138. Throttle controls
  139. Sea Water Strainer Question
  140. Winterizing HP525's
  141. Reversion?
  142. Bennett Tabs
  143. B-Max Drive Info?
  144. EFI live
  145. Eldelbrock Air/Fuel Moniter
  146. Mild SBC Upgrades
  147. Holley carb gurus
  148. Looking For Image
  149. 500HP Starting Problems
  150. Merc To Fram Filter Conversion
  151. Can 5psi be reliable on a non-magnum 454?
  152. Lost major power--- Why????
  153. Guesstimates on 502MPI 415HP gain over 330HP
  154. HELP: Engine alignment to Borg Warner Transmission.
  155. 502 Mag
  156. 177 blower on a 502
  157. who knows the differences in a 2006 bravo III vs a 1998
  158. High Performance/Flow Fuel Pumps
  159. Winterizing ?
  160. 15 Over Bore On Hp 500
  161. Konrad Drives
  162. Trick Access Around Boats on to Boatlifts?
  163. Trick Flushing Techniques While On Lift?
  164. Need a contact # for Mr. Gadgets
  165. How much can stock roler lifters handle
  166. Exhaust Resonators
  167. adding a stand off box
  168. Salt Away ???
  169. Code 81 on scanner - MEFI 4
  170. Suggestions ?
  171. Bravo 1 outdrive with metal shavings on drain plug
  172. CMI headers on 353fastech/496HO's
  173. Starter
  174. 188 heads
  175. GPS Wizards
  176. 190 hrs on H.O. Change to synthetic?
  177. Anyone know the thread size/pitch 4 Bravo?
  178. Anyone have Victory Tabs??
  179. Changing Drive Oil in the Fall
  180. milkshake again
  181. bbc chevy loses voltage
  182. bravo III making noise in forward
  183. New Longblocks, Rebuilt, Remanufactured???
  184. Trs Outdirve Full Of Water
  185. Winter Engine Layup
  186. Inconel valve question ?
  187. 454 mag-450hp with stock cam
  188. fuel/water separator
  189. Toe in n Toe out?????
  190. 454 mag engine miss
  191. TRS Power steering removal
  192. 496 HO's- 425 at the crank or prop???
  193. Rev limiter
  194. Pair of 500 efi's
  195. Looking for opinions on Hydraulic steering set ups.
  196. Trim pump oil
  197. #6 Dry-sump conversion...
  198. 454 4 bolt a mag motor
  199. Merc 454 oil pickup help needed
  200. Adding ITS
  201. Ignition upgrade
  202. speedmaster3 to bravo questions
  203. Bravo Dimensions
  204. got my new bravo one and transom today
  205. Bravo engine setup with an Alpha drive?
  206. Another leakdown question
  207. Intake manifold sealant
  208. New 300xs optimax's
  209. Idle question
  210. trim tabs don't go up even
  211. Garboard Brass Drain Fitting?
  212. Should I upgrade?
  213. 496HO hot manifold
  214. 496 Elbow Paint
  215. need a dyno chart 350 mag mpi stock
  216. I Need a trailer
  217. weights of drive oil vs speed of boat
  218. new member new ride
  219. fuse block needed
  220. X dimension
  221. What's my drive?
  222. 241 Libby -Engine Misses - Burnt Valve?
  223. Bad 502 pump gas Piece by Mesa
  224. Oil filter for '96 502 efi
  225. Leakdown test on a cold motor
  226. 509 fuel presure
  227. 29scarab finally getting somewhere.
  228. Edelbrock VS Merlin Intake
  229. Hydraulic Steering Upgrade
  230. Donzi 25 top speed
  231. Wide or narrow band air / fuel meter
  232. Unabashed Gearhead Gnarlyness
  233. To choke or not choke?
  234. CMI Headers/496 HO
  235. Need 16 rib blower belt
  236. poll, how fast will my chevelle be with the new power?
  237. are all bravo couplers the same?
  238. Who does ECU mapping
  239. 496 Oil Filter
  240. Using A/C while on a lift
  241. Marine Vinyl Supplier?
  242. wstsidesrf shoot me a email
  243. How did oil get here?
  244. cool fuel drain plug
  245. I did it to myself and now I need help selecting injectors and fuel mapping
  246. 5.7 GM Marine HP?
  247. Gen V heads on early 454 block
  248. Worth the gain? AFR CNC heads/Crane 731 roller/carb on 454 magnum?
  249. EFI with big cams
  250. Replace Dip Stick?
