PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. 496 running warm
  2. Excessive distributor gear wear from billet cam
  3. 21 foot maxum to what? new to forum need help please!
  4. Holley floats - brass versus nitrophyl
  5. can anyone confirm hp rating for a 7.4 LX MPI
  6. Tyler Crocket 100hp upgrade
  7. Teague motors
  8. 496 HO - fuel pressure adaptor
  9. merc fuel pump
  10. Streaming audio with Bluetooth?????
  11. Oil filter with bypass valve suggestion
  12. Adjustable rocker/Valve adjustment help
  13. Best drive shower Bravo X?
  14. Marine grade carpet
  15. Gaffrig fuel Pressure sending unit replacement?
  16. Drive coupler and gimbel bearing help
  17. What tooth flywheel is my 502
  18. ran the new combo yesterday....
  19. How do I tighten my Merc Single lever conmtrol? feels loose
  20. 502 mag mpi heads wanted
  21. 1989 454 hydrolock questions
  22. Drive coupling replacement cost
  23. Mercruiser serial numbers
  24. 500 efi fuel rail pressure
  25. 454 mpi steaming out exaughst with high water psi
  26. Ignition timing
  27. How much do u think I could gain from this?
  28. HP 500 EFI, Fuel Pressure - Schrader Valve?
  29. 496 HO Sea Water Temp sensor location
  30. 5 blade for midrange performance?
  31. Which gauges will sound the alarm
  32. Engine builder references
  33. 1996 252 7.4l lx mpi sea water pump
  34. water passing through on hose engine off
  35. Balancing water flow
  36. Ethanol/Non Ethanol Fuel
  37. Color of drive oil bottle wires for the alarm
  38. Vibration
  39. Help with power trim
  40. Engine rpm low, help a rookie out please!
  41. Water in Bilge
  42. moldy 5200, how to clean
  43. no start on 1998 7.4 mpi
  44. engine alignment
  45. O₂ Readings: Naturally vs. Super Charged
  46. HELP - auto mechanic PLEASE
  47. 1987 26 scarab excel front air vent
  48. Beehive Valve Springs
  49. Gasoline expansion in fuel tank
  50. Ok, so how many of you guys are running automotive carbs, be truthful.
  51. 305 carburetor
  52. Puzzled by compression readings
  53. temp sending unit
  54. Need a tow from st clair race
  55. String has a little localized rot, what to do? Video inside.
  56. 454 Carb vs. 454 MPI
  57. Shifting a fuel injected motor
  58. 20 or 22 rake prop
  59. Changing pitch on Bravo?
  60. Question on rebuilding a 502
  61. 525 EFI Injector Removal Tips??
  62. Ran Lean
  63. Sea Pump Belt Sqeals
  64. Bravo 1 x
  65. Engine Alarms into Intercom
  66. Proper way to mount bolster seats through fiberglass floor?
  67. Prop sice for 29ft Scarab.
  68. 7.4 lx mpi stall no restart
  69. Any info on this boat? 1979 7 meter Martini
  70. Running Warm ??
  71. Input on Advantage boats
  72. Mercury 6.2 MX hard to start
  73. livorsi bezel fell off
  74. HP difference 454 vs 502 all else being same?
  75. 454 mag change to 502
  76. HP 500 EFI Motors for Sale???
  77. HP 500 EFI...Problems....HELP!
  78. daytona speed loss at altitude
  79. Needs some help 675SCI outlaw
  80. 454 bravo 1 overheating...really stumped! :-(
  81. Complete bravo package, good price ?
  82. upgrade????
  83. block differences
  84. 525 SC Motors what are they worth /
  85. Best spot for Fuel Vent
  86. Will adding Quick & Quiet to a muffled transom exhaust help with flow?
  87. Acceptable Oil Consumption
  88. Cyclone mufflers
  89. Boat stalls immediately after start
  90. stock gen 5 fuel pump mercruiser !!
  91. Prop help!
  92. 500 EFI anyone bypass/replace cool fuel?
  93. Cam question
  94. 502 mag mpi valve seats
  95. merc. tech help on 6.2 timing
  96. Hose Size
  97. V-6 to v-8 swap
  98. Alternative for Merc pressure relief valve?
  99. Changing from efi to carb and vice versa
  100. Mercury 525 Issue Engine Shutting Down
  101. 5 Blade Vs. 4 Blade Stern Lift..??? How Much We Talking??
  102. Engine just lost power 454 mag.
  103. port needs more throttle then Starboard on take off?
  104. HP 500EFI Loss of Power
  105. How much pressure with a pre-oiler and cordless drill? (Is my relief valve stuck?)
  106. Bravo 1 prop nut size?
  107. 454 Mag MPI runs rough
  108. 25 daytona speed?
  109. 6.2MPI exhaust manifold dripping
  110. 9 and 10 pin plugs
  111. 575SCI backfires, need help!
  112. 460 Ford in a baja?
  113. 500efi running poorly
  114. Pressure gauge help/drive help
  115. livorsi water temp gauge sending unit?
  116. Trim tab manual adjustment?
  117. Lifting engines from boat
  118. SBC oil leaks. Gasket recommendations?
  119. No Thermastat..?
  120. Possible electrical issue, help sorting?
  121. Imco shorty
  122. Bravo One Lower Unit Mod??
  123. Need Help: Alternator seized and leaving tomorrow (496)
  124. Bolsters
  125. Need engine coupler
  126. crankcase ventalation setup
  127. small block prop/carb testing
  128. oil droplets in exhaust
  129. No power anywhere, even with jumper cables
  130. Intake Manifolds, Question
  131. Fuel problem help
  132. Hydraulic assist bleeding
  133. 500 efi vapor locking???
