View Full Version : General Q & A
- Carburetor experts only please
- Rusty Water after layup? How dangerous?
- OT- Marinized mazda rotary dyno sheet?
- Procharger
- Anyone need a pair of 496 ho's?
- KPM 112 / Mercruiser replacement pump body's
- ecu programing
- High RPM oil pressure
- Water in oil help!!!!
- Hey Oso
- Chevy 572
- retorquing head gaskets
- 2000, 502 mag?
- Removing both nuts to install new no-drill Simrek showers
- smart craft
- 2006 496 mag alternator question
- cruise control
- 502 headgasket
- 502 oil pressure question yet again
- 454 mag mpi swap with 500hp carb
- Hard cold starting carb 502 (Choke problem?)
- GPS speedo question
- 496 changing sparkplugs ?
- Help me get parts for my Baja (interior)
- Best sprk plug for my engine
- Need advise on 500 efi's
- 496 Mag Ho misbehaving...help!
- Thoughts on Teleflex hydraulic steering?
- Mufflers ??
- Instruction for Sea water Pump HP 500
- Help Needed!!!!!!!!!!
- Need Advice
- 496 mag won't start
- 496 mag exhaust? anyone?
- How do you backflush(clean out) on 496 engines
- Blew a fitting off stbd exhaust manifold 496
- Popular Hot Rodding's got the new Mesa Racing Engine Article
- Is this for real???
- Skater 36 Propshaft Positioning
- mefi tuning question for experts
- late 496ho Water pressure sender
- oil temp relay?
- Thoughts on Bennett trim tabs
- A better Merc mechanical fuel pump (seawater pump mounted)?
- Sleeve in a 500HP???
- Oil Dipstick Tube For 454 Magnum
- Drives hitting swim platform.
- Fuel pressure loss (tank/check valve)
- has anyone tried this?
- Stereo Noise
- 2000 500 HP EFI with starting problems
- 500efi-575sci
- Small blocks and super chargers
- water and oil don't mix
- Oil and grar lube
- spark plug advice?
- Anybody know Guardo marines website ?
- water in gas
- Full mooring cover with side sun protection
- Need help on the oil bypass valves
- 2000 500efi, how good are the internals?
- switching from bravo 24 to 4 blade cleaver
- 454 magnum mpi idle help
- Tach lead ( what wire)
- Drive stabilizer brands ??
- 01' 502mpi Fuel Pump Problem
- Need some info on an oil thermostat set-up plz
- Merc 383 - 4 Winns 24' Liberator Prop Question
- Question
- Bravo side water pick up
- Help, click...click..click but no start
- 1996 502Mag MPI Fuel Pressure
- 502 mpi oil leak, plz help engine gurus....
- Crossover with or without t-stats?
- K plane help!
- help
- Merc 6.2 ????????
- Outdrive Gerus - can you help
- Need help with cooling system, 454 Mag MPI
- Dart Compacted Graphite Blocks
- ? K plane seal and bellow
- 496HO rough idle
- strange cavitation issue 26' sleekcraft TRS
- boat wrap
- 454 mag whats a fair price
- Spark plugs?
- Max EGT Temps???
- do not use
- 502 headgasket
- World Merlin ( Teague 509 block)
- Teague - World 509 Block Ring Gear
- Looking for new vinyl interior for Baja 29 Outlaw
- ??oil temp sendor size on Mercruiser relocator?
- GAS Question
- Precision Marine, Kenner La.
- Keith Eickert Sea Strainers
- Big Stuff 3
- Castrol Syntec Synthetic 20W-50
- Lower shift cable replacement....How hard?
- What bolt torque?
- Gaffrig speedometers problem
- 500 hp exhaust
- How important are coolers?
- Sensors
- Question on Hydraulic Steering Column
- Merc timing V6 module/msd questions
- problem removing volvo engine from transom
- What kind of sea pumps are these?
- How do I troubleshoot electrical?
- steering hose??
- Wanted: Performance Outboard Mechanic in Phoenix
- What makes a good V-bottom?
- 39 MTI speed with 525's ?
- questions for 500hp owners (dont hate me)
- Trim pump fittings/adapters
- 502 performance
- weiand blower pulley
- Boat would start but stumbled and quits???
- Velvet Drive "Neutral Switch" Question
- 496 HO horsepower chart needed
- External pickup pros & cons?
- ECU Calibration, 1994 vs. 1996
- Mermaid A/C Help
- (Cigarette) HI-TECH Hawk Super Sport 18'
- 502 mpi vs. 502 carb
- 6.2s suppercharged ???
