PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Hull number locations
  2. Dart Heads
  3. Bravo 1...No forward ..Reverse works fine
  4. 500 efi temp
  5. sea water pump hoses
  6. scored cylinder walls
  7. Head gaskets
  8. Help please!!!!!
  9. blower surge
  10. Needed...Whipple or vortech supercharger
  11. water in oil
  12. imco external steering
  13. 540 Bulldog motors
  14. Silent Choice will work with BMAX right?
  15. How to fix Formula FasTech sliding doorthat gets jammed?
  16. Baja 27.2 496 Ho 67mph@4850
  17. efi to carb conversion
  18. Engine gets hot 400 degrees
  19. 496 Sea Strainer Install - Help!
  20. Why 2 Pressure Regulators
  21. Play in drive. How much is OK?
  22. superchargfer boost chart
  23. Bravo rear cover
  24. cam specs 525 efi
  25. Oil Line Plumbing
  26. Peanut port, low compression, 454
  27. Charlyn helm lines
  28. Oil question
  29. Under Hatch Mirror,What backing do I need?
  30. EFI, Edelbrock vs Holley vs FAST vs Accel
  31. Diesel oils in boat engines
  32. exhaust flappers
  33. BPM drive vs. #6's with rudder
  34. Opinion on Headers Needed.
  35. Quicksilver Mirage Prop- no thrust washer?
  36. Shifter hard to move..Bravo 1
  37. HP500 efi spark table???
  38. Kpm 2 Stage Any Problems??
  39. Winterization question - True or False
  40. Cmi Headers
  41. 496 Air Actuator Problem
  42. 496: How often to change anti-freeze.
  43. 496 HO - Mercruiser with antifreeze in crankcase
  44. 496 HO - Mercruiser with antifreeze in crankcase
  45. 496 Mag HO exhaust manifold over heat
  46. Hardin Marine stainless sea pump assembly
  47. Hourmeter Guage
  48. Gaffrig gauges needed
  49. imco 2" shorty lower how does it help or not
  50. imco lower
  51. Help determining prop pitch
  52. Need mecruiser universal expertise
  53. what thermostat will fit????
  54. Nobody wants my money??????
  55. new 555ci that won't idle or get warm
  56. Drive Noise
  57. Procharger on 502 MPI Manual
  58. 454 mpi
  59. 3 blade prop to 4 blade questions
  60. 1997 truck vortec 454
  61. Back Flushing a 496 after blown Impeller
  62. Full transplant - 7.4 Bravo1 / 5.7 Alpha Gen2 - Possible?
  63. Silencers: Which one ?????
  64. Cam specs?
  65. mercury bridgeport 2.4 efi engine
  66. Overload and/or Low Voltage Interrupt
  67. Mirage vs. Mirage Plus
  68. 496 CMI Sport Tube package
  69. Blowing Exhaust crossover hose on Volvo 8.1 GSI
  70. exhaust tips
  71. Best upgrade options for 330hp 454....
  72. High temp exhaust hose?
  73. what year did the 502 500hp come out
  74. Mercruiser 496 with DTS
  75. Plumbing Suggestions for 496 take offs
  76. question on Imco hydraulic steering
  77. backfiring thru the carb
  78. torque specs
  79. Brass/bronze bushing direction/Bravo
  80. Direction of 496 Impeller? HELP!!!!
  81. Merc. Distributor question
  82. ignition coil
  83. Numbers on Mefi3
  84. Dart head water leak
  85. Power Steering
  86. #6 Skegs
  87. Spark Plug Change
  88. What is the oil capacity for a1999 502 MAG
  89. Spring pressure
  90. dimension of hydraulic lines for steering
  91. rm builder bob marada email???
  92. Tired of your white plastic yellowing...
  93. engine noise?
  94. Steering Dampers with 600 hp in a 96 outlaw ??? anyone use these?
  95. Cams With Gill Exhaust
  96. Prop Question
  97. Deck height discussion.
  98. LED Lighting problems
  99. Merc 800sc ??????????
  100. 93' 502 Oil Pan drain Plug Fitting ????
  101. 2 sete gill manifolds w/ risers
  102. exhaust for small block
  103. Trim switch needed
  104. 6.2 merc mods
  105. Very old Gas in Tank
  106. Drive acctuator
  107. fuel sender wiring
  108. Gaffrig GPS Speedo Problem
  109. Merc 454 water by-pass kit?
  110. Mercruiser 260 5.7L K&N
  111. Roller Cam Button
  112. need 2 intercoolers 177 weiand
  113. Help !!!!!!
  114. ADVICE NEEDED 496 MagHO Oil Leak
  115. What Carb for my 5.7L Mercrusier
  116. Gauge Rims
  117. Sea strainer on a Merc 496HO/Mag, 525efi, 600sci or 700sci engine
  118. roller lifters hours ??
