View Full Version : General Q & A
- what to do to keep Bravo 1 alive at 525hp?
- Anyone have a used set of gill like HP500 exhaust Manifolds?
- Is changing the 500hp valve springs a do it yourself thing?
- New mild power - go local or...
- Help W/ Alpha one
- connector kit
- Largest Prop to Swing on Speedy II?
- Alpha SS dirve
- Crack in lexan....
- Welcome to my Nightmare!
- oil coolers
- water cross over on bbc
- Drive shower advice
- Crank case pressure
- HELP, No fuel pump no beep 500EFI
- 540 engine advice wanted
- Prop for 1988 baja 235 Force
- trim pump
- trim pump
- More Power Upgrade
- need mufflers who can give me some help
- Bravo 1 drive trim leaking. Need help.
- engine flywheel coupler for b/w trans
- More questions about the Thunderbolt 8V 24
- Please explain HYDRAULIC STEERING to me.
- Nordic Rage 496HO
- Oil Change
- Skater Cat
- Transom Mount Transducer Install Secrets Needed
- looking for a set of BBc medium performance exhaust headers
- holley 750 carb swap
- ZZ502 DUD questions
- Does anyone have experience with older Kodiak exhaust headers?
- Engine Build Up Question
- Demon 850 carb/victor intake on a 454 mag. Anything to gain?
- IMCO manifolds discoloring
- Hydraulic Steering: IMCO or WPM ?
- How to keep your upper drive ears from breaking at high trim levels
- muffler suggestions
- Twin Blower Tests
- trim tab question
- Question about Tach's, Are they a Standard Size??
- Neutral saftey switch problems
- 500 HP What valve springs to use?
- Midnight Express Build by Mesa Racing
- Service Work In SW Florida
- Exhaust Manifold Installation Help Needed
- My 12 hour 555 just blew up
- VOLVO SX Steering Arm
- How Big
- Custom exhaust Question for H.P. gear heads
- 454-502 Mag heeads?
- Dana exhast?
- Closed cooling system?
- Help Needed - TPS Adjustment
- Smartcraft SC5000 Display
- engine swap from SBC to a LS-1 style motor
- Need Bravo One Trim Rams
- Bravo III "Diesel"
- Mystery Part (bravo out drive)
- Old car points/condensor/coil question, 1972 nova
- N.J. Upholstery shop Wanted
- surgeing at WOT
- 454 H.O. that wont stay together
- Wanted Diamond Plate Source
- props
- fuel hotter or colder
- Drive whine
- Cut bravo coupler no I wonder why
- winter storage help
- Small block 383 build-up
- Trim Tab Size Question
- Plumbing Superchillers
- permit for hydrohoist
- Gelcoat?
- trim tabs on 24' boat?
- Good engine builders
- Mobil 1, will it help ???
- 502 Cams
- "Pumpin Up" an HP500
- New 540's
- Formula 292 vs Donzi 28 ZX
- qjet vs holley 750 vac sec
- Seized spark plug
- BW 72C Tranny Noises
- Searay with shingles what now?
- Elec. Fuel Pump mounting
- 7.4L and merlin heads
- 32 pachanga
- 1990 baja 454 mag.
- Oh great gurus of OSO ... Info on 1999 7.4L MPI 310HP Mrec black motors???
- how much water pressure are you running?
- exhaust, where does the water exit?
- Lambo R&D work by Mesa
- Replacing an oil seal behind balancer??
- Help... waterflow
- How do I do this?
- Pick your upgrade for Twin 5.7s
- 454 mag carb: what ignition does it have? Anything to gain from upgrade?
- timing/curve on modified 502 mpi ???
- OMC cobra vs Volvo Sx transom assembly
- Whippling a 454 mag?
- which outdrive for fountain ?
- Broken distributor
- Vortec Heads Valves
- Merc XR or Imco SC???
- crash/standoff boxes ?
- Hatch inserts
- Diesel Go-Fast
- OMC lower unit ?????
- Trim tab limit switch...
- More prop/drive questions - for the experts
- OT: How to Get Gulf Coast Homeowners ins. ?
- Exhaust/engine/noises
- Seems I may have a " sacraficial " out drive... ANODES ???????
- Diacom recording wanted
- Oil Analysis, HP525's Mercruiser 25w40
- need help with 7.4. I.D.
- Prop Nut Torque Setting
- Side to side play in Bravo drive
- where is the Orofis valve in hydraulic steering?
