View Full Version : General Q & A
- Whats the next step
- Drop Down Bolsters
- Driver Bolster blows fuse
- Pair Of Used 25p Mirage Props For Sale
- "Newbie" salt water flush question
- #1 Alpha Impeller Installation...And Now No Forward
- Prop Advice. ,,,,,,,please
- mefi 3
- What size prop????
- Merc Sterndrive failure - Alpha One
- 496 HO compatibility with 1989 454 Mag
- Bypass Valve
- X dimension?
- understanding prop pitch?
- How do I get ~450hp out of Merc 454 -95?
- 40 seconds to get out the hole
- plug wire looms
- Extension Boxes with a Pad Bottom, Notch Transom
- 1,50 to 1,36 with twin Setup ??
- I Need Capts. Call
- 42' Tiger with 1,000 HP Motors
- Big BLock Chevy water pressure?
- 502 mag compression test
- alpha cutout microswitch
- Port Motor Won't Rev Past 2K RPM?
- Mercury Racing Remote Oil Filter
- How much oil?
- Need Advice On Fuel Pump Install
- Need a Gel Coat / Fiberglass Repair Recomendation
- Oil temps.
- Bravo Rotation
- Hydraulic Steering??
- New Toll Free Number
- Bravo bell housing support bushing
- Paging RumRunner! Carb tech
- Pre-labor Day Special
- Alignment
- 454 Won't idle???
- Tachometer problems??
- Oil Cooler Flow Direction
- Oil problems
- which prop on 31 warlock cat
- Stereo Amp??
- adjusting bravo I indicators ...
- hard shifting bravo one
- Speedmaster ?
- Recomended way to remove props on Speedmaster's?
- slip factor after labbing
- Alarm Sounding
- distributors FOR 454 HO'S
- Help Merc Oil thermostatic Bypass
- Miss/Tapping Noise @ 1100 RPM
- Sucked up Sand, now what
- holley or quadrojet
- Exhaust chirp
- help a dummy
- 496 h.o.
- New 525EFI, no crank - HELP!?!?!
- Turning a 502 Mag EFI into a HP EFI
- Weld on new skeg or replace lower gearcase?
- 500HP Carb Cap and Rotor
- Got a little bit of a weird one, at least to me
- Engine lifetime
- This is not SPAM, just looking for an opinion
- trim cylinder
- hp425 specs
- Best batteries for big systems
- SSM V drive
- hawk 40
- One manifold running warmer than the other
- warning beeper
- What thermostat housing is this?
- 500 hp ,,,prop rotation
- Extra Battery
- Trim Question?????
- What camshaft
- trs hp capabilities
- cast versus plastic water pump housing??
- Help, loosing HP above 4K RPM intermittently
- Serpentine Belt Help
- Interesting oil change challenge
- Electric over hydraulic brakes???!!!
- Trailer Lug Nut Torque?
- Header bolts
- please help with prop pitch on bL Hawk drive
- Rookie Fiberglass Work
- Trim pump and bypass pressure
- Speed,Speed, and More Speed!!
- Cooling System Question--Fresh Water System
- Eagle Rotating Assembly
- Where is the $/HP Sweet Spot?
- I always liked fuel injection
- microwaves
- Holley Experts Please
- 496HO and the Whipple….
- 502 Efi Flame Arrestor
- MOBIL 1 OIL FILTER for 502 efi?
- best method for bleeding trailer brakes?
- Drive trim indicator cable
- 2003 500 EFI Problem...
- cooling system - steam and possible debris?
- Austin, TX Mechanic
- Rigging
- Merc 454 Mag to Volvo 8.1
- Twin HP 525 RPM differences
- Using trailer switch to trim up?
- Delco voyager distrib. connections?tach?
- High Pitch Whine in outdrive
- how to remove old window tint?
- Snufflers
- Endplay in an Alpha drive prop shaft
- 1994 350 Magnum durability
- Trim Cylinder Help
- 33 Outlaw Power
- 525sc valve job
- Priming the raw water pump
- Upholstered Dash?
- Dash pad? (Formula)
- Max RPM for a 300hp Merc 350 Mag Horizon?
- Drive temp question?????
- Alternator woes...
- oil pressure switch/electric choke
- XR Prop Shaft Thread Size
- Rev Limiter Bypass harness
- Power valves for Holley carbs
- Kaama Question
- Clack, clack, clack...