  119. Anyone use GM lifters
  120. Engine Dyno Tuned COST? Don't want to overpay for service
  121. msd boxes
  122. K-plane parts
  123. sloppy shifter
  124. Bilge blowers, dumb question
  125. Mercury Drive Oil Warantee
  126. K plane thru hull fitting size?
  127. 454 raw water pump installation
  128. In need of detail advice...
  129. water temp ????
  130. 454 Mag cam
  131. Pulley and alternator conversion
  132. Service Manual 525 EFI
  133. procharger belt tension
  134. installing water pressure relief valves
  135. vinyl cleaning
  136. all those who have an air scoop
  137. Broken Intake Valve
  138. water pressure port ?
  139. Need spring cleaning advice......
  140. what is my oil capicity?
  141. Sea Pump priming????
  142. rotation question? single screw.
  143. How to change antenna battery on a Livorsi GPS speedo?
  144. Any Box Anchor users? Need advice
  145. 525 EFI Starter corrosion
  146. proper flat tappet cam break-in
  147. Props turn in or out on a 1994 Cigarette?
  148. Boat Paint
  149. Hydraulic Steering - do you keep the tiller arm?
  150. mercruiser shop manual
  151. Trash in fuel
  152. Shift arm removal on a bravo 1
  153. 500 EFI Engine Oil Question
  154. mfg'r of valve springs
  155. Hey John Arruda!
  156. Tool Kit?, what do you guys carry????
  157. who makes fuel cells?
  158. Bullet 632ci Power in Force 29 Cat
  159. bravo end cap bolts
  160. crane ignition box HI-6m wiring diagram
  161. flame arrestor screens
  162. Need a lead on a simple part
  163. Help-Sea Strainer Install on Merc 496HO
  164. Vent/Blower adapters???
  165. 2005 baja h2x wiring
  166. Gibson Turn Down Tips
  167. Help. Need plug to replace O2 sensor
  168. The best 500EFI blown setup
  169. VST Swap to ????
  170. age old ?,how to stop vapor-lock,vst system
  171. Will Smartcraft Gauges Work With Reg Bravo Transom
  172. Need heads for 7.4 MPI Anybody?????
  173. Coolent drain Plug Problem
  174. Merc 496 riser paint stripping
  175. Found the reason for the water intrusion on my HP500
  176. Anyone need 2 sets of 500 hp heads
  177. Feul Pump recommendation?????
  178. 525sc Blower Pulley???
  179. Man I Need Help...Trim Sensor Fault
  180. holley 4150 800 issues
  181. Looking for a 525 Mercury
  182. Pushrod Length?
  183. Anyone from EMI ?
  184. fuel sender
  185. 502 mag Fuel injection HELP
  186. dirve shower mounting
  187. starter problem
  188. Bravo hinge pins ??
  189. Depth Sounder Question
  190. TV reflection/glare
  191. Are my headers stock??
  192. roller rocker valve covers
  193. 260 sonic porpising
  194. parts 4 hp 500's
  195. need help with strange 7.4MPI problem
  196. hp500 with 300 hrs
  197. wt headers can i get away with this cam??
  198. delete
  199. konrad/trs
  200. 500 HP intake
  201. Oil pump pickup tube
  202. height of PSI supercharger
  203. Most Affordable Custom Oil System Plumbing
  204. Livorsi tachs acting strange - need help please
  205. Transmission cooler line size?
  206. Daytona Eliminator
  207. 500hp Carb Conversion
  208. Riser Flange Question
  209. Dart Block Oiling ??
  210. Opinions on Harmonic Balancers?
  211. Harmonic balancer ?
  212. Merc Bravo ITS Assy
  213. EMI Thunder Exhaust
  214. Extended warranty (MPP vs FPC)
  215. Imco steering system
  216. How American Car Makers Lost Their Nusinesses
  217. OIL PUMP&pickup,,,,head bolts
  218. Cam help
  219. 2 Sets Gen Vi Heads Off 500 Hp
  220. Hydraulic Steering Lines/Hoses
  221. Running lights and anchor lights, which ones should be on and when?
  222. 7.4 mpi heads to 454 330hp heads question?
  223. Water pressure and Oil temp interconnect?
  224. Innovate air/fuel ratio meter
  225. Need help with exhaust for my Fountain???
  226. Power steering hose size
  227. External stabilizers
  228. lifter question
  229. Breathing Systems
  230. harmonic balancer
  231. External Hydraulic Steering
  232. 575 Sci Experts
  233. Bravo 1X Lowers
  234. Camshaft selection
  235. Need Your Thoughts On This!!!!!
  236. Mercury Racing Dry-sumps...what year?
  237. Exhaust Flappers
  238. Gimbal repair
  239. oil cooler supply and return lines?
  240. 454 mag ?
  241. timing chain cover
  242. The wifes new toy!!!
  243. Opinions on gages?
  244. can a 496 be run on land without a garden hose on it?
  245. Water in oil with pics
  246. 496 mag question??
  247. Air mufflers not staying closed
  248. Looking for GPS, any thoughts???
  249. # 6 Trim Pumps
  250. 1985 verss 1989 4.3 mercrusier
