PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 [170] 171 172 173 174 175 176 177 178 179 180
  1. TRUE "Marine" Carburetors
  2. Engine start-up
  3. performance parts?
  4. Dash board upgrade
  5. Any recommendations for a good crank?
  6. Bravo upper casting repairs?
  7. Just 5 more MPH
  8. Write For Extreme Boats Magazine
  9. bulldog rods
  10. Best Crankshaft/Bearings for the $$$$
  11. which engine block do you prefer for xxx-large BB?..engine builders pls help!!!
  12. Future magazine articles III
  13. Future magazine article II
  14. Adjusting the shifter...
  15. prop help
  16. Future magazine article
  17. Effect of Air Temperature on Power
  18. EFI-What is normal operating temp?
  19. Best STARTING battery???
  20. 502 head upgrade please help
  21. Major Magnum Restoration
  22. Oil & Tranny Cooler Water Leak
  23. cam talk (spec's)
  24. 8.1 vs 7.4
  25. Quadrajet question
  26. IAC on EFI Blower
  27. Bottom Paint
  28. audacity, can you enlighten me on....
  29. Advice on HP500EFI - ECM - Cam -Valvesprings
  30. Stellings TRS to Bravo Extension Boxes
  31. Latham Power Steering Reservoir
  32. 540 prochaged or 632 n/a
  33. Volvo DuoProp question
  34. OPINIONS WANTED: Carb vs. Fuel Injection
  35. lifting a 42ft Fountain
  36. bb cylinder heads :how to choose?
  37. Bottom of the boat
  38. ? HP to hit 80 mph
  39. 496" bore / stroke ?
  40. Dumb Q about winterizing?
  41. Hard Starts
  42. 94 502 miss?
  43. Powder Coating Problem!!
  44. Exactly which heads do I have?
  45. RPMS with a 540
  46. How can I tell what cfm Demon carbs I have?
  47. Advice on MPI's fuel systems
  48. Surpentine belts
  49. Coil is hot to touch
  50. 850 Holley rebuild ????
  51. Best place to buy parts for Edelbrock carbs?
  52. 502 MPI Blows 90 Amp Fuse
  53. 6.2 Info
  54. more cam Q's
  55. Re-finishing gelcoat?
  56. Intake Question for Dennis
  57. Another Oil Question! Oil Pressure for 496MAG's
  58. Modifying a 502EFI
  59. Question for Mr. Moore-502 EFI
  60. Gear Oil?
  61. Fogging for winter
  62. 540 chevy
  63. THRU-THE-HULL water pick-ups
  64. Opinions please.
  65. Best cam choice for stock Gen VI 502?
  66. exhaust manifolds
  67. SBC 383-proaction heads any good?
  68. Single vs Double plane manifold
  69. OVERLAP---two ways to figure on a cam?
  70. need help!!!!
  71. Is 35 to much
  72. Can't get this thing timed!!!
  73. 454worth stroking
  74. Lobe seperation!!!!
  75. Fuel Flow Question???
  76. 496h0 bravo 1 X
  77. Hey you F'n1 and F'n2 guys give it up...
  78. Extension Box OR Shortie
  79. cmi vs stellings
  80. Is it NORMAL on step-hull's
  81. How much can GM roller lifters take?
  82. hawk 525
  83. Skater question
  84. Can I spin a 30P prop???
  85. How much power does it take to go 147.8mph?
  86. checkmate boats
  87. Need some help with my head homework...
  88. 575 SCi TO RICH!
  89. Anyone heard of a drive plate for a Bravo?
  90. Water pressure; Looking for the real answer!
  91. Rocker arm to retainer clearance?
  92. Spun Prop Hub??
  93. Trim pumps or drive indicators
  94. looking for some input on ready for some mods!!
  95. looking for the right prop
  96. Classic Question...HOW MUCH?
  97. 900sc - broken valve spring
  98. rebuild or replace?
  99. Crossover question???
  100. stepped hull and props
  101. winterizing 496/ho help?
  102. Need Hard to find TRS PART or Specs
  103. Scarab needs more speed
  104. Removing Risers with Silent Choice exhaust
  105. Drive oil bottle resovoir -- whos cheapest?
  106. 502 Loss of Power (continued)
  107. Drive Showers for 350 Mag-Alpha One
  108. Oil Spray Starboard Side Bilge
  109. Single vs twin outboards
  110. Special Alignment Tool??
  111. Winterize Question
  112. Goign to redo my freakin' 383. Suggestions?
  113. 496/ho. miss? anyone else?
