PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. 2 Alternators to choose from
  2. blower size help
  3. Replacing stock thermostat housing with Stainless,,,,,
  4. Mercruiser silent choice
  5. How often to clean the air intake 7.4 mpi
  6. Mercruiser Rev Limit Ignition by Firepower
  7. 496 whipple boost
  8. Cigarette 24 info
  9. Led Cockpit lights
  10. Exhaust Problems
  11. Cobra outdrive not pumping water
  12. Trim not moving evenly
  13. 502 water reversion
  14. Ultimate Warlock 24' Euro
  15. Alpha hit something no forward or reverse
  16. FAST Programmable EFI
  17. Oil foaming out of lower unit trim pump reservoir only while trimming lower unit.
  18. Loose/missing exh flapper
  19. Engine won't get boat on plane - ignition issue?
  20. blown 900 ate a distributor gear over the weekend, what now......
  21. Cost to rig a new hull?
  22. Outdrive Control Box
  23. 502 ss trying to get a hold of u bro ??
  24. Morse Controls
  25. Mercruiser Head Gasket Sealing
  26. Why no oil cooler 350 mag MPI
  27. Go Fast needed for a wedding
  28. Noise at Higher RPM's..... Details inside
  29. Rooster tail fittings on Normal drives - What and where?
  30. Removing compass
  31. Another water in oil milkshake thread
  32. Water in motor..need help fast!!
  33. Head Gaskets...head bolts..
  34. Baja 252 motor help
  35. When started, EFI motor will not idle below 3000 rpm
  36. Smart craft trim limit switch
  37. steering question
  38. Serp belt tension
  39. Lubricant for silicone exhaust hose?
  40. Painted boats hull cleaner?
  41. Scratched CMI polished Sport Tubes
  42. corsa solenoids ratling when diverted to prop
  43. wiring questions
  44. timing chain question
  45. transom assembley help
  46. Pondering the thought of doing a LS motor.......
  47. Any wlders in the house?
  48. Junk VST Electric Fuel Pump
  49. Hardin Gen 7 Sea Pump Install
  50. Motion actuator for power bolster seat, I need one from a Fountain or other boat!
  51. New engine ready to fire but WONT! Expierenced techs Please Help!!!
  52. Steering leak at the helm
  53. Boost referencing carbs
  54. recommended manifolds for 540 tall decks 600hp innovation marine
  55. twin engine fuel burn from side to side.
  56. Drain plug adapter
  57. 496 ho
  58. 03 496 ho double beep
  59. Horrible Idle on a holley 800..
  60. Smallbock oil adapter
  61. WTF,, does anyone make a tall life or ski vest for guys 6'-6'+
  62. 900 low oil pressure and cold filter after oil change???
  63. Recommended GPS with depth capabilities ?
  64. more HP for 502 mpi
  65. Lake Texoma Eating
  66. Running rough at low RPM after warmed up
  67. HP500/ BBC short water pump part#
  68. 502 MPI Surging over 4200 RPM
  69. New Oil Coolers? Yes or No?
  70. Gaffrig oil pressure sender
  71. Merc 7.4 Gen V clicking noise
  72. FAST Air Fuel Meter??
  73. RPM Drop in 1 Engine
  74. 12V DC Air Conditioner - Anyone have any experience with them?
  75. 496 with Whipple
  76. Gen IV Heads On Gen V Block Coolant Port ?
  77. Ethanol resistant fuel line?
  78. motor swap, now gauges dont work
  79. flame arrestor
  80. Bore notching 4.310 bore
  81. kiekhaefer trim tab manual or information needed...
  82. Throttle response.
  83. Anyone noticed slower speeds with the higher air temperatures?
  84. Heat Alarm wire..
  85. 1999 Donzi 26ZX performance results with new 502
  86. 600sci Impeller DIY?
  87. Replacing trim and drive indicator cables on Bluewater Performance panel HELP!
  88. Who designs custom dashes for older boats?
  89. Seeking a brochure for a 20 foot Cigarette
  90. Cast Iron manifold -> Stainless exhaust pipe
  91. Valve cover removal with exhaust on?
  92. Mando alternator wiring....
  93. Merc Racing 525EFI. SAE or Metric fasteners?
  94. Dana Exhust
  95. Replacing 502 with 496s
  96. Replacing 555 on 496 with MEFI Controller
  97. Exh manifold leak test w/acetone
  98. single 4150 fuel feed recomendations
  99. running hard with or without Silent Choice open
  100. This pizzes me off! Who is CP performance trying to kid
  101. Size of hose on speed master 3
  102. Swapping to a sea pump on sbc...
  103. anyone have 500efi valve cover baffle pics?
  104. fuel/water separating filters
  105. Pump size nozzle on a stock HP500 holley 850..
  106. Sierrs f/w sapartor
  107. Temp problems with 27' Advantage Victory
  108. Mefi 1 ecm bad, ideas??
  109. Need some help guys! Just bought a new boat.
  110. Dual Carb Adapter Gasket On Blower ?
  111. Skag repair on Sportmater lowers
  112. 1997 Gen VI MPI
  113. L-29 heads question?
  114. 7.4 MPI Vapor Lock and "jip joint gas"
  115. Oil cooler location and funny story
  116. exhaust manifold
  117. Oil Cooler Line Diameter
  118. 454 massive carbon build up on spark plugs back of the boat is covered in suit
  119. best prop for 26 Daytona
  120. 7.4 330 oil leak under power?
  121. Baffled by apparent reversion issues with Lightning headers and mild cam
  122. Changing oil with engs out
  123. Motec display with smartcraft?
  124. 525sc died at 70 mph no spark
  125. Bravo one trimming noise!
  126. Holley power valve sizing.
  127. ( A/F ) air fuel ratio for NA 350 vortex
  128. 330hp to 350hp vortec 454
  129. Engine Weight ?
  130. Fuel leaking out of vent ??
  131. Engine Oil Overfull (Due to extended high RPM runs)
  132. Intake Manifold Oil Leak?
  133. 4 Blade vs 6 Blade.
