PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. 525 EFI Guru's need help!
  2. plenum gasket
  3. Bizarre Carb issue
  4. Champion plugs
  5. LS6 Block
  6. Gil wet exhaust tubes getting hot
  7. 89 baja 320force
  8. Will big block CMI headers work on stock 496?
  9. 700sci Fuel Pump blowing fuses, WHY?
  10. 500 efi ATECO head kit
  11. Merc ignition help please.
  12. 350 mag carb version roller or not ?
  13. While my motor is out....
  14. Is this a Cigarette
  15. Need Gauge Wiring help!!
  16. blower guys
  17. Help! 07 496 no crank no start
  18. Problem with McLeod Bolster- no power
  19. 38 Donzi ZR Tired of losing blades off my propellers
  20. Chasing a 300-400 RPM drop issue in Port motor!!
  21. Monterey by Seabring
  22. Gaffrig gauges/ closed or open??
  23. Supercat engine questions and ideas
  24. Adjustable windscreen?
  25. Wind storm boat covers ?
  26. Strering Problem
  27. 496 replacement injectors
  28. Permatex
  29. Morse tilt steering knuckle
  30. HP 500 camshaft's Do they have a fuel pump lobe?
  31. Motor and 500efi injection question
  32. Mechanical indicator help
  33. Cleaning vinyl?
  34. 36' Apache trim tab cables???
  35. 500 efi issues
  36. EMI Thunder plumping problem
  37. Intake valve, severe cracks !?
  38. Prop wont go any faster.
  39. Computer/Thermostat Question
  40. steering
  41. Hearing whistle when secondary's open???
  42. Corsa exhaust issue. Has to be a simple fix??
  43. 575 sci fuel pressure
  44. Corsa Quick & Quite diverter valve solenoid
  45. 89 or 93 pump gas
  46. 502 efi's water pressure gauge's
  47. O2 Sensor bung installation CMI Etops
  48. steering actuator
  49. Does 93 octane leave chronic soot on the transom?
  50. 1989 scarab 21 excel motor ideas
  51. headbolts for 525 efi
  52. Pro charged 500HP, carb to EFI
  53. Switching from omc to merc, how hard is it?
  54. Starting Problems (Cranking Over)?
  55. Just can't catch a break
  56. Single engine/twin engine prop slip/speed
  57. Fountain shift/throttle-switch sides?
  58. Cobalt fuel pumps?
  59. what is a good qualit and resonably timing set and timing cover for a stock 1990 7.4?
  60. Boat handling issues
  61. looking for help, possible efi issue
  62. 525 cam sensor installation procedures
  63. 502 Mag MPI dies over 4000 rpm/full throttle
  64. Changing a fuel gauge?
  65. 350 Mag MPI WOT bog??
  66. What's the magic spot for a thru hull water depth gage transducer on stepped hull?
  67. Mississippi launches
  68. What do these Spark Plugs say??
  69. 502 EFI intermittently chokes and sputters, drops rpms at cruise speed, stalls
  70. Oil pressure sender 500 EFI
  71. Gauges
  72. Bravo 1 Drive
  73. Pulley slip on ribbed serpentine blower pulleys
  74. 522 missing, bog
  75. Ignition Module
  76. Hp500 EFI injector issue
  77. 496 Temporary Overheat?
  78. Dometic a/c question
  79. Charging diagram twin engine
  80. Replaced impeller 496 ho still no water pressure
  81. Potential Issues with 7.4 L Mercruiser (Year 2000) with Bravo I Drive
  82. Electrical question
  83. 502 quit on me
  84. Mercruiser serial number indentification
  85. What plug to run on a Gen 4 BBC 177 motor.
  86. Strainer cover won`t come off, wtf
  87. Yamaha 4.2 250hp
  88. apache scout motor height
  89. Gaffrig Gauge Questions??
  90. 454 Upgrades?
  91. Weird engine shut down last night 502 MPI
  92. Spinning hubs???
  93. 500 and 525 EFI Vacuum at Idle
  94. 496 Water Ingestion HELP
  95. SBC Valve Cover Clearance Issue with GLM Manifolds
  96. Small outboard question.
  97. Engine Oil Questions. What do you think i the best!
  98. Michigan Motorz Replacement Engine
  99. 300 Optimax parts
  100. inner transom plate
  101. Fuel system help
  102. drive oil in bilge...
  103. puke bucket on 583 ci
  104. drive off, vac and pressure test anything else?
  105. Another starter, this time ring gear also... advice while engine/drive are out?
  106. Standard bravo one sweptback serial number needed
  107. 1995 Formula SR1 has low compression - South Jersey
  108. Supercharged 350 tech advice needed!
  109. Power steering pump
  110. corsa exhaust max rpm
  111. High hour 502mpi mags still running good ??
  112. Oil Level Mystery
  113. Engine issues in my 98 Fountain... Please help!
  114. Anybody here a Dodge mechanic? have questions about a Journey in the fleet...
  115. holley jet sizing for my mild 355 merc ?
  116. Opinions on triples
  117. adjusting valves in 350 sbc
  118. ARP rod bolt question-resizing?
  119. First start up on my new big block :)
  120. 500 EFI Saltwater Questions
  121. 1997 STD 454 carb rev limiter?
  122. Quadrajet carb choke issue
  123. can only turn 4000 RPMS on a 500 EFI, rebuilt drop in
  124. Any experience with Raylar 103 Cams and/or Rockers?
  125. oil additive needed with mobil 1?
  126. 350 Mag Q-jet flooding through primary boosters
  127. Yes another 496 issue. possibly injectors
  128. Crank Driven Water Pump
  129. 2000 47 Lightning upgrading to 525efi motors... connecting to smartcraft? Help!!