  114. Odd oil deal
  115. Blown sea water impellar
  116. BW trans question
  117. Drives "clunk" into gear
  118. McLeod Bolster Seats
  119. Egt
  120. Correct Prop Search
  121. Octane Booster
  122. How to Build an Engine Hatch ?
  123. Volt gauge reading
  124. Oil Leak - Starboard Side
  125. Sandblasting risers?
  126. Grounded prop - Any Damage??
  127. Cutting a Bravo lower (updates and thread) ad repair))
  128. Shakespeare 5229 vhf/cell phone antenna
  129. Scientific calculations CFM for Boost, etc.
  130. Riser gasket leakeng water, now What?
  131. Dart Pro or Air Flow Research
  132. Thermostat Question?
  133. B@M 250 pulley questions
  134. BOOST vs. ELEVATION (for those who like math)
  135. Oil Filter Question
  136. patching gouges
  137. More Speed
  138. Boost referencing
  139. Cam Selection
  140. Pictures in the water
  141. Oil temps
  142. Oil Pressure Question
  143. Bravo/engine coupler question
  144. help with re-build motor specs
  145. Broken crank?????????
  146. Anyone have any Ringo hull cleaner?
  147. JimV question
  148. On & off slight vibration at cruise
  149. Throttle adjustment
  150. one engine won't idle consistantly
  151. How can you tell if your fuel pump is going?
  152. Leak Down Test Question
  153. which one should I buy B-max or IMCO SC
  154. Oil in the engine.... HOW MUCH
  155. a/c Inverter Question
  156. Bravo XR vs. New IMCO SC
  157. water reversion
  158. ecu reprogramming ?
  159. windshield
  160. help with battery switches
  161. prestolite module failures
  162. Marvel Mystery Oil for Fogging?
  163. New Motor Dilemma-Long
  164. strange boost readings
  165. Kiekaefer Tabs
  166. Extention Box's
  167. Need Prop Help
  168. Bravo Drive
  169. bravo 1 oil change procedure??
  170. The new fel pro permadryplus gaskets
  171. Custom Windshield
  172. Brabo one won't shift into forward
  173. Faulty trim sender or hyd. system?
  174. blowing the breaker on port motor??
  175. Offshore pickup & sea strainer
  176. Wire colors on Alternator
  177. Flushing Power Steering
  178. Who knows P-29s?
  179. 500EFI Cam Specs
  180. Help with Sender????
  181. Piston ring installation.
  182. Please help with HTM engine advice
  183. gimble ring
  184. D. Marine Shotgun Silencers
  185. SBC + Edelbrock Carb Jet Sizes
  186. Skinny chiller?????
  187. Bravo One Propeller Diameter /s ?
  188. #6 drive oil change-unit comes off 1st?
  189. Need Carb Help !!!!
  190. spark plug wires
  191. Help...Engine backfires!!
  192. bilge cleaner?
  193. HELP - Bravo 1 Oil Foaming??
  194. IMCO Shorty Drive
  195. Bravo 1 trim question
  196. Proper brak in ??
  197. Will this cam revert water with stock exhaust manifolds?
  198. Kiekhaefer control ?????s
  199. How Many Different Ways Can You Get Water In Your Oil???
  200. solid hub
  201. Bravo change
  202. Help me out with some leaky valve covers
  203. it's for certain now- THE FIX !!!
  204. 502 Ring Failure
  205. Gear Lube change - What Pump?
  206. 86 350 Mag
  207. OK. Now for the truth
  208. Everything you wanted to know about Drive height & X dimensions...
  209. Power steering belt.
  210. Mercruiser, the big round harness plug..
  211. Hyd. Roller Lifter Adjustment
  212. 502efi to 540ci ?????
  213. 496 Stroker/Dart Pro1 Heads
  214. Alpha uppers went bye bye- opinions please
  215. Blower on 24 baja outlaw
  216. 20' cig prop
  217. What oil should be used in trim pumps?
  218. SBC cylinder head opinions..
  219. What if the Cat ain't flat?
  220. Can I time a 350 MPI myself?
  221. HP500EFI head work???
  222. blower guys
  223. Help 500hp carb cam needed
  224. Replacing trim sender questions
  225. 575SCI's
  226. Radar vs. GPS
  227. HP ratings
  228. Which Gaffrig gauges do I have?
  229. Fuelling cylinder heads
  230. Propeller Efficiency/Slippage
  231. K&N Flame Arrestor for 7.4MPI
  232. Velcro?
  233. High Oill Pressure?
  234. dumb q about ssm?
  235. Fuel hydro lock?
  236. New Exhaust=Stumble...
  237. Mercury Labbed Props
  238. Thunderbolt Distributor Rotor - Stuck!
  239. Thunderbolt Distributor Rotor - Stuck!
  240. Hey ProCharger Guys, Question....
  241. NORMAL Merc EFI pressure ????
  242. 36 OUTLAW stringer problems/year?
  243. Tach bounce
  244. Base timming
  245. Big Block Spark Plug Question?
  246. HP 500 EFI Temperature ??
  247. Using a suck bottle to change tranny fluid
  248. Prop Slip
  249. timeing
  250. Setting up Supercharger
