View Full Version : General Q & A
- inner transom plate installation?
- Anyone Used Crane Marine Ignition Module?
- low water pick ups
- Magnesium anode for TRS
- Mercury HP 525 Water Pressure
- Miniature Unlimited Hydroplane
- Winterizing-Alpha Drive Question
- When to change Valve Springs
- desktop dyno my 400smblocks please/revised
- V.D.O gauges
- Anodes ???
- Speedo Help
- blowing drive oil
- Anybody Know Where To Look??
- 2 Bolt or 4 Bolt mains??
- boost & rpm
- OK to Boost?
- Transom assembly wires??
- Trim Pumps and Fluid Viscosity.
- Bravo I Trim Issues - Ideas?
- ended up limping home DOH!! what the f-?
- What's the deal withthe 524 CID...
- Bravo one top cap chalked w/ shower...?
- ProCharger refresh question...
- outboard prop on speedmaster
- Bottom Paint Removal
- carburetor air screws
- What Spark Plugs do you Use?
- HP525 EFI Dyno Numbers
- Gale Banks Cam
- Blown or NA?
- will running rich result in smoke
- Two Drives/Props off Single Engine
- Servicing a 575SCI blower
- hp500 valve spring job?
- What are your thought's on changing this Triple to a Staggered?
- Gear oil out of the water pickup?
- Age old 454 hop-up question
- B&M Blower Question
- Goofy fluid change question....
- alpha drives magnet
- 502 MPI - Redline on the Volts Gauge... Help.?
- Repairing bolt holes in transom
- Procedure for removing the engine and trans
- hey checkmate454mag,thankyou rmbuilder
- 383 Strokers?
- Shift Cable Adjustment
- Efi - Bank to Bank or Sequential?
- Need Help 500efi
- Turbine Dilemma
- Merc Racing Blue Paint
- God hates me, that's what it is!!! Now what do I do???
- drive alignment problem
- how do i winterize 350 mag
- Correct Oil Filter P/N
- Transom replacement
- hp500 remote oil filter and cooler ?
- Convert manual racing steering to power?
- RH or LH rotation
- rubber treated exhaust flapper
- Timming?
- home made swimplatform? is it worth doing.
- Changing Outdrive Oil
- Engine coolant for 496HO
- what can i drop in????
- desk top dyno my 400sb please
- Drive break-in?
- Need a Merc Part Number
- Feedback on new Bravo X Drives 6:50 ratio
- Stellings drive shaft problems
- 1978 Cigarette 35' Mistress Project-Engine Rebuild Questions
- Merc Or Omc
- 575 fuel consumption
- How many hours before a rebuild?
- Carnage! Tear down of 385ci sbc
- on line prop calculater
- timing "bounce" with v6 module?Normal?
- Hydromotive Guad4X vs Bravo 1
- upgrading stock Gen V 502 Mag's ???
- 35 Executioner w/ T-496HO's, Props??
- Got A Pair Of 496 Mags For Sale
- Checking electric brake controller
- Bravo one questions
- Timing?
- Part #'s for Merc 500 carb
- hoss props
- carb jetting
- Why did my 496HO blow @4400 RPM
- Best head gaskets and bearings for BBC
- Removing K Planes
- Lab props - Is it better to start with a bigger pitch or smaller pitch?
- Extention boxes/X-dimension on 31' Scarab?
- Mark IV block & Gen V heads - Who has done this? Please read.
- Prop Experts Please Take a look
- Cometic head gaskets
- Hyd. Steering advice
- Powdercoating Ext. boxes and uppers?
- water pressure
- 22' Baja Hammer, SPEED??
- what props are being used on 36 daytonas
- Bravo 1 question
- TRS/Speedmaster 2, trim cylinder
- propeller vs rpm question
- 24 Baja SHIFTING with OMC
- Merc vs. Volvo??
- Help! Developed vibration
- Scorpion upgrades
- I'ts Official! Rtech Fountain hits 100 MPH GPS
- Shorty Gear Box
- engine submerged while boat on trailer
- Scarab S 30': TRS vs. KAAMA
- Selecting a trailer?
- Procharger M-1 or M-1sc
- 24 Eliminator Daytona
- looking for a 3" dia. pulley for Holley 250 blower
- Bravo rear anchor pin assy.
- Computer whiz?
- bravo to arneson surface conv.
- Factory fuel tank location
- Piston part #
- Best Tranny for mercury 6 drives?
- trim tabs adj. from throttles ?