- 540 bulldog will not start
- Snapped Timing Chain?
- Fuel Pressure 502mpi will not got above 30psi
- Bravo 1 Upper gears split? Why? What can be done?
- Fix for leaking fender...
- ? About Upholstery
- Oil Temp Gauge...foggy
- Blower ?
- Am I going to need new batteries??
- Need TRS transom parts
- Best price for starter?
- Prop ?: Can this be fixed?
- Tailer GVWR Question?
- supercharged 525s
- Oil Temperature going to 240
- Spark plugs 502 MAG MPI
- Wheres The Parts #'s?
- sync gauge not working
- salvage parts
- Merc 502 MPI Tach bounce
- Konrad Vs. Bravo/Imco SC?
- Stroking a 454 Mag 360 hp advice
- GEN V head used on MarkIV-water in oil
- Time for rebuild?
- Getting the jetting right -500hp - 454
- Push button ignition switches
- Starter for a 540
- Best product for gel coat
- Leaking lower unit?
- Raw Water Cooling
- Peanut port 454 heads...How much power?
- Speedy 3's and 3A's
- Stereo / Amp / Battery / Voltage Q?
- How much power for a Bravo 1?
- 7.4 MPI (need more speed )
- propeller questions,,,
- Is this way off?
- Compression numbers for a 60HP Mercury Bigfoot?
- Engine getting hot
- louder exhaust
- Determining Drive Ratio --- Again
- what pistons to buy? 454 mag
- how much trim?
- i have always wonder'd
- Prop slip #'s
- pilot bushings for crashboxes?
- Same old Prop Question
- HEI Distributor mech.advance,How much???
- XR drive 1.36 vs 1.50 ratio
- What t-bolt module do I have
- 7.4 MPI Procharger ?
- Cutting 3" from VHF antenna?
- Leak Down Test
- Anti-siphon Valve, Where Is It?
- Water in oil...loss of rpm...HELP!!
- loose pivot pin on Bravo 1?
- 29 pitch Mirage Plus RH wanted
- Need Help with Ford Transmission
- Need more rpm from Hydromotives....Pitch change? Lab Finish?
- power steering noise
- Does Drive ratio/prop pitch affect heel to port side?
- Figure This
- Need advice on adding a second battery
- Fuel filter part number? Merc 575SCI
- Battery jumper boxes
- vacuum noise-500 EFI's
- donzi 500 hp prop selection
- Bravo creeps up
- Can't Get Power
- bravo 1 getting hot?
- overheating 502
- will this motor work for a supercharger
- Guage Problem
- Advice needed on Prop selection
- 502 efi plugs? Which ones?
- Problems arising from restricted exhaust
- hp500efi rev limiter
- stumped
- question
- Breslin Header Bolts
- Max HP thru prop exhaust
- Mirage Plus/Bravo 1 to Hydromotive change
- transom shower help
- Drive Rumble
- What are concerns over low vacuum pressure?
- Backpressure on a 502 mag efi
- Bravo 1 to Blackhawk?
- 420-425 cam?
- Bravo 3 Drive Shower
- outboard allignment
- Bravo 1 wont go up while going high speed
- Need top speed
- Higher oil temps on starboard engine...thoughts?
- How to replace prop seals on 50 Merc. OB.
- 215E Merc Transmission Actuator
- Nose cone adhesive
- 500EFI - Help Please
- Excessive steaming
- 28 sonic speed
- Rev Limiter Retrofit
- High volume oil pumps
- 28 Daytona and Tunnel Tab
- oil pressure problem 502mag mpi 2000
- Engine gurus!!!!!!!!!!
- Repowering to diesel: Need Advise
- Bravo Shift Cable Tools
- Ignition timing small block chevy
- Will paint stick to teak?
- Help - HP500 Backfire - Brand new
- federal mogul high volume oil pump bypass spring presssure
- Awlgrip Quote?
- What octane fuel for the motors?
- articfriends
- overheats at startup/vent,then OK???
- Audio Guys. . .Help Please
- Merc fuel pumps, good?
- Manifold Question...
- 496 water inversion
- TRS mechanic may have made BIG Mistake--can anyone help?
- New Gm 454 Ho Motor Advice
- Does color sanding really work?
- Mercury Racing HP500 C carb jetting
- Lesson learned