- GPS Question
- Where can I get a water pressure sender and gauge?
- First Bravos
- gimble question
- Trim Tabs Angle
- 502 Engine Upgrade
- How fast should my fountain go?
- The Need For More Speed
- Merc HP 500 Oil Thermostat
- What happens when Rev limiter kicks in?????
- Brad Penn oil???
- help with trim pump
- Fuel injector - 454 Mag MPI
- Opinions on Regal Velocity?
- Fuel water seperators
- Timing MSD/Thunderbolt igntion?
- 25P Mirage or 25P Mirage Plus
- Single plane or dual plane intakes
- Blowers
- Drive heartburn
- ITS drives
- OK, I got the gauges, now what should they read?
- What should I do lost RPM, but still same speed
- Rebuilding sea pumps?
- Depth Gauge Transducer Mounting?
- on engine still overheats at wfo..any ideas
- one of my drives moves faster than the other
- Adjusting trim pump pressure
- Need Twin Disc to Spicer Adapter
- Best deal on hydraulic steering?
- Staggered Engines?
- Whats missing from this bravo wing plate?
- help needed on pachanga
- Trim Tabs???
- whos gonna buy???
- Superchiller Question? ??
- 95 Fountain 32 Fever dash panel wire diagram
- Engine noise
- Who says Prochargers can't be impressive?
- Need help removing lower unit on johnson 85hp
- Ok I'm Lazy and...
- vent tube relocation?
- Which would you use
- Help Vortec L29 heads
- How can I convert to One-Wire alternator?
- whipple for 525efi?
- Does race fuel in a barrel get old.
- Cam Expert Needed
- Don't Want To Screw Through My Top Deck, Need Help
- fuel octane rating
- Replacing ignition switch
- Do I Need A New Alternator?
- low water pick up flush.
- propping a 38" scarab
- Anyone know the belt size for my 500hp?
- Kodiak Mar. Alum ehaust
- Bravo 1 slip ?
- Blown cooling hose
- Exhaust Gaskets Blown
- Mark IV vs. Gen VI
- What is it worth?? Anyone interested?
- Twin inboard to single Conversion?
- 2005 Fantasy Football Fun Pack!
- Transom Assm Torque Specs
- Timing on 500EFI
- Who has the best deal of 496HO
- nose cone on dual water pick up drive
- Headers and Silent Choice on HP500 Carbs?
- Dry Headers
- Water Crossover?
- Trim Control Ease
- Stuck in reverse
- Mercury Drive Spacers
- Engine Oil smells like HELP!!
- Rookie question about water cooling & flushing
- building your own hull????
- Any Merc coupler upgrades?
- Wanted Powersteering Pump
- Procharger on 502 question
- Gen VI heads on a Mark IV
- Trs to Bravo?
- How to measure fuel pressure on a 454 Mag MPI ?
- prop height help for newcomer please
- R-Tech superchargers
- Stainless Marine vs. CMI
- Need advice on gauges.
- Prop Advice
- Bravo Steering Arn Loose ? Here's a Fix
- Key on siren comes on as soon as you turn the ingition key
- New valves or not, How long should they last ???
- Horrable Marine products
- HEI ignition
- Tail pipes wanted (And a temp question)
- ignition problem
- overheating!! i think?
- Upgrading To Power Bolsters???
- Different Charging After Battery Drain
- RPM Airgap Guys
- Changing Props not Lower Unit
- Hydrulic steering. Single V.S. double rams
- 4" Air vent hose alternative
- Target Trailer help
- Voltmeters Always Moving In Unison?
- Drive spacers for bow lift
- Which Cat to buy?Need advice!
- TRS vs Bravo
- engine compartment heater question
- trim out while driving?
- batteries
- DRIVES, toe in or out?
- Back flushing motor procedure?
- BBC to diesel conversion
- TRS Drive Oil Leak
- So, you like stainless eh?
- Hydraulic steering over 70 mph
- ITS steering
- XR Spacers
- Amsoil Products
- Mercury Racing Oil T-Stat Filter Mount
- Overheating and lack of water
- Fuel Injection retrofit
- Selecting Trim Tabs
- Trans type???
- no bow lift
- Looking for Whipple Supercharger Pulley
- Oil System Plumbing
- Changing Fluid In Bravo Xz Drive?
- alum. nut for rear motor mount?
- ayway to tell hours on motor v.s what hour meter says???