  134. Formula 272 Driveline help
  135. 1996 mercruiser 7.4 mpi efi wont go past 2200 rpm
  136. Stock Merc exhaust
  137. Which spark plug for 496 Mag?
  138. 350 cu in merc efi's
  139. 1989 454 wot seems low...port runs higher than starboard
  140. 496 bbc afr heads new need help
  141. 1995 7.4 mpi efe mercuriser , bravo three
  142. 502 efi issues please help w/ suggestions?
  143. Engine rotation
  144. 30 amp shore power question
  145. 496HO wiring harness rubbing on computer bracket.
  146. anyone ever supercharged a 20.5 Cougar ? thinking about it
  147. Intermediate working tach
  148. American custom marine
  149. FORMULA 382 Fastech vs 330 or 370SS
  150. What's up with my 502 fueling?
  151. Prop Repair and tuning-Need recommendations
  152. main breaker popping
  153. Bow dropping at high speeds
  154. What shuts off the electric fuel pump?
  155. Easy 496 knock sensor question
  156. 454 bored and stroked to 508 cu in????
  157. 496 crank sensor
  158. 330 hp timing? 7.4 bravo 1
  159. Back in the Market!?!
  160. Replacing oil pressure relief valve
  161. 1990 BW rage 14 steering question
  162. 496HO issue - won't rev past 3,400 rpms
  163. blown up again (extension box)
  164. 4 INCH play in my steering
  165. What sea strainer for single 525 efi ?
  166. Does anyone have any info on the year by year changes on the Mercruiser 454?
  167. need help.just bought 03 carrera 59hrs 29 effect x cat
  168. Anti siphon valve in hose barb for fuel tank
  169. oil pressure
  170. Seawater pump/mechanical fuel pump cam problem
  171. 454 Mag. getting hot, HELP
  172. supercharger question
  173. 496 ho issue with leak and vacuum pump winterize
  174. Yellow stained bottem hull help?
  175. No More Reversion
  176. Fuel issues? Please help going crazy
  177. Hard Start Problem
  178. Anyone know what part number for a 509 head gasket?
  179. 1471 vs W305R SERIES
  180. Belt noise
  181. removing arp assembly lube from fibreglass??
  182. Starting a 7.4 mpi from long storage
  183. Who has Gotten Ripped Off by Kidapache??
  184. has anybody rebuilt their steering rams
  185. Not sure how?
  186. Uneven temps, at my wits end!
  187. #6 drives
  188. Water getting in my crank case... am I doomed???
  189. Way too slow (formula 41)
  190. Hidden HIN Location???
  191. Ah Ha moment,,,,
  192. rt930 torbo Artie
  193. Setting base timing
  194. Has it been done before?
  195. I need an oil temp sender and is this a good location?loactin
  196. Elevator Boat lifts?? 16k and 20K... are they any good???
  197. 2001 496 ho port manifold is hotter then starboard
  198. Gap specs?
  199. I need some help guys my motor is not cooperating
  200. 454 Mag Overheating - Help!
  201. Stock Exhaust Baffles
  202. Wix Racing Oil Filter Diff? *57003R vs 51222R*
  203. Mufflers
  204. Marine electronics preservation tactics
  205. 91 fountain fever diesel motor?
  206. HP500 Exhaust.
  207. 496 Oil Pressure Sending Unit
  208. new combo oil/p.s. cooler hose question
  209. surface drives are they worth it?
  210. Heads up drive indicators
  211. help with upgrade boat or not
  212. Faria fuel gauge or sending unit question
  213. Water in cylinders
  214. 454MAG MPI 5v reference?
  215. Fuel pump wont go on with key, have to flip on courtesy lights
  216. Kenwood Stereo and Remote Compatibility
  217. Water in oil
  218. Diesel for corrosion
  219. Milky oil, 7.4 Merc
  220. Occasional pop while running
  221. BORING! One hole?
  222. Prop change engine stalls
  223. Which boat to buy
  224. full hyd hoses failing
  225. Merc. 496 mag HO two beep alarm
  226. Does anyone have original Hawk 575hp specs?
  227. Merc Verado Oil Filters
  228. Crossover with restrictors
  229. Not enough oil for a rocker arm...
  230. 525EFI Intake Manifold Gasket
  231. Do Roller rocker arms lower oil temperature?
  232. MerCruiser Bravo1 new style?
  233. bbc 2 & 3 and 4 & 7 firing order swap?
  234. 500 efi distributor
  235. Baja 272 454 EFI RPM issues
  236. hour meter stoped working?
  237. 502 Mag Mpi (re)Build - Mild Cam Upgrade
  238. Raysoncraft 26' cat?
  239. Best Boat For Speed -Search of new Boat
  240. Spark Plug Gap for HP500?
  241. water line size
  242. Flex plate/flywheel
  243. head gasket/condensation or I'm gonna hang myself
  244. Starter or battery issues?
  245. Installing mech gauges on 575sci's at engine...
  246. cutting edge props..is anyone running them?
  247. Engine alarm constantly
  248. Bravo one to XR advice needed
  249. Timing covers
  250. Newly Rebuilt 502 EFI rpm race from 2000 to 3500