  130. MercMonitor, Smartcraft, Vessel View...HELP!
  131. 1999 merc 7.4 mpi vi altinator output post bolt wearing hole in coolant hose???
  132. Too much pressure !!!
  133. Engine and prop set up
  134. Engine water and oil temps too cold
  135. what are the chance
  136. Distributor/ignition issues, need help diagnosing
  137. Hi Tek exhaust manifolds
  138. 525 efi intakes
  139. Video lcd Monitor Info
  140. Re-power with triples? Stagger twins? OR Twins with a larger cockpit??
  141. 1990 7.4L bravo 1 carb replacement
  142. BBC circulating pump
  143. adjusting flat tappet valves
  144. water temp sending unit
  145. Iac controller 496 ho & diacom test
  146. Carb Spacers and Jetting
  147. Help please, possible gas leak?
  148. Dennis Moore's Book
  149. Exhaust question
  150. 088 vs AFR 265 dyno comparison
  151. Need a new 502 BBC rear crank seal. Mine blew out this weekend. Who's is the best??
  152. Insurance company info need for boat Insurance
  153. Air Fuel Ratio Meters...who makes a cheap one that works well?
  154. 496 sportstube headers??
  155. Replacement headers for 525 EFI - Which ones?
  156. 502 mpi mag change to carb help!
  157. 6.2 MPI problems
  158. oil bypass valve question on gen VI engine
  159. Stuck valve on Mercury 525 EFI - cause ??
  160. Thinking about replacing the dash and gauges on my 35' Fountain Lightning
  161. RH vs LH prop??
  162. 496HO missing at 3,000 rpms on take-off after warmed up
  163. High hour 496 loosing power
  164. How underrated are INBOARD engines? Twisting 5600 with the stock props 32 fever
  165. Broke starter and ring gear
  166. 496 CMI twin engine install ?s
  167. 496 Mag filling bilge with water
  168. Looking to upgrade alternator on a 496 mag
  169. 502 Idling/throttle-up Issue
  170. Teague rockers cracking has anyone seen this...
  171. Scarab overheat issue new rebuild
  172. 2007 525 efi
  173. KAMMA boots
  174. Broken Pushrod ball
  175. NXT1 Transmission problem, Advice, Service Repair Manual?
  176. Going crazy on my Mercruiser 496, need Help!
  177. Valve adjustment procedure
  178. Flywheel On 496 Stroker
  179. Wrapping my 47 Fountain? Who in Florida provides a decent wrap and how much $$?
  180. 496 Coolant in Bilge
  181. Shop crane help
  182. starboard runing cold!
  183. need cam expert help
  184. Baja not charging acting funny!!!! Quick question think I fixed want thoughts
  185. Broken Pushrod
  186. upgrading cam on 454 mag crossram efi
  187. 496HO issues, help and feedback needed!
  188. Has anyone used AUTOTEC pistons?
  189. Teage Marine Camshafts
  190. Electrical Question for Wellcraft NOVA III
  191. Cam advise
  192. Goto guy for tuffest bravos?
  193. 500efi problem
  194. Power Steering Pump Issue
  195. Gen v 7.4 belt diagram
  196. Mod my 420 intakes or buy 8:71's??
  197. Too much water pressure
  198. Header Temps ?
  199. 502 Mag cooling system problem
  200. Lost forward/ reverse. Help!!!!
  201. Mild 350 cams
  202. tranny making grinding noise
  203. Need add on steering help ASAP so I can boat tomorrow
  204. Any dyno in central Pa./ ne Maryland
  205. Port engine still weak, advice needed. 2005 496 ho's
  206. Grease points on Bravo?
  207. Whats up with Revolution Marine?
  208. Mirage 202 with a 492?
  209. 496 ho question
  210. Stock 525sc's
  211. Steering
  212. 502 MPI Nightmare!!!
  213. I am thinking about freshening my blown 454 mags after the season
  214. 496 seawater pump
  215. Any pointers for rebuilding Borg Warner 72c transmissions?
  216. thunderbolt ignition
  217. Engines won't turn more than 4200 RPM
  218. Name this part off of BBC whipple charged engine
  219. Mercruiser 454 MAG MPI weak!! help!
  220. 454 mag carbed timing??
  221. dominator carb question
  222. High idle trouble. Lookin for help
  223. Engine Stalling Issue
  224. Mercury Racing Motor Mounts
  225. 525 sc what lifters to use non roller
  226. Words to the wise from the not so wise regarding ignition pickup module or icm...
  227. Best Gen. For a 496 Stroker Gen 4 or Gen 6
  228. 7.4 mpi 2000 model had gaskets replaced the price good???
  229. Need Part Numbers for Gen V/VI 454 flywheel - cast crank versus forged
  230. 385HP 454 Rod knock
  231. 496 stroker jetting questions
  232. NMEA 2000 actuators?
  233. Figured out rpm surge but need some advice
  234. Can someone please tell me what boat this is?
  235. what is this amplifier/rectifier looking thing?
  236. 525efi 600sci and 700sci Heads... are they all the same???
  237. Snap on timing gun on 502 mag??
  238. Fuel pump fitting size 525sc
  239. 454 to 502 engine swap reused TB5 from 454 and im having ignition problems...i think
  240. problem with dual ram tab
  241. Merc 525 header bolt torque??
  242. BBC 540 performance upgrade ?'s
  243. Gaffrig Tachs/Smartcraft acting up
  244. Mechanical fuel pump on a fuel injected 454ci?
  245. ecm relocation
  246. 496 Oil Cooler, where to buy!
  247. Whipple VS Procharger
  248. Is GM Vortec 454 essentially the same thing as the 300-HP L29 7.4L?
  249. I.T.S. and imco stand off boxs question
  250. optima batterys