- procharger aw504 inner cooler pressure drop
- Dyno results
- Hey, TAZ! Bmax thread..
- what would cause?
- Bravo 1 shifting hard
- Last issue before I can finish up the resto and splash...Trim in handle won't trim up
- Anyone know what size blower this is?
- Cleaning marine growth from outdrive?
- Stern Powr drives?
- Crane Hyd. Roller cam breakage
- Blower on 24 Eliminator
- Stalker cat?
- Revolution Marine Exhaust
- V-belts
- Fuel sender/fuel tank ground?
- Rebuilding Alpha drive with aftermarket parts
- GPS With speedo attachment
- 29' Baja Outlaw Drive/Tab Indicators
- TOO LOUD !!!!! possible inexpensive fix
- M-3 Prochargers with Intercoolers - How Much $
- Drive temps...anyone checking?
- What cam for a 500 EFI
- Exhaust for a BBC????
- Carb recommendation on 454 mag with M-1
- Exhaust risers?
- 500efi
- Need clutch assembly & U Joint for Bravo 1
- Bandit 800 SC's???
- Electric Brake question
- Does suction hose to SW pump need wire??
- Anyone rebuild Bravo 1 drives
- New ACCLERATORS ON SALE&BRAVO-ONES
- Electric Trailer Jack
- Merc 600sc?Any Good?
- Tuning suggestions
- Year of Manufacture of Bravo Thru SN?
- Ford Vs Chevy
- Darin, did you get my prop?
- Closed Cooling
- Engine Transportation
- startup problem
- shifting problem?
- inverters
- Mercury RS-Drive ??
- Stroke, Blower, or Whipple
- Procharger M1
- serpentine belt
- Anyone with Desktop Dyno
- Water Jacket Plating?
- Anyone with Hydromotive P5X results?
- Anyone with 3.5 psi pro-chargers on 496HO?
- 468 w/871 blower
- Who's blown an outdrive??
- Carb 500Hp Maintenance
- Grab Rail
- How are dry headers set-up and how do they work?
- Headers or Manifolds ?
- Baja 240 Sport OMC 460 King Cobra Shifting Problem
- Exhaust Manifold Question
- Prop Manufacture ID
- Hot alternator shaft
- pressurized sump 454 Horizon
- #5 Drive Steering assy. Needed
- weeds in lower unit water pick up
- prop question
- couple of questions
- Compass problems ...
- Bravo1 How high X with std water intakes?
- Supercharging my 365 Mags, What else is needed??
- Sporadic overheating/vapor lock?SW pump?
- 24 daytona prop tuning
- Paint suggestions below the water line!
- Last Oil change for the season ....
- shuts down when put in gear
- 525 sc 1999 any good?
- How much more power with a tunnel ram type of intake?
- 13 fun cat or 12 foot minihawk
- 12' mini hawk
- Supercharging - Procharging???
- Ford Super Duty drivetrain problems
- From props to oil??
- Best lubricant for sticky shifters?
- Hydraulic steering questions
- small block whipple chargers
- throttle is hard to push
- Merc 440's
- Resurface Heads or Not?
- Resleeve Merc Pro Max outboard
- Pressure test EM's
- Heat range on Autolite AP605? HELP?
- Bravo 1 G-bearing and u-joint inspection
- Gm Zz 572
- BBC Merlin Head Questions
- water feed for a superchiller
- Imco Gatlin Mufflers
- Help with GM cam timing events?specs,
- KAAMA Drive Parts?
- Gil Manifolds
- Reasons for using a shorty drive
- Are Gaeffric Redline Gauges Accurate
- How much power with a two bolt main 454
- Crane Hydraulic Roller cam failures
- TRS Gear Housing
- Propshaft for Bravo
- why do blower engines surge at idle?
- I need a manifold
- Good oil pan for Big Block Chevy's
- Help Choose Engine Upgrades
- anyone need tall deck parts?
- Flywheel expert required
- Brand of "87" Gasoline and engine knock issues
- Whats The Deal????
- high oil temperatures
- Help with Gen VI 454 piston rings
- 420 Belts, Pulleys, and Idler
- old gas
- Pyrometers In Gil Exhaust
- Home made 525sc for Formula 357
- Valves Collide with Pistons ....
- Horsepower at crank vs prop
- gauge accuracy
- What type of plugs are recommended for Merc motors
- Gaffrie gauges
- Is the coupler pattern same as clutch?
- 502EFI missing / sometimes
- Trailer Question
- More HP for 420Hp