  134. Geico, Seaworthy Ins, Any Horror Stories?
  135. auto technician needed
  136. trouble with 525 sc
  137. looking for two pair of 4.5 flapprs for myexaust p
  138. 2004 47 fountain oil pressure sending unit
  139. Need opinions/suggestions 12volt battery system
  140. 525EFI water pump
  141. Gil Oil coolers
  142. Turbo question! Advice needed
  143. Dyno Day! Question for engine builders - A/F correction factor for dry dyno headers?
  144. 496 HO 2004 - Shutting down when throttling down
  145. anyone running a 5 blade with 525 efi?
  146. Corsa switchable exhaust swap.... Baja 272
  147. What are they worth?
  148. Ocean Marine AC unit reading HPF???
  149. Recommended oil for my 7.4
  150. Need advice about sea strainer on a superboat
  151. U joint shaft bravo2X
  152. 01 38 fountain lightning gen iv bbc what couplers and housings
  153. Anyone bought a new oil cooler that had something rattle in it?
  154. Power Steering Pump Pressure for Ram
  155. Where can I find a eddie marine part that is no longer made....
  156. Fuel Gauge...
  157. 525 Mercury Racing Engine pulling back once it hits 4200 rpm
  158. lying to your insurance company? ??
  159. TB IV and V ign info
  160. Where to place AFR sendor Or Stanless Marine Exhaust
  161. Backfire through exhaust on initial startup
  162. Hardin marine ?
  163. Spun Prop What Else to Look For
  164. EMI risers, cracked one
  165. 99 formula twin 7.4 mpi bIII vibration/hesitation help
  166. motion 30 vs spectre 30 ??
  167. how to I.D a 454 Magnum
  168. How reliable / durable is the Merc 6.2?
  169. Lost oil pressure
  170. Engine rotation
  171. Comp cams 212 Timing cover
  172. Drying out cabin carpet ??
  173. 502 mpi thoughts on pitching injection and going with the carburetor
  174. WPM Steering
  175. 144 blower on stock 350
  176. Oil Temp Question
  177. Here we go! blew up a blower motor
  178. Owners manual, 1991 Sonic 31'???
  179. Overheating problem-more challenging than usual
  180. Corsa quick and quiet exhaust mufflers
  181. gages
  182. Why jetting so staggered with a single plane?
  183. Anyone want a 2012 38' Powerquest? Looks like an auction for unfinished boat
  184. Carbureted 502 MAG Timing And Fuel Help Please!!
  185. Hardwall water hose
  186. Fuel pressure on carb 454
  187. MLS or Performance head gasket
  188. Dyed vinyl question
  189. 6.2 engine torque?
  190. Compression Test
  191. Finding Taco vinyl rubrail insert
  192. Stainless Braided Trim lines and Kplane line extending
  193. Problem !! Electric gremlin I think.. Help..
  194. Correct Flywheel??
  195. 496 Mag HO Rev Limiter ?
  196. Help with Warlock Performace Machine steering ram
  197. 7.4l 330 hp needs a new carb what do you guys suggest
  198. Replace silent choice on my scarab? or keep replacing seals?
  199. ethanol fuel messing up Gas Tank sending unit???
  200. Fuse or not to fuse "That is the question"
  201. Looking for Some Insight on Merc 500 EFI
  202. Where can I get exhaust block off plate
  203. 496 vs 540
  204. O2 sensor without drilling and welding Lightning headers
  205. hydrolic steering question please help
  206. 502 not firing on all cylinders/raw fuel in exhaust
  207. 502 MPI Cool Fuel vapor lock - other options than new electric LP pumps
  208. welding Lightning headers
  209. carbed 454 mag will not idle
  210. Aeromotive Fuel Pump issues
  211. BBC physical size
  212. best exhaust for the dollar
  213. Power steering ram leaking.. need help on finding parts
  214. baja to a sea ray
  215. 496 whipple loading up on idle
  216. Newly rebuilt 525efi will not fire... help!
  217. best place for hp transom assembly
  218. Engine shudders and sometimes stalls when Bravo 1 engages fwd/rev
  219. CROSSOVER help..yes another crossover question..
  220. Stellings Greens VS CMI Etops
  221. what heads 308 darts 290 or 305 afr heads
  222. gen v info?
  223. What makes a "fast hull"
  224. 525 sc ?
  225. Mercruiser 502 EFI stalling question
  226. performance gain???
  227. 500 EFI Issues. Wont Stay running......PLEASE HELP!!
  228. Battery Selector Switch??
  229. Does a K&N spark arrestor help or hurt? 500hp
  230. New water pump done. Problems?
  231. Gen iv gen v whats the difference
  232. Taco Part
  233. Where can I find plastic mipples that go into valve covers for venting??
  234. New or old style head gasket EFI 500 .
  235. Idle poblems 502 mag MPI. Please help!
  236. Please help identify what kind of boat this is!
  237. EMI Thunder Exhaust Manifolds HP limitations?
  238. 496 Mag water pumps not priming with new impellers. Time for new pumps?
  239. 502 mag part # please
  240. Battery Question.?
  241. 383 build opinions
  242. need help with 525 sc engine not going over 5000 rpm
  243. stelling header tails
  244. Changing Gil exhaust from wet to dry pipes
  245. iac duty cycle numbers
  246. Mechanical fuel pump, need some help
  247. Carb Spacers, Whats the low down on them?
  248. Mercruiser Fault Codes??
  249. Need help help
  250. 1978 python boat