- The best synthetic oil for flat out racing
- Cylinder head durability
- All Zerc's?
- Boost Level and A/f Ratios
- 575SCI sea water pump replacement ?
- engine steam
- 525 EFI Overheat Problem
- Gaffrig Gps speedo NG
- Leaking KPM sea strainers ?
- Cubic Inch Displacement formula question?
- Hp500 ???
- 496 help needed.
- RTV on exhaust manifolds?
- 525 EFI Header Gaskets
- NEED HELP, Engine dies after starting up
- Buna-n Orings ok to use for Captains Call actuator???
- Carb question
- Where is water pressure sending units
- engine temp question
- restrictive oil system?
- Pulls to right...
- bravo spacer
- 502 stuttering problem at 3800rpm
- Hydraulic Steering
- DART PRO 1 vs AFR
- Anybody Know about a Uniden VHF radio/telephone
- Perko Wiring for Dual Battery Setup
- WIX 51060R Oil Filter Capacity???
- Need help... someone with a bad Bravo 1?
- B&M 250 parts interchange with Weiand 256???
- 502 mag 195 hrs
- HP500EFI Rocker arms and seals, distributor rotor and cap
- Blower carbs
- Port 502 MPI just quites
- Blower question
- Blower motor air to fuel ratios ??
- Redline Oil
- Merc 502 415hp FWC Question
- Anybody using MEFIburn software ??
- SBC oil flow confusion
- Sonic Battery connection???
- Oil Pump Failure?
- braided oil lines
- 257 Mirage Selectable Exhaust Leaking -- Seeking Replacement Solenoids
- Vacumn at WOT?
- How much hp are you making with a 4150 base carb?
- No spark with MSD all in one
- fuel sender calibration
- oil help
- Two Speed Trannys for Diesels
- Part # Starter
- TRS oil cooler line fittings...
- cam duration 228/ 236 @50 .601 lift on Intake exhaust with a 112"cl
- Detroit Diesels
- How Much Should a MSD Box Cost?
- A/C Question for the F-350
- 2.5 Mercury 280hp need oil
- Fuel Meter/Gauges for 525's
- Cathouse Performance Marine
- Drive leak
- Mefi 1 Computer
- Help, Trim Tab Wiring
- Engine Hatch stops
- Fuel pump options
- Volvo Trim Senders
- re-rigging
- Calling Rookie - Jason
- 496 mercruiser will not start
- Couple ?'s after motor install
- twin 496 diffrent rpm's
- K E Race Pump
- tiller arm question
- can someone check my trim problem question please!?
- Having a trim problem
- 496 Mag Hard Alarm?
- power steering fluid
- help with harch actuator
- 502 Efi Manifold Air Temp Sensor
- 496 HO high water psi question?
- Source for Steel Flywheels
- 1996 502MagMPI Spark Control Module
- Need 496 pulley and belt, anybody have one laying around?
- rebuilt 502 burning oil
- help, loud noise and motor dies 454/trs
- Thermostat question
- Hydrocruiser ??????? oil related
- Synthetic Motor Oil or NOT ???
- Need some help...here are the symptoms
- 1996 7.4 carb. ignition timing
- HP500EFI valve springs
- 34 cat engine forward mounting questions
- Chicago to New port richey any empty trailers leaving ??
- $ 3500 to play with, lets make the boat faster
- Boat Headers why so expensive?
- Fuel Gauge Problem
- Looking for repair manuals
- One More Time Mark Prinz Is A Thief
- Blower Motor, Aluminum Shavings in Motor.
- Who rebuilds carbs, NJ area?
- 496HO with Raylar kit and Whipple Stage 2
- Questions on 565 Whipple Build-Up.
- 500hp carbed
- paging "bearpaw"
- 454 to 502 swap
- Shore power/battery charger issues
- vinyl repair kit
- gps wiring
- Super Deal on NEW Blower Motors
- merc hp500 seawater/fuel pump
- Bravo Spacer
- Fuel filter and pickup
- Mercruiser K-plane indicator cards????
- Wilmington, NC Does any member live near her
- Mercruiser 525 Experts: HELP
- Bad Ring Gear
- Marine Vinyl Re-upholstery - StLouis Area?
- 600 sci motors with no top end
- How to make 550-600 Hp in aŽ540
- 454 thrown rod....need to upgrade
- 500EFI Camshaft
- Wierd AF at Idle
- how to change from RH to LH prop
- mph dose'nt match rpm
- 700sci engin oil recommendations
